Self-Build Insurance - Supplier Recommendations
SteamyTea replied to Dave and Helen's topic in Self Build Insurance
If it is warm, and making a noise, put a meter on it and see how much power it is using.
What energy rating is your HW cylinder?
SteamyTea replied to Adsibob's topic in Boilers & Hot Water Tanks
And some people on here pay to get the pole taken away and bury the cable. As much as I dislike the pole and cables out the front of my house, I could, either a couple of broomsticks, reach them. May be useful oneday. -
There is a song called '30 thousand pounds of bananas' Has a line in it. "That's when he lost his head, not to mention an arm and a leg' There is a really important message in the song. -
It is also dependant latitude. Most of the USA is on a latitude with Madrid or below, this means that the sides of the house has less time exposed to direct beam irradiation than in the UK, which is a minimum of 10° further north. Most of the overheating in the UK is caused by a plume of hot air moving in from Europe and North Africa, venting a house does not help much then. If solar is causing an overheating problem, better off putting a reflective film on the windows.
Or the system shuts down in a safe manner. It is easier to route cables than pipes. PV is not exactly new technology, been around 50 years in the domestic setting. The efficiency is a tricky question to answer. While, for any given amount of area and insolation, ST will absorb more energy over time. The trouble is, because of the crude on or off control, much of that absorbed energy is of little use e.g. too cold or too hot. PV while needing a minimum amount of photons to lift the electrons to a higher energy state, produces a more usable amount of energy because the electronics in the inverter converts and conditions the output to what is needed i.e. 230V 50Hz, and that can be added to the general mix of electrical power from other sources, so can be used to help drive a heat pump, boosting efficiency more.
Not really as there is no fresh air entering the living room, just stale air dragged upstairs.
That isn't the issue in my idea. Not having an inlet or outlet in the actual living room is the problem. May be able to pipe through bathroom and airing cupboard.
Welcome. Have you done a heat load calculation?
Due to my house layout, basic 2 up, 2 down terrace, the easy solution is to fit a lift unit and plumb in the pipes upstairs in the traditional manner, then fit a large, through the wall dMVHR for the kitchen. The living room has the stairs in it, so the landing is in effect the same room. I could put some pipes in between living room ceiling and the bedrooms, but not really worth the effort.
Alternative broadband supplier questions
SteamyTea replied to ProDave's topic in Networks, AV, Security & Automation
I read a story book many years ago about a kidnap. The police used the landline to listen in on the kidnappers. So maybe you are being spied on. -
Cured my haemorrhoids going out with a vegan. Just had a donkey kebab for my tea, roll in the morning coffee, the French know it loosens anything.
V2G will probably become more useful in the next decade. Really want Vehicle to My House for a bit more control.
Yes, it is the same problem as ToU billing.
Are you talking about dMVRH? Why do you think the CO2 levels are too high, and why are they talking a long time to reduce. What is the humidity like in the troublesome places? Have you calibrated the CO2 meter? Stick it outside and it should read about 420ppm, though you are in a dirty part of the country, so maybe a little higher.
You can usually tell if water if from a loft tank or the mains. If you can stop the water coming out the tap with your thumb over the spout, it is from the loft. If you can't, and you get wet trying, it is probably from the mains.
Well you could charge batteries when the grid has excess low carbon generation. Should be easy enough to grab the 5 minute data from Templar Gridwatch and switch the charger on. I think last week most of my usage (22 kWh) was when low carbon generation was over 50% of total generation.
Update on Energy Use Based on 4 years of Actuals
SteamyTea commented on TerryE's blog entry in The House at the Bottom of the Garden
Have you done a HDD test? I have recently posted up a load of charts that take wind direction, speed, temperatures, solar power (not PV) and energy usage. Cant really tell what is happening except if the external air is warmer, the house is warmer. Is that because you have a wood burner? -
