flanagaj Posted June 21 Posted June 21 Is there a minimum distance that you need from a gate to the edge of the highway. I vaguely remember that you must be able to position your vehicle off the highway to enable you to open the gate? As all vehicles differ in length, I am unsure what the rules are around this.
DevilDamo Posted June 21 Posted June 21 It differs. Refer to your Highway Authority’s requirements. 1
JohnMo Posted June 21 Posted June 21 If your looking at that you should also look at the visibility splay as well. But this should all be detailed on your planning drawings. 1
nod Posted June 21 Posted June 21 We’ve just done ours The magic number seems to be 3 meters We’ve set ours at 4 to allow a vehicle to safely stop if there’s no one home to open the gate We are on a country lane with no pavement and 60 mph limit 2
Alan Ambrose Posted June 21 Posted June 21 My local highway guys say 3.7m to 5.5m as part of our planning conditions.
nod Posted June 21 Posted June 21 12 minutes ago, Alan Ambrose said: My local highway guys say 3.7m to 5.5m as part of our planning conditions. Our last build had a pavement and grass verge and good splay vision Our highways simply said NO We ended up putting gates at the side of the house Some eight meters in BUT a build that was completed 12 months after ours (4years ago) Sited there’s at the edge of the pavement About 1 meter from a busy main road As clear as mud
ProDave Posted June 21 Posted June 21 I would say the distance is decided by the longest vehicle you are likely to own. In my case that would be just over 6 metres. But we "solved" the question by just not having gates. Nobody does on our road. 1
nod Posted June 21 Posted June 21 1 hour ago, ProDave said: I would say the distance is decided by the longest vehicle you are likely to own. In my case that would be just over 6 metres. But we "solved" the question by just not having gates. Nobody does on our road. We wouldn’t have bothered either But with a 2.5 year old that seems to bolt at every opportunity
Kelvin Posted June 21 Posted June 21 We have dogs sheep and chickens so need to keep them all separated and off the road. Fortunately we have a large guest/delivery van parking area that will be on the roadside of the fence and gate and then a long driveway and secondary parking area that’s behind the gate.
IanR Posted June 21 Posted June 21 4 hours ago, flanagaj said: Is there a minimum distance that you need from a gate to the edge of the highway. Essex Highways require gates to be a minimum 6m from the highway to avoid a vehicle stopping on the highway in order to open the gates. Footpaths are part of the highway.
JohnMo Posted June 21 Posted June 21 Similar here also. But if you are on a single track road you also need a pull into layby for delivery vehicles (mail etc), so they impede other vehicles.
scottishjohn Posted June 21 Posted June 21 and of course in my area where planning are toal power freaks --its 6m for planning 1
-rick- Posted June 22 Posted June 22 22 hours ago, nod said: But with a 2.5 year old that seems to bolt at every opportunity Hang on a minute. Are you telling us that you've just finished a true self build of a large property between you and your wife, while doing a full time job AND looking after a 2.5 year old? How??
