I have some old sticky labels that came with my ex-demo fridge freezer. They have been on for a couple of years
The finish is stainless steel,and I need to remove them.
The initial advice from several directions has been to soften them with olive oil or baby oil then remove carefully.
Is it Ok to use a razor-blade glass scraper once I have softened the labels for a week or two? I am currently using the edge of a plastic card and it will take weeks of chipping away at it.
Has anyone done this and can confirm that scratches are unlikely?
Cheers
Ferdinand
not sure I'd risk a razor blade scraper just in case - 1 slip :(  I know WD40 is very good in removing labels but no idea what it would be like on SS
Would acetone do it?
I am sure that Nail Varnish Remover is a very expensive way of buying a slightly different version of a common product.
Will try WD40, then order some Multisolve ... which is quite pricey. Can I buy that at any standard outlets?
Peel the top edge if you can and spray WD40 above it so it starts to run into the label. Keep doing this and peeling it down a bit more each time. It will soon come off.
Looks like WD40 will do it over a couple of days.
One label is a 9”x9” triangular gloss faced bugger at the top corner.
Epilation of a bear would be easier.
  • Haha 3
I've just actually used Multisolve to remove some gummy labels and the residue of super sticky double sided tape from stainless steel control cabinets. Looks spotless but in a certain light there's still a "shadow". I might try WD40. Got a feeling I'll end up doing the whole panel!
Gentle heat is sometimes the trick on a full label if you can peel one corner and heat as you go. I use a hot air gun on its lowest setting. Hairdryer might work too.
Edited by Onoff
1 hour ago, lizzie said:
My handyman recommends lighter fuel
Is that so you can torch it when you get fed up? ;)
It's a matter of finding the right solvent for the adhesive on the label. Once you get the right one they usually come off easily. In the past I've tried Meths or even petrol.
Try that before petrol as it stinks less!
