We're at boarding out stage for the bathrooms, tiles not yet chosen, so not sure of weight. Bathrooms will not be full wetroooms, but a fall laid in the shower area in the concrete floor - no former.
I've been reading that Aquapanel is not the thing to use, unless fully tanked. I've heard tell of Wedi board and Fermacell was also mentioned as moisture resistant. We are planning on fermacell in the rest of the house, so anyone got any thoughts about using it as a backer board? Tiles will be full height.
What is best practice here? I know, not PB sealed with PVA! I have learned that much ....
Cheers,
dj
Used it and it’s fine but I’m moving towards using MR plasterboard and shower panels rather than tile as I don’t need to use any board behind them.
Fermacell is ok but it does swell when wet so not fully like an Aquapanel. They do a H2O board though that is water resistant.
So, I would prob need to tank the fermacell as well then. Probably MR (moisture resistant?) PB would be cheaper, regular fermacell is not that easy to source, I can;t imagine the H20 version is easy to come by. I take it the weight is potentially a problem with the MR plasterboard?  Does it still need tanking?
Tanked Fermacell or MR Board would be fine.
Fermacell is available nationwide through TP as it comes via their partner company CCF. Cheapest way is full pallets too.
What's the deal with Aquapanel being a problem? That's what I've got sitting here waiting to go on. Do plan on fully tanking it though.
Not a problem (as far as I understand) if it's fully tanked - people were using it untanked, thinking that it was waterproof - not an unreasonable assumption, given the name...
Good to know. More tanking! :(
Aquapanel is much stronger I'd say from the different areas I've done in each here. Don't forget it needs special Knauf screws.
Stronger, as in the weight of tiles that it will take? Of course, it needs special screws! Nothing would ever be less expensive than I was expecting.... *sob*
42 minutes ago, Miek said:
What's special about the screws? Would stainless screws be suitable?
They really are special screws. They sort of drill & clear the abrasive panel material and have ribs under the head to self countersink.
I tried self drill screws but they just ripped the Aquapanel to shreds around the screw hole. I wanted to go thru the Aquapanel into the blue Geberit steel frame. In the end just copious amounts of Sikaflex. The 9mm ply was ordinary Gold and self drill screwed first:
20170815_160609
Then the panel put on with the special ones:
20170815_164109
Used these:
https://www.wickes.co.uk/Knauf-Aquapanel-Gold-Screws-39mm/p/224585
Edited by Onoff
Don't use Fermacell as it is gypsum based and has a tenancy to go mouldy.  It is also fairly expensive and difficult to cut.
I recently used HardieBacker which is cement based but also difficult to cut.
I cannot believe how neatly @Onoff has cut out the holes for the Geberit.  Our tackers left gaps of up to 30mm on the basis that "the tiles will cover it"!
That’s odd as I’ve never had it go mouldy..? Even where we dug out parts from a ceiling where there had been a slow leak and it had gone to mush.
Riding on the shoulders of giants me!
I was inpired by advice from @Nickfromwales and then @PeterStarck's bathroom build. Tbh Peter's whole place screams attention to detail. I like to know that even what lies beneath is clean and tidy.
Mind, I could never make a living doing it! :)
...but then it's not why "we" do it!
We have had some for timber frame racking / sheathing and it got surface mould where OSB did not.  Nothing like as bad as plasterboard though.
I will be redoing my upstairs shower in a few months and was looking at using hardieback board. What's it like compared to MR plasterboard.
My vote is for Marmox boards, they also provide a little insulation, but work very well as tile backerboards for both floors and walls, and are impervious to water and also have a high resistance to water vapour permeability. They come in a variety of thicknesses, and there are other brands too, but basically, its XPS inner, with a cement polymer and fibreglass coating on either side.
The cement backer boards, such as no more ply are horrible things, really heavy, hard to cut too (you'll go through plenty of blades for both circ saw and jigsaw).
Edited by MikeGrahamT21
8 minutes ago, daiking said:
Got normal PB, skim then tiled for our over bath shower.
3 years and not fallen off yet xD
Got Aquapanel behind the wc then for the complete wet room corner. MR pb and marine ply all around the bath. MR pb behind the basin. Will all be tanked and then some.
2017-08-16_09-21-12
IMG_20170816_172231315
2017-08-16_09-21-12
And it never will if you don’t finish it...
Compared to MR plasterboard it's hard work to cut and drill but I used it in the wetroom, bathroom and en-suite and I think it's worth it.
What did you use to cut it?? Would a diamond tipped blade in a grinder do the job.
Do you have to use special screws with it that cut into it??
I used this to cut my moisture resistant render board for the exterior of our house and it made the job very easy
