Sparrowhawk
Everything posted by Sparrowhawk
  1. Opening up the side of a bay window, I could see daylight where the mortar had cracked away from the window. Water weeped in when it rained. I filled the internal gap with closed cell expanding foam, but I want to seal it from the outside as well. Last autumn I wiped CT-1 over the cracks which kept the water out for the winter, but it didn't withstand the expansion cracking in the summer heat. What can I do for a longer-term fix? Silicone might stretch enough but I want to be able to overpaint. And with the 135° angle where the window meets the wall it's not like a nice fillet of sealant will fit. Do I need to pop some plastic capping over this and stick it in place either side? of the joint?
  2. Hi @kentar going back to your original post... Last year we got a replacement gas boiler installed by a Heatgeek accredited installer. For some of the same concerns you have. The installer usually installs heatpumps but I didn't see our house as heat pump ready for a few more years (Gus Potter summarised well on page 2) so while we could have gone heat pump we didn't. And it's been brilliant. We've ended up with a system that runs at a lower temperature (we changed a few radiators) using weather compensation. Hot water reheats in 10-15 minutes, and that meant we could save some space with a smaller tank. So I'd say go for gas, and spend a bit more on an accredited installer to get an efficient setup.
  3. And pop them on the marketplace here.
  4. Good read @marshian, and that matches my experiences very closely. My heating curve ended up as Slope: 1.6 and Level: -7. It's still not perfect, as on days with lots of solar gain it overheats, while on other days, which are warmer outside but with no solar gain, the house is too cold. But I don't think that's fixable until we have better insulation and draft proofing. @Oz07 In my case we left the heating on 24/7 (previous years manually turned on/off) and our usage went from 13,300kWh to 14,500kWh - but the house was always comfortable, whereas in the previous year it had been down to 15C many winter evenings, and we were wearing coats indoors. This is still below the 16,500 kWh it was in 2021 when we tried to have it warmer with the old boiler.
  5. window surveyor = posh company's triple glazing salesman?
  6. Thanks @ETC a sketch or two would be appreciated. That's a good idea about looking back, I will look for earlier photos but I know it was built c1926-8 as the middle of 3 houses and extended (porch, 2 story side extension w. new garage) in the late 90's. I suspect the first floor pebbledash is original and it was red brick for the ground floor. Later rendered over to hold the soft red bricks together! The original roof was slate. Not much help but I have a B&W aerial photo from 1948 where our house (middle) is right at the back. Bournemouth is nearby so I'll look for similar period photos from there. @DevilDamo ChatGPT certainly has ideas 😂
  7. Yes. Round here people slap thick render over the downstairs bit to hold the soft red bricks on the lower half together, and if they want contrast add cedral cladding or similar to the top half. Or render it all the way up. If it were affordable to "swap out" the lower half of the brick walls for new brick people would be doing it, because the houses which are still like that look cracking.
  8. We're going round in circles here with the number of possible options, so I'd appreciate the forum's input. Having overhauled the front garden this spring, we need to bring the rest of the front up to scratch. Over the next few years we need to: Rerender the ground floor Repaint the house Replace the blue painted timber cladding and white PVC cladding (no ventilation behind!) Decide if keeping the barge boards and facias/soffits black or change to white Replace the windows Convert the garage to workshop/gym and pop an airtight front door on it (I see many ugly conversions, I don't want to be them) French windows on front? Or 1.2m+ wide door and window? Need to get wide handlebar push bikes and larges sheets of wood in and out Eventually rebuild the porch, so there's free rein here So there's lots of freedom, except for the roof colour which we're stuck with. We are struggling to choose the garage/porch style and pick colours that work together and visualise what areas should be what colour. We don't like the current magnolia/blue/white/black combo. The blue wood and the white PVC cladding sit awkwardly together. It's a seaside location. Next door has gone sage green for their doors and woodwork. We'd like to add a climbing rose between the current garage door and the bay window. I sketched something modern with cedar cladding for the garage door infill but my wife wasn't keen, and pointed out that french doors are more practical as they give a wider opening and more light, and will need less maintenance than wood, as neither of us like the natural grey it goes.
  9. @TerryE Yes let me know the credentials for our GSE account and I'll see how our account looks.
  10. They make no claims beyond it's robust and allows for hot composting. What does sticky stuff mean here? Stuff in the compost bin that's gone into anerobic decomposition? Assuming that home compost is similar to the council-sold "soil improvers" made from green bin composting, which is £125 per cubic metre delivered (and I see plenty to say that it isn't - but those people also want you to buy their "bio" compost at £35 for 15 litres), the economics aren't there but as you say it is very satisfying to make. I find the height and shape of the dalek composers makes it hard to turn their contents every couple of weeks so I've got the idea of replacing them with an insulated cube, ideally held off the ground on blocks to make it harder for rats to attack (OSB or paving slab base?) Unless I can get offcuts of insulation to use it won't be cheap compared to my £25 insulation of the dalek, as this needs £75 of EPS, and that's before making a hard inner lining out of something, probably timber at the same cost again. Which is half-way to the cost of a ready-made hot composting bin. Wrapping a hard shell in insulation would be easier and potentially cheaper, but I haven't found many cube shaped plastic containers, and plastic barrels need flexible insulation like this polyethylene stuff plus I'm back to a shape that's poor for turning the contents to re-aereate it.
  11. Insulation allows hot composting, which makes compost in 90 days or so. A mow of our lawn mixed with brown stuff fills half a dalek, and I only have space for 1, so it was very handy when I had it working. 3 years ago I wrapped a Dalek composter in 50mm glass wool inside thick polythene sheet, and it worked brilliantly for the first year, keeping the contents at 45C+ for 2 weeks after every new addition. That winter the rats moved in and tunnelled within the glass fibre and made nests (should've wrapped it in chicken wire), the insulation slumped and got wet, and it stopped keeping things warm. Now in 2025 the bin is still slowly decomposing last year's clippings. Yes this would seem the sensible way, I assume they chose insulation on the inside to keep their product looking smart.
  12. Bloody hell that's more expensive than PIR!
  13. I can't justify paying the silly money for one of these composters, but I'd like to work out which insulation material they're using and how much insulation it's providing. I don't think it's PIR or EPS. Thes are the best photos I found online: From a close-up it looks layered, like packing material. Maybe polyethylene insulation?
  14. The "Welcome forum" as a "Retrospective on my journey" thread?
  15. 50°C on sunny days in summer before we added tile vents (it's a 100yr old roof, re-roofed in 1989 with dark tiles, and no economic way to put a vented ridge on it). Thankfully it's nearly always windy here, and from memory the vents knocked at least 10-15C off that figure last summer. You will have loads of insulation in your roof, but it's the decrement delay that also matters. How long does it take the heat to enter - and leave - the insulation? You mount a chunk of crumbling sole plate on a plinth and give it to them as a Christmas present. Many broken nights recently @Iceverge?
  16. The ridge vent will also allow a way for the hottest air to get out - which is my current thinking on why to keep a few eaves vents plus ridge vents. Upstairs the biggest overheating problem we have is the roof space warming up and penetrating down through the loft insulation. The cooler I can keep the air in the attic the better...
  17. Was the dot and dab plasterboard then skimmed with jointing compound or with the hard brown (gypsum?) plaster? For the junctions, having tried to doit myself with CT1, I think your best long-term fix is to sand back a bit, and get a plasterer to insert folded paper tape over the join and feather it in. For cracks on the flat surfaces, scrim tape and a reskim or decent feathering in. None of this helps if you've got cold air circulating behind the dot and dab. Do your thermal camera images show it happening, and help you locate the source? You could drill holes and squirt expanding foam in top and bottom and see how much that improves it.
  18. Thanks for the reminder @GP41! I'd switched to posting individual threads in the topic forums so it's time for an update covering the past 18 months. We finally got the new central heating and hot water system installed in May 2024, done by a fabulous Heat Geek trained installer. As @MikeSharp01 said on page 1 it makes a big difference and for the first winter since we moved in we've been warm and kept the house consistently at 19C+ Electricity usage is down (no oil filled radiators needed) but gas usage (CH/HW only) is slightly up. But as we're stripped back to suspended wood floors with gaps between planks so it's going to drop from here onwards. Heating has also fixed the book lice and mold mite infestations in the house, and we run a dehumidifier once a day to keep on top of the humidity. Living in and working from the house you're renovating (with clients coming in 3 mornings a week) is a recipe for disaster excruciatingly slow progress. That's my excuse and I'm sticking to it anyhow, got nothing to do with me overthinking, trying to treat a house like a precision mechanical instrument (tolerences >1mm? Oh the shame), procrastinating or being a perfectionist, oh no. But I am having great fun learning new skills, my SDS+ drill is my new favourite toy, bonding plaster is great to work with, and the hypotheses I've had turn out to be right more than 50% of the time. Planning for MVHR has been a massive time sink. We don't need MVHR but we're on a clifftop by the sea where it's breezy on a calm day and windy the rest of the time, and what we really don't need is extractor fan sized holes in the walls and trickle vents in the windows. Wind washing is real, and removing the two extractor fans downstairs and sealing up their holes has made a noticable difference to heat retention on windy days. And this is with gaps in the floor and leaking windows. Back to MVHR, and ducts here are difficult to route due to extensions, and it became an obsession to see if I could work out how to make them fit and be concealed and within the thermal envelope. I've had far too many 3am wakeups drawing diagrams in my mind but victory is mine, and with the compromises of 75mm duct and one run in the (cold) loft I have it planned out - and promptly lost my enthusiasm because I'd solved it hadn't I and the fun bit was over... The first duct run is in and whether we actually buy a MVHR and fit it, it's there and ready. A big shout-out to @Gus Potter for his help on whether I could take a chunk out of a cavity wall to run ducts through. Just got to pluck up the courage to cut a 10x30cm slot now! I'm slowly adding underfloor insulation in the hallway. Another of those that's been excruciatingly slow because to begin with I spent ages trying to work out how to fit it in an airtight way under existing stud walls built on top of the floorboards. Eventually pragmatism won through and I'm fitting it where I can and will put an airtight membrane over the top of everything and taped to the walls before we lay a new floor on top. Anything else is too much hassle. Sound proofing is my nemesis and no matter what I do the downstairs toilet remains... a place for exhibitionists. Ditto airborne sound from ground floor to first floor in certain rooms. I've sealed the perimeters with airtight sealant, added glassfibre between the joists and made sure the floor is tight. And we can still have a conversation with barely raised voices. Next stop is overboarding the ceiling, and then resilient bars if required. We need to replace windows this year so we can get the house replastered. After dreaming of triple glazing, we got stupid quotes from Norrsken (£35k) and Nordan (£25k) for 4 windows, 2 bays, a front door and 2 narrow sets of patio doors and my piss-poor negotiating skills didn't get them to shift much, it's back to UPVC 2G. My questions about airtightness, corrosion resistance and whole-window U values rub double glazing salesmen up the wrong way so I am procrastinating about getting any more in because it's a painful process. Best purchase of 2024? One of these: https://www.bosch-professional.com/gb/en/products/gde-162-1600A001G8 which when connected to my dust extractor lets me drill anywhere in the house without making a mess.
  19. My 1920s house is cinder block from brick foundations with a brick stringer(?) at the 1st floor joists. It looks like your first floor could be cinderblock but hard to make out from the photos as not enough is visible. It's horrible stuff to work with. Can the plasterer not bed in a wide scrim at the junction to stop it from cracking?
  20. And what kind of effect do you want from the finished table? The colour and grain is going to be different in those two places.
  21. Thanks chaps, priming up now and I will go and get clout nails when the hardware shop opens tomorrow. I thought the conduit was required by regulations to somehow stop anyone drilling into the cable - which as the cable is in the safe zone above/below a socket, and the conduit fairly thin plastic, doesn't entirely make sense to me. Is it there instead to allow for rewiring in future? And this could be compliant without it? I'd have thought a nice U channel of 0.5mm steel over the cable would be better if one wanted to prevent peple drilling into it...
  22. Last week I did my first chasing into plastered cinderblock walls for a new socket and light switch. An electrician came and wired everything up, using 20mm plastic conduit, and I now want to plaster over them. However - I can't get the conduit to stay at the back of the chase. The electrician slapped some filler behind to hold it in place but it didn't stick to the dusty cinder block. Perhaps I didn't make the chases deep enough and it's meant to hang mid-way in the chase, but I wasn't expecting how bulky the conduit would be. Is there anything that will stick it in place or will I need to nail or screw the conduit to the wall before plastering? And next time, is there some narrow, flexible capping I can fix over the cable that will hold the cable tight against the wall?
  23. I've just switched to Podman Quadlets with one client (single server setup) and liking it - yes it's not as nice as Docker Compose for me to write, but just having everything systemd is nice. Plus, rootless containers too. Have we a CDN in front of the server for non-logged-in traffic? Again, something I do at $DayJob to reduce the size of server required.
  24. Yay, one of my guesses was right At the airflows involved, that shouldn't be an issue. It's because it's easy to adjust the flow at the valve during installation (25 different positions with that particular valve), avoiding the need to manually screw the valve in or out by X number of turns / avoiding the need to go backwards & forwards & cut sections out of a restrictor at the manifold. Thanks gents. I'd picked up - I think from this forum, but also from at least one supplier of radial systems - that it was easier to do it all back at the manifold. Good to have cleared this up before doing anything, and explains why the terminals are as they are and not £4.99 for a metal plate and 2 retaining clips.
