joth Posted March 31, 2019 Share Posted March 31, 2019 (edited) We're planning skylights in the faulted ceiling over the hallway -- 2.5 stories up. It will make great stack cooling, but that means electric (and ideally automatable) opening. Velux do one, but I've heard mixed things about it so at least want to explore a second option. Fakro can do PassiveHouse certified OR electric opening, but not both together, AFAICT. Any others I should look at, or just make Velux work? Edited April 1, 2019 by joth Link to comment Share on other sites More sharing options...
MikeSharp01 Posted March 31, 2019 Share Posted March 31, 2019 (edited) Both Fakro I hope ours open electrically as that is what we ordered and Velux supply ph rooflights with electric opening. Edited March 31, 2019 by MikeSharp01 Link to comment Share on other sites More sharing options...
jack Posted March 31, 2019 Share Posted March 31, 2019 1 hour ago, joth said: Farko can do Passiv or electric opening, but not both together AFAICT. What do you mean by "Passiv"? Do you mean PassivHaus certified? Is it on a flat or pitched roof? We have an electric opening quad (I think!) glazed Fakro rooflight on our flat roof. Not PH certified, but the numbers are fine. Link to comment Share on other sites More sharing options...
joth Posted April 1, 2019 Author Share Posted April 1, 2019 Yes, by Passiv I meant PH certified, editted to clarify. This will be on a 45° roof. I was using the Fakro product selector and pricelist: the U8 seems to be the only PH certified opening windows, but they're not list on pages 18-19 with all the other electrically opening units. Link to comment Share on other sites More sharing options...
jack Posted April 1, 2019 Share Posted April 1, 2019 55 minutes ago, joth said: Yes, by Passiv I meant PH certified, editted to clarify. Cool, thanks. Next question: why do you need them to be PH certified? From memory, PH-certified windows aren't a requirement even if you're going for PH certification. It's just that you get a little more leeway in the numbers (can't remember how it works for windows, but as an example, for MVHR you need to put in a penalty factor of something like 15% if the unit isn't PH-certified). If you aren't going for certification, I'd just look at the specs and make sure you're happy with them. The PH-certified product will be more expensive than the same spec non-certified, because of the fees paid to the PH Institute for certification. If you are going for certification, then it's only one window, and using a non-certified product in this position will likely make no difference to your ability to achieve certification (assuming appropriate specs otherwise). Link to comment Share on other sites More sharing options...
joth Posted April 1, 2019 Author Share Posted April 1, 2019 @jack That helps a lot. Obviously for majority of windows they should really be certified else the penalties would add up. But for the odd awkward one we can negotiate it. Very helpful input to be heading into detailed design with. Thank you. Yep the goal is certified EnerPHit. 1 Link to comment Share on other sites More sharing options...
Ferdinand Posted April 2, 2019 Share Posted April 2, 2019 (edited) 23 hours ago, jack said: PH-certified windows aren't a requirement even if you're going for PH certification. ????????? Loving it... Edited April 2, 2019 by Ferdinand Link to comment Share on other sites More sharing options...
Alex C Posted April 2, 2019 Share Posted April 2, 2019 When I spoke to Peter Warm, a Passivehause certifier he said not to worry about rooflights if they are in a communal area such as a hall as they are treated differently than if in your bedroom. He didn't have any problem with the two massive triple glazed automated Velux ones that I specified on my build. The Passivehause certified ones only come in smaller sizes, I guess because of the weight. The Velux rooflight didn't cause any issue on the airtest either. Link to comment Share on other sites More sharing options...
Eileen Posted April 20, 2019 Share Posted April 20, 2019 Our electrically opening one s is from Lamilux (around 60cms square) and is Passivhaus Certified - as is the house as a whole because the plaque arrived in the post today! We also have a big Lamilux roof-light (4m x 5m) but that is non-opening and has an external blind. 1 Link to comment Share on other sites More sharing options...
Gone West Posted April 20, 2019 Share Posted April 20, 2019 2 hours ago, Eileen said: Our electrically opening one s is from Lamilux (around 60cms square) and is Passivhaus Certified - as is the house as a whole because the plaque arrived in the post today! Congratulations . Link to comment Share on other sites More sharing options...
Eileen Posted April 20, 2019 Share Posted April 20, 2019 Thanks! Link to comment Share on other sites More sharing options...
Gone West Posted April 20, 2019 Share Posted April 20, 2019 22 minutes ago, Eileen said: Thanks! Take a picture of the plaque and use it as your avatar . 1 Link to comment Share on other sites More sharing options...
lizzie Posted April 20, 2019 Share Posted April 20, 2019 Well done @Eileen put some pics up please Link to comment Share on other sites More sharing options...
Eileen Posted April 20, 2019 Share Posted April 20, 2019 (edited) Thanks! Website is www.thewalledgardendevon.uk Edited April 20, 2019 by Eileen 1 1 Link to comment Share on other sites More sharing options...
lizzie Posted April 20, 2019 Share Posted April 20, 2019 Great house @Eileen... well done! 1 Link to comment Share on other sites More sharing options...
Gone West Posted April 21, 2019 Share Posted April 21, 2019 @Eileen It is stunning, well done. 1 Link to comment Share on other sites More sharing options...
newhome Posted April 21, 2019 Share Posted April 21, 2019 Gorgeous house @Eileen, well done! 1 Link to comment Share on other sites More sharing options...
PeterW Posted April 21, 2019 Share Posted April 21, 2019 @Eileen looks beautiful. Is that hoggin that’s been used for the paths..?? 1 Link to comment Share on other sites More sharing options...
vivienz Posted April 21, 2019 Share Posted April 21, 2019 Gosh, what a fabulous house! Amazing attention to detail. 1 Link to comment Share on other sites More sharing options...
Eileen Posted April 21, 2019 Share Posted April 21, 2019 @PeterW It's Cedec self-binding gravel - scarily bright gold when laid but then soon calms down to this pale look and hardens up with rain and footfall. 1 Link to comment Share on other sites More sharing options...
Eileen Posted April 21, 2019 Share Posted April 21, 2019 Have finally done an "introduce yourself" entry, so that's probably a better place to discuss the project than hijacking this thread! Also it's me rather than Eileen that's doing most of the writing as she's too busy doing the landscape..... Link to comment Share on other sites More sharing options...
scottishjohn Posted April 21, 2019 Share Posted April 21, 2019 I must be thick or more likley computer illiterate where are all the pictures please Link to comment Share on other sites More sharing options...
Jeremy Harris Posted April 21, 2019 Share Posted April 21, 2019 16 minutes ago, scottishjohn said: I must be thick or more likley computer illiterate where are all the pictures please If you follow the link above (https://thewalledgardendevon.wordpress.com/ ) and then click on "photos" on the top menu it takes you to a page with a link to a lot of photos. The direct link to all the photos is: https://www.flickr.com/photos/nigpic/sets/72157688294789963 (for all the construction photos) or this: https://www.flickr.com/photos/nigpic/sets/72157704667571174 (for all the completed photos). 1 Link to comment Share on other sites More sharing options...
joth Posted April 30, 2019 Author Share Posted April 30, 2019 (Strangely didn't see any these replies until now - sorry!) On 02/04/2019 at 12:31, Alex C said: When I spoke to Peter Warm, a Passivehause certifier he said not to worry about rooflights if they are in a communal area such as a hall as they are treated differently than if in your bedroom. He didn't have any problem with the two massive triple glazed automated Velux ones that I specified on my build. The Passivehause certified ones only come in smaller sizes, I guess because of the weight. The Velux rooflight didn't cause any issue on the airtest either. Thanks! I hadn't heard about the difference for communal areas (I thought that was more about shared-use passegeways in apartment blocks, but maybe totally confused!) On 20/04/2019 at 10:58, Eileen said: Our electrically opening one s is from Lamilux (around 60cms square) and is Passivhaus Certified - as is the house as a whole because the plaque arrived in the post today! We also have a big Lamilux roof-light (4m x 5m) but that is non-opening and has an external blind. Thanks - hadn't seen Lamilux before, I'll have a look. And, congrats on the build. Looks amazing! 1 Link to comment Share on other sites More sharing options...
joth Posted May 2, 2019 Author Share Posted May 2, 2019 (edited) Anyone heard of / got experience of "Roof Maker" rooflights & skylights? Luxlite for pitched roofs Roof lights overview - inc fancy stuff like sliding lanterns and a round one Quoted U values are good, typical best cases in the 0.6 area. Remote control opening and blackout blinds as an option. Targeting the Passive House market. 20 year warranty. Made in Leicester, UK What am I missing? Edited May 2, 2019 by joth 1 Link to comment Share on other sites More sharing options...
