Any ideas what is happening with my PV array
SteamyTea replied to Omnibuswoman's topic in Photovoltaics (PV)
Usually, PV systems have a generation meter installed. You could make one of my energy monitors and attach it, then you will see what is happening every Wh, and when it occurs. And you get loads of data to play with. I have also made a simple solar intensity meter, but it needs more polishing (as I have no idea how to reliably move and store data from an ESP to a RPi across a wireless network). Then you will have even more data. Worth correlating it with your overall energy usage and the local temperatures. RH is useful to, but then you also need air pressure to get a truer reading. -
The ASHP install. Lots of heating on/heating off then fingers crossed.
SteamyTea commented on TheMitchells's blog entry in Renovation of Ellesmere Bungalow.
You should have pointed them to Part 2 of several by Zoothorn -
Ubiquiti Cloud key confusion !
SteamyTea replied to Pocster's topic in Networks, AV, Security & Automation
Because of this thread, and never really having understood asymmetrical encryption, I have reread up on it. I think I understand it a bit more than I did. I still have not found a decent worked example i.e. the mathematical base of it. -
Could be incorporated into the MVHR to warm the incoming, low RH air. (you can get MVHR with small built in HPs)
Yes. But like governing Italy, is it worth it. I suggested something similar from old fridges years back (actually made on to warm the fishpond when I lived in Herts). Our old mate @Jeremy Harris pointed out that it would be very low powered as fridges usually only draw a few watts, around 100, when running. So at best, maybe only a 400W output, at 50°C (they don't get much hotter than that as small children may burn fingers).
It makes it easy to understand, and eliminates the risk of downloading from unknown sources. The original sunshine text was 85.2 kb, as most internet connections compress data, it is probably closer to 11 kb. As a comparison, Bramco's screen capture is 32.8 kb. So I think that the internet can handle it. -
Is the PV system connected to the main electrical grid.
Call this an engineering report....
SteamyTea replied to ThomasB's topic in General Structural Issues
The use of language in reports is interesting. As quite a few of you know, I spent way to much time at university and hated writing assignments. As I had to write a lot, usually I would say one thing, in one sentence. When read in isolation, the sentence should make sense. I also tried to use words of 3 syllables or less. I take the American Museum view by assuming my audience was is a 12 year old, until I started my PhD, then I raised it to 14 years old. Occasionally I accused of being condescending, but that is the readers problem, not mine. I believe that a 14 year old should be able to read, understand and benefit from others knowledge. Many years ago, I did a Chartered Institute of Marketing course. I was told to use more marketing focused language. I think what they meant was to be dishonest by changing the meaning of words. Facts mean nothing in marketing. I often get asked for advice (usually thermodynamics), but what is really wanted is a simple answer. I am sorry, the answers are not usually simple. Try explaining entropy, and why it increases with disorder. Took me 5 years of higher education, then 15 years of practical examples, and I have still only scratched the surface of it. As Richard Feynman said when asked to describe what he won his Noble Prize for, "If I could explain it in 3 minutes, it would not be worth a Nobel" -
I do. They do different things, at different temperatures and at different times. The 3Ds
Be careful, collecting and analysing data can become an illness. -
Secret. https://www.wunderground.com/dashboard/pws/ITAVIS24/table/2024-12-3/2024-12-3/daily The solar sensors are usually pointing directly upwards, so they show less of a peak than your modules will receive, but they do cover the whole sky. There is always some inaccuracy with amateur weather stations, but good enough to get a decent picture. -
Last 3 days in Tavistock, which I think is near you. December 1, 2024 Time Temperature Dew Point Humidity Wind Speed Gust Pressure Precip. Rate. Precip. Accum. UV Solar 12:04 AM 12.7 °C 12.6 °C 99 % SW 4.5 km/h 9.1 km/h 998.82 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:09 AM 12.8 °C 12.7 °C 99 % SSW 7.9 km/h 14.6 km/h 998.71 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:14 AM 12.8 °C 12.7 °C 99 % SSW 8.2 km/h 18.7 km/h 998.71 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:19 AM 12.8 °C 12.7 °C 99 % SSW 5.3 km/h 12.1 km/h 998.61 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:24 AM 12.8 °C 12.7 °C 99 % SSW 6.4 km/h 14.2 km/h 998.61 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:29 AM 12.8 °C 12.7 °C 99 % SSW 6.5 km/h 13.4 km/h 998.41 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:34 AM 12.8 °C 12.7 °C 99 % SSW 8.1 km/h 15.8 km/h 998.41 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:39 AM 12.8 °C 12.7 °C 99 % South 6.7 km/h 15.2 km/h 998.10 hPa 0.61 mm 0.10 mm 0 0 w/m² 12:44 AM 12.8 °C 12.7 °C 99 % SSW 5.5 km/h 12.1 km/h 998.10 hPa 0.61 mm 0.10 mm 0 0 w/m² 12:49 AM 12.8 °C 12.7 °C 99 % SW 7.3 km/h 15.4 km/h 998.10 hPa 0.61 mm 0.10 mm 0 0 w/m² 12:54 AM 12.9 °C 12.8 °C 99 % South 8.5 km/h 19.3 km/h 997.90 hPa 0.00 mm 0.10 mm 0 0 w/m² 12:59 AM 13.0 °C 12.9 °C 99 % SSW 8.5 km/h 16.1 km/h 997.90 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:04 AM 13.0 °C 12.9 °C 99 % SSW 7.6 km/h 15.4 km/h 997.90 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:09 AM 13.0 °C 12.9 °C 99 % SSW 9.6 km/h 16.2 km/h 997.90 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:14 AM 12.9 °C 12.8 °C 99 % SSW 7.7 km/h 20.8 km/h 997.90 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:19 AM 12.9 °C 12.8 °C 99 % SSW 8.5 km/h 21.2 km/h 997.80 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:24 AM 12.9 °C 12.8 °C 99 % SSW 6.8 km/h 19.2 km/h 997.90 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:29 AM 12.8 °C 12.7 °C 99 % South 6.1 km/h 15.9 km/h 997.70 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:34 AM 12.9 °C 12.8 °C 99 % SSW 6.0 km/h 15.8 km/h 997.60 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:39 AM 12.8 °C 12.7 °C 99 % South 4.7 km/h 14.9 km/h 997.39 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:44 AM 12.8 °C 12.7 °C 99 % SW 7.9 km/h 13.0 km/h 997.49 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:49 AM 12.8 °C 12.7 °C 99 % SSW 7.7 km/h 16.2 km/h 997.49 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:54 AM 12.9 °C 12.8 °C 99 % SSW 8.5 km/h 18.5 km/h 997.09 hPa 0.00 mm 0.10 mm 0 0 w/m² 1:59 AM 12.9 °C 12.8 °C 99 % SSW 5.3 km/h 12.0 km/h 997.19 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:04 AM 12.8 °C 12.7 °C 99 % SW 7.1 km/h 14.8 km/h 997.09 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:09 AM 12.8 °C 12.7 °C 99 % SW 6.2 km/h 14.7 km/h 997.19 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:14 AM 12.8 °C 12.7 °C 99 % South 5.2 km/h 11.6 km/h 996.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:19 AM 12.9 °C 12.8 °C 99 % SSW 7.2 km/h 15.2 km/h 996.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:24 AM 12.9 °C 12.8 °C 99 % South 6.2 km/h 13.8 km/h 997.19 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:29 AM 12.9 °C 12.8 °C 99 % SSW 6.4 km/h 14.9 km/h 996.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:34 AM 12.8 °C 12.7 °C 99 % South 7.1 km/h 15.5 km/h 997.19 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:39 AM 12.8 °C 12.7 °C 99 % ESE 5.7 km/h 14.5 km/h 996.82 hPa 0.00 mm 0.10 mm 0 0 w/m² 2:44 AM 12.8 °C 12.7 °C 99 % South 7.7 km/h 14.7 km/h 996.72 hPa 1.19 mm 0.30 mm 0 0 w/m² 2:49 AM 12.8 °C 12.7 °C 99 % SE 7.8 km/h 20.3 km/h 996.61 hPa 1.19 mm 0.30 mm 0 0 w/m² 2:54 AM 12.8 °C 12.7 °C 99 % SSW 8.4 km/h 16.5 km/h 996.72 hPa 1.19 mm 0.30 mm 0 0 w/m² 2:59 AM 12.8 °C 12.7 °C 99 % South 4.9 km/h 15.5 km/h 996.51 hPa 0.00 mm 0.30 mm 0 0 w/m² 3:04 AM 12.8 °C 12.7 °C 99 % South 6.8 km/h 13.4 km/h 996.51 hPa 0.61 mm 0.41 mm 0 0 w/m² 3:09 AM 12.8 °C 12.7 °C 99 % SSW 6.5 km/h 15.2 km/h 996.31 hPa 0.61 mm 0.41 mm 0 0 w/m² 3:14 AM 12.8 °C 12.7 °C 99 % South 6.9 km/h 13.4 km/h 996.41 hPa 0.61 mm 0.41 mm 0 0 w/m² 3:19 AM 12.8 °C 12.7 °C 99 % SSW 5.1 km/h 13.3 km/h 996.11 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:24 AM 12.9 °C 12.8 °C 99 % SSW 7.5 km/h 15.5 km/h 996.00 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:29 AM 12.9 °C 12.8 °C 99 % SSW 7.4 km/h 15.2 km/h 996.11 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:34 AM 13.0 °C 12.9 °C 99 % SSW 8.3 km/h 20.5 km/h 996.00 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:39 AM 13.0 °C 12.9 °C 99 % South 6.6 km/h 16.4 km/h 995.90 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:44 AM 12.9 °C 12.8 °C 99 % SSW 6.7 km/h 12.7 km/h 995.70 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:49 AM 13.0 °C 12.9 °C 99 % South 7.3 km/h 13.8 km/h 995.80 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:54 AM 13.0 °C 12.9 °C 99 % SSW 8.0 km/h 22.0 km/h 995.70 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:59 AM 13.0 °C 12.9 °C 99 % SSW 6.8 km/h 12.2 km/h 995.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 4:04 AM 13.1 °C 13.0 °C 99 % South 5.8 km/h 13.0 km/h 995.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 4:09 AM 13.1 °C 13.0 °C 99 % SW 8.1 km/h 12.8 km/h 995.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 4:14 AM 13.2 °C 13.1 °C 99 % South 7.6 km/h 14.9 km/h 995.50 hPa 0.00 mm 0.41 mm 0 0 w/m² 4:19 AM 13.2 °C 13.1 °C 99 % South 6.6 km/h 13.9 km/h 995.40 hPa 0.00 mm 0.41 mm 0 0 w/m² 4:24 AM 13.2 °C 13.1 °C 99 % South 5.5 km/h 12.2 km/h 995.40 hPa 0.61 mm 0.51 mm 0 0 w/m² 4:29 AM 13.2 °C 13.1 °C 99 % SSW 4.9 km/h 11.1 km/h 995.19 hPa 1.19 mm 0.61 mm 0 0 w/m² 4:34 AM 13.2 °C 13.1 °C 99 % South 7.6 km/h 15.7 km/h 995.09 hPa 1.19 mm 0.61 mm 0 0 w/m² 4:39 AM 13.3 °C 13.2 °C 99 % SSW 6.8 km/h 12.9 km/h 995.09 hPa 0.00 mm 0.61 mm 0 0 w/m² 4:44 AM 13.3 °C 13.2 °C 99 % SSW 7.1 km/h 14.0 km/h 995.09 hPa 0.00 mm 0.61 mm 0 0 w/m² 4:49 AM 13.3 °C 13.2 °C 99 % SSW 7.8 km/h 15.2 km/h 994.99 hPa 0.00 mm 0.61 mm 0 0 w/m² 4:54 AM 13.4 °C 13.3 °C 99 % SSW 9.1 km/h 21.8 km/h 995.09 hPa 0.00 mm 0.61 mm 0 0 w/m² 4:59 AM 13.4 °C 13.3 °C 99 % SSW 6.4 km/h 15.6 km/h 994.99 hPa 0.61 mm 0.71 mm 0 0 w/m² 5:04 AM 13.4 °C 13.3 °C 99 % SSW 8.4 km/h 18.9 km/h 994.99 hPa 1.19 mm 0.79 mm 0 0 w/m² 5:09 AM 13.4 °C 13.3 °C 99 % SSW 7.9 km/h 15.0 km/h 994.99 hPa 1.19 mm 0.79 mm 0 0 w/m² 5:14 AM 13.4 °C 13.3 °C 99 % SSW 7.6 km/h 14.8 km/h 994.79 hPa 0.61 mm 0.89 mm 0 0 w/m² 5:19 AM 13.4 °C 13.3 °C 99 % SSW 6.4 km/h 13.0 km/h 994.68 hPa 0.61 mm 0.89 mm 0 0 w/m² 5:24 AM 13.4 °C 13.3 °C 99 % SW 6.7 km/h 12.4 km/h 994.68 hPa 0.61 mm 0.89 mm 0 0 w/m² 5:29 AM 13.4 °C 13.3 °C 99 % SW 7.3 km/h 16.0 km/h 994.79 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:34 AM 13.4 °C 13.3 °C 99 % SSW 7.9 km/h 13.9 km/h 994.79 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:39 AM 13.4 °C 13.3 °C 99 % SW 6.7 km/h 14.1 km/h 994.68 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:44 AM 13.5 °C 13.4 °C 99 % SSW 9.5 km/h 18.3 km/h 994.68 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:49 AM 13.5 °C 13.4 °C 99 % SW 9.0 km/h 18.2 km/h 994.79 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:54 AM 13.5 °C 13.4 °C 99 % SW 12.2 km/h 21.4 km/h 994.79 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:59 AM 13.5 °C 13.4 °C 99 % SW 10.1 km/h 18.8 km/h 994.79 hPa 0.00 mm 0.89 mm 0 0 w/m² 6:04 AM 13.5 °C 13.4 °C 99 % SW 9.5 km/h 18.9 km/h 995.09 hPa 0.00 mm 0.89 mm 0 0 w/m² 6:09 AM 13.5 °C 13.4 °C 99 % SW 8.1 km/h 16.9 km/h 994.99 hPa 0.61 mm 0.99 mm 0 0 w/m² 6:14 AM 13.4 °C 13.3 °C 99 % SW 10.1 km/h 20.0 km/h 995.09 hPa 0.61 mm 0.99 mm 0 0 w/m² 6:19 AM 13.4 °C 13.3 °C 99 % SW 7.3 km/h 12.6 km/h 994.99 hPa 0.61 mm 0.99 mm 0 0 w/m² 6:24 AM 13.4 °C 13.3 °C 99 % SW 7.4 km/h 14.4 km/h 995.09 hPa 0.00 mm 0.99 mm 0 0 w/m² 6:29 AM 13.4 °C 13.3 °C 99 % SW 6.8 km/h 13.5 km/h 995.19 hPa 0.00 mm 0.99 mm 0 0 w/m² 6:34 AM 13.3 °C 13.2 °C 99 % SW 6.3 km/h 12.2 km/h 995.29 hPa 0.00 mm 0.99 mm 0 0 w/m² 6:39 AM 13.3 °C 13.2 °C 99 % SSW 5.2 km/h 10.0 km/h 995.19 hPa 0.00 mm 0.99 mm 0 0 w/m² 6:44 AM 13.3 °C 13.2 °C 99 % SW 5.5 km/h 9.6 km/h 995.29 hPa 0.00 mm 0.99 mm 0 0 w/m² 6:49 AM 13.3 °C 13.2 °C 99 % SW 5.5 km/h 9.9 km/h 995.19 hPa 0.00 mm 0.99 mm 0 0 w/m² 6:54 AM 13.2 °C 13.1 °C 99 % SSW 6.4 km/h 11.6 km/h 995.29 hPa 0.00 mm 0.99 mm 0 0 w/m² 6:59 AM 13.2 °C 13.1 °C 99 % SW 5.1 km/h 10.5 km/h 995.29 hPa 0.61 mm 1.09 mm 0 0 w/m² 7:04 AM 13.2 °C 13.1 °C 99 % SSW 6.7 km/h 10.5 km/h 995.29 hPa 0.61 mm 1.09 mm 0 0 w/m² 7:09 AM 13.1 °C 13.0 °C 99 % SW 5.4 km/h 10.9 km/h 995.40 hPa 0.61 mm 1.09 mm 0 0 w/m² 7:14 AM 13.1 °C 13.0 °C 99 % SW 4.2 km/h 8.6 km/h 995.29 hPa 0.00 mm 1.09 mm 0 0 w/m² 7:19 AM 13.1 °C 13.0 °C 99 % SW 5.2 km/h 10.4 km/h 995.40 hPa 0.00 mm 1.09 mm 0 0 w/m² 7:24 AM 13.1 °C 13.0 °C 99 % SW 5.9 km/h 10.6 km/h 995.19 hPa 0.00 mm 1.09 mm 0 0 w/m² 7:29 AM 13.1 °C 13.0 °C 99 % SW 6.5 km/h 11.9 km/h 995.40 hPa 0.00 mm 1.09 mm 0 0 w/m² 7:34 AM 13.0 °C 12.9 °C 99 % SW 5.6 km/h 11.4 km/h 995.19 hPa 0.00 mm 1.09 mm 0 0.1 w/m² 7:39 AM 13.0 °C 12.9 °C 99 % SW 6.1 km/h 10.3 km/h 995.40 hPa 0.00 mm 1.09 mm 0 0.2 w/m² 7:44 AM 13.0 °C 12.9 °C 99 % SSW 3.8 km/h 7.7 km/h 995.40 hPa 0.00 mm 1.09 mm 0 0.4 w/m² 7:49 AM 13.0 °C 12.9 °C 99 % SW 2.8 km/h 6.3 km/h 995.40 hPa 0.00 mm 1.09 mm 0 0.7 w/m² 7:54 AM 12.9 °C 12.8 °C 99 % SW 3.8 km/h 7.4 km/h 995.50 hPa 0.00 mm 1.09 mm 0 1.2 w/m² 7:59 AM 12.9 °C 12.8 °C 99 % SW 2.6 km/h 5.5 km/h 995.40 hPa 0.00 mm 1.09 mm 0 2.5 w/m² 8:04 AM 12.9 °C 12.8 °C 99 % SSW 3.6 km/h 6.5 km/h 995.40 hPa 0.00 mm 1.09 mm 0 3.5 w/m² 8:09 AM 12.8 °C 12.7 °C 99 % SW 3.1 km/h 5.6 km/h 995.40 hPa 0.00 mm 1.09 mm 0 4 w/m² 8:14 AM 12.8 °C 12.7 °C 99 % SSW 2.6 km/h 6.2 km/h 995.50 hPa 0.00 mm 1.09 mm 0 7.4 w/m² 8:19 AM 12.8 °C 12.7 °C 99 % SW 3.0 km/h 5.9 km/h 995.50 hPa 0.00 mm 1.09 mm 0 7.5 w/m² 8:24 AM 12.8 °C 12.7 °C 99 % SW 3.6 km/h 7.3 km/h 995.70 hPa 0.00 mm 1.09 mm 0 7.8 w/m² 8:29 AM 12.7 °C 12.6 °C 99 % SW 2.6 km/h 5.6 km/h 995.50 hPa 0.00 mm 1.09 mm 0 10 w/m² 8:34 AM 12.7 °C 12.6 °C 99 % SSW 3.2 km/h 5.4 km/h 995.70 hPa 0.00 mm 1.09 mm 0 10.7 w/m² 8:39 AM 12.7 °C 12.6 °C 99 % SW 3.3 km/h 6.5 km/h 995.80 hPa 0.00 mm 1.09 mm 0 17.2 w/m² 8:44 AM 12.6 °C 12.5 °C 99 % SSW 4.7 km/h 9.9 km/h 995.70 hPa 0.00 mm 1.09 mm 0 18.9 w/m² 8:49 AM 12.6 °C 12.5 °C 99 % SW 3.7 km/h 6.3 km/h 995.70 hPa 0.00 mm 1.09 mm 0 22.7 w/m² 8:54 AM 12.6 °C 12.5 °C 99 % SSW 3.2 km/h 6.3 km/h 995.90 hPa 0.00 mm 1.09 mm 0 25.3 w/m² 8:59 AM 12.6 °C 12.4 °C 99 % SSW 3.9 km/h 7.2 km/h 995.90 hPa 0.00 mm 1.09 mm 0 27.5 w/m² 9:04 AM 12.6 °C 12.3 °C 98 % SSW 2.2 km/h 5.4 km/h 995.90 hPa 0.00 mm 1.09 mm 0 26.4 w/m² 9:09 AM 12.6 °C 12.5 °C 99 % SSW 2.6 km/h 5.3 km/h 995.90 hPa 0.00 mm 1.09 mm 0 30.9 w/m² 9:14 AM 12.6 °C 12.4 °C 98 % SSW 4.1 km/h 7.4 km/h 996.00 hPa 0.00 mm 1.09 mm 0 31.2 w/m² 9:19 AM 12.6 °C 12.3 °C 98 % SSW 4.3 km/h 7.7 km/h 996.00 hPa 0.00 mm 1.09 mm 0 34 w/m² 9:24 AM 12.6 °C 12.3 °C 98 % SSW 3.3 km/h 6.7 km/h 996.00 hPa 0.00 mm 1.09 mm 0 32.1 w/m² 9:29 AM 12.7 °C 12.4 °C 98 % SSW 3.9 km/h 7.8 km/h 996.00 hPa 0.00 mm 1.09 mm 0 22.9 w/m² 9:34 AM 12.6 °C 12.3 °C 98 % SSW 3.5 km/h 6.8 km/h 996.21 hPa 0.00 mm 1.09 mm 0 38.5 w/m² 9:39 AM 12.6 °C 12.3 °C 98 % South 3.2 km/h 6.8 km/h 996.00 hPa 0.00 mm 1.09 mm 0 56.4 w/m² 9:44 AM 12.6 °C 12.3 °C 97 % SW 4.1 km/h 7.0 km/h 996.21 hPa 0.00 mm 1.09 mm 0 55.5 w/m² 9:49 AM 12.6 °C 12.2 °C 97 % SSW 3.5 km/h 8.6 km/h 996.11 hPa 0.00 mm 1.09 mm 0 51.6 w/m² 9:54 AM 12.6 °C 12.0 °C 96 % SW 5.6 km/h 9.9 km/h 996.11 hPa 0.00 mm 1.09 mm 0 56.1 w/m² 9:59 AM 12.6 °C 11.8 °C 95 % SSW 6.0 km/h 10.6 km/h 996.31 hPa 0.00 mm 1.09 mm 0 57.6 w/m² 10:04 AM 12.7 °C 11.9 °C 95 % SW 1.9 km/h 6.5 km/h 996.21 hPa 0.00 mm 1.09 mm 0 68.8 w/m² 10:09 AM 12.6 °C 11.8 °C 95 % SW 3.6 km/h 5.8 km/h 996.11 hPa 0.00 mm 1.09 mm 0 82.8 w/m² 10:14 AM 12.7 °C 11.8 °C 94 % SSW 4.2 km/h 7.9 km/h 996.31 hPa 0.00 mm 1.09 mm 0 73 w/m² 10:19 AM 12.7 °C 11.9 °C 95 % SSW 3.8 km/h 6.8 km/h 996.21 hPa 0.00 mm 1.09 mm 1 120.9 w/m² 10:24 AM 12.8 °C 12.0 °C 95 % SW 5.1 km/h 8.7 km/h 996.31 hPa 0.00 mm 1.09 mm 0 103 w/m² 10:29 AM 12.8 °C 11.8 °C 94 % SW 5.4 km/h 11.7 km/h 996.31 hPa 0.00 mm 1.09 mm 0 80 w/m² 10:34 AM 12.8 °C 11.7 °C 93 % SSW 6.3 km/h 11.4 km/h 996.51 hPa 0.00 mm 1.09 mm 0 81.6 w/m² 10:39 AM 12.9 °C 11.7 °C 93 % SSW 4.4 km/h 9.5 km/h 996.41 hPa 0.00 mm 1.09 mm 0 82.6 w/m² 10:44 AM 12.9 °C 11.9 °C 93 % SW 3.8 km/h 7.3 km/h 996.41 hPa 0.00 mm 1.09 mm 0 62.9 w/m² 10:49 AM 12.8 °C 11.8 °C 93 % SSW 4.5 km/h 8.0 km/h 996.21 hPa 0.00 mm 1.09 mm 0 97.6 w/m² 10:54 AM 12.8 °C 11.9 °C 94 % SSW 1.7 km/h 6.2 km/h 996.21 hPa 0.00 mm 1.09 mm 1 113.7 w/m² 10:59 AM 12.9 °C 12.0 °C 94 % South 2.9 km/h 5.6 km/h 996.11 hPa 0.00 mm 1.09 mm 0 104.7 w/m² 11:04 AM 13.1 °C 12.2 °C 94 % South 4.9 km/h 8.2 km/h 996.21 hPa 0.00 mm 1.09 mm 0 59.5 w/m² 11:09 AM 12.9 °C 12.2 °C 95 % SSW 4.1 km/h 8.2 km/h 996.21 hPa 0.00 mm 1.09 mm 1 160.5 w/m² 11:14 AM 13.0 °C 12.4 °C 96 % SW 4.8 km/h 7.4 km/h 996.21 hPa 0.00 mm 1.09 mm 0 89.9 w/m² 11:19 AM 12.9 °C 12.3 °C 96 % SSW 5.9 km/h 10.6 km/h 996.21 hPa 0.00 mm 1.09 mm 0 44.4 w/m² 11:24 AM 12.9 °C 12.3 °C 96 % SW 4.9 km/h 8.1 km/h 996.11 hPa 0.00 mm 1.09 mm 0 61.6 w/m² 11:29 AM 12.9 °C 12.3 °C 96 % SW 5.7 km/h 12.0 km/h 996.00 hPa 0.00 mm 1.09 mm 0 106.6 w/m² 11:34 AM 12.9 °C 12.5 °C 97 % SSW 5.3 km/h 9.6 km/h 996.00 hPa 0.00 mm 1.09 mm 1 144.1 w/m² 11:39 AM 12.9 °C 12.5 °C 97 % SW 5.7 km/h 9.4 km/h 995.90 hPa 0.00 mm 1.09 mm 1 143 w/m² 11:44 AM 12.9 °C 12.5 °C 97 % SW 5.4 km/h 10.9 km/h 996.00 hPa 0.00 mm 1.09 mm 0 57.6 w/m² 11:49 AM 12.9 °C 12.5 °C 97 % SW 5.0 km/h 9.3 km/h 996.11 hPa 1.19 mm 1.30 mm 0 55.7 w/m² 11:54 AM 12.8 °C 12.4 °C 98 % SSW 5.2 km/h 10.4 km/h 996.00 hPa 1.19 mm 1.30 mm 2 238.3 w/m² 11:59 AM 12.9 °C 12.6 °C 98 % SSW 8.2 km/h 14.2 km/h 995.90 hPa 1.19 mm 1.30 mm 2 282.3 w/m² 12:04 PM 13.2 °C 12.9 °C 98 % SSW 8.0 km/h 15.2 km/h 996.00 hPa 0.00 mm 1.30 mm 1 136.3 w/m² 12:09 PM 13.1 °C 12.7 °C 97 % SW 9.4 km/h 18.1 km/h 995.90 hPa 0.00 mm 1.30 mm 0 101.6 w/m² 12:14 PM 13.0 °C 12.6 °C 97 % SW 7.6 km/h 13.7 km/h 995.80 hPa 0.00 mm 1.30 mm 0 83.7 w/m² 12:19 PM 13.0 °C 12.6 °C 97 % SSW 8.1 km/h 15.5 km/h 995.90 hPa 0.00 mm 1.30 mm 0 69.1 w/m² 12:24 PM 12.9 °C 12.5 °C 97 % SW 7.3 km/h 15.3 km/h 995.90 hPa 0.00 mm 1.30 mm 0 49 w/m² 12:29 PM 12.9 °C 12.5 °C 97 % SSW 6.7 km/h 13.4 km/h 995.90 hPa 0.00 mm 1.30 mm 0 45.4 w/m² 12:34 PM 12.9 °C 12.5 °C 97 % SSW 6.1 km/h 10.9 km/h 995.70 hPa 0.00 mm 1.30 mm 0 36.7 w/m² 12:39 PM 12.8 °C 12.4 °C 97 % SSW 6.2 km/h 11.1 km/h 995.70 hPa 0.00 mm 1.30 mm 0 39.5 w/m² 12:44 PM 12.8 °C 12.5 °C 98 % SW 7.5 km/h 14.1 km/h 995.70 hPa 3.00 mm 1.80 mm 0 33.2 w/m² 12:49 PM 12.6 °C 12.3 °C 98 % SW 8.9 km/h 14.7 km/h 995.50 hPa 3.00 mm 1.80 mm 0 78.9 w/m² 12:54 PM 12.7 °C 12.5 °C 99 % SW 8.2 km/h 16.8 km/h 995.60 hPa 0.61 mm 1.80 mm 0 84.4 w/m² 12:59 PM 12.7 °C 12.6 °C 99 % SW 11.4 km/h 21.7 km/h 995.50 hPa 0.00 mm 1.80 mm 0 28.5 w/m² 1:04 PM 12.8 °C 12.7 °C 99 % SW 9.3 km/h 18.5 km/h 995.50 hPa 1.19 mm 2.01 mm 0 34.1 w/m² 1:09 PM 12.7 °C 12.6 °C 99 % SW 7.1 km/h 16.6 km/h 995.50 hPa 1.19 mm 2.01 mm 0 47 w/m² 1:14 PM 12.8 °C 12.7 °C 99 % SW 8.4 km/h 16.5 km/h 995.40 hPa 1.19 mm 2.01 mm 0 41.7 w/m² 1:19 PM 12.7 °C 12.6 °C 99 % SSW 6.5 km/h 13.2 km/h 995.50 hPa 0.00 mm 2.01 mm 0 78.8 w/m² 1:24 PM 12.7 °C 12.6 °C 99 % SSW 7.3 km/h 12.8 km/h 995.40 hPa 0.61 mm 2.11 mm 0 81.9 w/m² 1:29 PM 12.6 °C 12.5 °C 99 % SW 7.7 km/h 15.9 km/h 995.29 hPa 0.61 mm 2.11 mm 1 115.4 w/m² 1:34 PM 12.6 °C 12.5 °C 99 % SW 8.2 km/h 17.1 km/h 995.40 hPa 0.61 mm 2.11 mm 0 54.9 w/m² 1:39 PM 12.6 °C 12.5 °C 99 % SW 8.6 km/h 18.2 km/h 995.29 hPa 0.61 mm 2.21 mm 0 45.1 w/m² 1:44 PM 12.5 °C 12.4 °C 99 % SW 9.6 km/h 15.8 km/h 995.29 hPa 0.61 mm 2.21 mm 0 84.4 w/m² 1:49 PM 12.6 °C 12.5 °C 99 % SW 8.7 km/h 17.1 km/h 995.19 hPa 0.61 mm 2.21 mm 0 47.1 w/m² 1:54 PM 12.5 °C 12.4 °C 99 % SW 8.2 km/h 15.0 km/h 995.19 hPa 0.00 mm 2.21 mm 0 89.3 w/m² 1:59 PM 12.5 °C 12.4 °C 99 % SW 7.6 km/h 15.9 km/h 995.09 hPa 0.00 mm 2.21 mm 0 68.6 w/m² 2:04 PM 12.5 °C 12.4 °C 99 % SSW 9.9 km/h 18.2 km/h 994.99 hPa 0.00 mm 2.21 mm 0 60.7 w/m² 2:09 PM 12.5 °C 12.4 °C 99 % SW 10.4 km/h 18.5 km/h 995.09 hPa 0.00 mm 2.21 mm 0 73.2 w/m² 2:14 PM 12.5 °C 12.3 °C 99 % SW 8.6 km/h 16.5 km/h 994.99 hPa 0.00 mm 2.21 mm 0 75 w/m² 2:19 PM 12.4 °C 12.1 °C 98 % SW 7.7 km/h 15.7 km/h 995.09 hPa 0.00 mm 2.21 mm 0 57.5 w/m² 2:24 PM 12.5 °C 12.2 °C 98 % SSW 7.6 km/h 14.4 km/h 994.99 hPa 0.00 mm 2.21 mm 0 64.8 w/m² 2:29 PM 12.5 °C 12.2 °C 98 % SW 7.1 km/h 12.5 km/h 995.19 hPa 0.00 mm 2.21 mm 0 52.3 w/m² 2:34 PM 12.5 °C 12.3 °C 99 % SW 6.9 km/h 12.5 km/h 994.99 hPa 0.00 mm 2.21 mm 0 36.2 w/m² 2:39 PM 12.5 °C 12.4 °C 99 % SW 7.4 km/h 13.5 km/h 995.09 hPa 0.00 mm 2.21 mm 0 42.7 w/m² 2:44 PM 12.5 °C 12.4 °C 99 % SW 6.6 km/h 12.9 km/h 995.19 hPa 0.00 mm 2.21 mm 0 40.3 w/m² 2:49 PM 12.4 °C 12.3 °C 99 % SW 6.1 km/h 10.6 km/h 995.09 hPa 0.00 mm 2.21 mm 0 42.5 w/m² 2:54 PM 12.4 °C 12.3 °C 99 % SSW 6.1 km/h 9.3 km/h 994.99 hPa 0.61 mm 2.31 mm 0 44.7 w/m² 2:59 PM 12.4 °C 12.3 °C 99 % SW 6.4 km/h 10.0 km/h 995.09 hPa 0.61 mm 2.31 mm 0 35.4 w/m² 3:04 PM 12.4 °C 12.3 °C 99 % SSW 5.7 km/h 10.5 km/h 994.99 hPa 0.61 mm 2.31 mm 0 52.3 w/m² 3:09 PM 12.4 °C 12.3 °C 99 % SSW 6.2 km/h 13.5 km/h 995.09 hPa 0.00 mm 2.31 mm 0 27.4 w/m² 3:14 PM 12.4 °C 12.3 °C 99 % SW 5.0 km/h 9.6 km/h 995.19 hPa 0.00 mm 2.31 mm 0 40.3 w/m² 3:19 PM 12.4 °C 12.3 °C 99 % SW 6.3 km/h 11.3 km/h 995.29 hPa 0.00 mm 2.31 mm 0 28.3 w/m² 3:24 PM 12.4 °C 12.3 °C 99 % SW 6.3 km/h 12.6 km/h 995.50 hPa 0.00 mm 2.31 mm 0 23.6 w/m² 3:29 PM 12.3 °C 12.2 °C 99 % SW 5.2 km/h 10.7 km/h 995.29 hPa 0.00 mm 2.31 mm 0 19.2 w/m² 3:34 PM 12.3 °C 12.2 °C 99 % SSW 3.8 km/h 9.0 km/h 995.40 hPa 0.00 mm 2.31 mm 0 14.1 w/m² 3:39 PM 12.3 °C 12.2 °C 99 % SW 5.1 km/h 9.2 km/h 995.50 hPa 0.00 mm 2.31 mm 0 17.5 w/m² 3:44 PM 12.3 °C 12.2 °C 99 % SW 3.8 km/h 8.2 km/h 995.50 hPa 0.00 mm 2.31 mm 0 17.9 w/m² 3:49 PM 12.2 °C 11.9 °C 98 % SW 7.6 km/h 12.7 km/h 995.50 hPa 0.00 mm 2.31 mm 0 17.6 w/m² 3:54 PM 12.0 °C 11.6 °C 97 % SW 5.7 km/h 12.9 km/h 995.50 hPa 0.00 mm 2.31 mm 0 12.9 w/m² 3:59 PM 12.0 °C 11.6 °C 97 % SW 6.8 km/h 12.4 km/h 995.50 hPa 0.00 mm 2.31 mm 0 8.8 w/m² 4:04 PM 12.0 °C 11.4 °C 96 % SW 6.3 km/h 12.4 km/h 995.60 hPa 0.00 mm 2.31 mm 0 5.8 w/m² 4:09 PM 12.0 °C 11.4 °C 96 % WSW 4.6 km/h 9.5 km/h 995.60 hPa 0.00 mm 2.31 mm 0 5.5 w/m² 4:14 PM 11.9 °C 11.3 °C 96 % SW 4.3 km/h 9.3 km/h 995.60 hPa 0.00 mm 2.31 mm 0 4.4 w/m² 4:19 PM 11.9 °C 11.3 °C 96 % SW 4.3 km/h 9.3 km/h 995.50 hPa 0.00 mm 2.31 mm 0 2.1 w/m² 4:24 PM 11.9 °C 11.5 °C 97 % WSW 4.6 km/h 9.3 km/h 995.70 hPa 0.00 mm 2.31 mm 0 1.7 w/m² 4:29 PM 11.8 °C 11.4 °C 97 % SW 4.4 km/h 8.8 km/h 995.40 hPa 0.00 mm 2.31 mm 0 0.8 w/m² 4:34 PM 11.8 °C 11.5 °C 98 % SSW 5.3 km/h 9.4 km/h 995.70 hPa 0.00 mm 2.31 mm 0 0.2 w/m² 4:39 PM 11.7 °C 11.4 °C 98 % SW 3.8 km/h 8.0 km/h 995.60 hPa 0.00 mm 2.31 mm 0 0.2 w/m² 4:44 PM 11.7 °C 11.4 °C 98 % SSW 2.9 km/h 6.4 km/h 995.40 hPa 0.00 mm 2.31 mm 0 0.1 w/m² 4:49 PM 11.7 °C 11.4 °C 98 % SSW 3.7 km/h 6.7 km/h 995.70 hPa 0.00 mm 2.31 mm 0 0 w/m² 4:54 PM 11.7 °C 11.6 °C 99 % SSW 3.1 km/h 7.3 km/h 995.60 hPa 0.61 mm 2.39 mm 0 0 w/m² 4:59 PM 11.7 °C 11.6 °C 99 % SSW 3.9 km/h 8.0 km/h 995.70 hPa 1.19 mm 2.49 mm 0 0 w/m² 5:04 PM 11.7 °C 11.6 °C 99 % SW 3.7 km/h 7.4 km/h 995.70 hPa 1.19 mm 2.49 mm 0 0 w/m² 5:09 PM 11.7 °C 11.6 °C 99 % SW 3.2 km/h 7.6 km/h 995.70 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:14 PM 11.7 °C 11.6 °C 99 % SW 3.6 km/h 7.6 km/h 995.70 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:19 PM 11.7 °C 11.6 °C 99 % SW 5.9 km/h 8.4 km/h 995.60 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:24 PM 11.6 °C 11.5 °C 99 % SW 6.2 km/h 11.7 km/h 995.90 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:29 PM 11.5 °C 11.2 °C 98 % SW 6.4 km/h 13.0 km/h 995.80 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:34 PM 11.5 °C 11.2 °C 98 % SW 6.4 km/h 9.7 km/h 995.70 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:39 PM 11.5 °C 11.1 °C 97 % SW 3.9 km/h 9.1 km/h 995.80 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:44 PM 11.4 °C 11.0 °C 97 % SW 2.9 km/h 5.7 km/h 995.80 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:49 PM 11.3 °C 11.0 °C 98 % SSW 2.2 km/h 5.7 km/h 995.80 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:54 PM 11.3 °C 11.0 °C 98 % WSW 2.7 km/h 5.7 km/h 995.90 hPa 0.00 mm 2.49 mm 0 0 w/m² 5:59 PM 11.3 °C 11.0 °C 98 % South 2.4 km/h 5.2 km/h 996.00 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:04 PM 11.2 °C 10.9 °C 98 % SSW 2.6 km/h 5.5 km/h 996.11 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:09 PM 11.3 °C 11.0 °C 98 % West 2.6 km/h 6.0 km/h 996.11 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:14 PM 11.3 °C 11.2 °C 99 % SW 2.7 km/h 5.5 km/h 996.11 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:19 PM 11.3 °C 11.2 °C 99 % SSW 3.6 km/h 6.9 km/h 996.31 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:24 PM 11.2 °C 11.1 °C 99 % SW 2.7 km/h 5.8 km/h 996.00 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:29 PM 11.0 °C 10.9 °C 99 % SSE 2.2 km/h 4.0 km/h 996.00 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:34 PM 10.9 °C 10.8 °C 99 % SW 2.1 km/h 4.0 km/h 996.21 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:39 PM 11.0 °C 10.9 °C 99 % SSW 2.9 km/h 6.1 km/h 996.31 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:44 PM 11.0 °C 10.9 °C 99 % SSW 2.5 km/h 5.6 km/h 996.11 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:49 PM 11.0 °C 10.9 °C 99 % WSW 2.1 km/h 4.1 km/h 996.21 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:54 PM 11.0 °C 10.9 °C 99 % SW 2.5 km/h 4.4 km/h 996.31 hPa 0.00 mm 2.49 mm 0 0 w/m² 6:59 PM 11.0 °C 10.9 °C 99 % SSW 1.8 km/h 4.2 km/h 996.21 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:04 PM 11.0 °C 10.9 °C 99 % SE 1.9 km/h 4.3 km/h 996.11 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:09 PM 11.0 °C 10.9 °C 99 % South 2.5 km/h 5.1 km/h 996.31 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:14 PM 11.0 °C 10.9 °C 99 % SSW 5.7 km/h 9.4 km/h 996.31 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:19 PM 11.0 °C 10.9 °C 99 % SW 4.4 km/h 9.1 km/h 996.21 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:24 PM 11.0 °C 10.9 °C 99 % SSW 3.5 km/h 7.6 km/h 996.21 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:29 PM 11.0 °C 10.9 °C 99 % SW 5.1 km/h 9.1 km/h 996.21 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:34 PM 11.0 °C 10.9 °C 99 % SSW 5.3 km/h 9.1 km/h 996.41 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:39 PM 11.1 °C 11.0 °C 99 % SW 4.1 km/h 8.6 km/h 996.31 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:44 PM 11.0 °C 10.9 °C 99 % WNW 2.2 km/h 5.6 km/h 996.21 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:49 PM 11.0 °C 10.9 °C 99 % SW 2.8 km/h 5.6 km/h 996.41 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:54 PM 11.0 °C 10.9 °C 99 % SW 3.1 km/h 5.8 km/h 996.41 hPa 0.00 mm 2.49 mm 0 0 w/m² 7:59 PM 11.0 °C 10.9 °C 99 % WSW 3.6 km/h 7.0 km/h 996.41 hPa 0.61 mm 2.59 mm 0 0 w/m² 8:04 PM 11.0 °C 10.9 °C 99 % SW 3.4 km/h 6.0 km/h 996.31 hPa 0.61 mm 2.59 mm 0 0 w/m² 8:09 PM 11.0 °C 10.9 °C 99 % SSW 3.0 km/h 6.2 km/h 996.21 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:14 PM 11.0 °C 10.9 °C 99 % SSW 3.8 km/h 6.7 km/h 996.31 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:19 PM 11.0 °C 10.9 °C 99 % SW 4.7 km/h 8.3 km/h 996.21 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:24 PM 11.0 °C 10.9 °C 99 % SSW 3.5 km/h 7.1 km/h 996.31 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:29 PM 11.0 °C 10.9 °C 99 % SSW 3.0 km/h 6.1 km/h 996.31 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:34 PM 11.0 °C 10.9 °C 99 % SSW 3.6 km/h 6.6 km/h 996.31 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:39 PM 11.0 °C 10.9 °C 99 % SSW 3.1 km/h 6.6 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:44 PM 11.0 °C 10.9 °C 99 % SSW 3.1 km/h 6.0 km/h 996.51 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:49 PM 11.0 °C 10.9 °C 99 % SSW 2.7 km/h 5.5 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:54 PM 11.0 °C 10.9 °C 99 % SSW 3.3 km/h 6.1 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 8:59 PM 11.0 °C 10.9 °C 99 % SSW 3.3 km/h 6.1 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:04 PM 10.9 °C 10.8 °C 99 % SSW 3.7 km/h 7.3 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:09 PM 10.9 °C 10.8 °C 99 % SSW 3.7 km/h 7.4 km/h 996.61 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:14 PM 10.8 °C 10.7 °C 99 % SW 3.6 km/h 7.3 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:19 PM 10.8 °C 10.7 °C 99 % SW 4.3 km/h 8.6 km/h 996.31 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:24 PM 10.8 °C 10.7 °C 99 % SSW 4.3 km/h 8.6 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:29 PM 10.7 °C 10.6 °C 99 % SW 3.6 km/h 6.4 km/h 996.61 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:34 PM 10.7 °C 10.6 °C 99 % SW 2.4 km/h 6.8 km/h 996.51 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:39 PM 10.7 °C 10.6 °C 99 % SSW 3.1 km/h 6.3 km/h 996.51 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:44 PM 10.7 °C 10.6 °C 99 % SSW 3.2 km/h 6.6 km/h 996.61 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:49 PM 10.7 °C 10.6 °C 99 % SSW 2.2 km/h 5.3 km/h 996.61 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:54 PM 10.6 °C 10.5 °C 99 % SW 2.6 km/h 5.8 km/h 996.51 hPa 0.00 mm 2.59 mm 0 0 w/m² 9:59 PM 10.6 °C 10.5 °C 99 % SSW 2.5 km/h 5.3 km/h 996.61 hPa 0.00 mm 2.59 mm 0 0 w/m² 10:04 PM 10.6 °C 10.5 °C 99 % SW 3.4 km/h 6.7 km/h 996.51 hPa 0.00 mm 2.59 mm 0 0 w/m² 10:09 PM 10.6 °C 10.5 °C 99 % SW 3.0 km/h 6.2 km/h 996.51 hPa 0.00 mm 2.59 mm 0 0 w/m² 10:14 PM 10.6 °C 10.5 °C 99 % SW 3.5 km/h 6.5 km/h 996.51 hPa 0.00 mm 2.59 mm 0 0 w/m² 10:19 PM 10.6 °C 10.5 °C 99 % SW 3.1 km/h 6.3 km/h 996.41 hPa 0.00 mm 2.59 mm 0 0 w/m² 10:24 PM 10.6 °C 10.5 °C 99 % SW 3.3 km/h 8.1 km/h 996.31 hPa 0.00 mm 2.59 mm 0 0 w/m² 10:29 PM 10.6 °C 10.5 °C 99 % SW 5.1 km/h 8.7 km/h 996.61 hPa 0.61 mm 2.69 mm 0 0 w/m² 10:34 PM 10.6 °C 10.5 °C 99 % SSW 4.5 km/h 10.5 km/h 996.61 hPa 0.61 mm 2.69 mm 0 0 w/m² 10:39 PM 10.7 °C 10.6 °C 99 % SW 4.4 km/h 7.7 km/h 996.61 hPa 1.19 mm 2.79 mm 0 0 w/m² 10:44 PM 10.6 °C 10.5 °C 99 % SW 5.6 km/h 9.0 km/h 996.61 hPa 0.61 mm 2.79 mm 0 0 w/m² 10:49 PM 10.6 °C 10.5 °C 99 % SSW 3.9 km/h 8.2 km/h 996.51 hPa 0.61 mm 2.90 mm 0 0 w/m² 10:54 PM 10.6 °C 10.5 °C 99 % SW 2.8 km/h 6.7 km/h 996.51 hPa 0.61 mm 2.90 mm 0 0 w/m² 10:59 PM 10.5 °C 10.4 °C 99 % SW 3.1 km/h 6.8 km/h 996.61 hPa 0.61 mm 2.90 mm 0 0 w/m² 11:04 PM 10.4 °C 10.3 °C 99 % SW 3.1 km/h 6.7 km/h 996.61 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:09 PM 10.4 °C 10.3 °C 99 % SSW 3.8 km/h 8.3 km/h 996.82 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:14 PM 10.4 °C 10.3 °C 99 % SSW 2.4 km/h 5.1 km/h 996.72 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:19 PM 10.3 °C 10.2 °C 99 % SW 1.9 km/h 4.7 km/h 996.82 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:24 PM 10.1 °C 10.0 °C 99 % SSE 1.8 km/h 4.4 km/h 996.82 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:29 PM 10.0 °C 9.9 °C 99 % SSW 2.3 km/h 5.0 km/h 996.82 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:34 PM 9.9 °C 9.8 °C 99 % SSW 3.0 km/h 7.3 km/h 996.89 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:39 PM 9.8 °C 9.7 °C 99 % SSW 2.5 km/h 5.1 km/h 996.82 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:44 PM 9.7 °C 9.6 °C 99 % South 2.5 km/h 4.6 km/h 996.82 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:49 PM 9.5 °C 9.4 °C 99 % SSW 1.6 km/h 4.6 km/h 996.99 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:54 PM 9.4 °C 9.3 °C 99 % SSE 2.4 km/h 5.1 km/h 996.99 hPa 0.00 mm 2.90 mm 0 0 w/m² 11:59 PM 9.5 °C 9.4 °C 99 % SSW 5.1 km/h 7.8 km/h 997.09 hPa 0.00 mm 2.90 mm 0 0 w/m² December 2, 2024 Time Temperature Dew Point Humidity Wind Speed Gust Pressure Precip. Rate. Precip. Accum. UV Solar 12:04 AM 9.6 °C 9.3 °C 98 % SSW 5.4 km/h 9.1 km/h 997.29 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:09 AM 9.6 °C 9.3 °C 98 % SSW 2.8 km/h 6.9 km/h 997.39 hPa 0.61 mm 0.10 mm 0 0 w/m² 12:14 AM 9.7 °C 9.4 °C 98 % SSW 3.2 km/h 6.6 km/h 997.19 hPa 0.61 mm 0.10 mm 0 0 w/m² 12:19 AM 9.7 °C 9.4 °C 98 % SSW 2.6 km/h 5.5 km/h 997.09 hPa 0.00 mm 0.10 mm 0 0 w/m² 12:24 AM 9.6 °C 9.3 °C 98 % South 2.6 km/h 5.0 km/h 997.19 hPa 0.00 mm 0.10 mm 0 0 w/m² 12:29 AM 9.7 °C 9.5 °C 99 % SSW 2.9 km/h 5.9 km/h 997.19 hPa 1.19 mm 0.30 mm 0 0 w/m² 12:34 AM 9.6 °C 9.3 °C 98 % SSW 5.8 km/h 11.8 km/h 997.29 hPa 1.19 mm 0.30 mm 0 0 w/m² 12:39 AM 9.5 °C 9.2 °C 98 % SSW 4.5 km/h 8.6 km/h 997.29 hPa 1.19 mm 0.30 mm 0 0 w/m² 12:44 AM 9.5 °C 9.1 °C 97 % SSW 3.1 km/h 6.8 km/h 997.29 hPa 0.00 mm 0.30 mm 0 0 w/m² 12:49 AM 9.5 °C 9.1 °C 97 % SSW 3.4 km/h 7.2 km/h 997.19 hPa 0.00 mm 0.30 mm 0 0 w/m² 12:54 AM 9.4 °C 9.0 °C 97 % SW 2.8 km/h 6.1 km/h 997.39 hPa 0.00 mm 0.30 mm 0 0 w/m² 12:59 AM 9.2 °C 8.8 °C 97 % South 2.5 km/h 5.7 km/h 997.29 hPa 0.00 mm 0.30 mm 0 0 w/m² 1:04 AM 9.0 °C 8.6 °C 97 % SSE 2.2 km/h 5.2 km/h 997.19 hPa 0.00 mm 0.30 mm 0 0 w/m² 1:09 AM 8.9 °C 8.4 °C 97 % SW 2.3 km/h 4.9 km/h 997.29 hPa 0.00 mm 0.30 mm 0 0 w/m² 1:14 AM 8.6 °C 8.2 °C 97 % West 2.0 km/h 3.7 km/h 997.19 hPa 0.00 mm 0.30 mm 0 0 w/m² 1:19 AM 8.6 °C 8.3 °C 98 % ESE 1.7 km/h 4.1 km/h 997.60 hPa 0.00 mm 0.30 mm 0 0 w/m² 1:24 AM 8.6 °C 8.3 °C 98 % North 1.8 km/h 4.2 km/h 997.39 hPa 0.00 mm 0.30 mm 0 0 w/m² 1:29 AM 8.6 °C 8.3 °C 98 % SE 1.3 km/h 3.6 km/h 997.29 hPa 0.61 mm 0.41 mm 0 0 w/m² 1:34 AM 8.6 °C 8.4 °C 99 % SE 1.5 km/h 4.3 km/h 997.39 hPa 0.61 mm 0.41 mm 0 0 w/m² 1:39 AM 8.5 °C 8.4 °C 99 % ESE 1.6 km/h 4.2 km/h 997.39 hPa 0.61 mm 0.41 mm 0 0 w/m² 1:44 AM 8.4 °C 8.3 °C 99 % ENE 1.6 km/h 4.1 km/h 997.39 hPa 0.00 mm 0.41 mm 0 0 w/m² 1:49 AM 8.2 °C 8.1 °C 99 % NNE 1.0 km/h 3.7 km/h 997.29 hPa 0.00 mm 0.41 mm 0 0 w/m² 1:54 AM 8.1 °C 8.0 °C 99 % ENE 1.4 km/h 3.7 km/h 997.49 hPa 0.00 mm 0.41 mm 0 0 w/m² 1:59 AM 8.1 °C 8.0 °C 99 % ESE 2.0 km/h 4.5 km/h 997.39 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:04 AM 8.0 °C 7.9 °C 99 % East 1.9 km/h 3.9 km/h 997.49 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:09 AM 7.9 °C 7.8 °C 99 % ENE 1.5 km/h 4.3 km/h 997.49 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:14 AM 7.8 °C 7.7 °C 99 % ENE 2.3 km/h 4.0 km/h 997.49 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:19 AM 7.8 °C 7.7 °C 99 % ENE 1.3 km/h 4.0 km/h 997.49 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:24 AM 7.7 °C 7.6 °C 99 % ESE 1.3 km/h 4.1 km/h 997.70 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:29 AM 7.5 °C 7.4 °C 99 % East 1.4 km/h 3.9 km/h 997.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:34 AM 7.4 °C 7.3 °C 99 % East 2.1 km/h 4.2 km/h 997.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:39 AM 7.2 °C 7.1 °C 99 % SE 1.1 km/h 4.2 km/h 997.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:44 AM 7.1 °C 7.0 °C 99 % East 1.8 km/h 4.1 km/h 997.39 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:49 AM 7.0 °C 6.9 °C 99 % ENE 2.3 km/h 4.1 km/h 997.39 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:54 AM 6.9 °C 6.8 °C 99 % East 1.9 km/h 4.2 km/h 997.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 2:59 AM 6.8 °C 6.7 °C 99 % East 1.9 km/h 4.5 km/h 997.60 hPa 0.00 mm 0.41 mm 0 0 w/m² 3:04 AM 7.0 °C 6.9 °C 99 % WNW 1.5 km/h 3.8 km/h 997.70 hPa 0.61 mm 0.51 mm 0 0 w/m² 3:09 AM 7.1 °C 7.0 °C 99 % ESE 1.9 km/h 4.2 km/h 997.49 hPa 1.19 mm 0.61 mm 0 0 w/m² 3:14 AM 7.2 °C 7.1 °C 99 % ESE 1.8 km/h 3.9 km/h 997.60 hPa 1.19 mm 0.61 mm 0 0 w/m² 3:19 AM 7.3 °C 7.2 °C 99 % East 2.3 km/h 4.6 km/h 997.49 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:24 AM 7.4 °C 7.3 °C 99 % East 1.6 km/h 3.9 km/h 997.49 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:29 AM 7.4 °C 7.3 °C 99 % ESE 1.9 km/h 3.9 km/h 997.49 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:34 AM 7.4 °C 7.3 °C 99 % East 1.8 km/h 4.6 km/h 997.60 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:39 AM 7.4 °C 7.3 °C 99 % SSE 2.1 km/h 3.9 km/h 997.39 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:44 AM 7.4 °C 7.3 °C 99 % East 1.8 km/h 3.6 km/h 997.60 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:49 AM 7.4 °C 7.3 °C 99 % WSW 1.4 km/h 3.7 km/h 997.49 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:54 AM 7.4 °C 7.3 °C 99 % SE 1.5 km/h 3.9 km/h 997.70 hPa 0.00 mm 0.61 mm 0 0 w/m² 3:59 AM 7.5 °C 7.4 °C 99 % ESE 2.0 km/h 4.4 km/h 997.60 hPa 1.19 mm 0.79 mm 0 0 w/m² 4:04 AM 7.5 °C 7.4 °C 99 % SSW 2.5 km/h 5.7 km/h 997.70 hPa 1.19 mm 0.79 mm 0 0 w/m² 4:09 AM 7.6 °C 7.5 °C 99 % SSW 2.8 km/h 5.1 km/h 997.60 hPa 0.61 mm 0.79 mm 0 0 w/m² 4:14 AM 7.5 °C 7.4 °C 99 % SSW 2.0 km/h 5.1 km/h 997.70 hPa 0.00 mm 0.79 mm 0 0 w/m² 4:19 AM 7.5 °C 7.4 °C 99 % SSW 2.2 km/h 5.0 km/h 997.90 hPa 0.00 mm 0.79 mm 0 0 w/m² 4:24 AM 7.6 °C 7.5 °C 99 % SE 2.2 km/h 4.9 km/h 997.70 hPa 0.00 mm 0.79 mm 0 0 w/m² 4:29 AM 7.6 °C 7.5 °C 99 % NW 2.5 km/h 5.9 km/h 997.80 hPa 0.00 mm 0.79 mm 0 0 w/m² 4:34 AM 7.7 °C 7.6 °C 99 % South 2.3 km/h 5.0 km/h 997.70 hPa 0.61 mm 0.89 mm 0 0 w/m² 4:39 AM 7.7 °C 7.6 °C 99 % SSW 2.1 km/h 4.4 km/h 997.80 hPa 0.61 mm 0.89 mm 0 0 w/m² 4:44 AM 7.8 °C 7.7 °C 99 % SSW 2.6 km/h 5.0 km/h 997.80 hPa 0.00 mm 0.89 mm 0 0 w/m² 4:49 AM 7.9 °C 7.8 °C 99 % SSW 1.9 km/h 5.6 km/h 997.80 hPa 0.00 mm 0.89 mm 0 0 w/m² 4:54 AM 7.8 °C 7.7 °C 99 % SSW 1.5 km/h 3.9 km/h 997.90 hPa 0.00 mm 0.89 mm 0 0 w/m² 4:59 AM 7.7 °C 7.6 °C 99 % SW 2.4 km/h 4.7 km/h 998.00 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:04 AM 7.8 °C 7.7 °C 99 % SSW 3.7 km/h 7.7 km/h 997.90 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:09 AM 7.9 °C 7.7 °C 99 % SSW 3.6 km/h 8.5 km/h 998.10 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:14 AM 8.0 °C 7.7 °C 98 % SW 3.3 km/h 6.4 km/h 998.31 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:19 AM 8.0 °C 7.7 °C 98 % South 3.0 km/h 7.2 km/h 998.10 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:24 AM 7.9 °C 7.6 °C 98 % SSW 4.0 km/h 6.7 km/h 998.21 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:29 AM 7.9 °C 7.3 °C 96 % SSW 4.1 km/h 8.1 km/h 998.21 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:34 AM 7.9 °C 7.3 °C 96 % SSW 6.0 km/h 10.0 km/h 998.10 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:39 AM 7.8 °C 7.2 °C 95 % SSW 3.8 km/h 9.0 km/h 998.21 hPa 0.00 mm 0.89 mm 0 0 w/m² 5:44 AM 7.8 °C 7.2 °C 96 % SSW 5.2 km/h 12.3 km/h 998.41 hPa 0.61 mm 0.99 mm 0 0 w/m² 5:49 AM 7.9 °C 7.2 °C 95 % South 5.1 km/h 11.8 km/h 998.51 hPa 1.19 mm 1.09 mm 0 0 w/m² 5:54 AM 8.0 °C 7.3 °C 95 % South 4.4 km/h 8.6 km/h 998.51 hPa 1.19 mm 1.09 mm 0 0 w/m² 5:59 AM 8.0 °C 7.3 °C 95 % SSW 2.9 km/h 8.2 km/h 998.21 hPa 0.61 mm 1.09 mm 0 0 w/m² 6:04 AM 7.8 °C 7.1 °C 95 % South 3.0 km/h 4.9 km/h 998.41 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:09 AM 7.8 °C 7.1 °C 95 % SSE 2.6 km/h 6.1 km/h 998.51 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:14 AM 7.7 °C 7.1 °C 96 % South 2.6 km/h 6.6 km/h 998.31 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:19 AM 7.7 °C 7.0 °C 95 % SE 3.3 km/h 7.3 km/h 998.51 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:24 AM 7.6 °C 6.9 °C 95 % SE 1.8 km/h 5.3 km/h 998.51 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:29 AM 7.5 °C 6.8 °C 95 % ESE 2.8 km/h 6.1 km/h 998.61 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:34 AM 7.4 °C 6.8 °C 96 % East 1.8 km/h 4.8 km/h 998.71 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:39 AM 7.3 °C 6.8 °C 96 % East 2.9 km/h 5.3 km/h 998.92 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:44 AM 7.4 °C 7.0 °C 97 % SE 3.0 km/h 6.4 km/h 998.82 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:49 AM 7.5 °C 7.1 °C 97 % East 2.5 km/h 6.6 km/h 998.82 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:54 AM 7.6 °C 7.1 °C 97 % ESE 2.7 km/h 5.6 km/h 998.82 hPa 0.00 mm 1.09 mm 0 0 w/m² 6:59 AM 7.6 °C 7.2 °C 97 % SSE 2.3 km/h 4.9 km/h 998.92 hPa 0.61 mm 1.19 mm 0 0 w/m² 7:04 AM 7.6 °C 7.0 °C 96 % SSE 3.2 km/h 6.7 km/h 998.92 hPa 0.61 mm 1.19 mm 0 0 w/m² 7:09 AM 7.6 °C 7.0 °C 96 % South 3.9 km/h 8.1 km/h 998.98 hPa 0.61 mm 1.19 mm 0 0 w/m² 7:14 AM 7.7 °C 7.0 °C 95 % South 3.0 km/h 8.9 km/h 998.98 hPa 0.61 mm 1.30 mm 0 0 w/m² 7:19 AM 7.7 °C 6.8 °C 94 % SSE 3.3 km/h 7.8 km/h 998.92 hPa 1.19 mm 1.40 mm 0 0 w/m² 7:24 AM 7.6 °C 6.8 °C 95 % SE 1.9 km/h 5.2 km/h 999.09 hPa 1.19 mm 1.40 mm 0 0 w/m² 7:29 AM 7.5 °C 6.8 °C 95 % SE 2.0 km/h 4.7 km/h 999.19 hPa 0.61 mm 1.40 mm 0 0 w/m² 7:34 AM 7.6 °C 6.9 °C 96 % ESE 1.6 km/h 4.0 km/h 999.19 hPa 0.61 mm 1.50 mm 0 0.1 w/m² 7:39 AM 7.5 °C 6.9 °C 96 % SSE 2.0 km/h 4.6 km/h 999.19 hPa 0.61 mm 1.50 mm 0 0.3 w/m² 7:44 AM 7.5 °C 7.1 °C 97 % SE 1.9 km/h 3.6 km/h 999.29 hPa 0.61 mm 1.50 mm 0 0.9 w/m² 7:49 AM 7.4 °C 7.0 °C 97 % SE 1.8 km/h 4.4 km/h 999.29 hPa 0.00 mm 1.50 mm 0 1.6 w/m² 7:54 AM 7.3 °C 6.9 °C 97 % ESE 2.2 km/h 4.8 km/h 999.29 hPa 0.00 mm 1.50 mm 0 2.5 w/m² 7:59 AM 7.2 °C 6.8 °C 97 % ESE 2.1 km/h 4.5 km/h 999.49 hPa 0.00 mm 1.50 mm 0 4 w/m² 8:04 AM 7.1 °C 6.7 °C 97 % SSE 2.8 km/h 6.1 km/h 999.59 hPa 0.00 mm 1.50 mm 0 4.8 w/m² 8:09 AM 7.2 °C 6.7 °C 97 % SE 4.0 km/h 9.1 km/h 999.39 hPa 0.00 mm 1.50 mm 0 6.8 w/m² 8:14 AM 7.2 °C 6.6 °C 95 % SE 2.9 km/h 6.3 km/h 999.59 hPa 0.00 mm 1.50 mm 0 10.6 w/m² 8:19 AM 7.3 °C 6.6 °C 95 % SSE 2.2 km/h 5.1 km/h 999.59 hPa 0.00 mm 1.50 mm 0 14.1 w/m² 8:24 AM 7.4 °C 6.6 °C 95 % ESE 2.7 km/h 5.1 km/h 999.70 hPa 0.00 mm 1.50 mm 0 14.8 w/m² 8:29 AM 7.5 °C 6.6 °C 94 % ESE 2.9 km/h 6.1 km/h 999.80 hPa 0.00 mm 1.50 mm 0 14.1 w/m² 8:34 AM 7.4 °C 6.7 °C 95 % East 2.2 km/h 4.4 km/h 999.90 hPa 0.00 mm 1.50 mm 0 15.7 w/m² 8:39 AM 7.3 °C 6.4 °C 94 % ESE 2.6 km/h 5.8 km/h 1,000.00 hPa 0.00 mm 1.50 mm 0 20.8 w/m² 8:44 AM 7.2 °C 6.5 °C 95 % East 2.7 km/h 5.3 km/h 1,000.00 hPa 0.00 mm 1.50 mm 0 35.1 w/m² 8:49 AM 7.3 °C 6.4 °C 94 % ENE 1.9 km/h 5.7 km/h 1,000.20 hPa 0.00 mm 1.50 mm 0 33.9 w/m² 8:54 AM 7.5 °C 6.5 °C 93 % SE 2.6 km/h 6.9 km/h 1,000.10 hPa 0.00 mm 1.50 mm 0 23.7 w/m² 8:59 AM 7.4 °C 6.5 °C 94 % NE 1.3 km/h 4.4 km/h 1,000.41 hPa 0.00 mm 1.50 mm 0 38 w/m² 9:04 AM 7.8 °C 6.6 °C 92 % SSE 2.9 km/h 6.9 km/h 1,000.41 hPa 0.00 mm 1.50 mm 0 40.6 w/m² 9:09 AM 8.2 °C 6.7 °C 90 % SSE 3.5 km/h 7.1 km/h 1,000.41 hPa 0.00 mm 1.50 mm 0 41.5 w/m² 9:14 AM 8.3 °C 6.6 °C 89 % SE 2.0 km/h 5.6 km/h 1,000.51 hPa 0.00 mm 1.50 mm 0 52.3 w/m² 9:19 AM 8.3 °C 6.7 °C 90 % SE 1.7 km/h 5.4 km/h 1,000.71 hPa 0.00 mm 1.50 mm 0 64 w/m² 9:24 AM 8.4 °C 6.5 °C 87 % ESE 2.7 km/h 6.1 km/h 1,000.61 hPa 0.00 mm 1.50 mm 0 91 w/m² 9:29 AM 8.7 °C 6.8 °C 88 % ESE 2.6 km/h 6.6 km/h 1,000.91 hPa 0.00 mm 1.50 mm 1 114.1 w/m² 9:34 AM 8.8 °C 7.0 °C 89 % SE 5.8 km/h 9.8 km/h 1,000.61 hPa 0.00 mm 1.50 mm 0 51.4 w/m² 9:39 AM 8.5 °C 6.8 °C 89 % South 2.9 km/h 7.3 km/h 1,000.71 hPa 0.61 mm 1.60 mm 0 56.1 w/m² 9:44 AM 8.4 °C 6.7 °C 89 % East 2.7 km/h 5.1 km/h 1,000.81 hPa 0.61 mm 1.60 mm 0 49.3 w/m² 9:49 AM 8.6 °C 7.1 °C 90 % ESE 2.8 km/h 5.5 km/h 1,000.81 hPa 0.61 mm 1.60 mm 0 70.5 w/m² 9:54 AM 8.9 °C 7.1 °C 89 % East 3.4 km/h 6.6 km/h 1,000.91 hPa 0.00 mm 1.60 mm 0 74.9 w/m² 9:59 AM 9.0 °C 6.9 °C 86 % South 3.4 km/h 6.5 km/h 1,001.08 hPa 0.00 mm 1.60 mm 0 69.7 w/m² 10:04 AM 9.4 °C 6.7 °C 83 % SSE 4.3 km/h 9.4 km/h 1,001.08 hPa 0.00 mm 1.60 mm 0 94.2 w/m² 10:09 AM 9.6 °C 6.6 °C 82 % SE 4.6 km/h 10.3 km/h 1,001.19 hPa 0.00 mm 1.60 mm 1 115.8 w/m² 10:14 AM 10.0 °C 6.9 °C 81 % SE 3.0 km/h 7.6 km/h 1,001.08 hPa 0.00 mm 1.60 mm 1 112 w/m² 10:19 AM 10.2 °C 6.9 °C 80 % SSE 4.0 km/h 8.5 km/h 1,001.19 hPa 0.00 mm 1.60 mm 1 153 w/m² 10:24 AM 10.1 °C 6.9 °C 80 % SSW 4.4 km/h 7.7 km/h 1,001.19 hPa 0.00 mm 1.60 mm 0 73.9 w/m² 10:29 AM 9.7 °C 6.4 °C 80 % South 4.5 km/h 13.0 km/h 1,001.19 hPa 0.00 mm 1.60 mm 0 68.8 w/m² 10:34 AM 9.5 °C 6.6 °C 82 % ESE 4.6 km/h 9.5 km/h 1,001.39 hPa 0.00 mm 1.60 mm 0 65.7 w/m² 10:39 AM 9.1 °C 6.6 °C 84 % SE 3.6 km/h 8.7 km/h 1,001.59 hPa 0.00 mm 1.60 mm 0 102.7 w/m² 10:44 AM 9.2 °C 6.3 °C 82 % SE 3.7 km/h 9.1 km/h 1,001.59 hPa 0.00 mm 1.60 mm 1 149.3 w/m² 10:49 AM 9.6 °C 6.5 °C 81 % SE 2.6 km/h 6.1 km/h 1,001.69 hPa 0.00 mm 1.60 mm 1 133.2 w/m² 10:54 AM 9.4 °C 6.2 °C 80 % SE 3.9 km/h 9.1 km/h 1,001.59 hPa 0.00 mm 1.60 mm 1 152.6 w/m² 10:59 AM 9.5 °C 6.1 °C 80 % SSE 5.1 km/h 8.7 km/h 1,001.69 hPa 0.00 mm 1.60 mm 0 84.3 w/m² 11:04 AM 9.4 °C 6.1 °C 79 % SE 3.3 km/h 8.3 km/h 1,001.59 hPa 0.00 mm 1.60 mm 0 82.6 w/m² 11:09 AM 9.7 °C 6.3 °C 79 % SSE 2.6 km/h 7.0 km/h 1,001.59 hPa 0.00 mm 1.60 mm 0 103.2 w/m² 11:14 AM 10.0 °C 6.3 °C 77 % SE 4.4 km/h 8.0 km/h 1,001.69 hPa 0.00 mm 1.60 mm 1 203.3 w/m² 11:19 AM 10.4 °C 6.6 °C 77 % ESE 4.2 km/h 7.8 km/h 1,001.59 hPa 0.00 mm 1.60 mm 1 177.5 w/m² 11:24 AM 10.4 °C 6.6 °C 78 % SSE 4.7 km/h 8.9 km/h 1,001.80 hPa 0.00 mm 1.60 mm 0 82.3 w/m² 11:29 AM 9.7 °C 5.9 °C 77 % SE 5.0 km/h 10.9 km/h 1,001.80 hPa 0.00 mm 1.60 mm 1 143.7 w/m² 11:34 AM 9.6 °C 5.8 °C 77 % SSE 4.6 km/h 9.0 km/h 1,001.80 hPa 0.00 mm 1.60 mm 1 115.6 w/m² 11:39 AM 9.4 °C 6.0 °C 79 % ESE 4.5 km/h 8.7 km/h 1,001.59 hPa 0.00 mm 1.60 mm 1 117.4 w/m² 11:44 AM 9.3 °C 6.0 °C 80 % SE 5.8 km/h 11.4 km/h 1,001.59 hPa 0.00 mm 1.60 mm 0 88.6 w/m² 11:49 AM 9.1 °C 6.0 °C 81 % SSE 5.1 km/h 12.6 km/h 1,001.80 hPa 0.00 mm 1.60 mm 0 100.5 w/m² 11:54 AM 9.1 °C 6.3 °C 82 % South 5.5 km/h 9.8 km/h 1,001.90 hPa 0.61 mm 1.70 mm 0 64.9 w/m² 11:59 AM 8.5 °C 6.1 °C 85 % SSE 5.0 km/h 10.7 km/h 1,001.90 hPa 1.19 mm 1.80 mm 0 67.3 w/m² 12:04 PM 8.0 °C 5.8 °C 86 % ESE 5.1 km/h 10.4 km/h 1,001.90 hPa 1.19 mm 1.80 mm 0 66.5 w/m² 12:09 PM 7.9 °C 5.7 °C 86 % SSE 4.2 km/h 8.0 km/h 1,001.90 hPa 0.61 mm 1.80 mm 0 70.8 w/m² 12:14 PM 7.9 °C 5.6 °C 86 % SSE 4.0 km/h 7.9 km/h 1,001.80 hPa 0.00 mm 1.80 mm 0 59.3 w/m² 12:19 PM 7.8 °C 5.6 °C 86 % SE 3.0 km/h 6.3 km/h 1,001.69 hPa 0.00 mm 1.80 mm 0 83.6 w/m² 12:24 PM 7.8 °C 5.4 °C 85 % ENE 5.4 km/h 8.7 km/h 1,002.00 hPa 0.00 mm 1.80 mm 1 142.3 w/m² 12:29 PM 7.9 °C 5.5 °C 85 % South 4.5 km/h 8.7 km/h 1,002.00 hPa 0.00 mm 1.80 mm 0 102.3 w/m² 12:34 PM 7.9 °C 5.2 °C 83 % SSE 4.5 km/h 9.0 km/h 1,001.90 hPa 0.00 mm 1.80 mm 1 133.9 w/m² 12:39 PM 8.1 °C 5.5 °C 83 % SE 4.6 km/h 7.9 km/h 1,002.10 hPa 0.00 mm 1.80 mm 1 179.5 w/m² 12:44 PM 8.5 °C 5.8 °C 83 % SSE 3.9 km/h 7.9 km/h 1,002.40 hPa 0.00 mm 1.80 mm 0 95.4 w/m² 12:49 PM 8.3 °C 5.4 °C 82 % SSE 4.9 km/h 9.9 km/h 1,002.20 hPa 0.00 mm 1.80 mm 1 108.5 w/m² 12:54 PM 8.2 °C 5.4 °C 83 % ESE 4.6 km/h 10.3 km/h 1,002.00 hPa 0.00 mm 1.80 mm 1 169.1 w/m² 12:59 PM 8.7 °C 5.9 °C 83 % SE 4.9 km/h 8.4 km/h 1,002.00 hPa 0.00 mm 1.80 mm 1 189.6 w/m² 1:04 PM 9.4 °C 6.2 °C 80 % ENE 4.0 km/h 8.2 km/h 1,002.10 hPa 0.00 mm 1.80 mm 1 128.1 w/m² 1:09 PM 9.7 °C 6.1 °C 78 % SSE 4.9 km/h 10.7 km/h 1,001.90 hPa 0.00 mm 1.80 mm 1 112.9 w/m² 1:14 PM 9.9 °C 5.9 °C 76 % SSW 5.1 km/h 10.1 km/h 1,001.80 hPa 0.00 mm 1.80 mm 1 137.7 w/m² 1:19 PM 9.8 °C 5.7 °C 76 % SE 4.9 km/h 12.0 km/h 1,001.90 hPa 0.00 mm 1.80 mm 1 134.1 w/m² 1:24 PM 9.3 °C 5.7 °C 78 % South 4.7 km/h 9.4 km/h 1,002.00 hPa 0.00 mm 1.80 mm 0 81 w/m² 1:29 PM 9.1 °C 5.8 °C 80 % SE 4.0 km/h 7.9 km/h 1,002.20 hPa 0.00 mm 1.80 mm 1 137.6 w/m² 1:34 PM 9.2 °C 6.0 °C 81 % SSW 5.1 km/h 9.9 km/h 1,002.00 hPa 0.00 mm 1.80 mm 1 149.6 w/m² 1:39 PM 9.0 °C 6.1 °C 82 % SSE 4.2 km/h 8.3 km/h 1,002.10 hPa 0.00 mm 1.80 mm 0 70.4 w/m² 1:44 PM 8.8 °C 6.0 °C 82 % SE 4.1 km/h 8.6 km/h 1,002.10 hPa 0.00 mm 1.80 mm 0 63.2 w/m² 1:49 PM 8.9 °C 5.7 °C 81 % SSE 5.0 km/h 9.9 km/h 1,002.10 hPa 0.00 mm 1.80 mm 1 162.7 w/m² 1:54 PM 9.2 °C 5.4 °C 77 % SE 7.6 km/h 17.6 km/h 1,002.10 hPa 0.00 mm 1.80 mm 1 178.7 w/m² 1:59 PM 9.4 °C 5.7 °C 78 % East 3.4 km/h 11.1 km/h 1,002.20 hPa 0.00 mm 1.80 mm 1 167.3 w/m² 2:04 PM 9.6 °C 5.6 °C 76 % SE 4.7 km/h 8.6 km/h 1,002.30 hPa 0.00 mm 1.80 mm 1 127.6 w/m² 2:09 PM 9.7 °C 5.7 °C 76 % SSE 5.4 km/h 11.7 km/h 1,002.30 hPa 0.00 mm 1.80 mm 0 85 w/m² 2:14 PM 9.7 °C 6.0 °C 78 % East 4.7 km/h 10.6 km/h 1,002.40 hPa 0.00 mm 1.80 mm 0 66.1 w/m² 2:19 PM 9.6 °C 5.8 °C 77 % ESE 5.0 km/h 9.5 km/h 1,002.40 hPa 0.00 mm 1.80 mm 0 91.4 w/m² 2:24 PM 9.5 °C 5.3 °C 75 % SSE 6.6 km/h 12.7 km/h 1,002.51 hPa 0.00 mm 1.80 mm 0 97 w/m² 2:29 PM 9.1 °C 4.9 °C 75 % ESE 5.0 km/h 10.3 km/h 1,002.40 hPa 0.00 mm 1.80 mm 0 77.2 w/m² 2:34 PM 8.8 °C 5.2 °C 78 % NNE 4.4 km/h 8.5 km/h 1,002.51 hPa 0.00 mm 1.80 mm 0 39.3 w/m² 2:39 PM 8.7 °C 5.4 °C 80 % SE 5.2 km/h 8.4 km/h 1,002.51 hPa 0.00 mm 1.80 mm 0 49.6 w/m² 2:44 PM 8.5 °C 5.2 °C 80 % South 5.1 km/h 12.1 km/h 1,002.61 hPa 0.00 mm 1.80 mm 0 44.5 w/m² 2:49 PM 8.4 °C 5.2 °C 81 % SE 4.4 km/h 8.8 km/h 1,002.51 hPa 0.00 mm 1.80 mm 0 44.4 w/m² 2:54 PM 8.6 °C 5.2 °C 79 % ESE 3.7 km/h 7.8 km/h 1,002.61 hPa 0.00 mm 1.80 mm 0 43.5 w/m² 2:59 PM 8.8 °C 5.5 °C 80 % SE 3.1 km/h 6.9 km/h 1,002.71 hPa 0.00 mm 1.80 mm 0 41 w/m² 3:04 PM 8.9 °C 5.2 °C 77 % SE 3.8 km/h 8.4 km/h 1,002.61 hPa 0.00 mm 1.80 mm 0 39.3 w/m² 3:09 PM 8.7 °C 5.1 °C 78 % ESE 3.8 km/h 7.9 km/h 1,002.61 hPa 0.00 mm 1.80 mm 0 35.3 w/m² 3:14 PM 8.5 °C 4.9 °C 78 % NE 4.2 km/h 8.3 km/h 1,002.51 hPa 0.00 mm 1.80 mm 0 28.2 w/m² 3:19 PM 8.3 °C 4.7 °C 78 % East 3.9 km/h 8.2 km/h 1,002.61 hPa 0.00 mm 1.80 mm 0 25.1 w/m² 3:24 PM 8.3 °C 4.9 °C 79 % SE 3.5 km/h 7.6 km/h 1,002.51 hPa 0.00 mm 1.80 mm 0 23.2 w/m² 3:29 PM 8.2 °C 5.0 °C 80 % SE 4.2 km/h 7.9 km/h 1,002.51 hPa 0.00 mm 1.80 mm 0 23.4 w/m² 3:34 PM 8.2 °C 4.8 °C 79 % SE 4.2 km/h 8.4 km/h 1,002.71 hPa 0.00 mm 1.80 mm 0 23.4 w/m² 3:39 PM 8.1 °C 4.9 °C 81 % SE 3.8 km/h 7.5 km/h 1,002.61 hPa 0.00 mm 1.80 mm 0 25.1 w/m² 3:44 PM 8.1 °C 5.0 °C 81 % ESE 3.2 km/h 6.6 km/h 1,002.71 hPa 0.00 mm 1.80 mm 0 21 w/m² 3:49 PM 7.9 °C 4.9 °C 81 % SE 3.3 km/h 7.0 km/h 1,002.91 hPa 0.00 mm 1.80 mm 0 15.7 w/m² 3:54 PM 7.8 °C 4.8 °C 81 % SE 3.9 km/h 7.8 km/h 1,003.18 hPa 0.00 mm 1.80 mm 0 12.9 w/m² 3:59 PM 7.5 °C 4.6 °C 82 % SE 4.0 km/h 7.9 km/h 1,003.29 hPa 0.00 mm 1.80 mm 0 10.4 w/m² 4:04 PM 7.3 °C 4.4 °C 82 % ESE 4.2 km/h 8.8 km/h 1,003.18 hPa 0.00 mm 1.80 mm 0 8.1 w/m² 4:09 PM 7.0 °C 4.2 °C 82 % ENE 3.7 km/h 8.2 km/h 1,003.49 hPa 0.00 mm 1.80 mm 0 5.8 w/m² 4:14 PM 6.8 °C 4.1 °C 83 % ENE 3.1 km/h 7.2 km/h 1,003.39 hPa 0.00 mm 1.80 mm 0 4.3 w/m² 4:19 PM 6.5 °C 4.2 °C 85 % ENE 3.5 km/h 6.7 km/h 1,003.49 hPa 0.00 mm 1.80 mm 0 2.8 w/m² 4:24 PM 6.3 °C 4.2 °C 87 % NE 2.7 km/h 5.5 km/h 1,003.39 hPa 0.00 mm 1.80 mm 0 1.7 w/m² 4:29 PM 6.0 °C 4.0 °C 87 % East 3.4 km/h 6.6 km/h 1,003.49 hPa 0.00 mm 1.80 mm 0 1 w/m² 4:34 PM 5.8 °C 4.0 °C 88 % SE 2.8 km/h 6.5 km/h 1,003.49 hPa 0.00 mm 1.80 mm 0 0.5 w/m² 4:39 PM 5.8 °C 4.0 °C 89 % ESE 3.2 km/h 5.8 km/h 1,003.49 hPa 0.00 mm 1.80 mm 0 0.2 w/m² 4:44 PM 5.7 °C 4.0 °C 89 % East 2.6 km/h 6.9 km/h 1,003.69 hPa 0.00 mm 1.80 mm 0 0.1 w/m² 4:49 PM 5.6 °C 4.0 °C 89 % East 2.3 km/h 5.5 km/h 1,003.89 hPa 0.00 mm 1.80 mm 0 0 w/m² 4:54 PM 5.6 °C 3.9 °C 89 % East 2.5 km/h 5.9 km/h 1,003.89 hPa 0.00 mm 1.80 mm 0 0 w/m² 4:59 PM 5.5 °C 4.0 °C 90 % ESE 2.4 km/h 4.9 km/h 1,004.00 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:04 PM 5.5 °C 4.0 °C 90 % East 3.0 km/h 6.0 km/h 1,003.79 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:09 PM 5.6 °C 4.0 °C 90 % East 3.3 km/h 7.1 km/h 1,003.79 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:14 PM 5.6 °C 4.0 °C 90 % East 2.8 km/h 6.4 km/h 1,003.89 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:19 PM 5.6 °C 3.9 °C 89 % East 3.1 km/h 7.3 km/h 1,003.89 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:24 PM 5.4 °C 4.0 °C 91 % ENE 2.6 km/h 5.5 km/h 1,003.89 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:29 PM 5.3 °C 4.0 °C 91 % East 2.7 km/h 4.7 km/h 1,003.79 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:34 PM 5.3 °C 4.0 °C 92 % ENE 2.8 km/h 5.2 km/h 1,003.89 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:39 PM 5.3 °C 4.3 °C 93 % East 2.8 km/h 6.0 km/h 1,004.00 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:44 PM 5.5 °C 4.4 °C 92 % ESE 4.1 km/h 6.7 km/h 1,004.10 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:49 PM 5.7 °C 4.2 °C 90 % East 3.7 km/h 7.0 km/h 1,004.20 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:54 PM 5.8 °C 4.2 °C 90 % East 3.6 km/h 7.0 km/h 1,004.20 hPa 0.00 mm 1.80 mm 0 0 w/m² 5:59 PM 6.0 °C 4.3 °C 89 % ESE 3.6 km/h 6.9 km/h 1,004.10 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:04 PM 6.0 °C 3.8 °C 86 % East 4.9 km/h 9.0 km/h 1,004.10 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:09 PM 6.1 °C 3.9 °C 86 % ENE 3.9 km/h 7.0 km/h 1,004.20 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:14 PM 5.9 °C 3.7 °C 86 % East 4.1 km/h 7.9 km/h 1,004.20 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:19 PM 5.8 °C 3.6 °C 86 % ENE 3.3 km/h 8.1 km/h 1,004.10 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:24 PM 5.7 °C 3.4 °C 85 % ENE 4.6 km/h 8.9 km/h 1,004.20 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:29 PM 5.7 °C 3.3 °C 84 % East 4.4 km/h 8.2 km/h 1,004.20 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:34 PM 5.6 °C 3.0 °C 83 % East 4.5 km/h 8.3 km/h 1,004.50 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:39 PM 5.6 °C 3.0 °C 83 % ESE 3.2 km/h 7.0 km/h 1,004.40 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:44 PM 5.4 °C 3.1 °C 85 % East 3.7 km/h 7.5 km/h 1,004.30 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:49 PM 5.3 °C 2.9 °C 85 % East 3.2 km/h 6.8 km/h 1,004.40 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:54 PM 5.2 °C 2.7 °C 84 % East 3.6 km/h 7.0 km/h 1,004.30 hPa 0.00 mm 1.80 mm 0 0 w/m² 6:59 PM 5.2 °C 2.7 °C 84 % ESE 3.3 km/h 6.5 km/h 1,004.40 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:04 PM 5.1 °C 2.9 °C 86 % ESE 3.0 km/h 5.4 km/h 1,004.40 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:09 PM 5.0 °C 2.7 °C 85 % East 2.7 km/h 5.7 km/h 1,004.50 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:14 PM 5.2 °C 2.7 °C 84 % East 3.1 km/h 5.5 km/h 1,004.50 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:19 PM 5.2 °C 2.8 °C 84 % East 3.2 km/h 5.8 km/h 1,004.50 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:24 PM 5.2 °C 2.8 °C 85 % East 2.7 km/h 5.8 km/h 1,004.40 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:29 PM 5.0 °C 2.7 °C 85 % SE 1.7 km/h 5.6 km/h 1,004.40 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:34 PM 5.0 °C 2.7 °C 85 % East 2.8 km/h 5.2 km/h 1,004.61 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:39 PM 5.1 °C 2.8 °C 85 % East 2.3 km/h 5.5 km/h 1,004.71 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:44 PM 5.0 °C 2.7 °C 85 % NE 2.2 km/h 5.1 km/h 1,004.61 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:49 PM 5.1 °C 2.9 °C 86 % East 1.6 km/h 3.9 km/h 1,004.71 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:54 PM 4.8 °C 2.8 °C 87 % East 2.1 km/h 4.0 km/h 1,004.81 hPa 0.00 mm 1.80 mm 0 0 w/m² 7:59 PM 4.9 °C 2.4 °C 84 % East 2.2 km/h 5.3 km/h 1,004.61 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:04 PM 4.9 °C 2.6 °C 85 % ENE 1.2 km/h 3.3 km/h 1,004.91 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:09 PM 4.6 °C 2.6 °C 87 % ENE 1.6 km/h 3.2 km/h 1,004.71 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:14 PM 4.5 °C 2.4 °C 86 % ESE 1.8 km/h 5.4 km/h 1,004.71 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:19 PM 4.4 °C 2.5 °C 87 % ENE 1.3 km/h 3.1 km/h 1,004.81 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:24 PM 4.2 °C 2.4 °C 88 % ENE 1.0 km/h 3.6 km/h 1,004.71 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:29 PM 4.1 °C 2.3 °C 88 % ESE 1.4 km/h 3.2 km/h 1,004.91 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:34 PM 4.1 °C 2.2 °C 88 % ESE 1.4 km/h 4.4 km/h 1,005.11 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:39 PM 4.0 °C 2.4 °C 89 % East 1.9 km/h 4.3 km/h 1,004.91 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:44 PM 3.9 °C 2.3 °C 89 % East 2.2 km/h 4.0 km/h 1,005.11 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:49 PM 3.8 °C 2.4 °C 90 % ESE 1.4 km/h 3.9 km/h 1,005.22 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:54 PM 3.7 °C 2.3 °C 91 % ESE 2.7 km/h 5.5 km/h 1,005.22 hPa 0.00 mm 1.80 mm 0 0 w/m² 8:59 PM 3.9 °C 2.4 °C 90 % SE 1.8 km/h 5.1 km/h 1,005.22 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:04 PM 3.9 °C 2.4 °C 90 % ESE 2.3 km/h 5.0 km/h 1,005.22 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:09 PM 3.7 °C 2.3 °C 91 % East 2.8 km/h 5.1 km/h 1,005.32 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:14 PM 3.6 °C 2.3 °C 91 % ENE 2.8 km/h 6.2 km/h 1,005.22 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:19 PM 3.5 °C 2.3 °C 92 % East 2.1 km/h 4.7 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:24 PM 3.5 °C 2.3 °C 92 % ENE 2.4 km/h 4.6 km/h 1,005.32 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:29 PM 3.4 °C 2.4 °C 93 % ENE 2.6 km/h 5.0 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:34 PM 3.3 °C 2.3 °C 93 % ENE 3.1 km/h 5.1 km/h 1,005.49 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:39 PM 3.3 °C 2.3 °C 93 % East 2.2 km/h 5.1 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:44 PM 3.2 °C 2.3 °C 94 % ENE 2.3 km/h 5.5 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:49 PM 3.0 °C 2.0 °C 93 % ENE 3.0 km/h 5.6 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:54 PM 3.0 °C 2.0 °C 93 % ENE 3.0 km/h 5.9 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 9:59 PM 3.0 °C 2.0 °C 93 % ENE 2.7 km/h 5.3 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:04 PM 3.0 °C 2.0 °C 93 % North 2.1 km/h 4.8 km/h 1,005.69 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:09 PM 3.0 °C 2.0 °C 93 % ENE 2.1 km/h 4.3 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:14 PM 2.9 °C 2.0 °C 94 % NE 1.9 km/h 4.1 km/h 1,005.69 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:19 PM 2.9 °C 2.0 °C 94 % NE 2.0 km/h 4.8 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:24 PM 2.8 °C 1.9 °C 94 % NE 2.5 km/h 5.0 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:29 PM 2.6 °C 1.8 °C 94 % ENE 2.7 km/h 4.9 km/h 1,005.49 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:34 PM 2.4 °C 1.7 °C 95 % ENE 2.1 km/h 5.3 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:39 PM 2.3 °C 1.6 °C 95 % ENE 2.2 km/h 5.3 km/h 1,005.49 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:44 PM 2.2 °C 1.5 °C 95 % East 2.9 km/h 5.5 km/h 1,005.49 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:49 PM 2.1 °C 1.4 °C 95 % East 1.9 km/h 4.4 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:54 PM 2.0 °C 1.4 °C 96 % East 2.4 km/h 5.1 km/h 1,005.49 hPa 0.00 mm 1.80 mm 0 0 w/m² 10:59 PM 1.9 °C 1.3 °C 96 % East 2.0 km/h 4.1 km/h 1,005.32 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:04 PM 1.8 °C 1.2 °C 96 % ENE 2.7 km/h 4.8 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:09 PM 1.6 °C 1.2 °C 97 % ENE 2.6 km/h 4.7 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:14 PM 1.6 °C 1.2 °C 97 % ENE 2.2 km/h 4.7 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:19 PM 1.5 °C 1.1 °C 97 % ENE 2.3 km/h 4.6 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:24 PM 1.4 °C 1.0 °C 97 % East 2.3 km/h 5.4 km/h 1,005.32 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:29 PM 1.3 °C 0.9 °C 97 % ENE 2.6 km/h 4.6 km/h 1,005.38 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:34 PM 1.5 °C 1.1 °C 98 % ENE 2.4 km/h 5.0 km/h 1,005.49 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:39 PM 1.4 °C 1.1 °C 98 % ENE 2.8 km/h 4.8 km/h 1,005.49 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:44 PM 1.5 °C 1.2 °C 98 % ENE 2.6 km/h 5.5 km/h 1,005.59 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:49 PM 1.5 °C 1.2 °C 98 % East 2.6 km/h 5.7 km/h 1,005.79 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:54 PM 1.4 °C 1.1 °C 98 % East 1.7 km/h 4.9 km/h 1,005.69 hPa 0.00 mm 1.80 mm 0 0 w/m² 11:59 PM 1.4 °C 1.1 °C 98 % East 3.2 km/h 5.8 km/h 1,005.69 hPa 0.00 mm 1.80 mm 0 0 w/m² December 3, 2024 Time Temperature Dew Point Humidity Wind Speed Gust Pressure Precip. Rate. Precip. Accum. UV Solar 12:04 AM 1.4 °C 1.1 °C 98 % ENE 2.7 km/h 4.7 km/h 1,005.69 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:09 AM 1.5 °C 1.2 °C 98 % ENE 2.2 km/h 5.0 km/h 1,005.59 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:14 AM 1.5 °C 1.3 °C 99 % East 2.8 km/h 5.4 km/h 1,005.69 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:19 AM 1.5 °C 1.3 °C 99 % ENE 2.9 km/h 6.0 km/h 1,005.69 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:24 AM 1.4 °C 1.3 °C 99 % NE 3.0 km/h 4.9 km/h 1,005.69 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:29 AM 1.4 °C 1.3 °C 99 % NE 2.6 km/h 5.4 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:34 AM 1.3 °C 1.2 °C 99 % ENE 2.3 km/h 4.9 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:39 AM 1.3 °C 1.1 °C 99 % East 2.3 km/h 5.0 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:44 AM 1.3 °C 1.2 °C 99 % East 2.1 km/h 4.7 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:49 AM 1.4 °C 1.3 °C 99 % East 2.5 km/h 5.4 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:54 AM 1.4 °C 1.3 °C 99 % East 1.8 km/h 4.4 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 12:59 AM 1.3 °C 1.2 °C 99 % ENE 2.8 km/h 4.6 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:04 AM 1.2 °C 1.1 °C 99 % ENE 2.8 km/h 4.9 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:09 AM 1.1 °C 1.0 °C 99 % NE 2.5 km/h 5.1 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:14 AM 1.1 °C 1.0 °C 99 % ENE 3.1 km/h 5.5 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:19 AM 1.1 °C 1.0 °C 99 % East 1.9 km/h 4.7 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:24 AM 1.0 °C 0.9 °C 99 % East 2.4 km/h 4.8 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:29 AM 0.9 °C 0.8 °C 99 % ENE 2.6 km/h 5.0 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:34 AM 0.8 °C 0.7 °C 99 % ENE 2.0 km/h 4.7 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:39 AM 0.9 °C 0.8 °C 99 % ENE 2.0 km/h 4.3 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:44 AM 1.0 °C 0.9 °C 99 % East 2.3 km/h 4.3 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:49 AM 1.0 °C 0.9 °C 99 % East 2.7 km/h 4.8 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:54 AM 1.0 °C 0.9 °C 99 % ENE 3.1 km/h 5.5 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 1:59 AM 1.0 °C 0.9 °C 99 % East 2.5 km/h 4.6 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:04 AM 1.0 °C 0.9 °C 99 % East 2.8 km/h 4.9 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:09 AM 0.9 °C 0.8 °C 99 % East 1.8 km/h 4.7 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:14 AM 0.9 °C 0.8 °C 99 % East 2.4 km/h 4.6 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:19 AM 0.9 °C 0.8 °C 99 % East 2.9 km/h 4.7 km/h 1,006.20 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:24 AM 0.9 °C 0.8 °C 99 % East 3.3 km/h 5.9 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:29 AM 0.9 °C 0.8 °C 99 % ENE 1.8 km/h 4.2 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:34 AM 0.9 °C 0.8 °C 99 % East 1.7 km/h 4.7 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:39 AM 0.9 °C 0.8 °C 99 % ENE 2.3 km/h 4.8 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:44 AM 0.8 °C 0.7 °C 99 % East 2.0 km/h 4.5 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:49 AM 0.8 °C 0.7 °C 99 % ENE 2.0 km/h 4.1 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:54 AM 0.8 °C 0.7 °C 99 % NNE 1.8 km/h 4.6 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 2:59 AM 0.8 °C 0.7 °C 99 % East 2.4 km/h 3.9 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:04 AM 0.8 °C 0.7 °C 99 % ENE 2.0 km/h 4.2 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:09 AM 0.7 °C 0.6 °C 99 % East 2.2 km/h 4.4 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:14 AM 0.7 °C 0.6 °C 99 % ENE 2.1 km/h 4.5 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:19 AM 0.6 °C 0.5 °C 99 % East 2.0 km/h 4.5 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:24 AM 0.5 °C 0.4 °C 99 % East 2.5 km/h 5.0 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:29 AM 0.4 °C 0.3 °C 99 % ENE 2.3 km/h 4.4 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:34 AM 0.3 °C 0.2 °C 99 % ENE 2.6 km/h 4.8 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:39 AM 0.2 °C 0.1 °C 99 % ENE 2.2 km/h 4.5 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:44 AM 0.1 °C 0.0 °C 99 % ENE 2.5 km/h 4.4 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:49 AM 0.0 °C -0.1 °C 99 % ENE 2.5 km/h 4.3 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:54 AM 0.0 °C -0.1 °C 99 % ENE 2.4 km/h 4.5 km/h 1,005.69 hPa 0.00 mm 0.00 mm 0 0 w/m² 3:59 AM 0.0 °C -0.1 °C 99 % ENE 2.0 km/h 4.2 km/h 1,005.49 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:04 AM -0.1 °C -0.2 °C 99 % East 2.2 km/h 4.0 km/h 1,005.49 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:09 AM -0.1 °C -0.2 °C 99 % ENE 2.2 km/h 4.7 km/h 1,005.49 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:14 AM -0.1 °C -0.2 °C 99 % ENE 2.5 km/h 4.6 km/h 1,005.49 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:19 AM -0.2 °C -0.3 °C 99 % ENE 1.9 km/h 4.5 km/h 1,005.38 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:24 AM -0.3 °C -0.4 °C 99 % East 2.4 km/h 4.8 km/h 1,005.32 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:29 AM -0.3 °C -0.4 °C 99 % East 2.5 km/h 4.5 km/h 1,005.32 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:34 AM -0.4 °C -0.5 °C 99 % ENE 2.5 km/h 4.1 km/h 1,005.38 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:39 AM -0.5 °C -0.6 °C 99 % East 2.2 km/h 4.1 km/h 1,005.32 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:44 AM -0.6 °C -0.7 °C 99 % ENE 2.5 km/h 4.5 km/h 1,005.22 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:49 AM -0.5 °C -0.6 °C 99 % East 2.1 km/h 4.3 km/h 1,005.32 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:54 AM -0.5 °C -0.6 °C 99 % ENE 2.5 km/h 4.6 km/h 1,005.49 hPa 0.00 mm 0.00 mm 0 0 w/m² 4:59 AM -0.5 °C -0.6 °C 99 % ENE 2.3 km/h 4.6 km/h 1,005.38 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:04 AM -0.6 °C -0.7 °C 99 % ENE 2.4 km/h 4.3 km/h 1,005.38 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:09 AM -0.6 °C -0.7 °C 99 % ENE 2.5 km/h 4.2 km/h 1,005.59 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:14 AM -0.6 °C -0.7 °C 99 % ENE 2.3 km/h 4.8 km/h 1,005.59 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:19 AM -0.6 °C -0.7 °C 99 % East 1.9 km/h 4.3 km/h 1,005.59 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:24 AM -0.7 °C -0.8 °C 99 % East 2.4 km/h 4.4 km/h 1,005.59 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:29 AM -0.6 °C -0.7 °C 99 % ENE 3.0 km/h 6.1 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:34 AM -0.6 °C -0.7 °C 99 % ENE 1.8 km/h 4.4 km/h 1,005.79 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:39 AM -0.8 °C -0.9 °C 99 % NE 2.0 km/h 3.6 km/h 1,005.89 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:44 AM -0.8 °C -0.9 °C 99 % NE 2.2 km/h 4.3 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:49 AM -0.9 °C -1.0 °C 99 % ENE 2.4 km/h 4.3 km/h 1,005.99 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:54 AM -0.8 °C -0.9 °C 99 % NE 2.8 km/h 5.2 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 5:59 AM -0.8 °C -0.9 °C 99 % NE 1.9 km/h 4.7 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:04 AM -0.8 °C -0.9 °C 99 % NE 2.0 km/h 4.4 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:09 AM -0.8 °C -0.9 °C 99 % ENE 1.8 km/h 3.9 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:14 AM -1.0 °C -1.1 °C 99 % NE 1.6 km/h 4.4 km/h 1,006.20 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:19 AM -0.8 °C -0.9 °C 99 % NE 1.8 km/h 4.3 km/h 1,006.30 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:24 AM -0.9 °C -1.0 °C 99 % NNE 1.9 km/h 4.3 km/h 1,006.20 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:29 AM -0.8 °C -0.9 °C 99 % NE 2.0 km/h 4.3 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:34 AM -0.8 °C -0.9 °C 99 % ENE 1.8 km/h 4.7 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:39 AM -0.8 °C -0.9 °C 99 % ENE 2.9 km/h 5.2 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:44 AM -0.9 °C -1.0 °C 99 % ENE 2.2 km/h 5.2 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:49 AM -0.9 °C -1.0 °C 99 % ENE 1.7 km/h 4.3 km/h 1,006.20 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:54 AM -1.0 °C -1.1 °C 99 % ENE 2.2 km/h 3.6 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 6:59 AM -1.0 °C -1.1 °C 99 % NNE 1.8 km/h 4.7 km/h 1,006.10 hPa 0.00 mm 0.00 mm 0 0 w/m² 7:04 AM -1.0 °C -1.1 °C 99 % ENE 2.2 km/h 4.1 km/h 1,006.20 hPa 0.00 mm 0.00 mm 0 0 w/m² 7:09 AM -1.0 °C -1.1 °C 99 % NE 1.6 km/h 4.2 km/h 1,006.30 hPa 0.00 mm 0.00 mm 0 0 w/m² 7:14 AM -1.0 °C -1.1 °C 99 % ENE 1.9 km/h 4.3 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 0 w/m² 7:19 AM -1.1 °C -1.2 °C 99 % NE 1.9 km/h 4.5 km/h 1,006.30 hPa 0.00 mm 0.00 mm 0 0 w/m² 7:24 AM -1.1 °C -1.2 °C 99 % ENE 2.0 km/h 4.1 km/h 1,006.30 hPa 0.00 mm 0.00 mm 0 0 w/m² 7:29 AM -1.1 °C -1.2 °C 99 % ENE 2.8 km/h 5.2 km/h 1,006.30 hPa 0.00 mm 0.00 mm 0 0 w/m² 7:34 AM -1.1 °C -1.2 °C 99 % NE 2.6 km/h 4.7 km/h 1,006.40 hPa 0.00 mm 0.00 mm 0 0.2 w/m² 7:39 AM -1.1 °C -1.2 °C 99 % NE 2.4 km/h 4.6 km/h 1,006.30 hPa 0.00 mm 0.00 mm 0 0.3 w/m² 7:44 AM -1.1 °C -1.2 °C 99 % ENE 2.2 km/h 4.7 km/h 1,006.30 hPa 0.00 mm 0.00 mm 0 0.7 w/m² 7:49 AM -1.2 °C -1.3 °C 99 % North 1.7 km/h 3.9 km/h 1,006.40 hPa 0.00 mm 0.00 mm 0 1.3 w/m² 7:54 AM -1.2 °C -1.3 °C 99 % ENE 2.3 km/h 4.4 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 2.1 w/m² 7:59 AM -1.3 °C -1.4 °C 99 % ENE 2.1 km/h 5.3 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 3.2 w/m² 8:04 AM -1.3 °C -1.4 °C 99 % NE 2.5 km/h 4.7 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 4.5 w/m² 8:09 AM -1.3 °C -1.4 °C 99 % East 2.1 km/h 4.4 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 6 w/m² 8:14 AM -1.3 °C -1.4 °C 99 % NE 1.8 km/h 3.8 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 7.6 w/m² 8:19 AM -1.3 °C -1.4 °C 99 % NE 2.2 km/h 4.5 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 9.2 w/m² 8:24 AM -1.3 °C -1.4 °C 99 % ENE 2.4 km/h 4.6 km/h 1,006.81 hPa 0.00 mm 0.00 mm 0 10.8 w/m² 8:29 AM -1.3 °C -1.4 °C 99 % ENE 2.7 km/h 5.0 km/h 1,006.81 hPa 0.00 mm 0.00 mm 0 12.5 w/m² 8:34 AM -1.2 °C -1.3 °C 99 % ENE 2.8 km/h 5.4 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 14 w/m² 8:39 AM -1.2 °C -1.3 °C 99 % ENE 2.9 km/h 5.6 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 15.5 w/m² 8:44 AM -1.1 °C -1.2 °C 99 % NE 3.0 km/h 4.9 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 17 w/m² 8:49 AM -1.0 °C -1.1 °C 99 % ENE 2.5 km/h 4.7 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 18.3 w/m² 8:54 AM -1.1 °C -1.2 °C 99 % ENE 2.2 km/h 4.9 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 19.8 w/m² 8:59 AM -0.9 °C -1.0 °C 99 % ENE 3.2 km/h 5.0 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 25.3 w/m² 9:04 AM -0.6 °C -0.7 °C 99 % ENE 3.0 km/h 5.0 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 27.6 w/m² 9:09 AM -0.2 °C -0.3 °C 99 % ENE 1.9 km/h 4.2 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 29.6 w/m² 9:14 AM 0.1 °C 0.0 °C 99 % ENE 1.3 km/h 4.2 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 32 w/m² 9:19 AM 0.3 °C 0.2 °C 99 % East 1.7 km/h 4.2 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 34.7 w/m² 9:24 AM 0.7 °C 0.6 °C 99 % East 1.9 km/h 4.2 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 39 w/m² 9:29 AM 0.9 °C 0.8 °C 99 % ENE 1.2 km/h 3.5 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 44.4 w/m² 9:34 AM 1.2 °C 1.1 °C 99 % East 2.4 km/h 5.2 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 50.9 w/m² 9:39 AM 1.5 °C 1.4 °C 99 % North 2.5 km/h 5.7 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 61.9 w/m² 9:44 AM 1.9 °C 1.8 °C 99 % ENE 2.6 km/h 5.5 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 71 w/m² 9:49 AM 2.3 °C 2.2 °C 99 % East 1.8 km/h 4.6 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 71.1 w/m² 9:54 AM 2.1 °C 2.0 °C 99 % ENE 2.7 km/h 4.5 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 53.9 w/m² 9:59 AM 2.4 °C 2.3 °C 99 % ESE 2.0 km/h 4.6 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 59.8 w/m² 10:04 AM 2.6 °C 2.5 °C 99 % East 1.3 km/h 4.7 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 67.3 w/m² 10:09 AM 2.4 °C 2.3 °C 99 % ENE 1.8 km/h 4.2 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 69 w/m² 10:14 AM 2.8 °C 2.7 °C 99 % East 1.0 km/h 3.6 km/h 1,006.71 hPa 0.00 mm 0.00 mm 0 70.2 w/m² 10:19 AM 3.3 °C 3.1 °C 98 % ESE 1.5 km/h 3.9 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 70 w/m² 10:24 AM 3.6 °C 3.1 °C 96 % ESE 2.2 km/h 4.1 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 75.3 w/m² 10:29 AM 3.9 °C 3.2 °C 95 % East 1.7 km/h 3.9 km/h 1,006.50 hPa 0.00 mm 0.00 mm 0 88.5 w/m² 10:34 AM 4.1 °C 3.1 °C 93 % ESE 1.8 km/h 3.6 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 93.1 w/m² 10:39 AM 4.1 °C 3.0 °C 92 % SE 1.8 km/h 4.0 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 99.3 w/m² 10:44 AM 4.1 °C 3.1 °C 93 % SE 1.9 km/h 4.2 km/h 1,006.60 hPa 0.00 mm 0.00 mm 0 106.9 w/m² 10:49 AM 4.2 °C 3.2 °C 93 % ESE 2.0 km/h 4.3 km/h 1,006.60 hPa 0.00 mm 0.00 mm 1 126.8 w/m² 10:54 AM 4.2 °C 3.1 °C 92 % SE 1.9 km/h 5.2 km/h 1,006.60 hPa 0.00 mm 0.00 mm 1 121.9 w/m² 10:59 AM 3.9 °C 2.8 °C 93 % SE 1.9 km/h 4.5 km/h 1,006.71 hPa 0.00 mm 0.00 mm 1 122.3 w/m² 11:04 AM 4.2 °C 3.2 °C 93 % ESE 2.9 km/h 5.8 km/h 1,006.60 hPa 0.00 mm 0.00 mm 1 114.8 w/m² 11:09 AM 4.5 °C 3.3 °C 92 % SSW 2.7 km/h 5.6 km/h 1,006.60 hPa 0.00 mm 0.00 mm 1 121.9 w/m² 11:14 AM 4.7 °C 3.4 °C 91 % South 3.6 km/h 6.5 km/h 1,006.71 hPa 0.00 mm 0.00 mm 1 117.7 w/m² 11:19 AM 4.8 °C 3.5 °C 91 % SSW 3.4 km/h 6.7 km/h 1,006.81 hPa 0.00 mm 0.00 mm 1 128.5 w/m² 11:24 AM 5.1 °C 3.6 °C 90 % ESE 3.4 km/h 6.7 km/h 1,006.71 hPa 0.00 mm 0.00 mm 1 133.4 w/m² 11:29 AM 5.2 °C 3.8 °C 90 % SSE 3.4 km/h 7.1 km/h 1,006.71 hPa 0.61 mm 0.10 mm 1 133.5 w/m² 11:34 AM 5.4 °C 3.9 °C 90 % ENE 3.1 km/h 7.4 km/h 1,006.81 hPa 0.61 mm 0.10 mm 1 142.1 w/m² 11:39 AM 5.7 °C 3.9 °C 88 % SE 3.5 km/h 6.6 km/h 1,006.81 hPa 0.61 mm 0.10 mm 1 147.1 w/m² 11:44 AM 6.1 °C 4.2 °C 88 % ESE 2.8 km/h 6.7 km/h 1,006.91 hPa 0.00 mm 0.10 mm 1 142.1 w/m² 11:49 AM 6.4 °C 4.5 °C 88 % SE 3.4 km/h 5.5 km/h 1,006.71 hPa 0.00 mm 0.10 mm 1 139.5 w/m² 11:54 AM 6.6 °C 4.4 °C 86 % ESE 2.6 km/h 6.6 km/h 1,006.60 hPa 0.00 mm 0.10 mm 1 133 w/m² 11:59 AM 6.8 °C 4.5 °C 85 % ESE 3.4 km/h 6.2 km/h 1,006.60 hPa 0.00 mm 0.10 mm 1 120.7 w/m² 12:04 PM 6.9 °C 4.4 °C 84 % SE 2.5 km/h 5.8 km/h 1,006.60 hPa 0.00 mm 0.10 mm 1 117.1 w/m² 12:09 PM 6.8 °C 4.3 °C 84 % SE 2.5 km/h 5.9 km/h 1,006.50 hPa 0.00 mm 0.10 mm 1 115.7 w/m² 12:14 PM 6.9 °C 4.4 °C 84 % ESE 2.7 km/h 6.1 km/h 1,006.50 hPa 0.00 mm 0.10 mm 1 114.1 w/m² 12:19 PM 7.1 °C 4.6 °C 84 % ESE 3.3 km/h 5.5 km/h 1,006.50 hPa 0.00 mm 0.10 mm 1 115.3 w/m² 12:24 PM 7.1 °C 4.9 °C 86 % ESE 2.9 km/h 6.1 km/h 1,006.50 hPa 0.00 mm 0.10 mm 1 117 w/m² 12:29 PM 7.1 °C 4.8 °C 85 % ESE 3.5 km/h 6.0 km/h 1,006.40 hPa 0.00 mm 0.10 mm 1 127.8 w/m² 12:34 PM 7.4 °C 5.1 °C 85 % SE 3.7 km/h 7.8 km/h 1,006.60 hPa 0.00 mm 0.10 mm 1 126 w/m² 12:39 PM 7.6 °C 5.2 °C 84 % SE 4.0 km/h 7.2 km/h 1,006.60 hPa 0.00 mm 0.10 mm 1 119.7 w/m² 12:44 PM 7.7 °C 5.1 °C 84 % East 4.0 km/h 7.6 km/h 1,006.30 hPa 0.00 mm 0.10 mm 1 115.9 w/m² 12:49 PM 7.8 °C 5.2 °C 84 % East 4.2 km/h 8.1 km/h 1,006.40 hPa 0.00 mm 0.10 mm 1 109.1 w/m² 12:54 PM 7.8 °C 5.1 °C 83 % ESE 4.9 km/h 8.4 km/h 1,006.30 hPa 0.00 mm 0.10 mm 0 101.3 w/m² 12:59 PM 7.7 °C 5.0 °C 83 % SE 5.0 km/h 8.3 km/h 1,006.30 hPa 0.00 mm 0.10 mm 0 99.6 w/m² 1:04 PM 7.9 °C 5.0 °C 82 % ESE 4.4 km/h 9.1 km/h 1,006.30 hPa 0.00 mm 0.10 mm 0 100.5 w/m² 1:09 PM 8.1 °C 5.0 °C 81 % SW 4.8 km/h 9.2 km/h 1,006.20 hPa 0.00 mm 0.10 mm 0 96.9 w/m² 1:14 PM 8.1 °C 4.9 °C 80 % SE 5.3 km/h 9.1 km/h 1,006.20 hPa 0.00 mm 0.10 mm 0 80 w/m² 1:19 PM 8.1 °C 4.3 °C 77 % SSW 5.8 km/h 9.3 km/h 1,006.30 hPa 0.00 mm 0.10 mm 0 93.9 w/m² 1:24 PM 8.2 °C 4.2 °C 76 % SE 5.3 km/h 10.1 km/h 1,006.30 hPa 0.00 mm 0.10 mm 1 108.8 w/m² 1:29 PM 8.8 °C 4.4 °C 74 % SSE 6.6 km/h 9.8 km/h 1,006.20 hPa 0.00 mm 0.10 mm 1 111.8 w/m² 1:34 PM 9.3 °C 4.3 °C 71 % SSE 6.7 km/h 11.7 km/h 1,006.20 hPa 0.00 mm 0.10 mm 1 112.2 w/m² 1:39 PM 9.7 °C 4.5 °C 70 % East 7.7 km/h 12.8 km/h 1,005.99 hPa 0.00 mm 0.10 mm 1 108.8 w/m² 1:44 PM 10.0 °C 4.1 °C 67 % SE 6.7 km/h 13.4 km/h 1,006.20 hPa 0.00 mm 0.10 mm 0 105.6 w/m² 1:49 PM 10.0 °C 4.4 °C 68 % ESE 7.1 km/h 12.4 km/h 1,005.99 hPa 0.00 mm 0.10 mm 0 102.1 w/m² 1:54 PM 9.6 °C 3.9 °C 68 % ESE 6.7 km/h 11.6 km/h 1,005.79 hPa 0.00 mm 0.10 mm 0 97.9 w/m² 1:59 PM 9.7 °C 4.1 °C 68 % East 7.2 km/h 13.2 km/h 1,005.79 hPa 0.00 mm 0.10 mm 0 91.9 w/m² 2:04 PM 10.0 °C 3.8 °C 65 % SE 6.8 km/h 12.2 km/h 1,005.79 hPa 0.00 mm 0.10 mm 0 83 w/m² 2:09 PM 10.4 °C 4.2 °C 66 % NW 7.5 km/h 12.1 km/h 1,005.79 hPa 0.00 mm 0.10 mm 0 73.3 w/m² 2:14 PM 10.3 °C 3.4 °C 63 % East 7.6 km/h 12.5 km/h 1,005.79 hPa 0.00 mm 0.10 mm 0 65.4 w/m² 2:19 PM 10.2 °C 3.6 °C 64 % SSE 7.0 km/h 14.7 km/h 1,005.99 hPa 0.00 mm 0.10 mm 0 61.6 w/m² 2:24 PM 10.6 °C 3.9 °C 63 % ESE 7.1 km/h 14.5 km/h 1,005.79 hPa 0.00 mm 0.10 mm 0 58.3 w/m² 2:29 PM 10.4 °C 3.5 °C 62 % ENE 6.6 km/h 14.3 km/h 1,005.89 hPa 0.00 mm 0.10 mm 0 55.4 w/m² 2:34 PM 10.4 °C 3.5 °C 63 % SE 7.1 km/h 13.1 km/h 1,005.99 hPa 0.00 mm 0.10 mm 0 53 w/m² 2:39 PM 10.4 °C 3.5 °C 63 % SE 6.7 km/h 13.1 km/h 1,005.89 hPa 0.00 mm 0.10 mm 0 50.4 w/m² 2:44 PM 10.7 °C 3.6 °C 62 % WNW 6.2 km/h 13.1 km/h 1,006.10 hPa 0.00 mm 0.10 mm 0 48.1 w/m² 2:49 PM 10.6 °C 4.0 °C 63 % East 6.5 km/h 13.3 km/h 1,005.99 hPa 0.00 mm 0.10 mm 0 45.9 w/m² 2:54 PM 10.3 °C 3.9 °C 64 % NNE 6.6 km/h 12.2 km/h 1,006.10 hPa 0.00 mm 0.10 mm 0 42.6 w/m² 2:59 PM 10.6 °C 4.1 °C 64 % East 5.4 km/h 12.8 km/h 1,005.99 hPa 0.00 mm 0.10 mm 0 41.2 w/m² 3:04 PM 10.8 °C 3.9 °C 62 % ESE 4.3 km/h 10.3 km/h 1,006.10 hPa 0.00 mm 0.10 mm 0 38.9 w/m² 3:09 PM 10.8 °C 4.3 °C 64 % East 7.3 km/h 12.3 km/h 1,006.10 hPa 0.00 mm 0.10 mm 0 36.7 w/m² 3:14 PM 10.1 °C 3.6 °C 64 % ESE 7.4 km/h 14.0 km/h 1,006.20 hPa 0.00 mm 0.10 mm 0 33.9 w/m² 3:19 PM 9.7 °C 3.9 °C 67 % NNE 5.4 km/h 10.9 km/h 1,006.40 hPa 0.00 mm 0.10 mm 0 31.7 w/m² 3:24 PM 9.6 °C 3.9 °C 68 % SSE 5.8 km/h 9.2 km/h 1,006.40 hPa 0.00 mm 0.10 mm 0 29.1 w/m² 3:29 PM 9.5 °C 4.1 °C 69 % SSE 5.2 km/h 11.0 km/h 1,006.30 hPa 0.00 mm 0.10 mm 0 26.4 w/m² 3:34 PM 9.1 °C 4.2 °C 72 % ENE 6.3 km/h 10.1 km/h 1,006.30 hPa 0.00 mm 0.10 mm 0 23.4 w/m² 3:39 PM 8.6 °C 4.4 °C 75 % East 6.2 km/h 10.2 km/h 1,006.50 hPa 0.00 mm 0.10 mm 0 21 w/m² 3:44 PM 8.7 °C 4.7 °C 76 % East 6.4 km/h 10.6 km/h 1,006.60 hPa 0.00 mm 0.10 mm 0 17.4 w/m² 3:49 PM 7.9 °C 4.4 °C 78 % ENE 6.3 km/h 10.7 km/h 1,006.60 hPa 0.00 mm 0.10 mm 0 15.4 w/m² 3:54 PM 7.4 °C 4.1 °C 80 % East 6.8 km/h 12.5 km/h 1,006.60 hPa 0.00 mm 0.10 mm 0 12.1 w/m² 3:59 PM 6.9 °C 3.9 °C 81 % ESE 5.5 km/h 10.5 km/h 1,006.60 hPa 0.00 mm 0.10 mm 0 9.9 w/m² 4:04 PM 6.5 °C 3.7 °C 82 % ENE 6.5 km/h 10.8 km/h 1,006.71 hPa 0.00 mm 0.10 mm 0 7.6 w/m² 4:09 PM 6.0 °C 3.5 °C 84 % NNE 6.7 km/h 11.8 km/h 1,006.91 hPa 0.00 mm 0.10 mm 0 5.9 w/m² 4:14 PM 5.5 °C 3.3 °C 86 % ENE 5.7 km/h 11.5 km/h 1,006.81 hPa 0.00 mm 0.10 mm 0 4.2 w/m² 4:19 PM 5.0 °C 3.0 °C 87 % NE 5.4 km/h 11.5 km/h 1,006.91 hPa 0.00 mm 0.10 mm 0 2.8 w/m² 4:24 PM 4.7 °C 2.9 °C 88 % ENE 5.8 km/h 11.2 km/h 1,006.91 hPa 0.00 mm 0.10 mm 0 1.7 w/m² 4:29 PM 4.3 °C 2.7 °C 89 % East 5.4 km/h 11.5 km/h 1,006.91 hPa 0.00 mm 0.10 mm 0 1 w/m² 4:34 PM 4.2 °C 2.8 °C 90 % ENE 5.9 km/h 11.6 km/h 1,007.11 hPa 0.00 mm 0.10 mm 0 0.6 w/m² 4:39 PM 4.2 °C 2.9 °C 91 % East 7.0 km/h 11.0 km/h 1,007.21 hPa 0.00 mm 0.10 mm 0 0.2 w/m² 4:44 PM 4.0 °C 2.9 °C 92 % ENE 6.4 km/h 14.0 km/h 1,007.32 hPa 0.00 mm 0.10 mm 0 0.1 w/m² 4:49 PM 3.9 °C 2.9 °C 93 % ENE 6.8 km/h 11.9 km/h 1,007.48 hPa 0.00 mm 0.10 mm 0 0 w/m² 4:54 PM 3.7 °C 2.8 °C 94 % ENE 5.1 km/h 11.3 km/h 1,007.42 hPa 0.00 mm 0.10 mm 0 0 w/m² 4:59 PM 3.6 °C 2.7 °C 94 % East 6.8 km/h 13.0 km/h 1,007.48 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:04 PM 3.5 °C 2.6 °C 94 % East 6.6 km/h 11.7 km/h 1,007.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:09 PM 3.4 °C 2.5 °C 94 % East 6.0 km/h 10.5 km/h 1,007.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:14 PM 3.3 °C 2.5 °C 94 % ENE 6.1 km/h 11.2 km/h 1,007.79 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:19 PM 3.2 °C 2.5 °C 95 % East 6.3 km/h 11.0 km/h 1,007.89 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:24 PM 3.2 °C 2.5 °C 95 % ENE 6.4 km/h 12.1 km/h 1,007.89 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:29 PM 3.2 °C 2.5 °C 95 % SE 6.3 km/h 11.1 km/h 1,008.09 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:34 PM 3.2 °C 2.5 °C 95 % SE 6.2 km/h 11.4 km/h 1,007.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:39 PM 3.2 °C 2.5 °C 95 % NE 6.0 km/h 10.5 km/h 1,008.09 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:44 PM 3.1 °C 2.4 °C 95 % East 6.5 km/h 12.0 km/h 1,008.09 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:49 PM 3.1 °C 2.4 °C 95 % East 5.9 km/h 10.7 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:54 PM 3.1 °C 2.4 °C 95 % NE 5.4 km/h 11.1 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 5:59 PM 3.1 °C 2.4 °C 95 % East 5.9 km/h 12.0 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:04 PM 3.1 °C 2.4 °C 95 % ENE 5.3 km/h 11.6 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:09 PM 3.1 °C 2.4 °C 95 % East 5.3 km/h 11.3 km/h 1,008.40 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:14 PM 3.2 °C 2.4 °C 95 % East 6.6 km/h 10.9 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:19 PM 3.3 °C 2.4 °C 94 % NNE 6.0 km/h 10.5 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:24 PM 3.3 °C 2.4 °C 94 % NE 5.8 km/h 9.4 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:29 PM 3.3 °C 2.4 °C 94 % East 5.0 km/h 9.6 km/h 1,008.40 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:34 PM 3.3 °C 2.4 °C 94 % NE 4.7 km/h 8.9 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:39 PM 3.4 °C 2.5 °C 94 % East 5.0 km/h 9.8 km/h 1,008.50 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:44 PM 3.5 °C 2.6 °C 94 % East 5.7 km/h 10.0 km/h 1,008.40 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:49 PM 3.5 °C 2.6 °C 94 % ESE 5.2 km/h 9.3 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:54 PM 3.5 °C 2.6 °C 94 % East 5.5 km/h 8.8 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 6:59 PM 3.4 °C 2.6 °C 95 % ESE 5.2 km/h 8.5 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:04 PM 3.5 °C 2.8 °C 95 % East 4.5 km/h 8.4 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:09 PM 3.5 °C 2.7 °C 95 % East 5.1 km/h 9.4 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:14 PM 3.4 °C 2.5 °C 94 % SSE 4.6 km/h 8.5 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:19 PM 3.4 °C 2.6 °C 95 % SE 4.6 km/h 7.9 km/h 1,008.40 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:24 PM 3.4 °C 2.6 °C 95 % NE 4.0 km/h 8.0 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:29 PM 3.3 °C 2.4 °C 94 % ENE 3.9 km/h 7.7 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:34 PM 3.3 °C 2.4 °C 94 % SSE 4.6 km/h 7.8 km/h 1,008.50 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:39 PM 3.3 °C 2.4 °C 94 % ENE 5.0 km/h 8.0 km/h 1,008.30 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:44 PM 3.3 °C 2.4 °C 94 % ENE 4.4 km/h 8.7 km/h 1,008.09 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:49 PM 3.2 °C 2.3 °C 94 % East 4.8 km/h 7.4 km/h 1,007.79 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:54 PM 3.1 °C 2.2 °C 94 % East 4.5 km/h 8.5 km/h 1,007.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 7:59 PM 2.8 °C 1.9 °C 94 % NNE 3.9 km/h 7.4 km/h 1,007.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:04 PM 2.7 °C 1.8 °C 94 % East 3.6 km/h 7.0 km/h 1,007.79 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:09 PM 2.5 °C 1.8 °C 95 % NE 4.0 km/h 7.1 km/h 1,007.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:14 PM 2.4 °C 1.7 °C 95 % East 3.5 km/h 7.2 km/h 1,007.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:19 PM 2.4 °C 1.7 °C 95 % NNE 3.9 km/h 6.7 km/h 1,007.79 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:24 PM 2.4 °C 1.8 °C 96 % NE 3.4 km/h 6.9 km/h 1,007.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:29 PM 2.3 °C 1.7 °C 96 % East 3.3 km/h 6.5 km/h 1,007.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:34 PM 2.2 °C 1.6 °C 96 % ESE 3.4 km/h 6.3 km/h 1,007.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:39 PM 2.1 °C 1.5 °C 96 % ENE 3.6 km/h 6.6 km/h 1,007.99 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:44 PM 2.0 °C 1.5 °C 97 % ENE 3.3 km/h 6.3 km/h 1,007.89 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:49 PM 1.9 °C 1.5 °C 97 % East 3.4 km/h 6.3 km/h 1,007.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:54 PM 1.9 °C 1.5 °C 97 % East 3.3 km/h 6.8 km/h 1,007.79 hPa 0.00 mm 0.10 mm 0 0 w/m² 8:59 PM 1.9 °C 1.5 °C 97 % ENE 3.5 km/h 6.6 km/h 1,007.59 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:04 PM 1.7 °C 1.3 °C 97 % ENE 3.0 km/h 5.8 km/h 1,007.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:09 PM 1.8 °C 1.4 °C 97 % ENE 3.0 km/h 5.9 km/h 1,007.48 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:14 PM 1.7 °C 1.3 °C 97 % ENE 3.3 km/h 5.6 km/h 1,007.59 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:19 PM 1.7 °C 1.4 °C 98 % East 2.9 km/h 5.8 km/h 1,007.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:24 PM 1.7 °C 1.4 °C 98 % ENE 3.0 km/h 6.1 km/h 1,007.79 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:29 PM 1.6 °C 1.3 °C 98 % ENE 3.3 km/h 5.4 km/h 1,007.89 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:34 PM 1.6 °C 1.3 °C 98 % East 2.8 km/h 4.6 km/h 1,008.20 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:39 PM 1.5 °C 1.2 °C 98 % East 3.4 km/h 5.8 km/h 1,008.60 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:44 PM 1.5 °C 1.2 °C 98 % ENE 2.9 km/h 6.1 km/h 1,008.81 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:49 PM 1.4 °C 1.1 °C 98 % East 2.2 km/h 5.3 km/h 1,009.21 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:54 PM 1.5 °C 1.2 °C 98 % ESE 2.8 km/h 5.5 km/h 1,009.21 hPa 0.00 mm 0.10 mm 0 0 w/m² 9:59 PM 1.5 °C 1.2 °C 98 % ENE 2.9 km/h 6.1 km/h 1,009.31 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:04 PM 1.4 °C 1.1 °C 98 % ESE 2.2 km/h 5.0 km/h 1,009.31 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:09 PM 1.4 °C 1.2 °C 99 % East 2.5 km/h 5.3 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:14 PM 1.4 °C 1.2 °C 99 % East 2.5 km/h 5.4 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:19 PM 1.4 °C 1.3 °C 99 % East 2.5 km/h 5.2 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:24 PM 1.4 °C 1.3 °C 99 % East 2.2 km/h 4.8 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:29 PM 1.3 °C 1.2 °C 99 % ESE 2.3 km/h 5.0 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:34 PM 1.3 °C 1.2 °C 99 % East 2.4 km/h 5.0 km/h 1,009.58 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:39 PM 1.2 °C 1.1 °C 99 % East 3.0 km/h 5.9 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:44 PM 1.1 °C 1.0 °C 99 % ENE 2.3 km/h 5.7 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:49 PM 1.0 °C 0.9 °C 99 % East 3.5 km/h 6.4 km/h 1,009.41 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:54 PM 1.0 °C 0.9 °C 99 % ENE 2.6 km/h 4.7 km/h 1,009.58 hPa 0.00 mm 0.10 mm 0 0 w/m² 10:59 PM 1.0 °C 0.9 °C 99 % East 3.2 km/h 6.0 km/h 1,009.58 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:04 PM 0.9 °C 0.8 °C 99 % East 3.2 km/h 5.8 km/h 1,009.58 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:09 PM 0.9 °C 0.8 °C 99 % East 3.7 km/h 6.1 km/h 1,009.69 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:14 PM 0.8 °C 0.7 °C 99 % East 3.4 km/h 6.1 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:19 PM 0.7 °C 0.6 °C 99 % East 4.0 km/h 6.4 km/h 1,009.52 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:24 PM 0.6 °C 0.5 °C 99 % East 3.0 km/h 6.1 km/h 1,009.41 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:29 PM 0.6 °C 0.5 °C 99 % ENE 3.5 km/h 6.4 km/h 1,009.41 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:34 PM 0.6 °C 0.5 °C 99 % ESE 3.3 km/h 6.5 km/h 1,009.31 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:39 PM 0.5 °C 0.4 °C 99 % ESE 3.3 km/h 6.6 km/h 1,009.41 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:44 PM 0.5 °C 0.4 °C 99 % ENE 3.6 km/h 6.0 km/h 1,009.58 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:49 PM 0.6 °C 0.5 °C 99 % ENE 3.6 km/h 6.0 km/h 1,009.58 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:54 PM 0.6 °C 0.5 °C 99 % NE 3.2 km/h 5.9 km/h 1,009.58 hPa 0.00 mm 0.10 mm 0 0 w/m² 11:59 PM 0.7 °C 0.6 °C 99 % ENE 3.3 km/h 6.0 km/h 1,009.69 hPa 0.00 mm 0.10 mm 0 0 w/m² -
Are they going to be grid tied?
Any ideas what is happening with my PV array
SteamyTea replied to Omnibuswoman's topic in Photovoltaics (PV)
Compound angles. This is what happened yesterday at your location time azimuth altitude 0:00 357.180818755071 -61.6108354278184 0:05 359.61668661041 -61.6330550884409 0:10 2.05329956310104 -61.6214672324821 0:15 4.48592702567635 -61.5761152767721 0:20 6.90989644479006 -61.4971684757178 0:25 9.32066014151002 -61.3849189414315 0:30 11.7138577589677 -61.2397765763194 0:35 14.0853722793371 -61.0622621226386 0:40 16.4313779756364 -60.8529986006766 0:45 18.7483791465371 -60.6127014557525 0:50 21.0332389994977 -60.342167762126 0:55 23.2831985552697 -60.0422648390694 1:00 25.495885907197 -59.7139186225241 1:05 27.6693165532395 -59.3581021080349 1:10 29.8018858100251 -58.9758241409685 1:15 31.8923545103306 -58.5681187826839 1:20 33.9398292818487 -58.1360354304566 1:25 35.94373871688 -57.6806298182058 1:30 37.9038066853825 -57.2029559773628 1:35 39.8200239353545 -56.7040591946078 1:40 41.6926189824423 -56.1849699670021 1:45 43.5220291309378 -55.6466989257839 1:50 45.308872304231 -55.0902326777719 1:55 47.0539202045494 -54.5165304974741 2:00 48.7580731766053 -53.9265217928929 2:05 50.4223370219787 -53.3211042627723 2:10 52.0478019027894 -52.7011426617282 2:15 53.635623384774 -52.0674680914223 2:20 55.187005600363 -51.4208777398832 2:25 56.7031864599669 -50.7621349965298 2:30 58.1854248022622 -50.0919698768166 2:35 59.6349893494405 -49.4110796972383 2:40 61.0531493188216 -48.7201299483318 2:45 62.4411665357812 -48.0197553200375 2:50 63.8002888926875 -47.3105608401486 2:55 65.1317450028177 -46.5931230924628 3:00 66.4367399056911 -45.867991486597 3:05 67.7164516897788 -45.1356895562076 3:10 68.9720289092751 -44.3967162665704 3:15 70.2045886828754 -43.6515473161487 3:20 71.4152153737944 -42.9006364199446 3:25 72.6049597612462 -42.1444165651302 3:30 73.7748386240254 -41.3833012317406 3:35 74.9258346665566 -40.6176855731229 3:40 76.058896726707 -39.8479475524235 3:45 77.1749402127651 -39.0744490327035 3:50 78.2748477242762 -38.2975368193275 3:55 79.3594698179197 -37.517543654131 4:00 80.4296258853489 -36.7347891615463 4:05 81.4861051149685 -35.9495807473951 4:10 82.5296675140235 -35.1622144514643 4:15 83.561044971205 -34.3729757552841 4:20 84.5809423432908 -33.5821403467458 4:25 85.5900385521842 -32.7899748433474 4:30 86.588987681156 -31.9967374759495 4:35 87.5784200611808 -31.2026787349724 4:40 88.5589433400231 -30.4080419809783 4:45 89.5311435282283 -29.6130640215702 4:50 90.4955860174333 -28.817975656499 4:55 91.4528165674682 -28.0230021928189 5:00 92.4033622595968 -27.2283639318669 5:05 93.3477324139805 -26.434276629764 5:10 94.286419470044 -25.6409519330578 5:15 95.2198998289151 -24.8485977910411 5:20 96.1486346575084 -24.0574188461914 5:25 97.0730706541406 -23.2676168040917 5:30 97.993640775814 -22.4793907841026 5:35 98.9107649275034 -21.6929376519706 5:40 99.8248506139273 -20.9084523354696 5:45 100.73629355439 -20.1261281240922 5:50 101.64547826136 -19.3461569537244 5:55 102.552778583499 -18.5687296771578 6:00 103.458558213871 -17.7940363212191 6:05 104.363171164086 -17.0222663312207 6:10 105.266962205109 -16.2536088033655 6:15 106.170267275454 -15.4882527056705 6:20 107.073413857459 -14.726387087905 6:25 107.976721322289 -13.9682012809766 6:30 108.880501244293 -13.2138850861334 6:35 109.785057685285 -12.4636289542916 6:40 110.690687449274 -11.717624155737 6:45 111.597680308149 -10.9760629403927 6:50 112.506319198727 -10.2391386887883 6:55 113.416880391601 -9.50704605381167 7:00 114.329633632126 -8.77998109327118 7:05 115.244842253868 -8.05814139324533 7:10 116.162763264834 -7.34172618214314 7:15 117.08364740672 -6.63093643535398 7:20 118.007739187461 -5.92597497031293 7:25 118.935276887295 -5.22704653176432 7:30 119.866492538595 -4.53435786695991 7:35 120.801611879688 -3.84811779048492 7:40 121.740854282937 -3.16853723836259 7:45 122.684432657335 -2.49582931105095 7:50 123.632553325938 -1.83020930490486 7:55 124.585415878486 -1.17189473164429 8:00 125.543212999612 -0.521105325337236 8:05 126.506130273135 0.121936963622813 8:10 127.474345962988 0.757007988089898 8:15 128.448030771445 1.38388143785222 8:20 129.427347575416 2.0023288880143 8:25 130.412451141695 2.61211986266417 8:30 131.403487822206 3.21302191441938 8:35 132.400595230419 3.80480072044451 8:40 133.403901900292 4.3872201955223 8:45 134.413526929265 4.96004262274187 8:50 135.429579607035 5.52302880234328 8:55 136.45215903203 6.07593821922117 9:00 137.481353717724 6.61852922954444 9:05 138.517241191161 7.1505592668941 9:10 139.559887586263 7.67178506825513 9:15 140.609347234763 8.18196292011805 9:20 141.665662257801 8.6808489248586 9:25 142.728862161468 9.16819928746058 9:30 143.798963439826 9.6437706225328 9:35 144.875969189087 10.1073202814459 9:40 145.959868736916 10.5586066992771 9:45 147.050637290908 10.9973897611005 9:50 148.148235610528 11.4234311870029 9:55 149.252609706869 11.8364949350354 10:00 150.363690574692 12.2363476211318 10:05 151.48139396126 12.6227589548436 10:10 152.605620176481 12.9955021895487 10:15 153.736253948821 13.3543545856013 10:20 154.873164331334 13.6990978846947 10:25 156.016204662027 14.0295187935194 10:30 157.165212582506 14.3454094746115 10:35 158.3200101186 14.6465680421073 10:40 159.48040382628 14.9327990599528 10:45 160.646185005772 15.2039140399614 10:50 161.817129986299 15.4597319369776 10:55 162.9930004833 15.7000796382885 11:00 164.173544029419 15.9247924443308 11:05 165.35849447986 16.1337145376769 11:10 166.547572592032 16.3266994372463 11:15 167.74048667866 16.5036104346818 11:20 168.936933332786 16.6643210098614 11:25 170.136598222309 16.8087152225757 11:30 171.339156950934 16.9366880775006 11:35 172.544275981637 17.0481458597302 11:40 173.751613618028 17.1430064383 11:45 174.960821038258 17.2211995353358 11:50 176.171543375508 17.2826669586986 11:55 177.383420838476 17.3273627962568 12:00 178.596089864787 17.3552535702109 12:05 179.809184299805 17.3663183502066 12:10 181.022336593025 17.3605488243033 12:15 182.235179003945 17.3379493272116 12:20 183.447344809243 17.2985368255629 12:25 184.658469503024 17.242340860337 12:30 185.868191982024 17.1694034469211 12:35 187.076155707835 17.0797789336286 12:40 188.282009838538 16.9735338198371 12:45 189.485410322504 16.8507465352269 12:50 190.686020947632 16.711507181897 12:55 191.883514339844 16.5559172414102 13:00 193.0775729053 16.3840892490622 13:05 194.267889711467 16.1961464378816 13:10 195.454169302918 15.992222355049 13:15 196.636128448504 15.7724604535667 13:20 197.813496817284 15.5370136621217 13:25 198.986017581401 15.2860439361548 13:30 200.153447944855 15.0197217931925 13:35 201.315559597847 14.7382258354993 13:40 202.472139097098 14.4417422630827 13:45 203.622988173217 14.1304643800256 13:50 204.767923966792 13.8045920970376 13:55 205.906779195477 13.4643314330052 14:00 207.039402254806 13.1098940181934 14:05 208.165657255962 12.7414966015993 14:10 209.285424004054 12.359360564797 14:15 210.398597920803 11.9637114444344 14:20 211.505089915749 11.5547784653613 14:25 212.604826210322 11.1327940861749 14:30 213.69774811918 10.6979935587788 14:35 214.783811793337 10.2506145033552 14:40 215.862987929596 9.7908964999641 14:45 216.935261450756 9.31908069779135 14:50 218.000631161012 8.83540944289358 14:55 219.059109380835 8.34012592511047 15:00 220.110721565481 7.83347384465685 15:05 221.155505911106 7.31569709875142 15:10 222.193512952276 6.78703948849885 15:15 223.224805154444 6.24774444611304 15:20 224.249456504743 5.69805478244993 15:25 225.267552104237 5.13821245471335 15:30 226.279187764515 4.56845835410464 15:35 227.284469611286 3.98903211310341 15:40 228.283513697419 3.40017193199738 15:45 229.276445627632 2.80211442422084 15:50 230.263400196813 2.19509448001129 15:55 231.244521043779 1.57934514785623 16:00 232.219960322033 0.955097533173538 16:05 233.18987838896 0.322580713647316 16:10 234.154443514658 -0.317978329370379 16:15 235.113831611513 -0.966354763985493 16:20 236.068225985438 -1.62232594600854 16:25 237.017817109583 -2.28567144290572 16:30 237.962802421216 -2.95617304402396 16:35 238.903386142349 -3.63361475764192 16:40 239.839779124638 -4.31778279537509 16:45 240.772198718963 -5.00846554443504 16:50 241.700868670081 -5.70545352821386 16:55 242.62601903665 -6.40853935563017 17:00 243.547886136931 -7.11751765963603 17:05 244.466712520407 -7.83218502524653 17:10 245.382746965574 -8.55233990741225 17:15 246.296244504128 -9.27778253901111 17:20 247.207466471795 -10.0083148291931 17:25 248.116680586039 -10.7437402522644 17:30 249.02416105092 -11.4838637272495 17:35 249.93018868939 -12.2284914882218 17:40 250.83505110333 -12.9774309454437 17:45 251.739042861692 -13.7304905373021 17:50 252.642465717129 -14.4874795729787 17:55 253.545628851536 -15.2482080657336 18:00 254.448849150982 -16.01248655663 18:05 255.352451510545 -16.7801259284686 18:10 256.256769169615 -17.5509372096422 18:15 257.162144078253 -18.3247313675601 18:20 258.06892729528 -19.1013190912311 18:25 258.977479418747 -19.8805105625276 18:30 259.888171049512 -20.6621152155894 18:35 260.801383288658 -21.4459414837547 18:40 261.717508269482 -22.2317965333385 18:45 262.636949724818 -23.0194859835016 18:50 263.560123590393 -23.8088136113793 18:55 264.487458644919 -24.5995810415637 19:00 265.419397187513 -25.3915874189464 19:05 266.356395752994 -26.1846290638528 19:10 267.298925865407 -26.9784991083091 19:15 268.247474830009 -27.7729871121994 19:20 269.202546563671 -28.5678786579815 19:25 270.164662463384 -29.362954922543 19:30 271.13436231217 -30.15799222469 19:35 272.112205221242 -30.9527615466762 19:40 273.098770606705 -31.7470280280995 19:45 274.094659198382 -32.5405504304111 19:50 275.100494077543 -33.3330805702202 19:55 276.116921739286 -34.1243627195136 20:00 277.14461317417 -34.9141329708717 20:05 278.184264962228 -35.7021185657367 20:10 279.236600370858 -36.4880371837955 20:15 280.302370446084 -37.2715961915743 20:20 281.382355084353 -38.0524918484224 20:25 282.477364069342 -38.8304084681935 20:30 283.588238055056 -39.6050175351272 20:35 284.715849472879 -40.3759767727113 20:40 285.861103335981 -41.1429291646741 20:45 287.024937909684 -41.9055019277451 20:50 288.208325210831 -42.6633054364524 20:55 289.412271293005 -43.415932101017 21:00 290.637816267351 -44.1629552003983 21:05 291.886034000961 -44.9039276737705 21:10 293.158031426066 -45.6383808752006 21:15 294.454947383828 -46.3658232981086 21:20 295.777950916296 -47.0857392782499 21:25 297.128238909255 -47.7975876865295 21:30 298.507032977494 -48.5008006259673 21:35 299.915575472678 -49.1947821506516 21:40 301.355124483066 -49.8789070285494 21:45 302.826947684334 -50.55251957465 21:50 304.332314892532 -51.2149325860842 21:55 305.872489164803 -51.8654264165842 22:00 307.448716292133 -52.5032482338729 22:05 309.062212532751 -53.1276115102012 22:10 310.714150446538 -53.7376958031208 22:15 312.405642712189 -54.3326468904551 22:20 314.137723842068 -54.9115773299878 22:25 315.911329757114 -55.4735675201825 22:30 317.72727524808 -56.0176673427334 22:35 319.586229431727 -56.5428984702558 22:40 321.488689412581 -57.048257422158 22:45 323.43495248267 -57.5327194478353 22:50 325.425087331716 -57.9952433078469 22:55 327.45890489506 -58.4347770097858 23:00 329.535929629771 -58.8502645353253 23:05 331.655372171812 -59.2406535678817 23:10 333.816104476371 -59.6049041962791 23:15 336.016638664339 -59.9419985291124 23:20 338.255110873199 -60.2509511082073 23:25 340.529271422352 -60.5308199595081 23:30 342.836482534519 -60.7807180685312 23:35 345.173724693684 -60.9998250186445 23:40 347.537612459687 -61.1873984878775 23:45 349.924420203078 -61.3427852680218 23:50 352.330117784761 -61.4654314525662 23:55 354.75041570843 -61.5548914409391 -
If I go to a site and try and work out who the idiot is and fail, then I know it is me.
Embrace the homo-erotic behaviour.
What curves and what brands for consumer unit at modules.
SteamyTea replied to MikeSharp01's topic in Power Circuits
I have an induction hob, consumer unit still uses fuse wire. Never had a problem. I do seem to remember that there was something in the box about what type of breaker to use. Just had a quick look at a similar model and all it says is: "A circuit breaker with a contact opening of at least 3 mm, rated 32A and delayed functioning type must be installed inside the supply circuit." So no help at all. Why has the price gone up by 200 quid in 3 years, I only paid £140 for mine, now £350.
