Gav_P
    1
Everything posted by Gav_P
  1. Crikey!! Whoppers! I like big ones... got any pics? ?
  2. This... which is flow and which is return?? Probably the right way round as it’s been working for 15 years. Definitely sounds like an airlock.
  3. To be fair... anyone visiting his place needs to get past the obstacle course of dumped building materials and Harris fencing before even getting to the gates! ?
  4. To be fair, I don’t even have a LL phone plugged in. I do have unlimited data calls and texts on my mobile, but I still use the broadband when at home (including WiFi calling on my mobile). I would think we have close to 30 WiFi devices in our home, so this is why I wondered why people would want to use mobile phone network instead.
  5. I love the look of the front elevation... not so keen on the other 3 sides though. What’s the position in relation to the plot? I.e. if you are out in the garden what elevation do you look back at? Which way is north?
  6. That’s a cosy little pad... I’d probably add another bedroom!
  7. Radio switch can be switched with a magnet... smart meter can’t. also when the did the role out of 1st gen I don’t think the meters could deal with eco7.
  8. The top draw in ours has a u shape cutout for the trap.
  9. Wot e said! Really not worth falling out with a neighbour about... not worth stressing yourself about either.
  10. I’ve ordered one of these and a 1000mm 22mm SDS Plus bit. I’ll use this and sleeve with 22mm pipe. Thanks everyone ??
  11. Great idea.. hadn’t thought of that.
  12. Out of interest, if it’s for your home why do you need any phone signal? Can’t you just use your broadband?
  13. But only half way! .. which I can do easily.
  14. That’s the big difference between SDS plus and SDS Max... Max seems to be indestructible and lasts forever, but also costs the earth!
  15. That’s exactly what’s happening.... time to order some beads! ?
  16. I Can’t find any SDS Max of suitable size at screwfix.
  17. Thanks, but SDS Plus and SDS Max are different sizes.
  18. Thinking about it, I could probably just get a longer drill bit for my cordless drill with a normal chuck. ... that will be cheap!
  19. Is there such a thing as cheap 3ft bit? I need SDS Max and they seem to be £100for a bit.
  20. I’ve measured a dozen times to get the spot to drill, then I used a 22mm bit, which I thought could hopefully make up for some minor deviation. ... next option is the 30mm bit.
  21. Yeah, this is what I did for the pipe work for the ASHP... I just didn’t want to go through that again for 2 poxy pipes. ... I was hoping for a cheat I was thinking that I could squirt in a load of expanding foam and then when it’s gone off, drill again. Maybe this would stop all the cack in the middle of the wall from dropping down?
  22. So I am trying to drill a couple of holes through the original stone wall (about 2ft thick) in my cottage to get 15mm water pipe through for an outdoor shower. I’m using a hilti with 18” drill bit, so have to drill from each side - hoping my measurements line up! However the guts of the wall are dust, rubble etc and keeps dropping and blocking the hole I have just drilled. ... it’s doing my nut in! What can I do to keep the drilled hole clear??
  23. I’m more concerned with that wall paper!
  24. Yeah, I can picture you as a Louis Litt kind of character!
  25. Oh yeah... I remember now. At least you can get it sorted now.... probably another chance for you to take someone to court. ?
