MVHR and log burner
Nickfromwales replied to Tetrarch's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I’d have done it for £20 less. 👍. “£20 is £20” 🤣 -
MVHR and log burner
Meaning the QS was a cock. -
MVHR and log burner
Yes, my point is relevant to the OP who hasn't installed a RS appliance. -
MVHR and log burner
The only elephant I see, is if the airflow out of the WBS is in excess of the power / flow of the fan in the MVHR unit, then there is a strong likelihood that 'smells' from bathrooms / kitchens 'could' make their way into the room that the WBS is in, but the stink from the WBS would probably overwhelm that anyways. Seems kinda moot now anyways as the OP has installed the kit and is 'happy'. The likely natural infiltration of this dwelling probably renders everything commented on above a complete waste of time anyways, as MVHR has no place in anything other than an airtight structure of 1.0 ACH or less......... -
Steel fitters are lazy if you've got lots of 3 and 4 layers overlapping? Time to cut accordingly and do it properly.
Shower Waste Sealing to Tray
Nickfromwales replied to Barney12's topic in Bathrooms, Ensuites & Wetrooms
Always a good time to see if the downstairs ceilings stand any chance lol -
The seat / face of where the rubber seal presses against, so on the trap, then put the rubber on, the seal again atop. You can’t go twisting these around or the rubber gets ejected. Take a bit of practice but always gets the results I need; 100’s of showers / wet rooms done over the last couple of decades (+) and not a single complaint or leak. -
You don’t have a choice! Either you go up or a plumber does, but if you don’t do as above then your system will stay airlocked and you’ll have just wasted time and money / chemicals for zilch. Some installers used to invert a pipe to a manual vent in the head of the attic space, so this can be vented (bled of air) without going on the roof. If you have bottle gents then you’re prob still going up as these cook and fail and are usually isolated by the installer with a valve so they don’t get called back when they leak (which they will do, so you’ll need to change those too most prob). This isn’t an afternoon job for DIY.
MVHR design
Nickfromwales replied to galleon87's topic in Mechanical Ventilation with Heat Recovery (MVHR)
+1. This needs to have an airtightness test done, and a score recorded, before moving an inch further with this -
Gavin’s isoquick foundation on clay soil
Nickfromwales replied to gavztheouch's topic in Foundations
Keeping a preheated tank warm 24/7/365 for no real benefit, my 2 cents. Burner lighting, pumps cycling, diverter valves moving about etc unnecessarily. PS I am a huge fan of heat-store combis, and have fitted loads of Vaillant 937(now 938)'s in the past. Fabulous things. Just this family doesn't need one IMHO.
If you've got one bath / shower then a massive output combi is a complete waste of money / effort afaic? Plus the storage boilers are physically bigger, and stick out a lot more than a regular combi. A 37/40kW combi will scream DHW out, but all of these things are cold mains dependant so that is the real question here. If cold water cannot get in, DHW will not get out, simples.
You can pressure test to sleep better, but I've not bothered more times than I've bothered, it's just that amount of confidence that I have in it. 25 years of installing UFH and no issues to date btw. This is a rock solid pipe, so does not 'inflate' like a balloon.....so pressurising with a bit of air or water will do zero to protect it from getting crushed. My screed guy has up-ended a barrow full of screed on a pipe and it only scuffed it. I wasn't happy his labourer did it, but I was impressed how much of a hiding this pipe actually takes. I'm not advocating a blasé approach or attitude, and prevention is better than cure, but by simply coordinating trades so you're getting the pipe down, and getting the concrete down asap afterwards, this will massively minimise risks / damage. Not employing morons will pay dividends here, obviously.....
Apologies. Things like kitchen islands or peninsulas are typically 600mm / 900mm / 1200mm deep or wide, so not installing UFH under these is pointless as the heat will get into the 'unheated' area anyway. Where there is a kitchen, and it can only have units on one or more wall, then I do not populate all the dead under cabinet space there as it will never be an emitter, per-se, but also there is always an unheated perimeter around a room with any good UFH design so I simply exaggerate that where kitchen units are always going to be located for the life of the dwelling. Islands and peninsulas come and go with design changes during re-modelling, so I just keep all such areas populated with pipe there.
Yup. I’d rather the extra pipe / volume / storage tbh, particularly if it’s not a huge house. Not running pipes under things like kitchen islands etc is just a complete waste of time and effort in a passive type setting, as a) the temp is too low to cook your cornflakes lol, as you’re only ever getting the floor to a few degrees about room target temp so just entirely moot tbh, and b) as the heating is on ‘long and low’ the omitted areas will warm up anyways! It’s in an insulted basket, so the heat will eventually get there folks, and there’s nowt you can do to stop it. I will leave a pipe at the start of the run of fixed kitchen / other units, stopping about 150mm into the dead under-plinth space, leaving an unheated perimeter of around 450mm in the slab, and then it’s ‘fill yer boots, matey’. I’ve been installing / or been in and around / specifying M&E for these types of (PH style) systems for over a decade now, first ‘taste’ was an MBC PH TF, and not looked backed since. These Pert pipes are 1000% kosher to attach near to / directly to steel reinforcement mesh and the results are always excellent. Damage to the pipe must literally be malicious to get it to the point where it’s a total loss. “People of Buildhub, go forth and zip-tie”. 🫡. El Presidenté.
Pert (alu) for me, and just looked at the last invoice from UFHTD Ltd and that's what's on there. Not sure where I've mentioned PEX, but I have used both over the years. FYI, Pert Alu on every job nowadays. Just bombproof stuff tbf.
For the 16mm stuff, contact Paul and the team @underfloorheating trade direct. That's who I've used for ages, great service and stuff is always delivered as / when promised. 01925 571999 No clue where to get the bigger stuff, but you could ask Paul maybe?
Interconnected smokes, junction box?
Nickfromwales replied to Super_Paulie's topic in Electrics - Other
All RCBO boards only lose 1 at a time as the main switch has no RCD -
Use the PU glue, “or perish in eternal hell and damnation”……probably. Just never used anything else and don’t fancy the thought of a mastic or silicone etc as they’re completely different products to do different things.
I will start a new thread for this, and then you can settle up mate
Creating a fall into a floor drain
Nickfromwales replied to Tony K's topic in Bathrooms, Ensuites & Wetrooms
Only when he's bladdered and falls asleep in the bath with the tap on For the record, you are both nuts . Bath mat is all you need...... Biggest ballache will be constantly going around topping the water up in the trap (every time it evaporates and the stink of last nights biryani is 'present').
