mjc55 Posted Tuesday at 16:26 Posted Tuesday at 16:26 So at what stage does this become an issue, if at all?  I am just looking at detailed plans for main house (we are currently building a Pod that we will live in during house build) and looking back at the Planning drawings I would like to slightly modify some of the external dimensions! Maybe up to 75mm or so to account for cladding. Is this going to be an issue? The overall width is 18.8m.  In my time as an AT it was never an issue (as far as I am aware at least) but all my work was in extending existing not new build.  Any thoughts welcome
DevilDamo Posted Tuesday at 17:27 Posted Tuesday at 17:27 The bottom line is you build in accordance with the approved drawings. 1
Mr Punter Posted Tuesday at 17:49 Posted Tuesday at 17:49 You will probably not get pulled up on this. They often allow a maximum 100mm leeway to work in with brickwork. If it already built you don't have much option. If not, just do as @DevilDamo suggests. 1
mjc55 Posted Tuesday at 19:13 Author Posted Tuesday at 19:13 Its the main house that I am looking at currently - not started the build on that yet.
BigBub Posted Tuesday at 20:45 Posted Tuesday at 20:45 Each council will have its own published Enforcement Policy and most take the view that proportionate action in relation to a proven breach of planning would only be taken where there is demonstrable harm caused and where it is expedient to do so. Whilst it is unlikely the council would even be made aware of a discrepancy less than 100mm, its also unlikely they would take any action over it as it would be considered de minimus. At most, you may be asked to submit a variation of condition to amend the approved plans, and at worst the changes could be considered material differences which negate commencement of the development and could lead to planning permission being lost. 1
nod Posted Wednesday at 05:19 Posted Wednesday at 05:19 75 mil or 750 No ones going to come out and measure unless someone complains So crack on 1
Alan Ambrose Posted Wednesday at 07:09 Posted Wednesday at 07:09 This has been discussed a few times on ‘t ‘ub already. If I remember rightly, the subtle difference between footprint and overall dimensions might help. Also, by convention, the planning drawings are an approximation e.g. they don’t include drainpipes, TV antennas etc and so some interpolation is allowed and expected. Also, a lot of drawings say ‘you shouldn’t take dimensions off the drawing’ or some such which gives you a little more scope. As always, planning enforcement is just your lovely neighbours. You could always put in a non-material amendment if you want to be squeaky clean. 1
Dave Jones Posted Wednesday at 07:14 Posted Wednesday at 07:14 look at the scale of your approved planning drawings, a pencil line thickness is likely to be at least 600mm! 1
Temp Posted Wednesday at 09:08 Posted Wednesday at 09:08 If they send someone to measure you can always offer to hold one end of the tape. 1
kandgmitchell Posted Wednesday at 09:22 Posted Wednesday at 09:22 As mentioned above you are obliged to build to the approved drawings. Do they specifically set out dimensions for the build and to what degree of accuracy? 18.8m could be anything up to 18.85m really, so arguably you could be only 25mm over Quite honestly I'd be very surprised if the planners got upset by a variation of 0.04% in a dimension caused by cladding thickness; they've got bigger fish to fry. 1
Pocster Posted Wednesday at 11:03 Posted Wednesday at 11:03 (edited) 😊 . You can go “ as far as you can “ off the original drawings . Without being ridiculous. As mentioned if no one complains I.e neighbor ; no one cares . If you do ‘grab a bit extra ‘ just be prepared to give a reason if caught . e.g I had this . Neighbor complains house is higher than drawings . Drawings show house against ‘original wall ‘ . The original wall didn’t exist ( I had knocked it down ) - so is my new wall higher than original wall ? . Also ( as a plan B ) I claimed to the enforcement officer that I had added extra floor insulation which had increased the height slightly .  As a side note . My build ‘grew’ 1 metre longer and 0.5m wider  Edited Wednesday at 11:04 by Pocster 1
