Pappa Posted December 29, 2025 Posted December 29, 2025 Hi guys. I've got a square patch of damp in my lounge that has just come about in the last month. Directly behind it is a brick wall that runs adjacent or away from this wall. Please note the paint peeling under the radiator. The external photo is directly behind this location. The DPC looks to be in good condition outside, although there is a rusty nail in the mortar line which has always been there. This brick wall was constructed in the last 20 years, before I bought the house. Relative humidity is consistently less than 60 percent in this room so I don't think it's condensation. Thanks in advance
Russell griffiths Posted December 29, 2025 Posted December 29, 2025 What’s that black plastic pipe. zoom the picture out. 1
saveasteading Posted December 29, 2025 Posted December 29, 2025 I think this is straight forward. see the green moss and algae on the wall? it is from water running from above. or simply rain hammering into that corner and not running off. also there appear to be gaps in the mortar. it is above the dpc and getting through to the inside where exactly is the internal dampness in comparison to this external photo? id have the wall cleaned and repointed. Plus check for water running out of gutters or flashings. You need to stand in the rain to se this properly. You may need to clean out or repair a gutter. 2
saveasteading Posted December 29, 2025 Posted December 29, 2025 the photo is helpful. I suspect a leak from the lower downpipe joints. Notice how the green is spreading out from that. 2
Pappa Posted December 29, 2025 Author Posted December 29, 2025 Thanks I thought so too The square patch on the interior is at the external corner or inside the external corner. The paint peels on the floor from behind the radiator correlates to the external picture approximately half way between the vent and the adjacent brick wall
Russell griffiths Posted December 29, 2025 Posted December 29, 2025 16 minutes ago, Pappa said: Rainwater pipe from roof. That’s your problem fix that and let the wall dry out, then re point it in the spring. 1
Nickfromwales Posted December 29, 2025 Posted December 29, 2025 Driving rain is pissing in through all the missing pointing. Leave until after April and then sort it. Is the down pipe blocked or do you have any leaking joints? If so fix that immediately. 2
Marvin Posted December 29, 2025 Posted December 29, 2025 And fill the old waste pipe hole before you get rats! And around the new waste pipe And any other hole that vermin can enter. 1
saveasteading Posted December 29, 2025 Posted December 29, 2025 I'd scrape the loose paint off to help it dry inwards and also to monitor it. You might find the the plaster beneath shows dampness, and I would mark that in pencil and be delighted to notice that it isn't spreading and may be reducing. Will you be doing diy ? Anyway you can brush off the green stuff now, as that is holding water. this is one of those queries where we can all feel good at sorting an issue so please repot back for better or worse. 1
Pappa Posted December 29, 2025 Author Posted December 29, 2025 Thanks guys. Would you advise doing the pointing before spring if there is X days / hours of dry weather forecasted? How many hours/days would you recommend? How much mortar do I need to rake out and refill? If you could point me in the direction of a useful guide or video that highlights best practice that would be appreciated. Thanks again
Russell griffiths Posted December 30, 2025 Posted December 30, 2025 8 hours ago, Pappa said: Thanks guys. Would you advise doing the pointing before spring if there is X days / hours of dry weather forecasted? How many hours/days would you recommend? How much mortar do I need to rake out and refill? If you could point me in the direction of a useful guide or video that highlights best practice that would be appreciated. Thanks again You need to consider the temperature for pointing, needs to be 5 degrees and rising for the duration that it will take to dry. fix the problem of water hitting the wall first and the pointing can be done in April.
saveasteading Posted December 30, 2025 Posted December 30, 2025 You might simply be able to push up the elbow to stop the leak. I'd repair the bigger holes ASAP. A pointing tool is a good investment and disguises my amateur work.
Roundtuit Posted December 30, 2025 Posted December 30, 2025 For good measure, I'd also cut the concrete/paving slabs back by 6 inches adjacent to the brickwork and fill with gravel to reduce rain splash.
Onoff Posted December 30, 2025 Posted December 30, 2025 9 hours ago, Pappa said: Thanks guys. Would you advise doing the pointing before spring if there is X days / hours of dry weather forecasted? How many hours/days would you recommend? How much mortar do I need to rake out and refill? If you could point me in the direction of a useful guide or video that highlights best practice that would be appreciated. Thanks again You first need to rake out anything loose: You can repoint using a hawk and finger trowel. This guy makes a nice job: For repointing I like using and have a few mortar guns. I had a Faithful type one but RUINED it by trying to gun a mix that had sharp sand through it. As the chap alludes to in the video, use the proper sand. I can't disagree with anything this he says. For admix I like this: https://www.amazon.co.uk/Everbuild-ILW5L-Integral-Liquid-Waterproofer/dp/B00133HA1A At the mo I've a couple of the slim silver type guns. One branded Roughneck and one slightly shorter tube wise but otherwise identical from Lidl and sold under the Parkside brand as a silicone/caulk/grouting gun! Simply not as good as the Faithful type. 1
Marvin Posted December 30, 2025 Posted December 30, 2025 Hi @Pappa On viewing your photo of the rainwater pipe from the roof there is green way above the lower bend of the down pipe. I would be inspecting the gutter down pipe outlet to see if there is any obstruction. Secondly I would also inspect its operation in the pouring rain to see exactly where the problem lies. Me thinks that the problem is starting higher up....
Onoff Posted December 30, 2025 Posted December 30, 2025 There's a definite "water course" from above as evidenced by the greenery in the vertical joints. 1
Nickfromwales Posted December 30, 2025 Posted December 30, 2025 Maybe a good opportunity to poke an inspection camera in one of the bigger gaps, to look down to check that there’s no masonry that has become lodged in the cavity and is bridging the damp.
Pappa Posted January 4 Author Posted January 4 Thanks guys I've had a careful look at this. There is nothing leaking from the top (basin and shower). The bottom pipe coming out of the wall is the washing machine. This is the offending junction. How do I make an airtight seal here? Thanks again
ProDave Posted January 4 Posted January 4 So that is not a rainwater pipe, but outflow from a bathroom? Bodgit and scarper plumbers strike again. Replace that downpipe with the proper round downpipe that will mate with the other black pipes all the way down.
Onoff Posted January 4 Posted January 4 8 hours ago, Pappa said: There is nothing leaking from the top (basin and shower). I think most of us suspected an overflowing roof gutter. There still appear to be some lines of greenery in the mortar joints above that pipe joint. You're in a world of fun here! That round waste pipe to square down pipe arrangement is a bit of a bodge. Normally you'd go from round waste pipe to round down pipe with a solvent weld, strap on boss like this. https://pipescenes.co.uk/shop/soil-waste/40mm-1-5-waste/solvent-fittings-40mm-1-5-waste/black-fittings-solvent-fittings-40mm-1-5-waste/black-3-82mm-x-40mm-43mm-boss-clip-strap-boss-1-1-2-glued-solvent-adaptor/ I don't think they do similar for square down pipe? You can get a pure solvent weld boss like this that could fit into the square pipe. Depends though on the dia of the waste pipe coming in: https://pipescenes.co.uk/shop/soil-waste/40mm-1-5-waste/solvent-fittings-40mm-1-5-waste/black-fittings-solvent-fittings-40mm-1-5-waste/black-3-82mm-x-40mm-43mm-boss-clip-strap-boss-1-1-2-glued-solvent-adaptor/ Consider changing the down pipe to a round one along with associated support brackets and getting a compatible, solvent weld strap on boss. Different makes may be slightly different diameters. Enough to make it a pita if you mix makes. Lots of variables for what might seem a little job. How is that joint done at the moment, I suspect just a hole drilled in the square pipe and the other one poked through? Don't go ordering any of the linked bits btw! A relatively straightforward job if you're a bit handy and have a good selection of tools, hole saws etc a potential pita if you haven't. Me, I'd work with what's there and 3D print an adapter that I'd CT1 on. But then I'm handy and have all the tools. A quick fix would indeed be a tube of black CT1 and run a bead around that joint. 1
Onoff Posted January 4 Posted January 4 Make sure too that those black waste pipe fittings haven't just been pushed on loose, i.e no solvent weld. Could be leaking down inside the cavity.
Spinny Posted January 4 Posted January 4 (edited) Which way is that horizontal round pipe across the wall above the window actually falling ? Looks very horizontal or even running the other way ? I'd say think about why someone has done that Heath Robinson type arrangement of pipe work. It looks like some kind of extension and/or remodelling work was done at some point, but wasn't very well planned with drainage routes not planned properly in advance - or else kind of botched to avoid spending money doing a proper job. If it had planning permission there may be some drawings on the local authority planning applications website. Kinda looks like the ground floor window may have been added blocking the vertical path down to the drain - and/or the drain moved along the wall to make room for a new wall. (Does surface rain water at ground level drain away from that external corner between the windows as it should - or towards it ulp ? I wonder if those leaves near the corner have been washed there because the surface falls into the corner ?} People do very weird and wacky stuff when they lack the brain or money to do things properly. It may be best to give the whole arrangement some thought to see if there is just a whole better layout which might involve more work but be a better long term answer if you plan to live in the house for many years ? Edited January 4 by Spinny
