scottishjohn
    23
  1. this discussion It depends what we are really talking about the savings from insulating all houses properly would drop energy consumption so much and it is needed for any system to be effiecent , that that is the way it should go first as a country just chucking heat into to leaky houses is never going to be a good solution to the base problem alot of houses are not big enough to do the obvious of internal insulation , like stud walls etc ,especially the older ones so massive exterior insulation must be the way for those dwellings. non of this is cheap -but insulation is a once only cost
  2. If i had the option for mains gas ,then iwold have gone that way ,but still with UFH and the same insulation that ihave put in the house now , powering ny solar and expensive batteries wouldd not work out with associated costs -not in my life time with the pitiful fed intariffs you get if you send excess back to grid If it comes back to 20p a unit then i might consider it to just change to ASHP on a house without the insulation would not work in most cases It did work for me on present house as it was LPG
  3. so it should be at least 2ft thick sounds like old age dry stone dykes fall down with age when they are not used as a retaining wall If it were me and its not i would tell him to just dig it out his side and get a dry stone dyker to rebuild it a days hire with a mini digger and couple of days for a dyker to rebuld it ly would no way class as a retaining wall in the true sense just relying on weight of stone to do the job and iam guessing its not leaning back tohelp the stone stay in situ should be at least a 6degree lean in at top if it was built as a retaining wall
  4. I agree with all thats has been said and talking nicely is the way forward but surely first thing everyone needs to know is how was it constructed and by whom the general rule is the ground pressure exerted by a retaining wall or indeed any wall will load the gorund at a 45degree angle from the bottom of the wall so if if 45angle hits gound at a level which you have dug down too ,then it might have an effect by same token if it was constructed correctly there should be no load on ground outside their ownership eg bottom of wall is at least twice as thick as the top EG. if 2m high then bottom should be at least 1m then down to 0.5m and with drainage at bottom of wall if more then base needs to be even thicker how high is the wall do they have a drain behind it to stop retained soil turning into mud lots of questions with retaining walls some of which can only be answered by knowing how it was construucted in the first instance and what sort of ground was it constructed on how high and how thick is it and what is it made from to give you an idea look at a gabion basket site and see hoow they are constructed and remeber gabions do not have driange problems --and do not retain water not so with solid walls
  5. and if it ever needs maintainence? no divert it aorund house although I would expect the water board will want to do it,and have rights to dig it up for maintaince if required
  6. when i had solar thermal system 40thermoax tubes and 300litre tank which ran dhw and uderfloor heating to a degree with a vlave to block it off if water temp was too low for ufh I had a similar problem ,though hot as bad just fitted a valve with stat which stopped flow if panels were not hot enough to add to tank problem solved
  7. you mention storage why not build the garage bigger where it is seems the simplest way to me and yes looks like a lot of window area cutting that down will save you big bucks
  8. how do you know if the smart meter is communicating with supplier
  9. looking for guidance my firepond is now going to be covered on outside with bits of granite like slips but uneven on the rear and textured most of them are not flat on the rear so what is the best stuff to use and how thick a bed can ican use vertical fixing of course
  10. to me iwould extend back into the garden area not as though either house looks that small and keep an access to the rear with no RTL problems
  11. don,t get me started on open reach ihave been trying to gat a new phone line and only after moths of chasing did they send a surveyor and that was after them telling me no way could thye put anew line in at this time the surveyor came and we agreed a way they fit new poles on to my land and i dig a trench to bury the ducting they would supply total distance 375 m the quote came £23939 and no mention of me doing any of the work and this is just for copper --fibre could only be done later as thats a different deptartment--wheres the sense in that so now we are back to square one andi have asked for another survey as the rate they charge for poles is £999 per pole so it would be cheaper just to put poles we will see where that goes
  12. If it was a scottish roof there would be no battons the slates would nailed to the roofing wrap making it much tighter to the flashing modern roofers even do away with the second row at bottom and use a grp strip -about 300mm wide which makes it even tigher to the gutter they even put it down the side og my valleys beofre the lead what it won,t do is give the slight kick up at bottom of roof where the double layer of slates is on a normal roof
  13. weather is so up and down been very hard to plan much this year ,with any certainy and at my age I don,t do wet days so now we getnearly 2 weeks of dry and me ,the wife and my man all get bad colds/flue everything aches --definatly couldn,t be lifting stone about
  14. unless he has a laser level +hieght pole and receiver it will be a guesstimate
  15. it is unlikely that it is not repairable --so I bet once its out --assuming its not wraped inconcrete another self builder will take it away and repair it with new pump and media balls --after a suitable power washing out by a septic tank emptying company it sounds very retrivable once the drainfield is sorted but i would not want to share septic system with another house if at all possible--thye could be flushing anything down it and causing problems
  16. fit a new system and do it on your own gorund there is obviously no legal agreement on who pays for upkeep and repairs --big mistake
  17. do you know how it was built ? maybe it was built with aircrete blocks and rendered -- and no expansion gaps - -thats why all modern builds have expansion gaps in the block or brick work and if the mortar was stronger than the very weak aircrete blocks it will just crack vertically where as brick houses usally crack along mortar joints --zig zag thend view looks like it has a mould problem in the render at top but again this is just a guess as without investigation -- without removing render its impossible to say what is going on or if it isa foundation problem and if it has stopped moving now it also looks like there have been alot of extensions to orginal house - was it a self build ? is it same as otyher houses next to it? all depends how cheap its going to be
  18. you need some access to the drainge pipe for when it gets blocked so concreting in where it seems to change direction is not good - myabe you should not be building over it ?
  19. In scotland it is SEPA who advise planning and buidling control- maybe be same in england ? It is there determination that deecides what is allowed had similar but slightly different problem and after consultation they allowed treament plant ,although mine runs to a flowing water course planning +bc had to bow to their decision
  20. look at the vortex system -- download the test certs for all you look at the water quality as far as ammonia and solid is nearly twice as good as bio disc so the water from it technically is drinkaable so if it could maybe be sent to a BIG soakaway along with rainwater ,which will clean it even more ? do you have psace for a seperate soakaway ? and even better its half the price
  21. or add extrs smaller joists joists in some places to make sheets work or run sheets other way with bits nailed in between joist for edge support a bit of thinking at start should cut down amount of extra PB edge supports needed like maybe cutting some boards into stripes to get you back on the joists eg cut first to 36" then then an 18" strip to get 54" then same again lots of ways just a bit of buggering about on paper to see which is best way
  22. so you using 6x3 palsterboard then Idid not know they made pir pklastergoard in 6x3
  23. may not be applicable i was in same postion at back door so I built a wall then put block and beam on top and finished off with paveeing blocks never gets wet i did drill a few small drainage holes in retaining wall so water did not gather up below that was 20 years ago and still fine a quick shot out of the window
  24. don,t forget to fit the lead valley in lengths --NOT one piece about 1.5m each bit and overlap them this will stop any problems from expansion of the lead when roof is hot also easier to get a long valley looking good
  25. It could be a little better than washibng up liquid ,but doubt its a game changer
