We have multiple concealed cisterns in the house.
They have stainless steel flexipipe as shown here connecting the refill valve to the water supply.
https://www.bathroomspareparts.co.uk/porcelanosa-flexi-kit-100306654-189163-p.asp
As far as I can see all the makers of concealed cisterns use almost identical pipes.
We just had the fourth one fail. One of the four failures causes quite a bit of water damage, the others all failed draining into the cistern.
I bought a load of replacement pipes and plan to check them more often to see if they look like failing.
Some of them seem to rust quite badly.
My suspicion is that the incoming water is quite cold and they are all sealed inside unheated spaces. This causes water to constantly condense on the outside of the pipes and they rust then fail. The local water supply is also very acidic.
When you Google flexipipes you get some research from Austrlai that says they are the number one cause of household flooding and account for 20% of all cases of water damage.
The one in the bathroom connected to our pool has failed twice. I believe it is because the humidity is higher in this room so more water condenses on the pipes. There is no chlorine. Yesterday it was the flea connector to the mains inside the wall. I managed to replace it with a lot of effort without having to cut the wall open, I did cut the top of the cistern away inside the wall. My arms are pretty scratched up!
I found a nylon tap connector and have used this as a replacement as hopefully it is unlikely to rust.
https://www.bes.co.uk/flexible-tap-connector-1-2in-x-15mm-x-300mm-17439/
I am considering replacing some of the fittings in the cisterns with these. I will buy one to give it a try.
https://www.amazon.co.uk/ARCORA-Attachment-Bathroom-Kitchen-Compression/dp/B09PFZ6PL8?th=1
It made me wonder why do these normally use stainless steel and not nylon? It seems like nylon braided ones are a lot more popular in the US. The extremely thin and cheap stainless steel in these is always likely to corrode. It also gets dangerously sharp when it does rust and break.
Picture of the two pipes I replaced -
  • AliG changed the title to Stainless steel flexipipe vs nylon braided
These have a PVC or EPDM inner tube usually.
Is the hose failing or the fitting?
Is the supply in copper or plastic?
Look as though they have been inside the cistern.
Was that a typo in your original thread about australia? All their loos seem to be connected on a flexible with a tap on the wall. Must be some kind of reg over there? Here a lot of our toilets are plumbed in with fixed pipes. Even my old concealed loo was done with fixed pipework IIRC. Is there a reason they have to be on a flexi? Presume its too hard to change now.
It’s the hose that fails.
The stainless steel rusts and breaks then the pipe pops.
If I look at the pipes the rust seems to be mainly on one side which fits in with my belief it is caused by water condensing on the outside of the pipe.
I have PVC piping and then they have used 15mm tap connectors at the end of each piece to connect to the fittings. This is the first time one of those has gone.
The main problem seems to be the ones inside the cisterns. They are not under water just at the top of the cistern. All concealed cisterns seem to use a similar connector.
44 minutes ago, Mr Punter said:
Well I have no idea how you would change these in a full tiled bathroom!  I have 6 at home.
The pipes inside the cistern can be replaced just by taking the flush plate off. All of the inside of a concealed cistern can be removed through the flush plate.
This was more difficult as it was a second flex connector connecting the valve inside the cistern to the mains.
I used metal cutting scissors to cut the top out of the plastic cistern.
Then I pushed my arm up into the wall, getting it all scratched up. Yesterday I did this with a small screwdriver to shut off the valve while I waited for a new pipe to arrive so I could turn the water back on. Today I was about to give up because there was no way to get enough purchase on the pipe inside the wall to unscrew the compression fitting.
Then I wondered if I could move the 15m PVC mains pipe, I remembered how flexible they are.
I pulled it out of the clip holding it to the wall and was able to pull the pipe out through the cistern. Then I could easily unscrew the compression fitting and replace it before putting it back into the wall. The new nylon flexipipe presumably won't rust.
Our last house did not use flexi pipes but the builders had put isolating valves in all the fixed pipes entering the cisterns. After around 10 years these all began to fail and we and multiple neighbours had floods due to this as the cisterns were all concealed and you didn't notice the slow leaks until the ceilings started to drip. The flex pipes burst under pressure so you can often hear straight away when they go.
Yes Australia, typo fixed thanks.
We have a 28mm hot and cold loops in the house with all the fittings connected to this using 15mm pipe. The loop was put in months before the bathrooms so I think they did this as they weren't connecting up the toilets. They just brought the mains close to where the toilets would would be.
Having once worked in a hotel that experienced at least one connector failing every month - but sometimes every week or more than once on the same day - I can confirm that this is a problem. Twisting them during installation is a known issue, but they do have a limited life even when correctly installed. I tolerate them in a cistern, but have returned to using regular copper pipe elsewhere. Replacement every 10 years is advised if they've been installed.
Only buy ones that are made to the relevant European / British Standard (sorry - I can't spot the number right now). The standard isn't very good, but it's better than pot luck.
The pipe I have ordered is from the US, it claims to meet their standards. I couldn't find a nylon one here for the 3/8 to 1/2 connection. I was able to buy a 15mm to 1/2inch tap connector in nylon here, but It doesn't mention any standards.
My thinking is to try it as it is nylon braided and so shouldn't rust.
From what I can see nylon ones might be a bit less strong and easier to pinch, but that is pretty much irrelevant as they won't be moving around. One of the ones that failed after just a few years I think might have been twisted during installation.
Some places do indeed recommend replacement every 5-10 years. Virtually no one must be doing this in reality.
I will certainly check the other pipes in the house, I did this last time I replaced one. Last time I checked there were no other issues and it seemed isolated to certain rooms, it seemed to be all the places where the cistern is on an outside wall and colder, although the cold water coming into the house is pretty cold. It was also the most used cisterns and again I think these have more water running through them so are generally colder.
I hate plumbing.  It is the cause of the vast majority of defects.  I think we should bring back the outside WC.  The hidden cistern is probably going to haunt me.
I’ve a bunch of these, most of which have been there for 30 years. No problems except for one within one of those shower-hose-like kitchen taps. I wonder whether some are much better quality than others? Real stainless shouldn’t rust much with standard water. Agree that relying on the rubber hose isn’t the smartest.
Just a quick thought, even if to rule out.
I wonder if there is a metal in the taps / cistern that is causing the corrosion. The end connection in the flexible tube becomes a sacraficial annode if the wrong way round in the galvanic series.
@SteamyTea
From the pictures it looks more like a black mould, rather than corrosion.
Stainless steels tend to fail when they are in an oxygen poor environment i.e. underwater, this is why they are not used structural elements on boats.
Chlorine can affect SS, as can some other cleaning chemicals, but @AliG says his pool does not use chlorine.  How is the pool treated, bromine or ozone maybe?  Both of those can cause problems.
Not sure about the galvanic problems, seems it can happen.
This is from the British Stainless Steel Association
What Forms of Corrosion can Occur in Stainless Steels
The most common forms of corrosion in stainless steel are:
  1. Pitting corrosion – The passive layer on stainless steel can be attacked by certain chemical species. The chloride ion Cl- is the most common of these and is found in everyday materials such as salt and bleach. Pitting corrosion is avoided by making sure that stainless steel does not come into prolonged contact with harmful chemicals or by choosing a grade of steel which is more resistant to attack. The pitting corrosion resistance can be assessed using the Pitting Resistance Equivalent Number calculated from the alloy content.
  2. Crevice corrosion – Stainless steel requires a supply of oxygen to make sure that the passive layer can form on the surface. In very tight crevices, it is not always possible for the oxygen to gain access to the stainless steel surface thereby causing it to be vulnerable to attack. Crevice corrosion is avoided by sealing crevices with a flexible sealant or by using a more corrosion resistant grade.
  3. General corrosion – Normally, stainless steel does not corrode uniformly as do ordinary carbon and alloy steels. However, with some chemicals, notably acids, the passive layer may be attacked uniformly depending on concentration and temperature and the metal loss is distributed over the entire surface of the steel. Hydrochloric acid and Sulphuric acid at some concentrations are particular aggressive towards stainless steel.
  4. Stress corrosion cracking (SCC) – This is a relatively rare form of corrosion which requires a very specific combination of tensile stress, temperature and corrosive species, often the chloride ion, for it to occur. Typical applications where SCC can occur are hot water tanks and swimming pools. Another form known as sulphide stress corrosion cracking (SSCC) is associated with hydrogen sulphide in oil and gas exploration and production.
  5. Intergranular corrosion – This is now quite a rare form of corrosion. If the Carbon level in the steel is too high, Chromium can combine with Carbon to form Chromium Carbide. This occurs at temperatures between about 450-850 deg C. This process is also called sensitisation and typically occurs during welding. The Chromium available to form the passive layer is effectively reduced and corrosion can occur. It is avoided by choosing a low carbon grade the so-called ‘L’ grades or by using a steel with Titanium or Niobium which preferentially combines with Carbon.
  6. Galvanic corrosion – If two dissimilar metals are in contact with each other and with an electrolyte e.g. water or other solution, it is possible for a galvanic cell to be set up. This is rather like a battery and can accelerate corrosion of the less ‘noble’ metal. It can avoided by separating the metals with a non-metallic insulator such as rubber.
You may be under the misapprehension that plumbing and building items are designed for the benefit of the end customer, whereas they are actually designed solely for the benefit of the installer. They only need to last long enough for you to lose the telephone number of the original plumber. You could call another plumber out at emergency rates - err oh gosh.
Cui bono.
As an installer, I can tell you that many products aren't even designed for the sole benefit of the installer, but that of the manufacturer, so we have to fiddle around unnecessarily and deal with call backs, hence why you get to spend a long time finding the products you stick to. When you find the good ones you find they're for the benefit of both installer and customer.
Yes really good design aimed at the full lifecycle and all stakeholders is rare.
I do think that much building stuff is bought by the trades, and therefore gets targeted at the trades. Very few of the public care to know anything about what their house is made of unfortunately. Self builders are a godsend becauise they do care and will go out of their way to buy more innovative products.
Problematic things in building...
Cavity closers made of plastic - ill fitting, loose, plaster over like cardboard, tacked in with clout nails that fall out
The absence of any ready made solution for 'the door threshold problem' in cavity wall construction
Flexible plumbing connectors that speed up install but have limited life
Roof ties that don't fit into the plasterline
Joist hangers that protrude below the joist with no tool to rebate the joist or the plasterboard.
Membranes in limited widths
connectors from 80mm roof outflow pipes to 68mm downpipes
press fit connectors that throttle pipe bore
The made to order cavity closers are much better quality than the ones bought in loose lengths. Even come with plastic ties which get set into mortar.
I just started to go and check the other bathrooms.
The first picture, the cistern is on an outside wall and the second one on an inside wall. I thought my theory that the outside wall spaces are cooler and water is more likely to condense on the pipes was proved.
The third picture is a bathroom right next to the second one. Both on inside walls, both basically the same room and the mirror image of each other. The difference is dramatic and frankly hard to understand.
The third one will be getting replaced tomorrow.
Even though this seems crazy, the cleaner likes to use Toilet Duck, it only goes in the bowl, nowhere near the cistern. But the rooms with issues are the ones that are used more so get cleaned more often. Could it be that Toilet Duck left in the cistern is producing fumes that are damaging the pipework, or travelling a little bit back up the flush pipe. A pattern might be clearer once I have checked them all.
Buy the cheapest, similar, flexie, and dunk it in some Toilet Duck.  Leave for a few days and see what happens.
