Everything posted by Dreadnaught
Thanks. I like this solution a lot. Now, I wonder if I can convince my M&E advisor of its merits. By my calculations, a 10mm hot pipe would hold 352 ml of cold water. Or if I chose to use a 15mm pipe, and included the shower in the arrangement too, then that would hold 1-litre of cold water. Thus when you entered the bathroom a litre of cold water would go down the drain. I notice that the urinal-PIR-thingy has a settable timer so that if you walk in-and-out of the room 5x times, 5x litres of water does not head down the drain.
With such an Ali-Express-type PIR-flush-valve, where would the water discharge? I imagine it would go down its own drain connection, not visible (and audibly) out-of-the-tap and down the sink. Its an ingenious solution.
Battery powered – is it not allowed to have a mains version in a bathroom I wonder?
This discussion also makes me think of sensor taps too. Anybody installed those?
This looks good as a possible solution (and doesn't look hideous): https://www.washroomhub.co.uk/dvs-ac02-023-wall-mounted-brushed-stainless-steel-urinal-sensor-c-w-2m-extension-cable, £125. But seems to need an expensive handheld controller to program it (£250).
How does that work? Microprocessor controlled?
Yes, nice solution. But I am aiming to avoid the extra complication of a hot return.
That makes sense. Looking online, the lowest temp for a TMV I found was 30º. Google in my hands could not find one that went lower.
True, although I was told that Geberit cisterns, which I am choosing, are insulated anyhow.
If the bathroom is a long way away from hot-water source, I recall a post where @PeterW suggested connecting the hot pipe also to the WC cistern so that flushing the toilet would pull through the dead-leg of cold water in the pipe. (I searched but could not find the old post.) Is this still considered a good idea? My bathroom will be about 15m from the hot-water source (a Sunamp).
@willbish, beginner question. In your (splendid) photos, all the walls seem to run at 90º to your joists above. What what if a wall ran in-line with the joists but there wasn't a joist directly above, just a void? In your photos, is it only the second photo that has staggered studs? Are those 300 centres? These seems to be some sort of spacer at the bottom or am I just seeing things? Really great to read about your experience. Thinking of using metal studs in my build.
Welcome to BuildHub, @DeanAlan. I am in central Cambridge too. A new-build Bungalow near the river. I'm at the foundations stage still a long journey ahead. Feel free to touch and good luck with your project!
Ebico bites the dust and British Gas bites my ...
Dreadnaught replied to ToughButterCup's topic in Electrics - Other
I signed up for Ebico just before the British Gas transfer. Electricity only. On Ebico I was on the "Ebico Zero Green Fixed v5". Britsh Gas have offered me ""British Gas Zero Fixed Sep 2021", with no standing charge. Furthremore, the transfer looks to be possibly slightly advantageous. Possibly. The ebico tariff had a "Minimum annual charge of minimum bill value of £52 a year including VAT". The British Gas tariff does not mention the minimum, even in the small print. In September 2021, I would not be surprised if British Gas withdraw that tariff and I am then left paying a standing charge. During the transfer, they did mess up my meter reading, but that's a different subject. -
Radon membrane: I don't think I need one …
Dreadnaught replied to Dreadnaught's topic in Foundations
Thanks @LA3222. Makes sense. -
Do I need a radon barrier or will a normal DPM do for my raft? Tanners, in their raft design for me, a "Radon barrier / DPM" is shown as a layer between the heave protection and insulation and they state "Radon sump to be provided in accordance with architects drawings and specification." And the fellow who will be building my raft has said I need to supply the radon barrier if needed. But, checking the Public Health England webpage on Radon shows the area of my plot (Cambridge, UK) has a "Maximum radon potental" of less than 1%, which is the lowest in their scale. (I know the Tanners are in Ireland and, from reading other BuildHub posts on the subject that Radon is assumed over there.)
The order, MOT before or after screw piles?
Thanks @Mr Punter. Yes, I sent the installer a photo of the exposed ground surface and he seemed happy. A concern about doing the MOT layer after the piles is whether it will be easy to spread it, presumably using a mini digger, and run the plate compactor around the 26x screw piles. Any relevant experience? -
Question: lay the MOT layer before or after the piles? My build is finally getting going on-site. I have signed-up for building control and my ground workers will be excavating for the levels this week, with lots of muck-away (10x grab lorries for soils are mentioned). Next will be screw-pile installation. 26x screw piles and the installer is booked for two weeks time. The installer is adamant that service trenches (foul drains, electricty duct, and water main pipe, etc., all under the raft) should go in AFTER the piles. Then after that, my raft foundation requires 100mm of well compacted MOT Type 3 and 30-50mm of sand blinding. Do I lay the MOT layer before or after the piles? If before, it provides a good base for the pile installer, but the soil is already quite good and gravel-ly for the digger with its torque head. If before, the MOT will then be messed up by digging the trenches for the services. Anyone else have any relevant experience? What order did you follow?
At the risk of hijacking @NSS's thread, what dilution factor do you recommend? (My concrete raft is being poured in a month or so.)
I recall that @Jeremy Harris used PVA glue on his insulated concrete raft, presumably diluted.
I heard about a trick of sucking a plastic bag attached to a cord through a duct with a vacuum cleaner. Does that work in practice?
@willbish, my timber frame is not up yet, so not porgressed the stud walling at all yet, but still convinced of my decision to use metal framing. As you probably know, @nod is our resident expert.
What can be done before water tight stage?
Dreadnaught replied to Conor's topic in General Construction Issues
You've prompted me to check with my window provider. Thanks! -
ASHP, Solar PV & SunAmp (Storage) Control Problems?
Dreadnaught replied to FredBristol's topic in Other Heating Systems
… plus the lower standing heat losses for a passive house. -
What type of tape to use please?
Toolstation discount, possible for a self-builder?
Dreadnaught replied to Dreadnaught's topic in Building Materials
Thanks @Ferdinand. Very interesting. Yes, I read that thread before posting, thank you. It look like Toolstation are quite miserly with their discounts. And I will try some independent merchants of various sorts too, see what I can discover.
