I have a bunch (~72m) of Ravatherm XPS blocks 100mm x 600mm x 1,250mm I need to make some cuts reasonably accurately at 30 degree angles. Something like below, if you're looking from the ends of the boards.
Anyone have a great method? The cut surface on the slope is 200mm long.
Can you make one cut and flip the cut-off over to be the second piece?
Not got practical experience but I've seen people make a wooden jig with a hot-wire.
If you need to also cut the length of the board to make a single angled cut work, could do this with another hot-wire jig or track/table saw.
What do you mean by reasonably accurate? I've used my jigsaw with a blade with 150mm cutting length on both woodfibre and eps at similar angles to this.  With this you need to make a jig so you have a flat surface on with the rest to jigsaw as it won't make the angle if using the large flat area of ther xps. The other option is to make up a plywood jig that sandwiches the xps and gives you a cutting guide to rest something like the Bahco insulation saw on. I'd probably for for the second option.
But if money is no object:
https://www.festool.co.uk/products/cordless-products/cordless-insulating-material-saw/577231---isc-240-eb-basic-gb
https://produkte.mafell.de/en/sawing/insulation-saw/insulation-saw-dss-300-cc
I would make up a 30 degree wooden wedge and use that to guide a handsaw at the angle.
Handsaw, straight edge, felt pen and practice.
Draw a straight line both sides.  Stand the sheet up so the lines are vertical and cut watching the lines both sides.
I think XPS is polystyrene so it’s easy to work, hand saw is ideal. I didn’t need a mask either (unlike PIR).
One left field thought.  Polystyrene has a lambda of circa 0.034 thingys.  (Thingys stands for whatever the units are, I can’t be arsed googling it).
Airtight foam has a lambda of 0.034 thingys too.
Doing this currently.
Handsaw ( multipurpose) for small cuts. Circular saw for longer cuts.
And mask, goggles, hat with the latter.
I had expected the eps to shed whole 'bubbles' but it cuts as very fine dust.
So do it indoors or you will contaminate the area.
If you have lots, then it could be worth getting a wavy-edge hand saw. I've got a Bahco ProfCut that works well and avoids the mess. Plus a knocked-up jig to keep the angle you want.
Tried the tracksaw followed by handsaw idea today. Works fine, but we actually need the tracksaw at 60 degrees and it has a max of 45.
I've also ordered a hot wire cutter, a Bahco wavy saw and some Bosch wavy jigsaw blades to try.
Intend to build a jig somewhat like @Super_Paulie 's.
Will report back.
I'm wondering if this is a scenario where stepping the blocks and making up the diagonal difference with mineral wool is the massively simpler and no worse performing solution.
What's it for?
The way I read the diagram it’s to reduce the cold bridging at the sole plate.
Otherwise cold air gets behind the plinth bricks.
I assume there will be wall ties linking the walls and the plinth bricks.  Not sure how that will work with polystyrene sheets.
Good point about wall ties. I had thought about those, then forgotten about them…
Reporting back:
+ wavy Bahco saw hard to push through XPS even with wax on saw to help. Possible, but hard work and needs some skill to keep the cut flat - the saw tends to bow and then the cut ends up bowed.
+ wavy jigsaw blades also dodgy - causing lots of vibration presumably due to friction. Was actually melting the xps.
+ hot knife works ok but I need to think out some sort of jig to cut a uniform profile.
1 hour ago, Alan Ambrose said:
Reporting back:
I cant get the saw moving after a foot or so. Has to be a circular saw I think.  BUT we have professionals doing it on Monday   Monday EPS Tuesday PIR,  so I will be watching closely.
I've seen someone do it by making the jig stationary and pushing the xps through it. Like a tablesaw/bandsaw. Vaguely remember that the standard wire was too flimsy to do at any speed but with a bit of juice and a thicker wire was able to get through it quite quickly. Thinking more, I have very vague recollections of someone using a welder as the power source (not sure it's the same one). In which case this is maybe not the easiest route to go down.
Different vapour permeability, it may be important.
  • 2 months later...
OK reporting back: after trying out lots of options, we cut the angle with a Proxxon Thermocut 650 and a home made jig. It lacks a bit of oomph and was fairly slow, but the flipside was that it didn't burn or smell much. We made the straight-through cuts with a big-assed circ saw - not crazily messy. You can get bigger hotwire cutters than the Proxxon and specifically for insulation, but we wanted to specifically cut 200mm deep.
p.s. the wire is very thin and breaks quite easily. Although it comes with 30m of wire on a little spool, you might want some extra.
Edited by Alan Ambrose
  • Like 5
