Hi,
Would appreciate any thoughts on ASHP's and noise?
The ideal location would be at the side of the house but this borders our neighbours.
Do I need to be concerned about noise potentially being an issue for us and our neighbours.
Luckily, the neighbours are great and so keen not to hack them off more than we have to.
Any advice gratefully received!
Thx
Depends on the heat pump I think.
I can honestly say my Veismann Vitocal is very quiet, I can stand right next to it and not know it’s running other than by the cold air coming from the fan.
other people have also remarked on how quiet it is.
It faces my neighbour and is 6 meters from the boundary, his oil fired boiler is considerably more noisy, he has never heard my heat pump running.
Our Mitsubishi eco Was very quiet when first installed You couldn’t hear it from 3 meters away
After about a month You can hear the fan from about 10 meters away
Vaillant twin fan (12kW) facing next door, neighbour cannot hear it and it is near silent at up to 85% output, above that there is a slight buzz but you wouldn't want to be outside for long when it is that cold.
Our cool energy 9kw isn't any louder than a large office fan. The only time it's noisier is when on cooling mode, when it sounds like an overboiling saucepan on a stove. But that's like 5 days a year.
Exactly
Its a large fan
9 minutes ago, nod said:
Exactly
Its a large fan
I know?! Some people think they sound like a motorway at rush hour or flight EZY665 on takeoff.
My extractor fan in the downstairs toilet is louder than my grant aerona3 unless it’s doing a hot water cycle the compressor noise is louder.
The mechanical noise of our ASHP is minimal  but the movement of air does create a quite a loud hum and the force of the fan is strong.
Personally, I would not position the pump facing neighbours though depends on distance etc.
Hopefully @SteamyTea will be along to explain about air particles colliding.
Last 2 Panasonics I fitted were virtually inaudible tbf, and the 2 Stiebel Eltrons we did even more so. Design is paramount so these aren't running flat out, ever, so measure twice install once (and nice & quietly!).
1x S.E. client could hear the neighbours combi flue (30m away) over the unit on full chat, when heating the house for the first time and stood right next to it. 1x Panasonic client had his backing on to the neighbours waffle fence (dwarf one) and on test the neighbour asked the client if they'd hear the unit....he said "It's going full chat right now!".....she said "I can't hear it".....client replied "yup!". Happy days.
There are cheap nasty ASHP's out there, and instances where they should not have been installed, so these are out there as poor examples which people fear. Minds are changing with each 'better' install, just gonna take time I guess.
We have the Vaillant aroTHERM plus 7kW. Its not bad but a bit noisy when working hard. Also get an annoying resonance at times. If I press against the case it stops but haven't yet been able to trace the cause. The sound of the water flowing around the rads is quite intrusive especially on the first few rads in the system. I say all this but having gone from no heating system it was always going to be different and we live remotely so dont have any background noise to mask the noise the system makes.
Sounds to me as if it is not set up right.
What are the flow temperatures and rates?
Thanks SteamyTea
Right now flow temp is down at 25c for an inside temp of 18C but the rads are still noisy. Its set up to only run from weather comp. Highest flow I have seen is 38C but I dont check it very often and dont yet have an app to easily see whats happening. No idea what the flow rates are as not sure where to find that info
Vaillant 7kW here, double glazed living room window just 30cm from the unit and adjacent utility room window immediately behind the unit.
Most of the time its totally silent indoors and whisper quiet outdoors, inaudible from >3-4m away.
When it working really hard, which it does for typically 5-10 minutes after a defrost at - temperatures and very occasionally for longer periods up to say 30mins, its just audible indoors, but still quieter than the fridge in the same room and quieter than the gas flue was in the bathroom to which the flue was adjacent.  Outdoors in this relatively rare situation there is a buzz which seems to appear at compressor modulation >80%.  I've turned on noise reduction mode at night out of respect for the neighbours, however I only did this about a month in and after some quite severe defrosts, and they now tell me that they didn't even know I had the heat pump!  Their bedroom window is about 6m away, albeit screened by the building.
No noise from pipework, which is odd because there was pipework noise with the gas boiler when it was heating DHW.
Overall, for me. no more of a problem than a gas boiler.
9 hours ago, Beau said:
Thanks SteamyTea
Crikey, is it cold where you are ? mines been turned off for 3 weeks and the internal temp hasn’t gone below 19.7 it was 23 this afternoon
houses are different - I won’t turn my heating off until mid may normally
Yep, we still get best part of zero at night. Heating could go off, every few days, but it's free from excess PV, so why bother switching it off.
Mine generally is heating, then cooling until September. Not much middle ground.
We live on Dartmoor. It's around 11C outside and been gusting 55 kmh. The house is only part renovated and we get poor solar gain due to having just two south facing windows and are very shaded from the east.
Edited by Beau
OK I don't have ASHP I have a Gas Boiler basically running ASHP flow temps. All rads no UFH.
My pet hate is system noise (flow thro the rads) I've gone to a lot of effort to get the flow rates right for each individual room based on the target room temp - I don't run any set backs - heating is on 24/7. I am running a with weather compensated flow temp but it's been well worth the time invested in getting every room right. Highest flow temp I've seen over winter was 35 deg C. Right now the boiler is targeting 22 Deg Flow temp.
Sitting in my living room right now all I can hear is the wall clock ticking no system noise at all.
I think if your circuit is noisy you might have a little too much flow thro it.
I suspect your right but not sure what to do about it. This morning I came down and it was just audible like say a gas boiler in a neighbouring room. Now it's just stepped up more like I am in the room with a boiler even though is not cold outside and flow temps are low. Sometimes when its cold you get a two noises one is just rushing water in pipes but there is a second like a distant car is coming up our quiet country road but never gets here. I think the second noise is the heat pump running getting carried through the pipes. It's interesting that others say their systems are near silent as I had just put it down to the ASHPs needing high flow rates but maybe this is not the case. I did mention it early on to the installer but they just shrugged as though it was normal. On the water noise in the pipes I dont think I saw them deburr inside any of the pipes it was just pipe cutter then clamp. Could the burrs be causing turbulence and in turn the noise of rushing water?
Not just houses, regional weather makes a difference.
Down here, our local temperatures are predominately governed by sea surface temperature.
