flanagaj Posted 13 hours ago Posted 13 hours ago When we had the footings dug, the JCB guy told me to pour the concrete footings and then dig the over site down, before commencing the foundation masonry. That made complete sense, but unfortunately, the brick layer was committed to starting on a specific date and it didn't get done. Now I'm thinking how blooming tricky it's going to be to manoeuvre the mini excavator around and not catch any of the block work. So unless I am missing something 'basic' here, my advice would be to dig it down first and then commence your foundation masonry.
flanagaj Posted 5 hours ago Author Posted 5 hours ago 6 hours ago, dpmiller said: why do you need to dig down? Ground bearing slab requires 525mm to be dug out below FFL. It's currently only dug down 200mm
MikeGrahamT21 Posted 5 hours ago Posted 5 hours ago (edited) You need 150mm from the finished level of your oversite to the bottom of your floor (whether that be joists or B&B). so as long as you’ve got at least that amount there’s no need to dig down. Obviously it must be lower than your DPC, but that will come naturally with the 150mm measurement Edit: just seen you’re going full concrete slab, so you’ll need plenty of space for insulation below your finished slab. I’m not sure what the minimum recommended thickness for concrete slab is but I’m sure someone will know on here Edited 5 hours ago by MikeGrahamT21
Mr Punter Posted 4 hours ago Posted 4 hours ago Have you got a section detail showing the foundation, slab, insulation, DPM, DPC, screed and FFL?
JohnMo Posted 4 hours ago Posted 4 hours ago 56 minutes ago, flanagaj said: Ground bearing slab requires 525mm to be dug out below FFL. It's currently only dug down 200mm We did similar, two of us did it by spade with a barrow. Gets you fit is one way to look at it, kills you is the other. We had a 192m² to do. This is us near the end Have fun
Owain1602 Posted 3 hours ago Posted 3 hours ago 10 hours ago, flanagaj said: my advice would be to dig it down first and then commence your foundation masonry. With all due respect, I don’t think you should be giving any advice. Just because you’re not comfortable to be operating an excavator and dumper around some block work. If you don’t trust yourself, get an experienced operator, or get the bulk of the material well away from the blocks out with machinery, then pick away at the rest by hand. It sounds to me like you should be spending more time doing things, rather than getting every opinion under the sun about how something should be done. Why was the material not excavated before the blocks started going in? No idea the footprint of what you’re doing, but I can’t imagine it would be more than a day of work. Did you ask the guy doing the blocks if you could delay him by a day?
Oz07 Posted 2 hours ago Posted 2 hours ago I get the machine to scrape out before he digs the last wall. You just go to whatever depth you need to bottom of stone for slab or clearance for suspended floor. Are you sure its only 200mm below ffl at present? Did you not even scrape the topsoil off prior to trenches? Presumably your ffl is around 150mm above the existing ground before you started?
Oz07 Posted 2 hours ago Posted 2 hours ago Say 200mm stone, 200mm insulation, 100mm slab. 500mm. Less full being 150mm above ground gets you to 350 reduced dig off ground height. Can reduce insulation with pir and prob go down to 150mm with stone
