jack
    41
Everything posted by jack
  1. I'm not aware of there being limitations on new users uploading, plus he managed to upload one yesterday. Size seems fine. Try going to where you have the file saved, then dragging and dropping them from there into the post where shown in the editor:
  2. Yeah, fair enough. Now that I think about the actual time slot, 5-6 pm isn't a great time for us to be reducing energy either. We rarely cook before 6, there's no hot water heating happening at that time of day, and the ASHP isn't likely to be doing any heating at this time until it gets colder. I haven't looked back further, but yesterday we used something like 0.8 kWh between 5 and 6. Short of stopping work for an hour and turning my computer and monitor off, I'm not sure what other easy wins there are. I'm not switching off the fridge or the freezer, as knowing my luck I'll forget to turn them back on again!
  3. Same here, but trying to use less during that period is still the right thing to do.
  4. Very much wish I'd gone with CC drivers (using a DC power supply) to begin with. I thought they were expensive at the time, but once you factor in the cost of mains dimmers and a driver per fitting, I'm not sure there's that much difference.
  5. I have one of Mike's 16 channel DMX dimmers. Great quality at a decent price, and as you say, supporting someone local.
  6. Brink (I have one) are more expensive than the Vent Axia equivalent. They're generally considered quiet and good quality. I had a minor issue with some internal water build-up in mine and Brink sent out an engineer something like 3 years after we bought the unit, so I can't fault their support. I know others on here (maybe @Nickfromwales?) rate Brink highly as well. The airflow rates quoted above are overkill imo. They're quoting for 5 bedrooms, 7 wet rooms, and 12 occupants (perhaps that's what you'll have, but it seems unusual compared to typical British living arrangements). From memory, the building regs rate for our 289 m2 house with higher than average volume was 180 m3/h, which in practice is far more than needed. We tend to run it at 80 m3/h year round, and that leaves us with perfectly fresh air (two adults, two teenagers, and a dog). Edited to add: I forgot to mention that some of the Brink units are rebadged under other brands. Envirovent (which might actually be a Brink sub-brand) and Ubbink are two that jump to mind - I think there used to be others. It might take some comparing to make sure you're getting all the same features, but I suspect there may be savings to be had if you can find one of these rebadged units. It's generally pretty obvious from the pics.
  7. Bloody Nora that's a ridiculous amount of money, even if commissioning were included. We had our electrician wire our MVHR unit in (literally just a single circuit with appropriate RCBO), and had the plumber install the appropriate drain (again, very little work). My wife and I installed the manifolds and ducts ourselves. From memory, it was basically two easy days of effort. For the £7k quote, even two guys at £350 a day (a ridiculously high day rate) would suggest 10 days onsite, which seems crazy. I doubt that your builder will have any difficulty. That's an unusual problem to have. Unless it's very high volume, white noise (and other random noise types - pink, etc) tends to quickly fade into the background for most people. It's usually more intermittent or repetitive sounds that cause problems. Even ordinary window vents surely let in far more objectionable noise than any decent, properly installed MVHR unit will cause? Nevertheless, noise shouldn't be an issue with a suitable unit, properly installed. We've been running a Brink Excellent 400 for the last 7 years. It's very quiet. We tend to run it well below the calculated building regs rates, which are massive overkill. At those rates, it's completely silent, to the point that I can't tell it's even running unless I stick my ear right near the duct. Passivhaus-certified units tend to be more expensive, but on average are likely to be quieter than non-certified units. I seem to recall that the Passivhaus Standard places restrictions on the noise output of MVHR units. The two main sources of noise in rooms with ducts are fan noise and moving air. You can reduce the former by including silencers between the MVHR unit and manifolds. You can reduce the latter by making sure airspeed in the ducts is kept low. This can involve, for example, doubling up duct runs and using larger inlets/outlets (e.g., long slots instead of the small "mushroom" type), which will reduce the noise of air entering/leaving the room. Make sure that outlets in places like the bedrooms (where you're likely to be more aware of noise) are as far from the bedhead as possible. We do currently get a little bit of noise from the unit itself. The fans, in particular, are starting to make a small amount of noise after 7 years of continuous use, and I wonder whether the bearings need replacing. Careful siting of your unit will help mitigate the impact of the small amount of unavoidable noise generated by the unit. I've heard rumours of this too, but I suspect they're more related to wide-bore branched (rigid) systems that are more typical with American ducted heating and aircon than with the radial systems installed with most MVHR units these days. I don't recall anyone on BuildHub reporting this, despite a large number of us having installed MVHR in our houses. Perhaps avoid the rigid systems is you're really concerned about this.
  8. It depends on your pipe spacing and power output requirements. I've run my ASHP at 25 ºC with pipes at 200 mm spacing, with weather compensation pushing that up to 27 or 28 ºC in very cold weather. The house has been perfectly comfortable with only that heat output. That's with a polished concrete slab on the ground floor and no other heating anywhere else. (To be fair, the bathrooms do get a little chillier than desirable, so we've installed some electric heaters to take the chill off in the morning.) The mixing valve on the UFH manifold is set at 30 ºC and is really just used as a safety cut-out in case a valve fails somewhere in the setup and the ASHP tries to deliver water intended for heating our unvented cylinder to the UFH circuit. Your calculated 14 W/m2 isn't that much more than the Passivhaus limitation of 10 W/m2, so I can't see it being a serious issue.
  9. A couple of years ago, running the UFH continuously (in the sense of leaving it to look after itself - it didn't literally run continuously) through winter, we paid around £1000 for the year. That's for a 289 m2 house with decent insulation and airtightness. We do have a lot of PV, so that will have significantly reduced summer electricity costs (eg, we'll have hardly used the ASHP for hot water at all during summer due to the immersion diverter heating the tank with excess solar power). We've now switched to Octopus Go, which gives us 4 cheap hours of electricity overnight. With our 5 kW ASHP having to do DHW duties during that period as well, it's inevitable that some heating will need to take place outside of that time during the coldest months. When it gets properly cold, I'm considering using the immersion to provide a supplementary heat boost to the DHW right at the end cheap period. Although it has a COP of 1, it's still cheaper running the immersion during the cheap period than running the ASHP during the expensive period. One of the issues we face is a fairly dumb interface for the ASHP. I've started implementing some logic via our home automation system, but it's tough going with just a dry contact to call for heating and a temperature sensor for the DHW.
  10. Hi @Euan21 I'm closing off this thread in view of the discussion around the same question (with a bit more detail) here.
  11. All fully open. Might as well minimise restrictions so the pump isn't working so hard.
  12. The mechanical side of our MVHR installation was one of the very few things we entirely did ourselves. It was extremely easy. We had a layout from the supplier, but when we went to do the installation we realised that the open-web joists allowed much shorter routing in some places, by going on the diagonal. In terms of tips, I'd suggest making sure that there are no "closed" routes. We had a minor scare when we realised all supporting joists around our stairwell were solid, even though half of them were shown as open-web on the plans. Thankfully, the savings we made pulling some of the runs on the diagonal left us with more than enough to take a slightly longer route around the stairs to reach the affected room. For pulling through the ducts, you really need two people, as they tend to catch on edges of joist webbing. Where your ducts join the manifold, you should ideally have a reasonable length of straight run beforehand. That is, don't have a duct bending right before the manifold. It makes them harder to join to the manifold, and can really obstruct the paths of adjacent ducts. Think carefully about whether manifold position can reduce your runs. In our case, moving the manifolds by a few couple of metres saved us multiples of that distance in ducts, because nearly all of the runs went in the direction we moved the manifolds. For example, if you have 10 ducts coming out of a manifold and they're all going in the same direction, moving the manifold 1m in that direction saves you 10m of duct. You might not have the option to do that, but we had the space and it worked well. Think about how you're going to support the ducts, as they shouldn't have significant dips along their length. It can be as simple as some offcuts of wood bridging wider gaps, and/or using something like leftover breather membrane screwed to something above to provide support.
  13. Fewer thermostats (perhaps only one), no need for per-loop actuators, no need to worry about changing flow rates as different numbers of zones are calling for heat, possibility to avoid a buffer tank (because you're always using the whole volume of the UFH loops). It works fine in a well-insulated house. We've been running ours like this for 7 years without any issues. If you really prefer having a zone a bit warmer/cooler than the rest, you can just manually adjust the flow rates on the manifold. I just run all of ours flat out though.
  14. A more important one, which I mentioned in another thread, was a fan heater that my son left running full bore overnight in the garage gym. The gym sometimes isn't used for a few days at a time, so that could have been an expensive one. I only noticed it because the display screen for our smart meter is in my office, and it was showing high and persistent energy consumption despite the fact I knew nothing significant should be on.
  15. It doesn't worry me, I quite enjoy the process and the chat.
  16. So plumb for the outdoor shower and decide later. The cost of the plumbing is a few quid at this stage. If it's cold and wet outside, you've already been walking in it with the dog for God knows how long. A few seconds extra for a quick rinse isn't going to hurt you. Worst case, you have the indoor shower anyway, so use it when you want to.
  17. But yours will look very different to mine, in a way that probably can't be distilled into a single meaningful number. Perhaps "baseload" is not actually that useful a term.
  18. Okay, I was confused by you saying you were going to wash him down outside and then put him in the shower. If I had an outdoor tap, I'd just skip the shower bit entirely and avoid the clean-up.
  19. Yes, exactly. There's no point me saying my baseload is 300 W if we don't all understand whether that includes intermittent devices like fridges (intermittent but pretty regular) and cookers (intermittent and less predictable/regular than a fridge).
  20. Is there a formal definition of "base load"? If it means the absolute minimum, then we're somewhere around 300 W. I recently realised that I'd disabled the UFH pump switch controller in our home automation setup when doing some testing a couple of years ago, so it's been on continuously since then. I need to reprogram it so that it's only on when: the ASHP is running there's a significant difference between the slab temp in the kitchen (which gets more solar gain than anywhere else) and the slab temp in the TV room (which is under carpet and gets zero solar gain) there's a significant difference between the supply and return temps on the UFH manifold. That should save 20-30W a significant proportion of the time.
  21. I have one of those bellows-type toilet plungers in the downstairs shower, and just give the drain a good plunge now and again. Used properly, it pushes everything through the trap, even sand and small stones. The really annoyance is rinsing down the tray and surrounding walls after she's been rinsed down. If I had an outdoor tap, I doubt I'd put the dog in the shower afterwards very often. At the moment, we need to rinse her off most days when she comes back from walk due to how wet and muddy it is. You shouldn't wash (in the sense of using shampoo) your dog anywhere near that frequently. At a guess, ours is washed properly less than 1 in 10 times.
  22. Wow, spooky. We've lived in our house for nearly 7 years, and I yesterday referred to the shower in the boot room as the "dog shower" for the first time. On the topic of dog washing, I wish we'd followed through on our original plan for a warm water tap outside for the dog. It's all well and good rinsing the dog down in the shower, but the amount of mud, sand, and other horrible stuff that comes off ours when we've gone for a walk in the wet is ridiculous. It gets stuck in the drain and generally makes for a fair bit of work cleaning up after the dog's been rinsed down. If you haven't considered it and can still run the pipework, an outside warm-water station with hand shower attachment (even just a standard garden hose type) lets you rinse the worst of the crud off outside. I'm with you on large utility rooms. We thought we were being overly generous with ours, but having lived with it for a while, it would definitely be better if it were larger.
  23. All of this sounds like someone looking for an easier way to do a job that I just don't have any interest in doing at all.
  24. It'd be a massive chore, which is why I've avoided cleaning or external venetians for 7 years so far. We chose a shade of grey that really just doesn't show the dirt unless you're very close, so they look fine.
