SteamyTea
    200
  1. Squirt with penetrating oil and put back in the shed till 2030.
  2. I think they should all be called thermal energy stores, even my storage heaters. Then sub dive them into vented, unvented, direct and indirect. Then the number if coils classed surface area.
  3. As you will be wanting to sell it once you have done with it, anything that makes it look good, and can be packed up inside it i.e. decking, skirt, EWI, cheap A2AHP should add value.
  4. I think that is okay. It is all about overall energy storage and modes of failure. While the water in either a pressurised, or vented system contains the same energy, a pressure vessel fails much more rapidly, seconds rather than months usually. This allows a much greater power delivery. Isn't a vented cylinder with isolation coils a thermal store. Or do you mean an old system boiler type cylinder, the ones with the coil in the base and an immersion element at the top.
  5. Seller used them when I bought a house though Anquish&Pain Estate Agents.
  6. If it is a pressurised system you need G3 signoff.
  7. Start looking at parasitic loads i.e. old gear on standby, most new stuff is pretty low these days. You are aware of the health risks associated with the poorer internal air quality of timber and coal burning?
  8. Too true, some may just totally pointless.
  9. That is not excessive. Your DHW usages seems very reasonable, how many in the house? Space heating is the real challenge, so realistically an ASHP is the way to go. That means getting the building to a better thermal specification. You have 4 months to improve airtightness, insulation and general maintenance. Then take a financial hit on this winters electrical usage, but record usage (get an energy data logger). It is better to spend a £1000 on one winter's usage than an extra £5000 on an incorrectly sized ASHP. Stored hot water usage is really down to three things, the same three things that affect a house. Reduce losses, don't overheat and only heat what is needed. There is no need to store water greater than 48°C, this reduces losses right away, add extra insulation around the cylinder (fill the airing cupboard up with it), and reduce usage if you can, so shorter showers, less baths. Economy 7, or one of the derivatives is an alternative, along with storage heaters. This will require extra wiring, which will be as messy as plumbing, and like a radiator system, you end up with 'boxes' in the rooms. Modern storage heaters are pretty good, they take a bit of getting used to, but work as well as any other system. Main thing is to reduce losses, don't be afraid to post up dimensions/sketches of the house. I am 'all electric' and my current daily usage, over the last 2 full weeks, has been 3.5 kWh/day. DHW is usage (with a bit of washing machine use) is 2.8 kWh/day. There is just me in the house.
  10. Welcome @Adsibob is the expert at London renovations, he has just about had everything go wrong. Make sure you get on with neighbours, and builders stay solvent. Not to mention getting wine fridges.
  11. Read some of it, and yes, fun describes it nicely.
  12. Park a (expletive deleted) off big crane outside the front of his house. See how he feels about things then.
  13. I agree, or is that disagree. I had a boss once that liked his office at about 15°C. The production area was at 24°C as it was a temperature dependant curing process. He used to complain about the heating costs. The halving of production would have cost more, and we burned waste timber in the Talbot, that saved in disposal costs. He was just a nob.
  14. I grew up in the Far East, South of France and the West Indies. I hate the cold. 26°C indoors still requires a jumper. Humidity can make you feel subjectively hotter or colder, depends how much you are perspiring. Being in direct sunlight or no makes a difference as well. If you need air movement, get a fan.
  15. 200 m up a hill where I am. North winds are killers.
  16. While I agree with all that, especially when you take the difference in the number of charge/discharge cycles into account, battery storage is useful when it comes to lighting and cooking. There is also the overriding issue of CO2e emissions , of the grid demand is smoothed out, then more efficient generation happens. Nationally the demand peak is at 'tea time', so batteries have had all day to be recharged from excess PV generation.
  17. What we need is a 'standard bean'. Then get every member on BH to plant some and record progress. This could be used to track the climate differences across the country. Or if that is just too much work, look for a pet dandelion and note the date it flowers.
  18. You win that one. Unless when I get home mine are in full bloom.
  19. Yes, in normal operation you only need a small airflow. This is mainly a noise issue, but a greater amount can be forced though on special occasions. Alternatively, as you have UFH, how about fitting a chiller unit to that. It would look very similar, identical in fact, to an ASHP.
  20. May just need regassing. It was a gas leak on mine that made it use 3 kWh a day. Was cheaper to buy a replacement at £110 than get it fixed. But it was a £90 fridge and 7 or 8 years old.
  21. Back to the original problem. How hard would it be to plumb in a portable A/C unit to the MVHR? Cheap solution for the few days a year it is needed and I am sure enough airflow can be generated to cool enough air.
  22. There is a flow meter that people borrow to set up their MVHR.
  23. Stops the neighbours seeing what I am doing.
  24. How much energy is the current one using, I am sure you have said. A+++++ is now the new A
