Nestor Posted August 2, 2018 Posted August 2, 2018 Can anyone recommend a UFH suppliers for new build as some of the quotes for supply and fit are a bit OTT. Screed on ground floor and first floor floating with diffuser plates. Thank you
CC45 Posted August 2, 2018 Posted August 2, 2018 Hi, Try Wunda. Google search them. They are supply only - you will need a plumber to install them or DIY it. Good luck. 1
PeterW Posted August 2, 2018 Posted August 2, 2018 WundaTrade is what a lot of us use. Yes, you can get pipe on eBay for 5-10p/m cheaper but with everything from Wunda it all fits as a kit and it’s pretty good stuff. @Nickfromwales prefers a different pump set but have a look at the design of the blending set and see if it suits your needs. 1
ProDave Posted August 2, 2018 Posted August 2, 2018 I got all mine from ebay, mostly from a dealer called PSW Trade Supplies LTD 1
nod Posted August 2, 2018 Posted August 2, 2018 We bought all of ours from warmup See if it’s any good tomorrow when we commission the UFH 1
Onoff Posted August 2, 2018 Posted August 2, 2018 @Nickfromwales I think knows this lot...discount? https://www.bhfunlimited.co.uk 1
Nickfromwales Posted August 2, 2018 Posted August 2, 2018 TBH Wunda are very competitive for a good product delivered. I have asked to speak to their sales manager as to why they stopped selling the capillary pump and blending sets that they used to. The blending sets I use in low energy properties are the Ivar Dualmix. Be careful to choose the wider temp range model, as one has a rather narrow temp selection. @JamesP If you send your plans to Wunda they'll do all the plans and QS list for free
Nestor Posted August 2, 2018 Author Posted August 2, 2018 @Nickfromwales Thanks Nick, I am haggling with Nuheat to supply kit and thought I should find an alternative. Getting there....
Nickfromwales Posted August 2, 2018 Posted August 2, 2018 Just now, JamesP said: @Nickfromwales Thanks Nick, I am haggling with Nuheat to supply kit and thought I should find an alternative. Getting there.... Get the quote sent to Boulder Developments, Wunda and NuHeat and get them warring 1
Redoctober Posted August 2, 2018 Posted August 2, 2018 Our materials were supplied by - http://www.optimumunderfloor.co.uk/ Another option to consider perhaps. 1
Nestor Posted August 13, 2018 Author Posted August 13, 2018 Quick question, One supplier has specified 1 x Wilo Para RS25/6 pump and another supplier 3 x Grundfos 22kW. 150sqm on the ground floor and 65sqm 1st floor. Your thoughts appreciated. Thanks.
Nickfromwales Posted August 13, 2018 Posted August 13, 2018 25 minutes ago, JamesP said: Quick question, One supplier has specified 1 x Wilo Para RS25/6 pump and another supplier 3 x Grundfos 22kW. 150sqm on the ground floor and 65sqm 1st floor. Your thoughts appreciated. Thanks. Pumps on manifolds ? 3 manifolds? More info please 1
Nestor Posted August 13, 2018 Author Posted August 13, 2018 @Nickfromwales Thanks Nick for picking this up. I have enclosed the item lists. Both have 3 x Manifolds. Nuheat 8,5,7. 1 x pump. Wunda 6,11,4. 3 x pump. Nuheat Items.pdf Wunda.pdf
Alexphd1 Posted August 13, 2018 Posted August 13, 2018 I have never came across 14mm pex as in the nuheat quote. I believe the wunda is mlcp type pipe if it is, it's nice stuff to work with?
Nestor Posted August 13, 2018 Author Posted August 13, 2018 @Alexphd1 I am surprised NH are using 14mm. Wunda use 16mm MLC Pert/AI/Pert Pipe.
PeterW Posted August 13, 2018 Posted August 13, 2018 (edited) That NuHeat system won’t work... not the first time I’ve seen them cut cost out with only a single pump too. Ask them for the flow rate per circuit and the total flow rate of the pump .... Edited to add that Wunda have included their self regulating valve heads - they are the dogs, wins my vote any day of the week .. Edited August 13, 2018 by PeterW 1
Nestor Posted August 13, 2018 Author Posted August 13, 2018 (edited) Thanks @PeterW I will ask for clarification. Edited August 13, 2018 by JamesP
Nickfromwales Posted August 14, 2018 Posted August 14, 2018 You need one manifold and one pump and blending set per floor minimum. Im not so sure you can't do both floors with 2 sets. Why are they mentioning 3 pumps? 3 pumps would mean 3 manifold locations, so are you doing towel rads off a 3rd ?
Nestor Posted August 14, 2018 Author Posted August 14, 2018 @Nickfromwales We do have 3 levels even though the lower ground is only a metre below the entrance ground floor level. LG is 84 sqm, GF is 114 sqm. FF is 84 sqm. 2 manifolds were going to cover the LG and GF. 1 manifold for FF. What spacing do you recommend for pipes. GF is all in screed with timber floor boards and FF is diffuser with timber floor boards.
Nickfromwales Posted August 15, 2018 Posted August 15, 2018 If you go for an ASHP, then I'd go for 3 runs of pipe to a void for the areas in spreader plates, that will give you more volume so less temp required to get the equivalent w/m2, and in the screed id go for 150mm centres. You want to get the volume of water & cross-sectional area up, and the flow temp down 3 pipe plate No reason why the LG and GF cant be on the same manifold as that'll be the highest point and will vent itself without issue. Manifolds are available as big as 12 ports so no bother from that PoV but will save you cost / complexity / extra 22mm primary HP pipe runs to the 3rd manifold / no 3rd wiring centre and less physical size / impact for the overall installation. I'd be very surprised if you cant do that off one manifold tbh, ( + the second manifold for FF of course ). Ask the question with your chosen supplier 1
Triassic Posted August 16, 2018 Posted August 16, 2018 On 02/08/2018 at 09:00, ProDave said: I got all mine from ebay, mostly from a dealer called PSW Trade Supplies LTD Just a word of warning I ordered a UFH pipe from them a week ago on a promise of a two day delivery. I’m still waiting for delivery a week later. I’ve now cancelled the order and will go elsewhere.
AdamSee Posted September 24, 2018 Posted September 24, 2018 (edited) I used Omnie to do my renovation job. I used the torfloor system which is just chipboard flooring routed out to accept a 12mm pipe, but they do all the normal screed systems etc. The price seemed reasonable, but hard to compare as everything has to be quoted for and its priced as an lump sum. Was delivered within the week tho which was great....excepts its all be sat in my living room for 4 weeks now. Edited September 24, 2018 by AdamSee 1
Alexphd1 Posted October 14, 2018 Posted October 14, 2018 Bargain, would have been buying it myself if I was closer! https://www.ebay.co.uk/itm/uponor-unipipe-16x2-under-floor-heating-pipe-500m/302913530961?hash=item46870dac51:g:~gIAAOSwrHxbu3Vn:rk:4:pf:0
