Temp
Everything posted by Temp
They also weigh less so are easy to fix to plasterboard.
Perhaps but I would just replace the whole fitting. Modern LED fittings are slimmer and can be brighter. They just have two wires like a light bulb or fluorescent fitting. Only issue is that some have a socket one end for the wiring rather than a hole on the top middle. Screwfix have lots in different lengths, brightness and shade of white light. Something like this.. https://www.screwfix.com/p/reeve-slimline-twin-5ft-led-batten-40w-4000lm-220-240v/804pg
Back garden, uncovered compacted soil
Temp replied to martin55's topic in Landscaping, Decking & Patios
I would install some land drains and ideally remove and replace as much of the clay with a free draining soil as you can afford. -
Seek advice from the contact @joe90 gave. Possibly the VAT help line as well. To qualify as a new build you are only allowed to retain some walls, typically the front wall. Important to get it right because if you pay 5% VAT to a builder in error thinking it's a conversion you can't claim it back from HMRC. See VAT 708 para 3.2 and 3.2.2
Help identifying please. Or even better, help solving please.
Temp replied to NotMoreStress's topic in Waste & Sewerage
I think they are called "internal manhole covers" or "internal inspection covers". There are a range of different styles for things like tiled or vinyl floors. Think most builders merchants should be able to supply one. https://www.kentstainless.com/access-covers-manholes/tiled-resin-floor/solo-industrial-manhole/ -
My advice is to try find a similar planning application and see what they provided. The condition says you need to provide a "Construction Ecological Management Plan (CEcMP)" so I would try and find a document with that title on the portal and read it. If there is anything irrelevant to your site edit it out. Make sure you aren't committing yourself to anything expensive etc. I'm pretty sure that a CEcMP will be all about protecting wild life during construction, whereas a "Biodiversity net gain (BNG)" is more about ensuring your planning application as a whole improves Biodiversity. I would stick with the former until they insist on the latter.
Gap between my wall and neighbour’s extension
Temp replied to Smelly Duvet's topic in House Extensions & Conservatories
Will it be a flat roof and which way will it slope? Normally any overhang and or gutter will determine the gap as much as anything. I don't think 50mm will be enough for them to properly fix/finish the edge of roofing felt. I would ask about this detail and future maintenance. -
If you assume the UFH loop pump and ashp pump have same flow rate then no water flows through the short circuit. If there is any difference in flow rate it will go through the short.
Technically I don't think you don't need PP for a van for building workers to live in. So if all occupants can claim to be doing at least some work on the house you should be ok. No children obviously. I believe this even extends to a van on neighbouring land. I'm travelling at moment so can't easily quote a source but it should be possible to find it in the GPDO somewhere. Edit: The menu on my flight includes "Fluffy egg preparation" I guess that's an omelette then.
When we built the regs required a level entry to meet part M of the building regs. Basicaloy followed this example from the web.
Non standard construction can sometimes be hard to get a mortgage on.
I thought what you want isn't allowed in building regs? Don't they have to be staggered in height or is that only when one side is smaller than the other?
The effectiveness of insulation depends mostly on.. a) The thermal conductivity of the raw material it's made from. Lower is better. b) The thickness. Pure Aerogel has the lowest thermal conductivity but in it's raw form it's very fragile and expensive so it's not normally used except perhaps on spacecraft. Usually it's in a different form like a blanket and these have a higher thermal conductivity. Beware sellers quoting the thermal conductivity of raw Aerogel in adverts. Compare with the actual specification of the prouct. Post the numbers including the units of any product you are looking at and someone might be able to comment. Next best is probably something like a PIR based foil covered foam. Typical all insulation products have thermal conductivities that vary by perhaps 30% so none can be 1/10 the thickness of another and have the same performance. Beware some manufacturers quote U-values for their product when installed with an air gap. Anyone can make their product look better by requiring an air gap. I'm currently on a train in India so might not be able to reply. Family are at home so it's not a risk me posting this.
incorrect scale within submission of .pdf drawing to Planning
Temp replied to Post and beam's topic in Planning Permission
If you simply converted the whole drawing (including scale bar) from .pdf to jpeg and then back again any unwanted scaling should affect both the building and the scale bar equally. To get such a large discrepancy either it was always wrong or you magnified the building and scale bar differently? Sometimes you get can get this issue if you accidentally scale x and y differently. For example by doing "fit to page" without "preserve aspect ratio set" when printing? Can happen when printing on different size paper or landscape Vs portrait. -
I feel for you. Our Planning Officer went silent for a similar period and we eventually found out he had quit his job. Same happened with the conservation officer a few months later. Literally had to wait for them to hire a new one. I'm afraid I can't suggest any ways to really speed them up other than to write an point out the deadline. Remember I think your deadline to appeal for non determination is 6 months but from when I don't recall.
I'm glad you explained what it was. For a moment there I wondered what you were going to 3D print with soft flexible (TPU) pink (coral) filament.
Is that the exact wording they used? It appears to confuse the max depth and max area rules in one sentence. There are a bunch of rules.. https://www.gov.uk/government/publications/permitted-development-rights-for-householders-technical-guidance But they seem to be confusing these two... "line of building"... That could be an issue if already extended. It's to prevent you adding one small extension after another to get a really massive house without permission. "area"... . That's only normally an issue if you have a large house on a small plot. Perhaps you do run foul of both.
Discharge of this condition. How much detail did you provide
Perhaps find another planning application with same condition in your area and see what they wrote. -
Our crew hung the doors then took them down to oil them on trestles.
Has anyone used tile.expert website to order tiles?
Temp replied to leemkule's topic in Wall Tiles & Tiling
Use a credit card (not debit) for the consumer protection? -
Anyone had first hand experience of Shower Power Boosters?
Temp replied to Del-inquent's topic in General Plumbing
Toolstation have several pumps in that range. They have a 2 bar twin for under £200. So it looks like you're only saving the installation cost. What's the current pump? Do they still make it. If so that's worth considering as all the pipes should line up. -
Not me, I had to google them. The website I saw said they are 12 Watt. That's not a lot of power. The few conventional pumps I've looked at have been over 100W per pipe. I don't think there is any possibility of them having similar performance because even if their design was 100% efficient (12W in and 12W out) the conventional pump would have to have an efficiency of less than 12% to have the same output (100W in but only 12W out). -
Yes that's because a bungalow loft conversion normally results in a two storey house where as most loft conversions result in a three story house. So the rules for a bungalow loft conversion are similar to that of a two storey house without loft conversion. They typically only requires interlinked alarms. It's actually the height that matters not the number of floors but the effect is the same.
