Canski
    3
Everything posted by Canski
  1. Sorry ( can't resist) I only watched the first 13 minutes and I was sure I had seen these guys in action before. In Wome I think it was.
  2. Does anyone have any recent cemfloor quotes ? I've just had a supply and fix quote in for £6 k for 16.65 m3 seems a tad high to me at £360 per m3 This is varied between 100 mm fill and 75 mm but mainly 75 mm Has anyone ordered direct and done it themselves ?
  3. I would attend it will be like attending the birth of a child.
  4. Don't forget to allow for the frame but yes the frame can be fixed to the studs
  5. I can't get my head round all of this at the moment so will be outsourcing it. I have had my basic SAP calcs done but have had a quote for Simplified method £ 200 and Dynamic thermal modelling at £900. Plus VAT Hope this helps.
  6. I must be having some luck for a change. Open reach installed a junction box a few weeks ago without even notifying me, right where I would have wanted it. Then today without any input from me are on the phone offering me ducting and drawings for installation ( he did say that the ducting had to end outside the houses )he also offered me all the assistance I need and his mobile number. Free installation as well.
  7. That helps me out too. I’ll get my red pen out and do a redesign.
  8. Howdens version of a discount month.
  9. That’s good news. So why don’t they give accurate timescales that people can work with?
  10. I've lost all love for bats. The new saying is "don't be a tw$t splat a bat.''
  11. They have finally agreed to a pole that is the same size as a telegraph pole. So I'm going to form a concrete pad and bolt a 100 x 100 mm steel post to it and then fix 2 x 200 x 47 mm timbers to that to hang the bat boxes off. This will be a temporary feature until the bat boxes and ridge tunnels ?? are built into the main house. My natural England bat licence application went in yesterday but they are now saying that they are taking 45 working days to process. Waiting game again then. So frustrating.
  12. There’s a product called brick brace that I have used before it works fine. Not cheap though.
  13. 30 m2 in the woods would suit me now. 😀😀
  14. Wellcome to the forum. Despite being a tradesman for 40 plus years I’ve still learnt loads from here. It’s such a great group full of knowledge. The search button is invaluable.
  15. I finally got planning through today a year and a few weeks since I bought the site. I got the notification just as I was completing a retaining wall to the rear. The only real problematic condition (apart from looking after the invisible constipated bats) is number 4 shown below. Does this mean that I can plough ahead unless I find contamination or do I need to do a site investigation ? I'm confused and I haven't had a drop yet.
  16. The ones I get are usually ok on the ends apart from the odd one or two so I wouldn’t be happy with your delivery. It’s lucky you had to cut them. I would have sent them back. The 10 mm wouldn’t bother me but then I don’t usually get involved with the insulation or screed but it allways looks ok in the end.
  17. do you have a 20 m tape measure, 3 pairs of hands and a nail ?
  18. You are not far out. If you want your minimum dimensions of 5.8 x 4.9 m then the diagonal is 7593 mm How wide is the timber frame ? 100 mm or larger ? you could hang the frame off the slab slightly to accommodate but I wouldn't go too mad. Yes opposite sides need to be equal and the diagonals equal to achieve 90 degree corners.
  19. Courtesy of Pythagoras. The builders best friend. Throw those foldable squares in the skip !
  20. does this help ? All square and fits on your slab
  21. You'll probably need to be higher than 25 mm to floor level off ground level. See Oakwood Garden Rooms on Youtube for ideas for foundations.
  22. water will run out of the outlet even if it's level OK there may be a slight pool in the base of the channel but who cares ? It's below the grid. My guess is that maybe they put the channel drain in too early and have miscalculated the gap and are now trying to fob you off.
  23. Yes this could be a problem.
  24. My advice is to burn it down before the ecologists get involved. Just saying 😀
