puntloos Posted June 23 Share Posted June 23 My current patio keeps standing water, even though there's a french drain next to it. Does this mean the tilers didn't put down an appropriate angle? A "random video" online tells me that for proper draining you need at least 2%, so 2cm per 100cm? Or is it not standard to angle outdoor tiles a little? What's an accurate way to measure the drain angle of the patio? Or can I just from this picture claim the patio isn't angled appropriately? (for what it's worth the scaffolding planks might've stopped some of the potential draining, although I imagine water would find a good way around it?) Link to comment Share on other sites More sharing options...
joe90 Posted June 23 Share Posted June 23 Put a spirit level on it 🤷♂️yes minimum 2%. Link to comment Share on other sites More sharing options...
JohnMo Posted June 23 Share Posted June 23 5 minutes ago, joe90 said: Put a spirit level on it The buble should be biased towards the lines either left or right of centre. If it's in the middle it's flat not sloped. Link to comment Share on other sites More sharing options...
puntloos Posted June 23 Author Share Posted June 23 3 minutes ago, JohnMo said: The buble should be biased towards the lines either left or right of centre. If it's in the middle it's flat not sloped. Cheers, but the challenge is more to measure what the actual angle is. I think you can't tell from a spirit level if it's 1% or 3%? Or is there a way to semi-accurately eyeball this with a spirit level? And so I take it indeed I should expect 2% slope else I can say they didn't do a good job? Link to comment Share on other sites More sharing options...
joe90 Posted June 23 Share Posted June 23 If you want 2% use a 1 mtr piece of wood, stick a 2cm little block one end and put your sprit level on it on the patio (block lowest end) and the bubble should be central. This will give you an idea of the slope (or not). 1 Link to comment Share on other sites More sharing options...
Ferdinand Posted June 23 Share Posted June 23 The surface of the water will be perfectly level, so you can judge the gradient of the patio it by measuring the depth of water in mm at each end. If the measurements are too small to measure easily, add more water .... 😛😉. (TBH I'd suggest that the water escape routes are perhaps blocked with all that dust'n'gunge.) 1 Link to comment Share on other sites More sharing options...
puntloos Posted June 23 Author Share Posted June 23 50 minutes ago, joe90 said: If you want 2% use a 1 mtr piece of wood, stick a 2cm little block one end and put your sprit level on it on the patio (block lowest end) and the bubble should be central. This will give you an idea of the slope (or not). That's a great tip. Easy to do. Will figure it out. 39 minutes ago, Ferdinand said: The surface of the water will be perfectly level, so you can judge the gradient of the patio it by measuring the depth of water in mm at each end. If the measurements are too small to measure easily, add more water .... 😛😉. (TBH I'd suggest that the water escape routes are perhaps blocked with all that dust'n'gunge.) It's certainly better now, but agreed there's still some dust and grime but not really "mountains" of it. If anything the tiles are angled away from the drain: Link to comment Share on other sites More sharing options...
joe90 Posted June 23 Share Posted June 23 Looks like a slight fall but not much. Water has a surface tension which is why a minimum of 2% is advocated. Link to comment Share on other sites More sharing options...
saveasteading Posted June 23 Share Posted June 23 20 minutes ago, puntloos said: That's a great tip. Easy to do. Do it then reverse the spirit level. They are often inaccurate. If you get the same bubble position then you have confirmed the accuracy. If it is a different position then the average applies. a 2p coin is about 2mm thick. Link to comment Share on other sites More sharing options...
MortarThePoint Posted June 23 Share Posted June 23 (edited) I'm a fan of laser levels so you can do this with one too. The laser shines a level plain so, with the laser set up in single position, as you move away from the house you should measure and increasing height between patio and laser beam. Edited June 23 by MortarThePoint 1 Link to comment Share on other sites More sharing options...
puntloos Posted June 23 Author Share Posted June 23 2 hours ago, joe90 said: Looks like a slight fall but not much. Water has a surface tension which is why a minimum of 2% is advocated. But to be clear - this is the wrong way.. the bubble is slightly 'toward' the drain, so the slight fall is towards the grass. (which is on pretty solid clay sadly so it soaks the grass) 1 Link to comment Share on other sites More sharing options...
Nick Thomas Posted June 23 Share Posted June 23 My smartphone has a spirit level application (https://f-droid.org/packages/org.woheller69.level/) which is surprisingly great - although YMMV with the quality of the sensors in the hardware, of course. It's been very handy for measuring the actual angles of things that are already up, though. Just make sure you use a flat side on the phone, not a side that has protruding buttons or cameras or whatever. Don't ask me why I need to say this. Link to comment Share on other sites More sharing options...
Dave Jones Posted June 24 Share Posted June 24 depends what you mean by standing water. porcelain hangs onto a couple mm all over, more if there is a dip/bow which nearly all porcelain has. Use your level from the house pack it up on a couple bricks make it dead level then move over and level off last pile to next until you are at french drain. tape measure starting block and end block do the math. Link to comment Share on other sites More sharing options...
puntloos Posted Monday at 21:03 Author Share Posted Monday at 21:03 (edited) OK, managed to use the spirit level app @Nick Thomas suggested. Took me a minute to realise that I didn't look for 2 degree angle but 2 percent slope. (which is, if you're using a 1m measuring stick, about 1.2 degree) To be clear though - if a patio is not 2%ish slope, would you all consider it poorly designed and/or something I can complain about? My result is as I expected which is that my patio is pretty much flat, maybe 0.5% slope at best.. Edited Monday at 21:04 by puntloos Link to comment Share on other sites More sharing options...
puntloos Posted Wednesday at 18:20 Author Share Posted Wednesday at 18:20 (edited) Ping? 😃 sorry but the last question is quite important since I might have a difficult discussion with my builder: Is it reasonable for me to expect a 2% slope patio or should this have been agreed previously? Edited Wednesday at 18:37 by puntloos Link to comment Share on other sites More sharing options...
Buzz Posted Wednesday at 18:32 Share Posted Wednesday at 18:32 7 minutes ago, puntloos said: Ping? 😃 sorry but the last question is quite important since I might have a difficult question with my builder: Is it reasonable for me to expect a 2% slope patio or should this have been agreed previously? Yes it is reasonable to expect a fall on your patio and your paths too, the only thing up for discussion would be where to have the fall if not obvious but as you have a french drain I'd have thought that was a big enough clue and shouldn't need pointing out . 1 Link to comment Share on other sites More sharing options...
