Everything posted by jack
Update on Timeshifting to Minimise Heating Costs.
jack commented on TerryE's blog entry in The House at the Bottom of the Garden
Ha. My air test guy did loads of MBC tests, so he wasn't that impressed with our result! -
The guy I used was very experienced and had never seen anyone achieve an EPC of 100 before. To be fair, I think a lot of his work was with developers, so perhaps not that surprising he wasn't see much in the way of low-energy builds. -
Wow, it sounds like you can do most if not all of what I'd like to be able to do with mine. I didn't get as far as looking at controls, to be fair. When I looked into Nibe 7-8 years ago, I'm not sure it was even possible to buy them retail, or if it way, they were way more expensive than the equivalent power Panasonic. They also didn't (at least on the published figures) perform as well. I'd certainly be thinking a lot harder about controls if I were buying today. I'll eventually get around to looking into whether the optional controllers from Panasonic offer better functionality than I can get with the one that was in the box.
It's certified though. I can't imagine the PassivHaus Institute certifying a house that didn't pass the standard. In this case, there's loads of glass AND an uninsulated masonry arch that makes up the vast bulk of the non-glass fabric. -
To be fair, even if you'd had the required airtightness, it's extremely unlikely you'd have managed to get certification after the house was built. It's technically possible to start the PH certification process after building, but there's a huge amount of record-keeping required to prove that what was designed was actually built. For example, every junction would need to be thermally modelled at design stage, which you can do/show after the fact, but then a full photographic record of every junction is needed to show that what was designed was actually built. The only building I've heard of managing this feat in the UK was that amazing arched house that was on Grand Designs: I really don't know how they managed it tbh. The arch is exposed internally along most of its length, and I can't see how they managed to insulate it at all, let alone to the sort of value that would been needed to meet the Passivhaus energy consumption standard. -
Yes, I've been doing some tweaking of this too. I'm getting very frustrated with the controller that came with my ASHP. Setting the timer is a hideous experience. For example, it isn't clear exactly how the timer periods work. You basically program in a series of events, each of which is either "on" or "off". For each "on" event, you select whether it's DHW or UFH. The "off" event doesn't refer to the mode. It isn't clear whether setting UFH "on" from midday say, then DHW "on" from 14:00, results in the DHW setting overriding the UFH setting (in which case a single "off" event is all that's required to end both programs), or the DHW setting "nesting" within the UFH setting (in which the first "off" ends the DHW setting and the ASHP returns to UFH until the next "off" trigger). I don't really have the time (okay, the patience!) to experiment with this but knowing the details would make a difference to how I program it.
Well mine's working fine, more or less! I do think it could work more efficiently. Ideally I'd like to be able to change the flow temperature based on time of day or a trigger, so I can turn the temperature up when there's off-peak or solar power available, and run it cooler when energy is expensive.
Keep posting. I think the BuildHub hive mind has solved most of the ASHP and UFH problems that have been posted over the last couple of weeks. I've never seen this sub-forum so busy. I think a lot of people are suddenly finding in this cold snap that their ASHPs perhaps haven't been installed or commissioned as well as they should have been.
Amazing numbers, especially given your location. Back of a fag packet calculations: 50 kWh at COP of 3 = 150 kWH total energy provided for heating 150/7 = ~21 kWh/day That's an average of less than a kW over that period, which even in a Passivhaus would be impressive. What temperature are you keeping your house at? What sort of weather have you had? We've been mostly very cloudy, so very little solar gain, meaning the ASHP has been working harder. You mentioned some supplemental heating with your diverter - do you think you had much from that? I don't know exactly what we're using for heating at the moment, but I do know that I've never seen a weekly electricity cost as high as last week's (admittedly we were doing loads of driving, so the electric car was the cause of a lot of those costs). -
Whatever you do next, it should not in any way involve this plumbing firm!
Can you tell whether the water from the ASHP is getting into the UFH manifold? You might get cycling like this if TMV on the manifold isn't letting water past properly or the pump on either the manifold or in the ASHP itself isn't working properly (although I think most ASHPs will throw an error code if the internal pump isn't working properly). Might also be a blockage or restriction somewhere - is there an inline filter/strainer you can check?
Weather conditions are really unusual down here at the moment. Despite it falling well into the negative single digits for 12+ hours a day for nearly a week, we've also had a lot of mist and freezing fog, so there is some moisture in the air despite the temperature. My ASHP has been defrosting for a few minutes every 45-70 minutes, even when it's -4 to -7 outside and it isn't working that hard.
Any reason you can't install inlets and outlets high up on a wall instead of in the ceiling? Alternatively, all of our upstairs outlets (bedrooms) are in the floor, with ducting run through the posi-joists underneath the floor. Extracts in the bathrooms are in the ceilings, but could have been installed high up on the wall if that hadn't been an option for some reason.
I'm not sure it's reasonable to assume costs will be similar. As well as the cost of an extra pane of glass (+spacer, plus gas assuming it's argon or krypton filled), the glazing unit will be about a third heavier (and triple glazed units are already quite heavy). You also need to account for yet more thickness, which potentially means deeper frames (and again, triple glazed frames are already pretty deep and heavy). Quad glazing is generally only sold into countries with climates that make it worthwhile. Even in the colder parts of the UK, the benefits of quad glazing are probably marginal. Certainly if you live in the more temperate parts of the UK, the additional cost is unlikely to make it worth the extra cost, weight, and bulk of adding a further pane.
I'm not a lawyer either, but the second result for Googling "fines for exporting electricity" gives this: https://www.deif.com/land-power/cases/avoid-power-export-fines But systems aren't specced to avoid overcapacity in the middle of June. I don't have batteries, but with 8.5 kW of PV, our immersion diverter regularly maxes out our hot water cylinder by late morning though the sunniest months of the year. Yet we averaged less than 7 kWh/day in November, and I expect December to be far worse than that. Similar principles apply for batteries.
Soundproofing a heat-pump's external unit
jack replied to Garald's topic in Air Source Heat Pumps (ASHP)
I seem to recall that OP is in France. -
Hi @EmmaSp, welcome to BuildHub. I see that you've posted the same question in the "House Extensions and Conservatories" sub-forum here: To avoid splitting answers across two posts, questions should be posted only once. I think the "House Extensions and Conservatories" sub-forum is the more appropriate of the two you posted in, so I've locked this post. People can find the other one by following the link above.
greetings all, I'm here for some building advice
jack replied to johnhenstock83's topic in Introduce Yourself
Welcome John. A couple of pointers: - add the term "Buildhub" to a Google search to find info on the forum - if you have a question, drop it in the relevant sub-forum for the quickest reply. As to what not to do, just use your common sense and I'm sure you'll be fine. Plenty of the regulars have no common sense at all and they get by.- 1 reply
I'm in the southeast and we get the occasional one - maybe once every year or two for 1-4 hours.
Hi tomaus Welcome to BuildHub. It's generally best to post specific questions in the relevant sub-forum, as not everyone monitors the Introduce Yourself sub-forum. In this case, this is the right place to post your question: https://forum.buildhub.org.uk/forum/79-mechanical-ventilation-with-heat-recovery-mvhr/ Any drawings, photos, or details about when and how the problem happens will likely help you get a better/faster answer. For example, when you say the "intake" circuit, do you mean this is a vent that extracts air from a room?
We're just doing it (without going crazy) because it seems like the right thing to do. If you were really struggling and your usage pattern allowed you to significantly reduce usage at the right times, being able to make a couple of quid here and there wouldn't hurt.
Balancing Query - Replacement MVHR
jack replied to TimCx's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Also, some MVHR systems adjust per terminal airflow at the manifold. If you have such a system, you should have all terminals wide open while you get as close as you can by adjusting airflow at the manifolds. Once that's done you can make fine adjustments at the terminals if needed. -
Essential standby equipment, energy use and solutions
jack replied to ProDave's topic in General Alternative Energy Issues
Absolutely. Plus more people means more incidental heating, particularly from showers, but also things like PCs and other tech used by occupants. -
I think you're right about ratings. They're usually the highest output you can expect, which will generally be when it's warmer outside and you're generating relatively low temperature water. I have a 5 kW unit. With a well-insulated house, I never particularly felt the need for anything bigger until the cost of electricity went up and we went onto Octopus Go. On very cold nights it's realistically going to be more like an average of 3 kW when you take the lower output and periodic defrosting into account. Stuffing all of our expected 24 hour heat loss into a 4 period with Go isn't realistic, especially when I'd ideally like to also heat up our hot water tank at the end of that period. Realistically, a more powerful heat pump would give me more options. I may think about that if and when the current into needs replacing.
