nod
    72
Everything posted by nod
  1. Your probably better going down the small claims option Cheap and simple
  2. Thanks both of the above Yes we’ve been registered with Counsul and post office for three months No issues with utilities Except BT 😂
  3. I wondered if anyone else has encounter this We are trying to get standard home insurance and have been turned down by two insurance companies due to the house having a name rather than a number I pointed out that none of the houses down here have numbers While we are quite rural We are only ten minutes aways from hundreds of new homes One has stated that a house name implies that it’s a small holding Also the proximity of the coast 11 miles Any thoughts ?
  4. I saw this Really sad He had also worked in his home country doing the same job So no comp
  5. If your going the TF route You probably don’t need a main contractor Once watertight You could bring in a heating and electrical company to get it first fixed Then it’s just a case of coordinating plasterers joiners any render etc Established firms will be happy to quote for each stage and should be self sufficient
  6. Sorry should say Wouldn’t
  7. NO I would lay flags like that Whilst voids behind wall tiles to really matter He’s making work for himself A nice even 10 mil notch on the wall and a 5 mill lick on the back of the tile
  8. Exactly It Will hardly be noticed on the monthly bill
  9. With electric nearly four times the price of gas It’s a no brainer
  10. Hard to tell from the picture Point it out and ask him to take the bad ones out
  11. If the edges match the tiler will probably blame the walls You can always find Something with tiles Some tilers are using leveling systems on wall tiles Which can give a nice edge but cause hollows I’m not keen on levelers on walls
  12. Pay for the materials net of vat and let him settle the vat Then claim it back later
  13. Most things are possible At a price A SE will do you a drawing to put to the truss designer for a couple of hundred
  14. I’d try an electrician on a labour only quote We’ve just paid £4700 for labour only and bought the materials ourselves on a substantially larger property He was looking to come away with £30 per hour
  15. That’s good to know We are almost at the reclaim stage The last time we did this We had to physically send every invoice to them Making copies seem to take forever Do they only ask for a random sample now
  16. Terminate any deal you have with them Hopefully you haven’t paid to much and get someone local to do the first fix and get a separate LOCAL company for the HP Same with the plumbing
  17. I’ve found that the larger the house the lower the cost per m2 Endless surveys services are all the same So my answer would be The bigger the house the larger the saving on a middle floor But your right Big savings adding a middle floor I’m not sure what percentage of the build cost doing this would be I’d guess no more than 20%
  18. If it’s been down five weeks You can put the heating on as normal without damaging the tiles
  19. Bolt a joist to the wall Fix hangers on the joist and on the trimmer Back to back with what is already there Such a short span will be fine
  20. I do hundreds of these each year Lots of variation
  21. It’s usually But can be done with two walls together with a minimum of 50 mil void with fire stops along the perimeter But can be done single (Shaft wall) Needs to be done in none combustible MF or masonry If it’s in a void loft ceiling etc It can be done with a curtain
  22. If your not looking to replace the roof It’s normally quite easy and cheap to do a fibreglass repair around the skylight May not look pretty but will cure most leaks The trick is to make sure the area is dry Not easy at the moment May have to temporary sheet over for a couple of weeks
  23. Fortunately You don’t have to employ a principle contractor Or designer You can be a self builder and not be shackled to anyone
  24. As above Its a bit like Cadburys telling us that we all need to each more chocolate
  25. Yeah it’s different with a main contractor with sole control of the build Subbies would just blame each other
