I need to install the waste run in our plant area and was wondering if there was a specification for the size of the waste pipe needed to handle outputs from the tundish(s) etc around the tank. It will be an MCS install so I expect they have a rule for that but I cannot find it, it's probably buried in one of the standards or hiding in plane sight. Gemini says 22mm but that feels too small to me: "For an unvented domestic hot water cylinder safety system, the waste pipe (also called the discharge pipe) should typically be 22mm in diameter, with the section leading to the tundish potentially being a smaller size like 15mm, but always ensuring the pipe from the tundish is at least the same size as the tundish outlet itself; always consult local building regulations and consult a qualified plumber for specific installation details. Key points about unvented cylinder waste pipes: Pipe size: 22mm copper pipe is usually the standard size for the discharge pipe. Tundish connection: The pipe leading to the tundish may be smaller (like 15mm), but the pipe leaving the tundish should be at least 22mm. Fall and drainage: The discharge pipe should have a continuous fall and be routed to a safe discharge point outside the building. Professional installation: Due to safety concerns, always have an unvented cylinder installed by a qualified plumber familiar with building regulations. "
Like the conversation posting - especially as you work to cajole it to focus on the question at hand! Switching to Podman makes perfect sense, it's open source so will probably evolve faster than Docker - who I see are fighting a solid rear guard action in the new world of contested containerisation, and it uses the docker command line which aids learning. How much, given what you have Git, of it will port straight forwardly and how much re-working is needed, outside anything associated with moving to a differently resources VPS.
PS @nod is not in the wrong job, I don't suppose the average mortgage broker can plaster a wall perfectly, lay a tile flat, build their own home mainly on their own - several times, let alone be able to afford to do that .
It's a balance of risk in that when you think of it the £4K you are paying is going to be relatively small beer on the overall cost of the build and it gets you on the rails with ease. Can you earn the £4K doing other aspects, spend time to save money, of the project in the time you save going via the broker. If not I would perhaps question it.
ASHP grants for self-build?
MikeSharp01 replied to Benpointer's topic in Air Source Heat Pumps (ASHP)
Yes because self builders are specifically mentioned in the legislation, so you don't need be removing an old gas boiler, and there are some other criteria which mean you are a self builder anyway so easy to meet. -
I also use onShape for 3D work it is very good and an excellent grounding if you ever want / get to use the bigger packages like Solidworks, Catia or Autocad / Revitt
Another 'Cool Energy' heatpumps thread
MikeSharp01 replied to HughF's topic in Air Source Heat Pumps (ASHP)
Yes one is forced to assume so, or something similar, or this machine is able to warp physics. It has been like that forever and I told them about when I enquired. I guess it's a small company trying to do a good job but it can't quite yet sweep in all the corners. All my dealings with them have been good, professional and supportive. -
We are looking to do the same with them, we are awaiting the MCS certification of their tiny unit Pro Inverter Air Source Heat Pump | CE-iH6 | 1.74kW - 6kW to move ahead on it, it has great modulation depth and we, if I have my calculations correct, will only need about 2kW at -3 so it should cover us. Everybody else quoted silly money above the BUS grant. -
So the target then is run continuously, well down to minimum modulation after which the HP will run intermittently.
Why not, it is anonymous and it gives the response a load of contextual information although I suspect most people on here fall into a small set of common socioeconomic groups. Also vouchers and other tiny incentives - larger ones would stretch ethical rules and finances, are commonplace these days. All the relevant details of the study were posted with it and there was / is no compulsion to take part. Finally and perhaps most interesting point is that you (we all) already give this information to the world, well the tech giants, in our social media, online purchasing, lifestyle and public demeanor. It's just that researchers have to ask for it because the tech giants don't give it away. All that said scepticism is a useful trait, it often keeps us safe.
Welcome to THE forum for people like us. Not my bag but others will be along shortly.
You can't do this in England anymore, they got fed up will false alarms, you have to use an alarm monitoring company who text you when there is a problem, you can then decide what to do about it. The exception is the panic alarm when they will call to check you meant it and if you did they will call the police.
You are right to want to avoid WiFi cameras. Round here when the scallywags want to do mischief they first jam the WiFi
You will need to push the council to deal with this as unless you have very deep pockets they are the only way forward. I suspect that the owner will try to argue it is reinstatement so dig out any old pictures that show how high the old wall was OR that this roof is temporary cover while they build the new one underneath but this does not explain the new blocks. On your deeds does it say who owns the wall? You need to be aware that in planning law you are not entitled to a view but you are entitled to object to anybody building in it.
Hello, paint and decorator and general diyer.
MikeSharp01 replied to Roger Dovey's topic in Introduce Yourself
Been there, done it, got the tee shirt, still paying off the credit card (not) but at least she lives there now and not here - love her to bits though. Welcome to THE forum for people like us.- 1 reply
Make the application and be realistic about expectations. We got what we asked for on a single phase, 6kW. Pretty sure we would not have got 12kW but optimistically we might. The only risk is that they worry about future applications so squeeze yours at this stage to protect the medium term.
Outdoor powder coating peeling
MikeSharp01 replied to Pocster's topic in Landscaping, Decking & Patios
Is the material magnetic? It looks like oxidised Aluminium to me, so won't be galvanised steel. -
Calibration not needed, I did ours with an dust extractor unit a relatively cheap anemometer and a length of plastic tube to make a manometer ( I also used a high end differential pressure meter as well but the manometer gave a reliable result.) I got within a few % of the official test. Builhub has an anemometer in its loan system.
Not really because the ring system is 24V at 500mA AC by the looks of it. Your transformer is 8V at 1.00A so neither has the power output needed (12W needed 8W available) or the voltage (24V needed 8V available.)
