Yes, and they are probably in the majority. Not sure how to change that, environmental taxes has not worked, nor the recent price increases. Ritual Public Humiliation fails as well.
I think that's the only one that needs a comment Can't you get wool insulation that fully fills cavities. Think @joe90 used it. He had a wet wall until he sealed it, seems not to have had adverse effects. Still think that using cheap weed control membrane with mineral wool above it will solve the problems, and easy to fix. may need to glue so battens, for easy stapling, to the steel, that is easy to do though.
The trouble is, just basing it on income, it is a blunt tool. The energy price increase has shown how little people really understand how the energy market works, and, more importantly, how they use energy. It might be possible to add a surcharge to utility bills for homes below an EPC C. That then relies on many landlords doing some extra work, which, in our imagined housing crisis, will not work. In reality, for owner occupiers, it is up to them to do what they want. If they do nothing, they cannot really complain. It is amazing how much can be saved with small changes.
That sounds like a good idea. I do wonder how many claims are successful and what hoops have to be jumped though to make a claim.
That would stop the woodburns. Yes, not sure how it would actually work in practice, but it seems to me that solicitors are constantly surprised when asked to sell a house.
Not the best picture. I just screwed into the main window frame, not the opener, that would not have stopped the leaks. Gap is around 25mm. I don't have trickle vents, there are enough holes in the house as it is.
EDF are going to charge me 34p/kWh for night usage.
How often do you take advantage of that dimmability? Is it a case of just using the strips under the counter when you don't want much and the others are on or off (or at best partly dimmed and off). I worked at the RNIB and they had very fancy lighting, it ended up on or off.
A system set to PVGIS's optimal angles would yield around 37 kWh/kWp installed, so around 1.2 kWh a day in December and January. Changing the slope angle to 75° would up that a bit to 44 kWh, so 1.4 kWh/day. The power, at any given time, would be pitifully low, probably peaking at 200 W. So the only real way to make use is to have a large array and battery storage. Once you have electrical storage, you can run a heat pump, which at that time of year may effectively double the output. But not every day some days will be better than others. You can get a bit smart by linking a control system to the Met Office (I think they have an API, @TerryE uses it I think) to help predict what you may generate, then use accordingly. All in all, it will be an expensive system, so may be better off thinking about getting a small CHP unit to supplement it. Best to work out your expected loads first, the lower they are the better off you are. My small (50m2) terrace house uses around 13 kWh/day in the winter, purely resistance heating here. I am hoping to get that down to 9 kWh/day this winter, but it is going to be harder that getting down to 13 from 25 kWh/day.
Hello... first time buyer and renovator.
SteamyTea replied to darkrabbit's topic in Introduce Yourself
Someone did a few a while back (probably on the predecessor to here). Have you tried LISA? -
New to new build, keen to get going but talk about bad timing...
SteamyTea replied to DAMcN's topic in Introduce Yourself
As you are London based, you probably have a large pile of cash. Wait. Or look a bit further out I used to live in Hertfordshire and Buckinghamshire, but work in London. My commute was usually quicker. Jeremy Hunt used to be in charge of the NHS. 'I may not be a gynecologist, but I know a Hunt when I see one' -
I knocked up some secondary glazing a few weeks back. Just cheap styrene sheets, cheap moulded timber, cheap foam W seals, all held together with double sided tape. I have timber framed so just drilled and screwed them in place. Apart from reducing draughts (which is what I wanted) the noise reduction has been dramatic. The neighbour that goes to work at 3 AM is not public enemy number 1 now (though may still squirt some expanding foam up the big bore exhaust). I did this as a proof of concept, may redo them a bit prettier next year, shall see how much energy I save first. I think the 14 windows did not cost me 200 quid.
Welcome. Only if you want to loose all that £60k and have no value added. Making any house low energy is really quite simple, control the air changes and insulate. Most of the rest is bling. If your house is NW facing, does that mean halve is SE facing? UFH requires a lot of insulation under it, around 200mm. Why lime render, if you control the ventilation, why do you want walls that are breathable? Not that lime is, in reality, any more breathable, than cement based render. At least you know cement based sets hard. -
I had my old frosty lenses changed to nice, shiny, acrylic ones about 14 years ago. All I can say is that most places are over lit, harsh and painful. Cataracts can affect everyone. So I am happy with With 3W warm LEDs in them. Anything extra is just flash, literally and metaphorically.
You could do a bricklaying course. Not for the trowel skills, but you will get to know a lot of people on it and who is good, and available.
Was he surprised?
Not here it isn't.
Going to myself in trouble for posting this up, but it is close to Halloween. I suspect between @pocsterand @Onoff, a small device could be printed. But at 1200 quid to cure the leak, I am tempted to rent one out in my back room
Food Waste Caddy built in to worktop - Smell?
SteamyTea replied to puntloos's topic in Kitchen Units & Worktops
Put food waste into the general (black bin) waste and then the council will send it to the incinerator. Then get some electricity from it. https://suezcornwall.co.uk/what-we-do/energy-recovery/electricity-generation/ -
Cinders. My Mother told me, when we lived in a cold house, that the Queen had a heated toilet seat.
Works when you have a very small variation in heat load per °C external temperature variation (say 100W/°C), probably kills the CoP once the ASHP is outside of it modulation range (say 450W/°C).
I don't think so. Flow [kg/s] x temperature [K] = power [W] Power [W] x time [s] = energy [J] To heat up stuff you need energy, the faster the energy is delivered, the more powerful the heater, that is the basic of thermodynamics. There may be many temperature sensors added to a system for control and efficiency reasons, but basically if just two are used on the flow and return, and knowing the flow rate, the energy delivered is then known. The room thermostat is then just a device to stop overtemperature. In a very basic system as described above, manual room temperature correction would be initially needed, but once compensation curve is set, then, except in extreme conditions, the system can be left alone. Room and external temperature sensing can be used to help set that curve automatically and change the rate of thermal delivery to help efficiency, but they are not absolutely necessary to get a functioning system. (bit of a cross post with @JohnMo)
Pretty grim isn't it.
There is switched on and ready to go, and switched on and heating. When in weather compensation mode, the difference between flow and return temperature is what tells the unit when to input more heat. The room stats are there to set an absolute maximum, and sometimes minimum, temperature.
