Just been discussing a similar thing here:
So do I. I understand BASIC and the underlying assembler, but seemed to miss the decade when C came along. When I worked for Welcome Break they had a new POS system designed in Israel. One of the test engineers came over and on a Monday morning started, what looked like random touch screen presses, until something went wrong. Then she wrote the sequence down, and started again. She did that for two weeks. I would have cheated.
Solar DC cable direct to hot water tank element.
SteamyTea replied to epsilonGreedy's topic in Photovoltaics (PV)
(expletive deleted)ing good job I am upcountry then. -
Or just a cheap, non sine wave inverter do it. The kind you see for 40 odd quid. Do the cheap inverts match an elements impedance better? -
I thought you were working on cold fusion, shame it is not taking up more of your time. -
This woman only needed 9 days treatment. http://news.bbc.co.uk/1/hi/england/cornwall/3035606.stm -
Hence But there are a lot of nobs that tinker under the assumption that relatively low voltage is pretty 'safe'. -
There was someone, in the dim and distant past, who set his ST up so that it never overheated, then all he needed was a simple controller. There is a problem that if, and it is not very likely, that the DC side electrolysed the water, it would put off the hydrogen economy pretty quickly. -
The easier way to to get someone that already has a stove to find out what the mean surface area temperature is and then assume an airflow around it (they can keep a small paper plane hovering, so not that great), and work it out from there. It will probably be a lot less than stated.
https://www.ebay.co.uk/itm/254103933935 Yes, a 13 and a half quid one if you stick to 48V modules. -
The element may be OK, but how about the thermal cutout, and a bog standard thermostat, can they cope with the extra arcing? -
I think in a home wood burner, visible smoke is more to do with the water content being driven off. From the colour you can estimate the temperature, so if you know the area that it is radiating from, you can work out the power it is delivering. Temperature (°C) Colour 480 Barely red in the dark 600 Dark red 800 Cherry red 950 Orange, barely visible in sunlight 1100 Orange-yellow, visible in bright sunlight 1300 Light yellow, nearly blinding, welding goggles required. 1500 Nearly white, blinding
Fixed costs in a roof PV installation.
Would also show if the system is not generating without having to go into the inverter menus. -
Well it will be at those sort of prices. -
I was driving up country, still here. But for about 10 miles on the A30, at 6:30 AM yesterday were free Christmas trees in the road. Driving against a stiff NE wind hurts my fuel consumption by about 10 MPG.
- 40 replies
Did we not have a similar conversation about the cost if fitting roof integrated PV against tiles. And you decided all the people that had actually done it were talking nonsense.
