Temp
Everything posted by Temp
New (to me) nail guns. Where best to get info.
Temp replied to saveasteading's topic in General Joinery
I hired one for a weekend to build a fence. They have an adjustment on them to control how far in the nails go. Do some test shots on the same thickness of wood and adjust according to the manual and off you go. Main advantage is they give you a free hand to hold the wood in place. Keep well away from kids! -
Vaillant ecoTec Plus 630 boiler not reaching target temp
Temp replied to windsor-tg's topic in Boilers & Hot Water Tanks
Weather compensation faulty? -
I would seal the grout as soon as possible and consider more coats than the minimum recommended. I've used a few different makes and they all seem much the same. Some are possibly slightly more matt than others? Will need ventilation.
+1 But I wouldn't just write "Proposed" on them. Write in big letters something like.. "Existing elevation. This application involves NO changes to the external appearance" I doubt it will go to committee but you would be surprised how dumb some of the older members can be. I've sat in the audience at a few meetings and had to bite my tounge. If you just write "proposed" someone might not like it and decide to vote against.
Sorry I've been away from the forum. 13A fuse will work but is too high. I think most heating pumps are <250W so a 3A fuse should be plenty.
The manifold loop pump is needed to circulate water around the floor loops. I suspect without it the return temperature to the boiler might be too high causing it to switch on and off so not delivering 6kW continuously. The pump will eventually be controlled by the room stats and wiring centre which will also open the appropriate actuators. If you want to run the pump without control I would remove the actuator heads so the loops are all on. Turn the mixer down to control the flow temperature. Turn it up gradually to dry the screed. Don't rush it or you will get cracks. Might get them anyway.
4 plumbers out and no fix. UFH not working downstairs. Return pipe cold
Temp replied to Markca's topic in Underfloor Heating
+1 If the supply to the manifold is hot, the actuator(s) are open and the pump is running then something is blocking the flow. Two possibilities are.. 1) Sludge in the pipes. How good a job did the plumber do in flushing the system? 2) The mixer/blender (on the left) is faulty. The only other thing I can think of is that the pump was faulty and they put the new one on the wrong way around. Check the arrow on the pump and compare with your other manifold. -
I don't think that's true if that bit of your land is highway. Thats why the OP needs to know where the highway boundary is. Some houses own the land to the middle of the road.
I think that's only needed if it's in a Conservation area or it's listed.
OK so in short.. You think their proposed access crosses your land. That's legal if part of your land is public highway. You need to find out. I suggest writing to the highways department enclosing a site plan and ask if they can confirm where the highway boundary lies.
I would contact highways and ask them to confirm in writing that the highway extends across the green land as mentioned in the attached deeds. Then write to the planners stating that you do not need planning permission to form an access onto an unclassified highway which the highways department have confirmed includes the green land. If worried about future come back apply for a Certificate of Lawfulness. On the grounds that that highway extends to your property boundary.
AO were cheapest for appliances last time I looked. Great delivery as well.
So did I pre-Brexit. Now you should be charged UK VAT not German, but you can still claim that back.
I think the site is probably too small. 50*200m is about 2.5 acres. https://www.startupdonut.co.uk/start-up-business-ideas/types-of-business/how-to-start-up-a-paintball-centre Although I did Google up some at 12 acres. Google found code of practice from 2016 here mentions rights of way. https://ukpsf.com/wp-content/uploads/2019/03/Code-of-Practice-For-Paintball-Site-Operators.pdf You could consider asking a planning consultant for a quote to do a quick look at the site and comment verbally on the chances of someone getting PP for paintballing. A written report would only be worth getting if an application was submitted. The reason I suggested it was unlikely to be dangerous is because if granted permission there would likely be a planning condition attached intended to prevent paint balls leaving the site. That might be by erecting netting. If paint balls were to enter your garden on a regular basis i suspect that would put them in breach of their planning permission or amount to a statutory nuisance. Loss of privacy can be an issue that prevents planning being granted but again it might be addressed by the paintball co erecting fencing. I'm not trying to defend paintballing next to your house, just point out how the paint ball co might try and overcome your perfectly understandable objections.
Difficult one the comment on. I've only done it once with my kids. I think the noise might bother me but I doubt it's a safety issue. Government policy tends to encourage rural land owners to diversify into other areas. Find out if your council has any similar local policies. Perhaps find out if there are any bats or similar endangered species living there. Google found mixed results... https://www.planningresource.co.uk/article/563420/casebook-appeal-case-leisure-entertainment-paintball-games-permitted-ancient-woodland https://www.echo-news.co.uk/news/17774373.skirmish-paintball-faces-action-harm-woodland/ You should look for more cases and the reasons others cite for rejection. I also found mention of a document.. "English Nature & European Paintball Federation (1993) Paintball games in woodlands: a guide to good environmental practice, English Nature, Peterborough" Probably worth finding a copy to see what that says.
WPB is available in various grades ranging from absolute cr&p to the best quality boat building marine plywood. Some of the big timber stores sell more than one grade at different prices for the same thickness. Might be worth asking around. I bought some that claimed to be WPB from a big store beginning with W and it delaminated quickly. I suspect there is probably a CE, EN or UKCA standard that the best grades should meet but I haven't bought any for awhile. Plywood is sometimes specified to prevent racking so check with the designer before deleting any.
What I did was lay a flat concrete slab (excavate, compacted hardcore shuttering, sand blind, DPM, concrete), then two courses of engineering bricks, a DPC and timber frame (Mostly 2x4 and 4x4). Then on the outside WBP to prevent racking. A vapour permeable membrane, then vertical battens and horizontal cladding. I used oak boards but T&G also works. I extended the battens and cladding down over the bricks stopping about 25-30mm above the concrete. Gravel around the outside of the slab to reduce splashing. Ideally water running down the cladding would drip onto the gravel not the top of the slab but the engineering bricks keep out any water that does. The roof is pitched and tiled but flat roof with fall also possible. The front of my building has a stable like roof overhang to shelter the door. The wall plate of the timber frame was bolted down to the slab. I did this by pushing "bolts" made from threaded rod and nuts into the wet concrete slab. These were tall enough to go through the two courses of bricks and the wall plate, big washers and nuts. Caution: I tripped over and nearly impaled my head on one of these "bolts". After that I put 50mm plastic pipe off cuts over them. Scary moment. I also put some electrical duct/pipe in the ground before pouring the slab so that later I could run SWA cable up in through it. I used a so called "garage CU" which has 1 power and 1 lighting breakers. Electrician installed Earth rod etc. The inside was insulated between the frame and another layer of WBP painted white. I wanted it strong due to tiled roof.
We have a similar size utility room. It's slightly more square and 2.8m ceiling. We have a single 3600 lumnen LED batten in the middle. It's one of these... https://www.amazon.co.uk/gp/aw/d/B07WMMLJFZ?psc=1&ref=ppx_pop_mob_b_asin_title Plenty bright enough. The only issue with that particular model is it's designed to be linked together so the power goes in via a socket on the end rather than just a hole on the top. I think you will be fine with two panels around 2000-2500 lumens each.
