Berkshire_selfbuild Posted January 17, 2025 Posted January 17, 2025 Hi all. Firstly, I’m super proud to say that we have reached 1st floor joist level and currently building up to 2nd floor - progress is accelerating! On to my dilemma. We are having 4 bedrooms on 1st floor with 2 en-suites and 1 family bathroom as per following: I’m now thinking of modifying the layout so it resembles the below which will give us 4 en-suites: Note: entrance from bathroom show via landing but can be via bedroom 4. This will give us all bedrooms with en-suite (bedroom 5 with en-suite is on 2nd floor). Reason for this is that I believe it may increase GDV, increase future saleability, make better use of space and minimal extra cost. My only negative is that the rear end will go from this: To this: As I’m not adding in new window panels or making the windows bigger, I should be able to make this change without going through planning. Although I’m not happy with the way the window configuration looks from the rear, I think I’m happier with the extra en-suite, and the way it looks from the rear may not bother me too much. I’m hoping you amazing lot may help me decide if it’s worth while making this change, or should I just stick with what I’ve got in the plans? I’ll be up to the hight requiring making the decision next week!
JohnMo Posted January 17, 2025 Posted January 17, 2025 I am in the camp, you change stuff at the planning stage, never ever after you start construction. One small change leads to 10 unforseen changes, each adding cost and delay. So my answer is follow the plan. 29 minutes ago, Berkshire_selfbuid said: As I’m not adding in new window panels or making the windows bigger, I should be able to make this change without going through planning Not sure that is correct, your plans when approved form what is legally agreed scope of work. Any deviation needs some approval, your planning agreement will say that. So minor or major change requires, a document trail, possibly revised approvals. 1
ProDave Posted January 17, 2025 Posted January 17, 2025 I would say build for your expected occupancy and use, not resale value. 2
DevilDamo Posted January 17, 2025 Posted January 17, 2025 From a Planning perspective and as a minimum, it should go through the Non-material amendment process. Btw, is your username missing an “l”? 1
torre Posted January 17, 2025 Posted January 17, 2025 "Five bedrooms all ensuite" has a great marketing ring to it, but I'd prioritise whichever will work for you living there. Also I think most people buying a house that size would expect at least one to have a bath in it. Three bedrooms without any built in wardrobes doesn't sound so great though so I think you'd want to try and relocate those. If you don't like the external look, I wonder if you could fit a fake pane or similar in the middle and run the cill through 1
ProDave Posted January 17, 2025 Posted January 17, 2025 Hot having seen all the floor plans, if you went got 5 bedrooms all en-suite, would there be any shower or toilet that was NOT accessed through a bedroom?
Berkshire_selfbuild Posted January 17, 2025 Author Posted January 17, 2025 8 hours ago, DevilDamo said: From a Planning perspective and as a minimum, it should go through the Non-material amendment process. Btw, is your username missing an “l”? Yes fair point. Non-material amendment would be sensible. Now that you mention it, yes is it missing an ‘l’!! Can’t believe I never noticed that. Will see if I can update it! 🫣 (Done.. Admin)
Berkshire_selfbuild Posted January 17, 2025 Author Posted January 17, 2025 6 minutes ago, ProDave said: Hot having seen all the floor plans, if you went got 5 bedrooms all en-suite, would there be any shower or toilet that was NOT accessed through a bedroom? There would be a ground floor WC. Otherwise all showers will be via bedroom.
crispy_wafer Posted January 18, 2025 Posted January 18, 2025 Very nice, You've still maintained symmetry so it's not so bad, Maybe just space the windows further apart so that they are above the sidelights on the downstairs french doors instead. Once it's built though, you'll not really notice after the first few months!
MikeSharp01 Posted January 18, 2025 Posted January 18, 2025 8 hours ago, Berkshire_selfbuild said: There would be a ground floor WC. Otherwise all showers will be via bedroom. Does that breach any regs I wonder and if you are having a big party would it not make sense to have a second one accessible without going through a bedroom, perhaps look at a Jack and Jill arrangement. I am also with @JohnMo in respect of sorting it now and then leaving well alone for the build. 1
dpmiller Posted January 18, 2025 Posted January 18, 2025 Another vote for a Jack & Jill door setup if you should decide to make the change
Berkshire_selfbuild Posted January 18, 2025 Author Posted January 18, 2025 (edited) Thanks all for your super helpful comments. Our main driver for another ensuite was to provide both our kids with an ensuite. As some of you have mentioned, Jack and Jill set up might work. To avoid making any window changes, I could leave it as 5 bed and 4 bathrooms but do the jack and Jill to the main bathroom via the bedroom and landing. Therefore it will just be the 1 bedroom which does not have ensuite access and they would have access to bathroom via landing. Edited January 18, 2025 by Berkshire_selfbuild
Redbeard Posted January 18, 2025 Posted January 18, 2025 11 hours ago, torre said: If you don't like the external look, I wonder if you could fit a fake pane or similar in the middle and run the cill through +1. Slightly mirrored glass on the outside, PIR and ply to complete the 'sandwich' and then the stud wall seals to the ply.
ETC Posted January 18, 2025 Posted January 18, 2025 Leave it as it is but put doors from each bedroom into a single rear en-suite to be shared by both bedrooms.
Berkshire_selfbuild Posted January 18, 2025 Author Posted January 18, 2025 8 minutes ago, ETC said: Leave it as it is but put doors from each bedroom into a single rear en-suite to be shared by both bedrooms. Thanks yes I think this will the path of least resistance and in essence gives us what we want - either Jack and Jill via both bedrooms or via bedroom and hallway. Thanks 😎🔥
Berkshire_selfbuild Posted January 18, 2025 Author Posted January 18, 2025 3 hours ago, ETC said: Thanks so much for this. I think I’ve been fixated for a while on having the same number of bathrooms as bedrooms but I need to let go and make best use of the space and situation by keeping it simple and having something similar to what you have mentioned. Thanks!
bmj1 Posted January 19, 2025 Posted January 19, 2025 (edited) 3 hours ago, Berkshire_selfbuild said: Thanks so much for this. I think I’ve been fixated for a while on having the same number of bathrooms as bedrooms but I need to let go and make best use of the space and situation by keeping it simple and having something similar to what you have mentioned. Thanks! We did 5 bedrooms, with 4 bathrooms, 2 ensuite, 2 with baths. Works perfectly for our needs, and I'm glad we didn't do more unnecessary bathrooms. We're expecting to be here 20+ years, so it's got to make sense to do what is right for you. Edited January 19, 2025 by bmj1 1
ETC Posted January 19, 2025 Posted January 19, 2025 13 hours ago, Berkshire_selfbuild said: Thanks so much for this. I think I’ve been fixated for a while on having the same number of bathrooms as bedrooms but I need to let go and make best use of the space and situation by keeping it simple and having something similar to what you have mentioned. Thanks! @Berkshire_selfbuildNo problem. Anytime.
Mike Posted January 19, 2025 Posted January 19, 2025 On 18/01/2025 at 09:49, Berkshire_selfbuild said: Jack and Jill set up might work The downside is noise transmission through the doors so, if you go this way, install acoustic-rated doors & frames. Personally, I'd avoid them. 1
Andeh Posted January 19, 2025 Posted January 19, 2025 Multiple En suites are up there with wooden kitchen surfaces, outdoor kitchens,dining rooms and resin driveways etc..... Great in theory but in the real world have real world draw backs. With en suites it's the amount of additional clesning... 5 toilets a week, 5 basins, 4 showers, 4 tiled floors etc... It really adds up!! Jack and Jill, or just additional "general" access bathrooms vets my vote. 1
