SteamyTea
    200
  1. So @pocster's walk on glazing did find a home.
  2. How many miles a day do they travel, 2?
  3. Something that had been happening, since he was a lad
  4. The doggerel was bad, which made him sad.
  5. Seem to effect halve my customers tonight. (expletive deleted)ing morons, can't read off a menu.
  6. Grip Strength
  7. A good counter example, a rubbish statement, backed up by another one. You got to get a grip on it.
  8. That is exactly my point. I do not know. I understand not using any imported energy, and I can assume that consumption is 10 kWh, but is that a day, a week, or for the whole month.
  9. Thiyse figured are meaningless, or wrong. What is the time period, second (in the case ift kW) or month (in the case of kWh). 50%+ if the time I have no consumption, measured at the Wh (3600J) level.
  10. So you have fallen for the dodgy carbon accounting methods used for all biofuels. Oh dear, there is little hope left.
  11. A few of us are mucking about with wires and code, hoping to make a cheap and accurate energy meter. May be worth spending 25 quid and knocking one up. https://forum.buildhub.org.uk/blogs/entry/946-the-energy-meter-experiment/page/2/?tab=comments#comment-5986
  12. There is a similar problem with composite plastics. Many a time I have heard 'we added loads of hardener and it went off (hardened) just fine'. This is a real problem when doing flat roofs as the pigments change the depth that UV radiation can penetrate. So you can end up with a partially cured base layer, with excess liquid or gaseous styrene monomer trapped in it, but a fully cured top layer.
  13. Yes, been telling people this for decades. Few listen @Joe-90 Get a proper heat loss calculation done, then see what your options really are. General point, who thinks far infra-red heating will enter the conversation here?
  14. They are not brave enough to take on the independent roasters down here. Wish they were, when I see a 'Cornish Coffee' sign outside cafe, I walk away fast.
  15. If I was there, first trips would be to Fort William or Inverness. They seem to be the closest Costa Coffees.
  16. Can you explain a bit more, intrigued how you get a 15° twist out of a plank with a plainer.
  17. How do you know they are all working optimally?
  18. Right. They need to update it.
  19. I lived in an island in the West Indies. It is the ruggedness and remoteness I grew to hate.
  20. Wind power follows a weibull distribution. Plugin the mean windspeed and adjust the skew to your local topology. Small turbines can be noisy, especially from the stay cabling. They are expensive and need maintenance. But you can make your own. Hugh Piggott Axial-flow PMG wind turbine May 2003.pdf
  21. What is needed is a PHEV with a 6 kW PTO and 30 kWh of usable storage. A thermal PTO may be useful as well. Better get my pencils out and use my 40 year old degree in automotive engineering to save the world.
