Have you fitted a module. Easy enough to fit as you can brace against the rail. Once fitted the rail is covered.
How does your garden grow?
SteamyTea replied to recoveringbuilder's topic in Landscaping, Decking & Patios
We are the experts, @Onoff and I. Do you like bean and potatoes mash? I can donate a succulent cutting I steal from the sub tropical garden, and an echium that grew from bird poo. -
Half the time they produce nothing, then half of the remains time they produce less that 100W, half again, between 100W, but below 200W. So while it is true to say you get less maximum power, you probably get a lot more energy oversizing. If you store that energy, you can design to draw more power via other methods.
That is the difference, Nod's wife built the shed/garage/workshop.
Can't you get pressure activated valves. https://www.norgren.com/uk/en/list/fluid-control-valves/pressure-operated-valves?refine=port-size-over-portsg1forwardslash4 I seem to remember they had them dotted all over the oil refineries I used to play on as a kid.
Where is the kWh price heading in 2022?
SteamyTea replied to epsilonGreedy's topic in General Self Build & DIY Discussion
Listening to the news this morning, there was some German energy person on. He was saying that they (the Germans) need to find a German solution to the energy crisis. Will that be another Final Solution for them. While I was pondering all this, another bit came on about how, if we had done the suggestions mooted at the beginning of the 'crisis', they would have been wrong and inadequate. I agree with this. Then I thought more, and wondered if we do not bail out the energy retailers (as opposed to the producers), should we give discounts to individual users, similar to what we are currently doing. Then I thought even more. If you get RHI, FiTs or had a grant to fit RE kit, should you be getting any help. You have been claiming 'help' already, sometimes quite a lot. Then, after more thinking, I realised that is way to hard to manage it all, so went back to my original idea mentioned it on here somewhere some weeks ago, that we just need to support the energy retailers. Then a bit more thinking, to what extent do we need to support them. The long term, auction mean price of electricity has been around £50/MWh. So why not set the price cap at £75/MWh that retailers can pay, then the Treasury chips in the difference, which some days may be £100/MWH, other days nothing. The records are there, accounts and bookkeepers like doing that sort of stuff, and the end users (us) have manageable bills, all be it higher than they were. A secondary advantage is that it should encourage investment in RE. I would include nuclear in that, but they cannot buy a £1 sandwich from Poundland without it costing a million quid, and by the time they got the sandwich it would be a decade old and more mouldy that a British Rail one. Then I thought my 2 minute shower was over and I better get out, don't want to waste energy. No one can see your tears of pain as hot shower water goes down the plug hole. -
Can you not just do s split at the incoming mans, then run the house of one part of it and the iMist on the other. Not as if a broken pipe is going to cause a real problem in a fire. Have yo read the news recently about power cuts and rationing?
I have often wondered how good pumping the heat back into the ground works as an intersessional store. What usually happens is that moving ground water, which has percolated from a large, local, catchment area, moves past the borehole pipes and is the real source of the energy. Having said that, you have to dump the energy from cooling somewhere, so may as well use the borehole pipes.
Why would you not improve the current insulation to at least current regulations.
Amazon warehouse fire linked to solar installation
SteamyTea replied to LnP's topic in Photovoltaics (PV)
Will that be the same idiots that claim they don't work and never, ever, pay back their energy debt. -
I am in a Bird Flu area, avoiding them all.
What temperature do you intend to store DHW at, that changes the number of kWh stored and the recharge time. Keeping the temperature as low as possible reduces the losses and increases the CoP. When guests stay, put the immersion heater on, cost less than a bottle of cheap wine.
Do you man the power taken to run a kettle ~2.8 kW, or the energy to boil a kettle full of water ~0.16 kWh. I had a quick look at the first 72 day of this year, daily mean of 16.3 kWh, then looked at the 72 days from June 1st, 3.1 kWh. So 3.1 kWh/day for DHW and everything else (ish). So to heat my 48 m2 house takes, on average 13.2 kWh/day. 72 days is 2448 hours [950.4 kWh] works out at a mean power of 423 W, or 9W/m2. The mean room temperature was 19.2°C, mean external temperature 7.5°C, a delta of 11.7°C. The mean room temperature is a little lower than I aim for [20°C], but the hourly profile is pretty good now [delaying the start of heating helps]. With my new draught proofing measure this year, I expect to see a reduction in usage and an increase in temperature to close to the target. Below is a more detailed profile. -
Rainwater Harvesting Experiences (2022 Edition)
SteamyTea replied to BristolBuild2020's topic in Rainwater, Guttering & SuDS
@CADjockey Thanks. I assumed it was something fairly basic. Do you mean recycling or recirculating to/from the header tank? -
Do you get your car 'borrowed' a lot.
Have you been reading this weeks New Scientist!
In the middle of Lidl last week they had a self darkening wielding mask and an inverter arc welder. Wait a while and they will have a band saw again. Failing that, they have a cordless angle grinder, batteries (and I assume a charger somewhere) and a contraption to mount the angle grinder to make it into a cut off saw. Sure they will have a tin of Hammerite as well.
Welcome. Add heat loss calculations, airtightness and condensation risk analysis to the list.
Would not thank me for not flushing it.
I chopped my beans down last Monday. I think I may have planted too many in the container. Then not watered them enough. Always next year. Got a crap crop of potatoes as well. -
Does anyone understand how ADSL broadband actually works?
SteamyTea replied to ProDave's topic in Boffin's Corner
Why do you think anything a politician says should turn into reality. -
@CADjockey What are you doing to clean the water before use? -
Welcome. Ah, flat roofs. There are many methods to use, but if you just get it GRPed, problems solved, forever.
Yes, but some can disappear. I was with Lavabit, as was Edward Snowden, that got closed down, then I was with Gawab, they got bombed out in the Arab Spring. I got a Proton account, nice and secure, but cannot remember the passwords, and there is now way to have it reset. I thought I heard that you can keep your email address from old, mainstream, providers, but as the last time I used that type of service I was with AOL in the 1990s.
