Pocster Posted June 24, 2021 Share Posted June 24, 2021 39 minutes ago, Onoff said: Can't remember exactly what I've got running to the pillar underground... - 2.5mm2 3-core swa - Duct grade Cat-6 - A multi-core screened cable for luck...can't remember the spec. Any ufh going there ? ?? Link to comment Share on other sites More sharing options...
Onoff Posted June 24, 2021 Author Share Posted June 24, 2021 40 minutes ago, pocster said: Any ufh going there ? ?? You joke but I did seriously consider running UFH pipe in the sloping bit of the drive to de-ice it. 1 Link to comment Share on other sites More sharing options...
JFDIY Posted June 24, 2021 Share Posted June 24, 2021 16 minutes ago, Onoff said: You joke but I did seriously consider running UFH pipe in the sloping bit of the drive to de-ice it. Be warmer than that bathroom then.? 2 Link to comment Share on other sites More sharing options...
Pocster Posted June 24, 2021 Share Posted June 24, 2021 1 hour ago, JFDIY said: Be warmer than that bathroom then.? SWMBO would have her shower then go and stand on the driveway to dry off. That could make for some interesting cctv.... Link to comment Share on other sites More sharing options...
Onoff Posted June 24, 2021 Author Share Posted June 24, 2021 3 hours ago, pocster said: SWMBO would have her shower then go and stand on the driveway to dry off. That could make for some interesting cctv.... Can you get really wide angle, CCTV cameras? 1 Link to comment Share on other sites More sharing options...
Pocster Posted June 24, 2021 Share Posted June 24, 2021 Just now, Onoff said: Can you get really wide angle, CCTV cameras? Yes with ultra high resolution; so you capture all the detail Link to comment Share on other sites More sharing options...
Onoff Posted June 24, 2021 Author Share Posted June 24, 2021 29 minutes ago, pocster said: all the detail Aka folds and creases... 1 Link to comment Share on other sites More sharing options...
Onoff Posted June 24, 2021 Author Share Posted June 24, 2021 Back on thread... Never thought I'd say it but it's looking like Knightsbridge! ? The fact it's apparently IP65 is the seller for me. Then it appears quite subtle. They'll only come on anyway when the gates open. https://www.tlc-direct.co.uk/Products/GLWALL1LBK.html? 1 Link to comment Share on other sites More sharing options...
Onoff Posted June 24, 2021 Author Share Posted June 24, 2021 Ordered the lights. 1 Link to comment Share on other sites More sharing options...
Onoff Posted June 25, 2021 Author Share Posted June 25, 2021 Didn't do much tonight, lost my homemade Starrett adapter so had to drive to my mates to get the one I made him. He couldn't find it but did find another obscure bit of steel I gave him years back which has a 1/2" UNF 20tpi thread...that'll do. All will be revealed! 1 Link to comment Share on other sites More sharing options...
Pocster Posted June 26, 2021 Share Posted June 26, 2021 9 hours ago, Onoff said: All will be revealed! The suspense is unbearable 1 Link to comment Share on other sites More sharing options...
JFDIY Posted June 26, 2021 Share Posted June 26, 2021 The hole saw contraption is to enlarge an existing hole is guess, probably to let the ufh pipes pass..... 2 Link to comment Share on other sites More sharing options...
Onoff Posted June 26, 2021 Author Share Posted June 26, 2021 53 minutes ago, JFDIY said: The hole saw contraption is to enlarge an existing hole is guess, probably to let the ufh pipes pass..... Sort of but no plumbing involved! Just got to find/scrounge a 1/2" UNF 20tpi tap this morning... (Not that sort of tap! ?) Link to comment Share on other sites More sharing options...
Onoff Posted June 26, 2021 Author Share Posted June 26, 2021 Screw on the lamp base with a couple of M4 screws: Drill with a 20mm Starrett. The hole in the light fitting is a gnats under 20mm: Stick a washer between lamp base and post: Drill just the lamp base with a 27mm Starrett using the 20mm Starrett as the pilot, hits the washer and doesn't damage the post: Link to comment Share on other sites More sharing options...
Pocster Posted June 26, 2021 Share Posted June 26, 2021 (edited) I’m wee’ing my pants now Edited June 26, 2021 by pocster Link to comment Share on other sites More sharing options...
Onoff Posted June 26, 2021 Author Share Posted June 26, 2021 Ducting all run. First coat of Bedec Barn Paint: Link to comment Share on other sites More sharing options...
Pocster Posted June 26, 2021 Share Posted June 26, 2021 Fresh pants on , but still wee’ing Link to comment Share on other sites More sharing options...
Onoff Posted June 26, 2021 Author Share Posted June 26, 2021 2 coats... Link to comment Share on other sites More sharing options...
Onoff Posted June 26, 2021 Author Share Posted June 26, 2021 Etch primed, now painted black, the drilled out lamp backs: Link to comment Share on other sites More sharing options...
ProDave Posted June 26, 2021 Share Posted June 26, 2021 This thread is like watching paint dry......... 3 Link to comment Share on other sites More sharing options...
Onoff Posted June 26, 2021 Author Share Posted June 26, 2021 22 minutes ago, ProDave said: This thread is like watching paint dry......... Or in @pocster's case, like watching pants dry... 1 Link to comment Share on other sites More sharing options...
Onoff Posted June 26, 2021 Author Share Posted June 26, 2021 The duct is all run for the downlighters. I just stick my hand up inside, pop the gland through (on the end of the duct) and put the nut on. Another coat of paint to go on before that. Should look nice and tidy. Link to comment Share on other sites More sharing options...
Pocster Posted June 27, 2021 Share Posted June 27, 2021 I think as in most things in @Onoff ‘s life it will end with an anti climax Link to comment Share on other sites More sharing options...
Onoff Posted June 27, 2021 Author Share Posted June 27, 2021 1 hour ago, pocster said: I think as in most things in @Onoff ‘s life it will end with an anti climax Never premature like some though! ? Link to comment Share on other sites More sharing options...
Onoff Posted June 27, 2021 Author Share Posted June 27, 2021 NOW we wait for the paint to dry! Got my gland in! 1 Link to comment Share on other sites More sharing options...
