Mike
Everything posted by Mike
It used to, but most of that was closed down. It now holds 12 days maximum. https://www.dw.com/en/why-uk-gas-storage-levels-are-concerningly-low/a-71281361
Last time I checked Denmark was still the World's 2nd largest manufacturer of wind turbines - it was they who developed the technology in the '80s. Of course the UK could have done the same, but why do that when the North Sea was full of oil and gas? Though, in view the current headlines, maybe Denmark should have invested in nuclear weapons instead...
They’re best avoided - the problem is that they tend to push moisture-laiden internal air through gaps in the building, leading to condensation within the structure. MEV avoids this risk. Choose either a central central unit, or decentralised dMEV. If you're not going to DIY it, then yes, you need to find a contractor to propose a solution. You can post their proposal here for feedback.
X3 Immersion heaters on a single radial
Mike replied to RedSpottedSev's topic in Consumer Units, RCDs, MCBOs
It doesn't, so I'll get myself some more; thanks for the heads-up! Yes, there is a recommendation to use no more than 2 adjacent contactors unless there's a gap between them for cooling. I'm populating the row with alternating breakers & contactors, which should help. -
It depends. If the external wall is in good condition, free from penetrating rain and not very exposed, and provided the DPC is doing its job, then it's generally accepted that it's safe to apply internal wall insulation to a solid wall if the resulting wall u-value is at or above 0.5 W/m².K, pretty much irrespective of the method used. However there is significant research such as the Historic Scotland Refurbishment Case Study 4 where they went down to between 0.37 and 0.19 by using vapour-periable materials (important!) without using a vapour barrier, and without any concerns during their 18-month initial study (AFAIK they never published their promised follow-up report); it's worth downloading a copy. Since most of the research is on insulating solid walls I don't recall seeing anything about upgrading insulated cavity walls. Ideally you'd find someone to model the risk with software such as WUFI (though it isn't without problems - best to model the entire building, not just the walls). As mentioned in one of my earlier posts above, remove any gypsum plaster if there's a risk of any condensation against the existing wall - many materials can tolerate some moisture in winter temperatures provided they dry out again quickly enough in spring (so a Glaser analysis using a tool such as Ubakus isn't very useful), but gypsum holds the moisture and turns to slurry. For more reading, see the link to the other thread I posted above. You'll see there that I chose hemp insulation for my own IWI due to its good moisture handling abilities (plus good decrement delay). I wouldn't have been at all comfortable going as low with my u-values using mineral wool, or using a vapour-impermeable build-up. I'd probably choose cork.
That is a lot! Double checked my contactors and they seem to be 0.8 to 1.8 W. Mine claim to be good for 100,000 to 150,000 switching cycles so until your post I wasn't too worried about that - but maybe I should be? The only snubber at the moment is for the circulation pump. -
Decentralised mvhr
Mike replied to Jane W's topic in Mechanical Ventilation with Heat Recovery (MVHR)
dMVHR can be useful in an apartment or retrofit, but in a new-build house a central MVHR unit normally has the advantage. Only 2 holes to cut through the outside wall, only 2 visible external grilles, no visible boxes on the internal walls, constant-flow-rate fans to counteract the build-up of filter debris, only 1 set of filters to change, no worries about noise from fans or the outside world, many more units - PassiHaus-approved or otherwise - to choose from, the availability of a summer bypass (on good units), a single point of control, pre-heater and/or post-heater* options if needed, often lower installation costs (except in retrofit). *could be added to ducted dMVHR too. -
My guess is that it would flex too much on a ceiling as you tried to apply the plaster, but maybe not. On a wall it's possible, but there you have a rigid support behind it. BTW, not mentioned above is the need for a airtightness membrane; I'd choose Intello or similar. There are other threads on the topic if you need more info.
I'd guess that the weak point is likely to be the junction of the insulation and the wall, not the plasterboard to the insulation; the wall is unlikely to be perfectly flat (so the bonding patchy) and the surface might be friable. So, if I was concerned, I'd add some mechanical fixings before fixing the plasterboard.
For me 4000K is the ideal temperature, everywhere. But above all, be consistent - that is, all lights in a room that will be turned on at the same time should be the same temperature, otherwise they just look odd. So if you like 3000K, stick to it.
I've not used them myself, but AFAIK they have good vapour permeability; I'm not sure about moisture buffering. However, for a standard ceiling you normally wouldn't worry much about moisture so, if I had spare cash I'd choose to upgrade the insulation instead, by using either flexible wood fibre (e.g. Steico Flex) or hemp (e.g. IndiBreathe Flex). Both of these handle moisture better than synthetic insulation and also provide a much improved decrement delay (non-technically = resistance against summer heat). Hemp edges ahead of wood fibre for moisture handling, while wood fibre edges ahead for decrement delay, but not a big difference. Don't hang the light fitting from the plasterboard; you need to fix it through the plasterboard / wood wool board into a joist, or into a nogging fixed between two joists. 9.5mm is OK if your joists are no more than 450mm apart, but it will be a little less robust & have a little less fire and sound resistance. I'd choose 12.5mm unless cost is a factor.
Clay plaster does have better moisture buffering qualities and can moderate daily variations but, if you have adequate heating and ventilation, that won't make a big difference. If you don't have adequate heating and ventilation, consider those first. Unpainted clay plaster can look good though! For more, see my comment in this thread. ^ This.
Bloody tired of being confused. What heating system to fit ?
Mike replied to Big Jimbo's topic in Other Heating Systems
No space in a 1,750 square foot house? I'm not the only one that's fitted one in an apartment a fraction of that size; they really aren't that big. Could go on the wall or ceiling of the laundry room, or study next the hot water tank, or the kitchen, or the largish entrance hall, or the WC... -
Timber frame infill over cavity wall/steel lintels
Mike replied to lookseehear's topic in General Construction Issues
If that's a pair of steels over that window (difficult to tell from the resolution of the pic), then I'd remove the outer one and span over the window with the timber frame instead, to cut the thermal bridge. At least it doesn't look like a single steel across both leaves. BTW, make sure that the rafters over that ridge beam are adequately secured; I hope that the SE has specified something for that. -
In that kind of build the air sealing won't end up being external; external insulation goes over the top of what you see there. Or at least the majority would go on the outside. You could put some between the studs but, following the UK rule-of-thumb, it would be no more than 1/3 of it avoid the risk of condensation within it and hence the need for a separate internal VCL.
- 77 replies
- flat roof
- condensation
(and 2 more)
German self-build inspiration - Poing near Munich
Mike replied to RedRhino's topic in New House & Self Build Design
Time to radically reform the system. As reported in https://www.parliament.uk/globalassets/documents/commons-committees/public-accounts/2018-07-09 - MHCLG Report to the PAThe Role of International Evidenc.pdf -
You're right; it is standard practice to use a non-return or waterless trap for the reason you mention, but Zehnder's instructions sometimes suggest otherwise. For example they require only a U-bend with water seal in the CA 200 manual, but a non-return trap on my more recent CA 225 model. Avoid a dedicated water trap as it's likely to dry out. A good illustration of the principle, although my CA 225 has a 20mm drain so requires an alternative pipe adapter. A hole drilled through a rubber bung is doing fine so far.
I guess it's a different model number? That one seems to be single channel 25A? Indeed, sticking it over a bedroom wouldn't be a good idea with regular contactors. -
I was going to follow Terry's lead before I found that silent domestic contactors are readily available in France, for a premium. I've got Legrand 412501 (way below the list price) & presume they're solid state. My understanding is those in the Shelly are. Though if these are destined for a loft then clunking may not be an issue and would save a few £s. -
I've did similar. Bbattery powered camping shower + shower tent + paddling pool + drill pump. It gave a pretty good shower.
Hmm. The Pro 4PM is rated for a maximum switching load of 16A per channel, subject to (1) a maximum of 40A across all channels at once; (2) leaving 10mm cooling space around it for currents over 10A and (3) using solid core heat-resistant wire (4) adding a snubber across inductive loads. However the Live input has a 2.5mm² connector which would normally be fused at 16A or 20A, limiting the total continuous load. IMHO it would seem wise to use the Shelly for control and contactors to handle any serious loads. -
Correct, the Shelly only switches the contactors. You need an RCBO & contactor for each immersion, plus another RCBO to protect the Shelly itself. -
As an alternative, consider the Shelly Pro 4PM for the remote control functions, used to switch 3 x 25A contactors (1 for each immersion). If they won't fit in your main consumer unit, fit an auxiliary one in the loft. -
If you have the cash and have already done / plan to do other obvious thermal improvements, then it's worth considering - unless you can apply external wall insulation, which would be preferable. If you're able to withstand the disruption of IWI then presumably it would be part of a larger improvement scheme? With an insulated cavity wall the risk of condensation is greatly reduced / eliminated (depending on insulation thickness and provided rooms are adequately heated and ventilated). If it turns out that there is a significant risk then any gypsum plaster needs removing. Ensuring the airtightness of the existing wall (and all the junctions between the wall and other materials) is more important than a vapour control layer, as airflow through the structure is likely to cause much more condensation than the absence of / gaps in a VCL (as well as causing heat loss). If you add a VCL too, then only choose an 'intelligent' one such as Intello. There's a long meandering thread here that's worth reading. It relates to solid walls, but still useful: Plasterboard & regular plaster are vapour-permiable but, as mentioned above by @Redbeard, regular vinyl paints aren't - you'd need clay-based / lime-based paint to maintain permeability. With an insulated cavity wall permeability is normally less of a concern.
