nod
    72
Everything posted by nod
  1. It won’t make any difference wait 12 months
  2. Limited companies don’t get any special treatment when it comes to vat
  3. You can get the plumber and plaster in any order But most will get the plumber first Easier to run wires around pipes than the other way round Your plumber will put the pipe work in for the boiler and put the boiler in with the Rads bath etc on a second fix after plastering and paint
  4. Just to follow on from earlier The installer has been out checked everything Tweaked a few bits He said it can only be the flow switch He will order one from Mitsubishi in the morning
  5. We’ve had this twice The installer is out tomorrow or Weds He seams to think it’s air between the pump and the buffer tank He said in any case it’s a flow problem man’s will be easy to find I’ll keep you posted
  6. Use one of these hooked into the cavity 1500x2mil thick are best They need to span three joists Take a 2 mil notch out of the top of the joist to stop the floorboards rocking You will also need to nog under the strap and nail or screw the strap down
  7. If BC insist You can always put a slit in afterwards
  8. No I never have Some BC insist in this But I can’t see any good reason I’ve asked the last two BC and they have said it’s up to you
  9. I’m guessing you’ve tried the installer They really should come out on the day you move in Id a similar issue a few weeks ago Went round in Circles with the manual Called the installer who was home with Covid He just said let me face time you and reset everything Ten minutes and it was all sorted Your ok if your like John Mo and know what you are looking at Ours was something to do with outside temp compensation Yep meant nothing to me either So annoying when it’s probably something really simple
  10. As long as you leave a clear air passage It will be fine
  11. Fine as it is I let tha cavity insulation rise above the wall plate an act as a stop end for the roof insulation Giving a continuous 50 void
  12. We decided to vault three ceilings and have the DS ceilings at 2.8 Absolutely no benefits But look bloody great 😊
  13. Ideally you want the points of the pattern facing you as you come through the door
  14. The actual design will need to be done by a Structural Engineer Im not sure why the Architects would get involved with foundation design Not really there bag
  15. There just caps on the top of the pots
  16. Gas boiler 200 HP 150 Mate it’s free If it’s no good to you Then you haven’t lost anything I’ve used them on both our builds
  17. No They don’t ask for any of that Just a floor drawing
  18. I was referring to the temperature of the Rads Warm more than hot
  19. Contact Warm up they will do you a full design FREE of charge
  20. We didn’t want to cover our beautiful slate roof with horrible solar panels As stated our buyer has decided to put these things up The salesmen has predicted around £700 per year saving 12 k supply and fit If the saving is correct and I’ve no reason to doubt a salesman 15 years to break even is a long time and the batteries will probably need replacing by then Definitely not a no brainer
  21. We’ve a gate guy off at the moment with stress He only has to open and shut the gate 😂
  22. You missed out mental health 😂
  23. First thought ill Second Dead Try his business address
  24. We are into December So able to make a comparison between our current and previous build All things considered I think the HP will be the same or slightly more to run We didn’t have an option on this build Both builds are traditional Scoring about the same B89 A if we ever got the urge to add PV Which our buyers are in the process of doing While the HP works exactly the same with UFH I wouldn’t like to have to rely on Rads with a HP They are slow to heat and don’t get very hot I wouldn’t like to have to rely on Rads to heat a poorly insulated home The installer came back to check and set everything up for winter He asked if we could leave the Rads on for a few hours All in all we are pleasantly surprised at how straightforward a HP is and hot water on tap 24-7 is a bonus
