So I have this table saw I use in my workshop I've had it for a few years and recently changed the blade for the first time with a nice Rutland blade after the original one was blunt as anything causing the wood to smoke and taking ages to cut. I also cleaned out the table saw whilst removing the old blade. The problem is I am using it currently to cut cls studs to the desired length for my project and the blade keeps catching/ jumping/ kicking when I use it even though I'm being quite careful to the point I don't want to use it anymore. The blade seemed ok for the first few weeks with no jumping happening  but now not so much. What an I doing wrong? I never really had this problem with my old smoky blade I would have thought a new sharp blade would cause the table saw to kick less.
I would say wrong saw for the job.  You want a chop saw for that.  A table saw is normally used with a fence for cutting a length of timber down to a particular size.
The complete lack of a guard over the blade does not inspire confidence.
  • Like 5
And I think there may be a small issue with the dust extraction...
Ah ok I did have a chop saw but thought I could change to a table saw (plus jigsaw)  as a 'do it all saw', didn't realise people didn't use it for what I am currently doing. I don't remember having this problem with my old blade but perhaps I wasn't cutting much cls.
I have the saw located at my workshop entrance so the most dust goes straight outside.
Edited by cowboy25
A table saw is for sheet material, or trimming down timbers lengthways, not for cross cutting etc. You'll just hurt yourself or the saw.
You'll be able to do mitres etc with a chop (mitre) saw too.
  • Like 3
You're lucky you haven't seriously injured yourself. Table saws are one of the most dangerous tools in the shop, even when used for what they're designed for.
You can use a table saw for cross cuts, but you need a cross cut sled or similar. Easy enough to knock one up, but even then it really isn't designed for cross cutting long pieces of wood.
100% chop saw territory.
Hmm, IMHO I'd be a bit cautious about that blade. I know Rutlands have built some kind of reputation, but I bought something from them that was total and utter over-priced rubbish. I was reluctant to touch them again until I ordered some tools from Bang Good having watched the YouTube channel 'China tools' - and yes there are some quality bits of kit that can be had - but what was very interesting is that one measuring tool I received came with Rutland written all over the tool and packaging even though it was from a totally different vendor and about a 1/3 of the price. After this I'd never buy anything from Rutland.
I'd be going to buy a well know and trusted brand of blade first. And then seriously look at and question how I'm using the tool and whether I'm doing it correctly and appropriately! 😉
One thing I forgot to mention and not clear in the photograph is the left hand wing of the table saw was bent downwards about half an inch so I was trying to accomodate for this as well when cutting the cls, so obviously this just added to the danger. I have since sorted out that bent left wing - a couple blows with a lump hammer at the top of the support struts where they connect to the table surface sorted that right out, so now the surface is completely level.
But yeah I'll no longer be using the table saw for cross cuts, I don't really have the space or £'s for a mitre saw sadly I'll use another type of saw for now, its called a hand saw. Thanks all.
Erm, drop the blade down and put it on the table saw….
£60……. :ph34r:??? :S
I always use a sled for cross cutting on the table saw. If you don't then pushing on the wood can cause it to bind on the saw blade. The sled pushes on the wood evenly right upto the blade so the cut doesnt tend to close up.
