I was glad I didn't do a final check  for level when I stopped working on the mezzanine joists last night. I would have had another really bad nights sleep.
Look at this.... this is how un-level  I managed to nail the joists hanger: no, the red laser line isn't disappearing to infinity, it's 30mm out at one end and 0 on the other - over 2 meters
For those of you wondering what self-build does to you - it makes you tired enough to make significant - and sometimes costly- errors
All I had to do last night was
  • recognise how tired I was
  • tack the joists in position with cramps and one or two nails
  • go home
But no, I had to hammer home 24 nails on the joist hanger with one end of the joist 30mm too low.
In the cold light of day it beggars belief .
The remedy?
Make a 2 meter long stealer piece (wedge) : half a day's work
and thank God for Debbie's Christmas cake.
Ahhh - you've a curve on the icing there - that means an end piece - they're the best. building cock up or not, that has to level things out for the day.
(see what i did at the end there?)
At 10pm last night I was about to cut a hole in the only working foul drain on site to fit a boss and merge in the grey water drainage from the static caravan. Then I thought if I get this wrong it is back to bucket & chuck-it in the morning. I put my drill down, called it a day and slept well.
It takes a lot to recognise you are tired and might make mistakes, I used to try and do stuff that took brain power earlier in the day and mundane graft later.
1 hour ago, Construction Channel said:
On the bright side, at least you are getting out there and doing it. I am really struggling to drag myself to the house atm. ?
Been there, know the feeling. I gave up bothering for a week or so until I felt like it. Guilt free, conscious decision not to go or try. Did things a liked including bugger all. Plus some vitamin B50 tablets helped.
  • go home
The remedy?
Done this too! 10 studs at 2570? no bother. wham bam. Huh? Eh? Oh.... 2750.
At least you can shorten them to the correct length. It could have been worse.
I'm hoping a couple of weeks skiing next week will revive my enthusiasm ??
Or just pack the end of the support beam up by 30mm! Job done!
Edited by Triassic
Typo
17 hours ago, Construction Channel said:
Love it, just printed this off to hang in my workshop, shame I can’t print it any larger!!
