April 28Apr 28 Author Thanks. It is very rare any standards get mentioned or the grade of stainless steel.
April 28Apr 28 This is Spain. There's a sticker on each pipe but don't know what it says...everything easy to get to
May 4May 4 Author For people interested in the serviceability of these hidden cisterns. This one has also had a dodgy flush valve that sometimes kept running if you didn't push the flush plate long enough. I had put off fixing it assuming it would be a pain to do. I bought a new flush valve as I had disconnected it anyway to fix the pipework. It took roughly five minutes to replace the flush valve. You literally just pull it out and push the new one in. It bends to fit through the flush plate hole. Taking off the front plate and putting it back n tight actually took longer than replacing the flush valve. It was an unusual instance of a job actually being as easy as it was supposed to be.
July 28Jul 28 Having just discovered a leaking flexi pipe on a toilet cistern, what is the general consensus on best practice here? Replace and set a 10 year reminder or fit something like https://www.screwfix.com/p/hep2o-plastic-push-fit-angled-tap-connector-15mm-x-1-2-/3036f to the cistern and go straight into plastic pipe, even if that involves a couple of elbows? This is all inside a vanity cabinet so not something that can regularly be inspected, it needs silicone cutting back from the toilet to even see.
July 28Jul 28 I didnt have a great deal of success with those fittings, I'm sure they are fine but this ham fisted eejit had a failure on the washer. I used the 1/2" to 15 female coupler with a street elbow instead.
July 28Jul 28 2 hours ago, S2D2 said: Having just discovered a leaking flexi pipe on a toilet cistern, what is the general consensus on best practice here? Replace and set a 10 year reminder or fit something like https://www.screwfix.com/p/hep2o-plastic-push-fit-angled-tap-connector-15mm-x-1-2-/3036f to the cistern and go straight into plastic pipe, even if that involves a couple of elbows? This is all inside a vanity cabinet so not something that can regularly be inspected, it needs silicone cutting back from the toilet to even see. I use these regularly, very reliable bits of kit for concealed toilets / showers / wall mounted basic taps etc. 2 hours ago, crispy_wafer said: I didnt have a great deal of success with those fittings, I'm sure they are fine but this ham fisted eejit had a failure on the washer. I used the 1/2" to 15 female coupler with a street elbow instead. Did you swap the square edged rubber seal for the chamfered one? @S2D2, it doesn’t say it, but these come with a second loose rubber seal, and you simply switch to the one that matches the application; square for a traditional tap aka ‘flat-faced’, or chamfered if its a cone fitting (that takes an olive usually). Don’t use anything like lube or paste on these, just whack them in dry and you’ll be right for life.
July 28Jul 28 2 hours ago, Nickfromwales said: Did you swap the square edged rubber seal for the chamfered one? Probably not... Application was both gerberit, and grohe cisterns...
July 28Jul 28 6 hours ago, crispy_wafer said: I didnt have a great deal of success with those fittings, I'm sure they are fine but this ham fisted eejit had a failure on the washer. I used the 1/2" to 15 female coupler with a street elbow instead. Immediate failure or at a later date? Thanks both, parts ordered.
July 28Jul 28 6 hours ago, Nickfromwales said: or chamfered if its a cone fitting (that takes an olive usually). I use these nowadays, far more reliable with cone fittings: https://directplumbingsupplies.com/product/bonfix-insert-brass-with-o-ring-15-mm
July 28Jul 28 3 hours ago, S2D2 said: Immediate failure or at a later date? Thanks both, parts ordered. Straight away, so likely my fault, or has been pointed out the wrong washer used!
July 28Jul 28 3 hours ago, SimonD said: I use these nowadays, far more reliable with cone fittings: https://directplumbingsupplies.com/product/bonfix-insert-brass-with-o-ring-15-mm Does that convert you from cone to flat-faced?
July 29Jul 29 On 28/07/2026 at 13:34, Nickfromwales said: I use these regularly, very reliable bits of kit for concealed toilets / showers / wall mounted basic taps etc. Did you swap the square edged rubber seal for the chamfered one? @S2D2, it doesn’t say it, but these come with a second loose rubber seal, and you simply switch to the one that matches the application; square for a traditional tap aka ‘flat-faced’, or chamfered if its a cone fitting (that takes an olive usually). Don’t use anything like lube or paste on these, just whack them in dry and you’ll be right for life. Have to say, I'm having the same issue as @crispy_wafer, doesn't seem to be a way to stop it leaking attaching to a plastic cistern feed with the flat washer as per a flexi pipe. Takes a brass stop end with the tapered washer with zero issues, but flat washer and cistern, nope. Starting to suspect I might have loosened something in the cistern messing about with it but that'll be a full disassemble of the unit to confirm.
August 5Aug 5 On 29/07/2026 at 18:01, S2D2 said: Have to say, I'm having the same issue as @crispy_wafer, doesn't seem to be a way to stop it leaking attaching to a plastic cistern feed with the flat washer as per a flexi pipe. Takes a brass stop end with the tapered washer with zero issues, but flat washer and cistern, nope. Starting to suspect I might have loosened something in the cistern messing about with it but that'll be a full disassemble of the unit to confirm. Forgot to follow up on this, I swapped to: https://www.screwfix.com/p/hep2o-hx19-15ws-angled-service-valve-15mm/8634f Which has no leak. The tap connector when tightened was causing the cistern connection move and leak. Wouldn't have been an issue if I could get more tools in to hold it but this was all through a 10x20cm access hole so a right pain. I suspect the cistern leak is what caused issues with the flexi so the other two that I had planned to replace can stay put as an inspection camera showed no leak or corrosion.
August 7Aug 7 Author So. I went around checking the pipes when I started this thread. For some reason one of the cisterns had a screwed on plastic cover behind the flush plate instead of a plastic twist like the other ones have. I didn't check that one as I couldn't be bothered getting a screwdriver at the time. Of course that one blew two days ago. Luckily I got up really early and heard it. It was dripping through the ceiling, but just needs repainted. I think it had maybe only blown half an hour before I got up. Of the nine of these that I have, I have replaced four, another four seem fine and I need to check the one today in my daughter's bedroom. Two of them would probably have blown within the next year. We have stopped leaving Toilet Duck in the cisterns, I will report back in a while to see if this has stopped the corrosion. I also, however, have to replace three or four of the connectors between the inlet valve and the pex pipework in the house. I am hoping that now I have figured out there is slack in the pex, I can just pull it through into the cisterns to change the flex pipes over. But I suspect it won't be that simple as the pex often comes up from below and the hole in the cistern is in the top, so the pex won't bend enough to come through the small holes and I will have to cut the holes bigger. I have ordered nylon coated flex pipes for this, so that they cannot corrode in the wall unseen.
August 8Aug 8 On 28/07/2026 at 23:26, Nickfromwales said: Does that convert you from cone to flat-faced? Yes it does. Here's a couple of pics from an installation I'm finishing off at the mo.
