Everything posted by jack
Feel like silly questions but may not be.
jack replied to MikeSharp01's topic in Networks, AV, Security & Automation
Make the delay an hour or two from the last motion. You shouldn't really be sitting completely stationary for two hours, and a decent presence (not motion) sensor doesn't require you to run around the room to be detected. Another approach is to program the lights to briefly dim a couple of times shortly before turning off. If that happens, you can just wave your arm around to reset the timer. -
Exactly. I think a lot of people don't realise how flexible home automation can be. For example, I have lights in some rooms set so that they behave differently after dusk (the HA system tracks the changing dusk time). If I'm turning the lights in the bedroom on during the day, it's generally because I need a lot of light. At night, the same switch just turns on the bedside table lights, because I almost never need/want downlights on at 10 or 11 pm (but can put them on with about 10 seconds' effort on the phone if needed). Even in the small number of rooms with just downlights, many are set so that the downlights come on at ~60% at night and 90-100% during the day. I personally don't have any lights set to come on automatically as a result of motion within a room. If I did use motion/presence sensors, I'd be more likely to set them so the lights still need to be turned on at the switch, but automatically turn off after some period of inactivity in the room. -
Reducing Energy Bills - How goes it?
jack replied to Ferdinand's topic in General Self Build & DIY Discussion
Oh yeah, completely forgot about that! -
Standby mode (in which energy is intentionally consumed to keep the components in the main signal path warm) is definitely something to watch out for. I have no idea how much power is involved, but I'd be surprised if it's less than a few watts per channel. As you say, across several channels in a home theatre amp, this could add up to a lot. It's true that non Class D amps are inefficient, but most amps are rarely if ever used at anything like their full rated power. Unless you're using inefficient loudspeakers and/or listening at very high volumes, you're unlikely to be using more than a few percent of the rated output most of the time. To be fair, this has completely changed since Class D amplifiers started making inroads a few years ago. They run at very high efficiencies, and when designed properly can sound excellent as well. Also, more expensive amps are more likely to use Class A output stages, which are less efficient than the Class AB output stages typically used by cheaper amps. Class A means higher power consumption for a given power output. -
You had me going for about 2 seconds...
I believe there were several documented problems with the Immersun unit, at least in its older incarnation. Its design may have been updated since. Mine (bought about 7 years ago) died in less than two years, and wasn't covered under warranty because the original company had gone under and had its assets bought out in the meantime. My electrician installed several Immersun units over the same period, and then stopped recommending them after several failed in service. I think it's a little narrow-minded to reject an entire product category just because of historical experiences with one particular product. In the right installation, some units have a payback period that's shorter than the warranty period, so you have little to lose.
I'll admit to having been beyond frustrated by the end of that thread. I probably should have just picked up the phone and spoken to Jeremy rather than trying to keep hammering the same point online. That said, I doubt it was just me. He'd previously taken at least one extended break from BuildHub of his own accord.
We have an 8.5 kW array with Enphase micro inverters, and managed over 50 kWh yesterday. Looks like about the third best day this year for us (best was 52.2 kWh on 14 June). Much better than the same date last year (the line on the same graph).
Zehnder ComfoAir Q450 vs Brink Flair 400
jack replied to Adsibob's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Sorry, never used it - my unit is too old to have the app! -
There's zero way for him to charge you for the costs of any attempt at obtaining an injunction if he undertakes it before you've done anything. If he waits until you start building and you never do any of the things he says he's worried about, the situation is the same. If you start doing things he disagrees with, he is required to attempt to negotiate with you before seeking an injunction. If that fails and he seeks an injunction, you would likely be responsible for some (generally not all) of his costs if, and only if, you lose. I think it's too early to be worried about an injunction. I suspect what's more likely to be a potential problem is him impeding your use of this access, such as by placing things in the way. You'd then need to get your own injunction to force him to give back the access to which you believe have a right. It never ceases to amaze me the way people behave when it comes to anything even vaguely related to their property. It seems as though all sanity and reason goes out the window, along with any consideration of previously good personal relationships.
We should have installed air conditioning… now what?
jack replied to Adsibob's topic in Other Heating Systems
Having lived and worked in Australia (not without aircon, I'll add!), humidity definitely has an impact. But the main thing is that I just subjectively hate the heat. Always have, even on holidays. -
Warmer temps are fine when I'm outside and there's some air movement (either a breeze, or I'm moving around). But 24+ degrees inside and I'm dripping with sweat, and completely unable to concentrate. I've worked in non-airconditioned offices a couple of times, and I definitely didn't adapt. Thankfully my office (I work from home) is downstairs, where we have underfloor cooling and concrete floors. It's heaven during a heatwave. -
MVHR - Self install!?
jack replied to richo106's topic in Mechanical Ventilation with Heat Recovery (MVHR)
That seems unusually reasonable for an MVHR installation. Nice! -
Recession + building trade = ?
jack replied to DazRave's topic in General Self Build & DIY Discussion
The formal definition of a recession is two consecutive quarters of contraction. From my perspective, the two most likely outcomes are severe recession (and possibly depression) or massive (possibly hyper-) inflation. I don't see any way we go from the current situation to a situation of stable growth, inflation, and employment. It's like the punchline to that joke about the guy asking for directions from a farmer: "Well I wouldn't start from here". -
Most EVs allow you to program their charge times, so you can match that to, eg, the Octopus Go cheap period.
Bit late to the party, but for others who might follow: I believe you did need to use someone certified if you wanted to claim the home charging grant, but the system changed earlier this year, and only flat owners and renters qualify for the subsidy. I don't believe an electrician needs any special certification to install a charger. You do, however, need some special kit if you want to do the required testing. I don't know how common it is for a typical one-person-band electrician to have this kit. The electrician I use just bought the required equipment in the last few weeks, as he now has enough interest from his regular clients to make it worthwhile having.
Service should be zero rated. You can only claim back VAT on goods, or goods and services supplied together. You can't claim back VAT on a service/labour-only invoice. Compare with a plumber: - If labour only (i.e., you supply all fittings), you claim back VAT on fittings upon completion, plumber charges zero VAT on labour - If plumber supplies fittings, VAT is zero for both labour and fittings. No materials are being supplied here. You own the bricks and are having a service performed upon them.
Just as in the title: what's a reasonable day rate for a plumber (sole trader) in the south east for general plumbing work (moving a water softener with decent access to all pipework, that sort of thing). I know it isn't the £1000 one guy quoted me last year just to move the water softener, even if he did explain that he'd need to "include materials to build a shelf".
I'm on Octopus Go and have just been moved onto a 34.86 p/kWh rate for 04:30-00:30, 7.5 p/kWh rate for 00:30-04:30, and about 43.12 p/day standing charge. Only 4 hours on the cheap rate, but at a bit over 20% of the day rate, it takes some beating. We put everything on during that period during winter - washing machine, dishwasher, car. We have a lot of PV, so we focus on using that during the day during summer and on sunny days the rest of the year, but it's nice to know there's a cheap period for when the timing doesn't work out (eg, dishwasher is full after dinner and we don't want to wait until mid-morning the next day to start a cycle).
In our case, we knew we were going for a super king size bed, so based the measurements on that. I assume in most cases people will know what size bed will be going in a space (OP said that there was only room for a double), but yes, they should consider the largest bed that would reasonably be put there.
I doubt you'll have an issue. We had all sorts of copies downloaded from, eg, Screwfix, till receipts with no name, even a couple of invoices in the wrong name (one was in the name of our tiler, the other was in some random name due to an error by the supplier). We explained any oddities in the covering letter and not a single invoice was queried.
Yes, exactly that. I suppose it depends what you want. I don't want my bedside drawer + cupboard right up against the bed, so this works fine for me. We did a worst case measurement on the bed and it worked out fine (just!).
We estimated what size of bed would be going in the space, then put double sockets just outside where the bed would finish. Even where the plug for, eg, an alarm clock or charger sticks out, it's hidden in the space between the bed and the bedside tables. The plugs are nearly invisible, but still quite accessible. Works well for us.
Sure, but my point was that I've never bothered quantifying it. It seems a pretty difficult thing to model accurately, given the almost constantly changing outside air temperature, and that's before you get into second order effects like heat recovery via condensation at the heat exchanger in very cold weather (which itself is at least partly recovering heat absorbed from the environment when the moisture initially vapourised).
