Mike Posted May 22 Posted May 22 (edited) 2 hours ago, JohnMo said: 6 hours ago, Mike said: No more than 6 circuits per manifold That's a strange one - any obvious reason for this rule? It isn't obvious, but I've tracked down the 1998 version of the regs that includes an explanation. That says to limit the circuits to 5 or 6 and to optimise the routing of loops to avoid concentrations of pipes, particularly in hallways, but to insulate them if necessary. Which I would take to mean to avoid condensation on parts of the floor that would, if pipes are too bunched up and not insulated, be a few °C cooler than the general floor temperature. UFCH with cooling is pretty common France - apparently 1/3 of all new houses have it - and it has a long history, so their current regs (last updated in 2023) ought to be a good guide; I can spot a few things that have changed since 1998. Edited May 22 by Mike 1
richo106 Posted 1 hour ago Author Posted 1 hour ago Hi all I set my UFH temperature to 15 deg for cooling last heat wave and I monitored dew on the manifold and there was nothing. However when I turned it on Sunday for this hot period, I saw dew on my manifolds and the tiled floor felt very very slightly damp ish yesterday so I have upped the temp to 17 deg. This seemed ok until this evening when the manifolds had dew on them again albeit only very slightly. how/what is the best way to monitor my dew point within the house? is there anything I can integrate into my system retrospectively? any advice/information greatly appreciated!
