Alan Ambrose Posted March 15 Posted March 15 I have a bunch (~72m) of Ravatherm XPS blocks 100mm x 600mm x 1,250mm I need to make some cuts reasonably accurately at 30 degree angles. Something like below, if you're looking from the ends of the boards. Anyone have a great method? The cut surface on the slope is 200mm long.
-rick- Posted March 15 Posted March 15 Can you make one cut and flip the cut-off over to be the second piece? Not got practical experience but I've seen people make a wooden jig with a hot-wire. If you need to also cut the length of the board to make a single angled cut work, could do this with another hot-wire jig or track/table saw.
SimonD Posted March 15 Posted March 15 56 minutes ago, Alan Ambrose said: I have a bunch (~72m) of Ravatherm XPS blocks 100mm x 600mm x 1,250mm I need to make some cuts reasonably accurately at 30 degree angles. Something like below, if you're looking from the ends of the boards. Anyone have a great method? The cut surface on the slope is 200mm long. What do you mean by reasonably accurate? I've used my jigsaw with a blade with 150mm cutting length on both woodfibre and eps at similar angles to this. With this you need to make a jig so you have a flat surface on with the rest to jigsaw as it won't make the angle if using the large flat area of ther xps. The other option is to make up a plywood jig that sandwiches the xps and gives you a cutting guide to rest something like the Bahco insulation saw on. I'd probably for for the second option. But if money is no object: https://www.festool.co.uk/products/cordless-products/cordless-insulating-material-saw/577231---isc-240-eb-basic-gb https://produkte.mafell.de/en/sawing/insulation-saw/insulation-saw-dss-300-cc
Beau Posted March 15 Posted March 15 I would make up a 30 degree wooden wedge and use that to guide a handsaw at the angle.
G and J Posted March 15 Posted March 15 Handsaw, straight edge, felt pen and practice. Draw a straight line both sides. Stand the sheet up so the lines are vertical and cut watching the lines both sides. I think XPS is polystyrene so it’s easy to work, hand saw is ideal. I didn’t need a mask either (unlike PIR). One left field thought. Polystyrene has a lambda of circa 0.034 thingys. (Thingys stands for whatever the units are, I can’t be arsed googling it). Airtight foam has a lambda of 0.034 thingys too.
saveasteading Posted March 15 Posted March 15 Doing this currently. Handsaw ( multipurpose) for small cuts. Circular saw for longer cuts. And mask, goggles, hat with the latter. I had expected the eps to shed whole 'bubbles' but it cuts as very fine dust. So do it indoors or you will contaminate the area.
Mike Posted March 15 Posted March 15 If you have lots, then it could be worth getting a wavy-edge hand saw. I've got a Bahco ProfCut that works well and avoids the mess. Plus a knocked-up jig to keep the angle you want.
Super_Paulie Posted March 16 Posted March 16 (edited) build a sled if you have loads to do? a sled and a hardpoint saw is what i used. Edited March 16 by Super_Paulie
Alan Ambrose Posted March 16 Author Posted March 16 Tried the tracksaw followed by handsaw idea today. Works fine, but we actually need the tracksaw at 60 degrees and it has a max of 45. I've also ordered a hot wire cutter, a Bahco wavy saw and some Bosch wavy jigsaw blades to try. Intend to build a jig somewhat like @Super_Paulie 's. Will report back.
G and J Posted March 16 Posted March 16 Or use several layers of thinner stuff cut square. Will the small voids actually matter?
Iceverge Posted March 16 Posted March 16 I'm wondering if this is a scenario where stepping the blocks and making up the diagonal difference with mineral wool is the massively simpler and no worse performing solution. What's it for?
G and J Posted March 16 Posted March 16 The way I read the diagram it’s to reduce the cold bridging at the sole plate. Otherwise cold air gets behind the plinth bricks. I assume there will be wall ties linking the walls and the plinth bricks. Not sure how that will work with polystyrene sheets.
Alan Ambrose Posted Friday at 18:22 Author Posted Friday at 18:22 Good point about wall ties. I had thought about those, then forgotten about them… Reporting back: + wavy Bahco saw hard to push through XPS even with wax on saw to help. Possible, but hard work and needs some skill to keep the cut flat - the saw tends to bow and then the cut ends up bowed. + wavy jigsaw blades also dodgy - causing lots of vibration presumably due to friction. Was actually melting the xps. + hot knife works ok but I need to think out some sort of jig to cut a uniform profile. 1
saveasteading Posted Friday at 19:28 Posted Friday at 19:28 1 hour ago, Alan Ambrose said: Reporting back: I cant get the saw moving after a foot or so. Has to be a circular saw I think. BUT we have professionals doing it on Monday Monday EPS Tuesday PIR, so I will be watching closely.
-rick- Posted Friday at 20:04 Posted Friday at 20:04 1 hour ago, Alan Ambrose said: + hot knife works ok but I need to think out some sort of jig to cut a uniform profile. I've seen someone do it by making the jig stationary and pushing the xps through it. Like a tablesaw/bandsaw. Vaguely remember that the standard wire was too flimsy to do at any speed but with a bit of juice and a thicker wire was able to get through it quite quickly. Thinking more, I have very vague recollections of someone using a welder as the power source (not sure it's the same one). In which case this is maybe not the easiest route to go down.
SteamyTea Posted Sunday at 14:39 Posted Sunday at 14:39 On 16/03/2026 at 22:10, Iceverge said: mineral wool is the massively simpler and no worse performing solution Different vapour permeability, it may be important.
