Berkshire_selfbuid Posted 7 hours ago Share Posted 7 hours ago Hi all. Firstly, I’m super proud to say that we have reached 1st floor joist level and currently building up to 2nd floor - progress is accelerating! On to my dilemma. We are having 4 bedrooms on 1st floor with 2 en-suites and 1 family bathroom as per following: I’m now thinking of modifying the layout so it resembles the below which will give us 4 en-suites: Note: entrance from bathroom show via landing but can be via bedroom 4. This will give us all bedrooms with en-suite (bedroom 5 with en-suite is on 2nd floor). Reason for this is that I believe it may increase GDV, increase future saleability, make better use of space and minimal extra cost. My only negative is that the rear end will go from this: To this: As I’m not adding in new window panels or making the windows bigger, I should be able to make this change without going through planning. Although I’m not happy with the way the window configuration looks from the rear, I think I’m happier with the extra en-suite, and the way it looks from the rear may not bother me too much. I’m hoping you amazing lot may help me decide if it’s worth while making this change, or should I just stick with what I’ve got in the plans? I’ll be up to the hight requiring making the decision next week! Link to comment Share on other sites More sharing options...
JohnMo Posted 6 hours ago Share Posted 6 hours ago I am in the camp, you change stuff at the planning stage, never ever after you start construction. One small change leads to 10 unforseen changes, each adding cost and delay. So my answer is follow the plan. 29 minutes ago, Berkshire_selfbuid said: As I’m not adding in new window panels or making the windows bigger, I should be able to make this change without going through planning Not sure that is correct, your plans when approved form what is legally agreed scope of work. Any deviation needs some approval, your planning agreement will say that. So minor or major change requires, a document trail, possibly revised approvals. 1 Link to comment Share on other sites More sharing options...
ProDave Posted 6 hours ago Share Posted 6 hours ago I would say build for your expected occupancy and use, not resale value. 2 Link to comment Share on other sites More sharing options...
DevilDamo Posted 6 hours ago Share Posted 6 hours ago From a Planning perspective and as a minimum, it should go through the Non-material amendment process. Btw, is your username missing an “l”? 1 Link to comment Share on other sites More sharing options...
torre Posted 6 hours ago Share Posted 6 hours ago "Five bedrooms all ensuite" has a great marketing ring to it, but I'd prioritise whichever will work for you living there. Also I think most people buying a house that size would expect at least one to have a bath in it. Three bedrooms without any built in wardrobes doesn't sound so great though so I think you'd want to try and relocate those. If you don't like the external look, I wonder if you could fit a fake pane or similar in the middle and run the cill through 1 Link to comment Share on other sites More sharing options...
ProDave Posted 6 hours ago Share Posted 6 hours ago Hot having seen all the floor plans, if you went got 5 bedrooms all en-suite, would there be any shower or toilet that was NOT accessed through a bedroom? Link to comment Share on other sites More sharing options...
Berkshire_selfbuid Posted 6 hours ago Author Share Posted 6 hours ago 25 minutes ago, DevilDamo said: From a Planning perspective and as a minimum, it should go through the Non-material amendment process. Btw, is your username missing an “l”? Yes fair point. Non-material amendment would be sensible. Now that you mention it, yes is it missing an ‘l’!! Can’t believe I never noticed that. Will see if I can update it! 🫣 Link to comment Share on other sites More sharing options...
Berkshire_selfbuid Posted 6 hours ago Author Share Posted 6 hours ago 6 minutes ago, ProDave said: Hot having seen all the floor plans, if you went got 5 bedrooms all en-suite, would there be any shower or toilet that was NOT accessed through a bedroom? There would be a ground floor WC. Otherwise all showers will be via bedroom. Link to comment Share on other sites More sharing options...
