Sparrowhawk
Everything posted by Sparrowhawk
  1. Good to hear that these could be flush I don't yet (and in light of this thread now likely won't) but Ubbink's "pop out" rings were the kind of thing I was thinking of. Which valves are you using in your photo, they look well engineered?
  2. +1. Toolless connectors are so much easier to use. At the other end (your patch panel, where you connect everything up) I use these ones: https://www.cablemonkey.co.uk/cat6-modules-outlets/9503-cat6-utp-tool-less-keystone-module.html. I got my cable and other bits from Cable Monkey too.
  3. Second question: I understand the base of extract valves is proud of the ceiling to prevent streaks forming as moist or dirty air is sucked towards it. But why is the base of a supply valve proud of the ceiling by 1cm? Is this required for better mixing/the coanda effect?
  4. I've got my first supply and extract terminals here (Zehnder Luma). Doing a radial system with semi-rigid ducting, my plan is to do the throttling for each run at the manifold and have the terminals wide open for less resistance and noise. In this setup, does the solid central bit inside the terminal holding the flow adjuster do anything useful (like meaningfully shape the airflow) or would a radial system like this do just as well with a flat plate hiding the plenum, a place for a filter cone, and nothing more? I'm thinking the design is a hangover from traditional branched systems where these are the flow restrictors, hence the name 'valves'.
  5. Went for silicone grease in the end and it made the task a piece of piss. Thanks for your help!
  6. Android is a right pain for these kinds of things, see e.g. https://caddy.community/t/running-caddy-2-on-android/13993 for running a webserver on it. I haven't gone far into what other OS's you can install on an old phone, as a second hand thin PC will pull under 7W, costs under £70 and is significantly more powerful.
  7. Or this? https://www.screwfix.com/p/floplast-silicone-spray-40ml/3290f
  8. This kind of stuff? https://www.screwfix.com/p/floplast-lubricant-gel-800g/10631
  9. The assembly pictograms that come with the ducting and seals show some kind of liquid being dripped onto them. Nowhere does it specify what it is. Have you done this and if so what did you use?
  10. They were indeed. Fast growth. Senapt Limited who have a controlling interest are the other accounts to look at. There's quite a network of companies out there.
  11. I'm doing something similar in our hallway, because there's the stairs, an understairs toilet and stud walls built on top of the floorboards. Having spent way too long trying to figure out how to lift the floor, the pragmatic outcome is to lay an airtightness membrane over the top of the existing floor (and lap it up the walls), and then lay a new floor over the floor like you've done. In this house the membrane is needed, because the previous occupants did exactly what you did, but the cold air still whistled out at the edges and around the skirting boards
  12. Hi @DanielE, having made a start on this in a 1920s house this winter (and working on the basis that insulation is good, but airtightness is even better): draping a membrane works, and doing it plus glass fibre fill is cheaper than PIR, but PIR is a easier (so long as you're not aiming for perfection). PIR is also easier in odd shaped rooms, and avoids trying to fix the membrane onto an uneven wall / get it round the asbestos-containing DPM sticking out of the wall which can't be cut but is in the way. My thread when I asked this question (has product names for what you can use for draping) Why do I caveat PIR with "as long as you're not aiming for perfection"? Cutting it to fit exactly between joists is impossible, especially old ones. So you end up with gaps at the edges, which you need to foam up (or use Gapotape to make a snug fit). I suck at foaming small gaps, and you still have a thermally weak spot... so you won't get a perfect finish. For me that's okay given the fabric of the house, it's better than what's before. I then stick airtightness tape over these because what I really want to stop is the cold air coming into the house.
  13. Exactly. Obligatory Heat Geek article: https://www.heatgeek.com/hot-water-temperature-scalding-and-legionella/ I chatted unofficially to our heating engineer, looked at our hot water usage (daily turnover %), and keep our UVC with a target temperature of 47C (range 45-49).
  14. I'm more a theoretical type but I'd be more than happy to come up and stand and point at things while others lift and fit the Sunamp. I can even hand people the right tool at the right time..!
  15. Welcome back @Jeremy Harris, nothing useful to add to this thread but I wanted to say I have learned a heck of a lot from your posts on the forum (and still getting my head round some of the more technically inclined ones). Thanks for all your input over the years.
  16. If you remove the baseboards, have a look along the wall-floor joint with your thermal camera. You may find there's a little draught coming up there which you can fix without removing the cupboards. Also if you know where the penetrations are, a multitool will let you cut an access hatch in the back of the cupboards to get to them. The damage can be hidden by gluing a new hardboard back over the existing one (trimmed to size) so future buyers won't know there's any damage.
  17. Is there somewhere in the ViCare app to see the daily starts? I can only find the total under Diagnostic Information
  18. And keeping the UVC gives you options when the boiler needs replacing. You can go for a 4-pipe boiler (different temps on HW and heating circuits, don't know what they're really called but we're getting great results with our new one), a heat pump, whatever. With only a bathroom and an en-suite, if your boiler can put enough heat into the tank to reheat quickly you can downsize it a bit if you want to save weight in the loft? Though that they doesn't play into heat pump etc in the future...
  19. "How to manage contamination of the home" Do you have lots of people spending hours in your house? As in, have you quantified the risk? I would look at good ventilation and air changes as your baseline strategy, and if you have a busy area consider an air purifier. We're thinking about adding one to my wife's home office as she sees little germspreaders children for hours every day and anything that may help us stop catching their bugs is worth a try.
  20. I waited until Christmas dinner was over in case I messed anything up... not the fuse you were expecting: Took the front off the extension consumer unit and here's some photos. Arrow shows entry point of cable from other fuse board.
  21. The washing machine and cooker are still on so I haven't been able to isolate the extension yet, but this is the board at the meter end. "MAIN SWITCH" is the cable running to the extension consumer unit (up the cavity, under loft insulation, down the cavity) Looking in the extension, the cable feeding the consumer unit looks the same size as the one running to the electric cooker. The cooker manual says Total load at 230V is 14.8kW and the previous home owner who installed the cooker has written "(32 amp cut out). Cable? (6 1/2mm sq)" in the manual.
  22. We have 2 consumer units in the house. After the electricty meter there's a box where the cables split, one to the main consumer unit, and the other via a long white cable (in photo) to the other side of the house. This is a photo of the cable linking the two. I'm trying to estimate the current it can carry before we make alterations. Does this look like 80A cable?
  23. @nod is right, but so is everyone else. Require receipts, no cash payments, and keep records. https://www.gov.uk/report-tax-fraud
  24. For those who extract to the outside, it would be helpful if you detail how you make the external vent airtight when not in use. And tell us if you did your airtightness tests with this taped over or also tested with it in its 'closed' position to confirm how airtight it is. A couple of options have been mentioned in threads but not all in one place, and it'd be helpful to group the options together.
  25. I'd be pretty pissed if I bought something that all over the website shouts "Full MODBUS connectivity" as a feature... and then you can't use it. The only thread of interest I've turned up yet is https://community.home-assistant.io/t/heat-recovery-mvhr-integration-titon-beam-in-ireland-mechanical-ventilation-with-heat-recovery/454942/9 using the RS485. Different models but may have helpful links.
