Which internal doors have to be fire doors? if any
Post and beam
  On 24/01/2024 at 22:06, nod said:
The door between the house and your internal garage The rest are fine unless your over three floors
Expand
This, though mine is three floors from the front and two floors from the back. I discussed with the BCO and architect about the fire strategy and the BCO was satisfied there was an acceptable escape route to the rear on the part with two stories. I made sure I got this in writing before ordering and installing the doors.
This means I didn't have to have fire doors to the central stairs. Only fire door I needed was to the integral garage.
The bco will likely ask for a FD30s which is a 30min fire door with smoke seals.
  On 25/01/2024 at 10:11, Post and beam said:
We wont have an internal garage and its a 2 storey house so on this basis i dont need any fire doors.
I am trying to budget for internal doors so this makes a difference. Need 14 in total.
Thanks guys
Expand
Good to hear, though while on the subject of fire make sure your upstairs windows have suitable fire escape sizes and heights of the bottom of the openable area
Thanks guys
Expand
i've been told by quite a few friends to get FD30 doors anyway as they're much more solid. yes, they're double the price but you can get a deal if you shop around and i dislike the flimsy feeling non-FD30 doors. ymmv.
Expand
Buy solid core doors not hollow core.
You can also go 44mm for a heavy feel.
Expand
what's the price difference between a solid core 35mm door and a 44mm FD30 door though? probably not a lot. we got a good deal on FD30 doors, they're bloody heavy and should be a good solid door.
we got these XL Joinery doors for £143+VAT from Jewson. the 35mm version were £83+VAT.
Expand
From those figures it’s £60 times 12-14 doors that’s a grand.
My 35mm solid cores turned up today, I really don’t want them a lot heavier they where a pig to carry around the house.
Expand
yeah my 35mm solid cores feel heavy enough. Also the £60 uplift is there also due to the fire door certification
Expand
that's some interesting maths! 🤣 but i understand the sentiment.
Expand
that's the chippie's problem. 😉
  • 3 weeks later...
  On 14/02/2024 at 10:43, Willow said:
Hi Can I just jump on this convo , our house is 3 storeys the plans say fire doors for second and top floor but ground floor doesn't is this correct ?
Expand
Just thinking in common sense
basically if  your in the kitchen and a fire breaks out you will run out the back door, if your in the front room you will run out the front door.
but if you are upstairs and your route to outside is blocked by fire you will want to hide behind a fire protected door until help arrives.
look at it like this and walk around thinking how you will get out.
Obviously check the regs, but that’s the general gist of it.
