I noticed that the magic purple airtight paint was used on the entire surface of his OSB. i understood that OSB is regarded as airtight by design. Is this not so or did he just get carried away?
OSB is not airtight
Quite like the idea of the zip board you get in the US with the air tight waterproof coating already made. It's always seemed to me that our building material technology is a bit behind others, you can get ply coated (like "Smartply"), but coated OSB seems to be a mystery product.
OSB can be airtight, it depends on the thickness and how well made it is. I would be very surprised if a thick SIPs panel wasn't airtight to the degree required for an airtightness test. With the the way the SIPs panels are joined I would have thought the purple paint wasn't really required. I achieved an average airtightness on my house of 0.47ACH without any airtightness tapes, membranes or paints. I just had 15mm OSB3 and 350mm Icynene foam. The window and door frames were sealed in the openings with two rows of Compriband and Soudal SWS foam. There were no openings in the walls or roof other than the two ducts for MVHR.
Do you think, if time and price were no object, you could have improved it much. That is without getting silly and casting a block of concrete over it.
Very commendable, just shows what can be done, I have my doubts about the longevity of tapes 🤷‍♂️
I don't know what I could have done to improve it other than not have a lift slide door, which leaked a bit.
I suppose you would have to do a smoke test to see if any issues became apparent. Rather than theorise where improvements might be possible.
This is what i am expecting. My Potton home, if it ever happens,( sale chain has fallen through)  will be Sips. I am happy to tape the joints but dont fancy purple painting the entire panel area.
We did smoke tests, and the lift slide door was the only one showing a 'significant' leak, although nothing compared to most houses.
I can't imagine even the joints would need taping, but it comes down to how carefully the panels are joined together.
Agree, and i would be happy if my taping efforts are redundant. But once done i wont know either way. The size of the task is worth it to me.
We all look forward to the ACH figure from the leakage test, no pressure.
I've been very surprised that Booglehead (a guy I follow on YouTube) and Glyn Hudson (same) both passed their pressure tests without doing what I would have thought necessary.
Booglehead hadn't taped around his windows at all it seemed and hadn't taped the insides of his SIPS. The outsides didn't look very carefully taped either. He also put a lot of screws right through everything in a way that I thought would have caused leaks.
Glyn Hudson got his regular town house (not sure when built, but quite old) pressure tested and that passed too. I was really surprised by that one. Made me wonder what all the fuss is about.
Passed at what level. 0.2 or 5?
I passed my driving test, crashed sister's car 2 nights later, then my motorbike, twice, then my father's brand new car, got banned twice for my troubles.
Then, at 20 years old, I got glasses and it all seemed to stop happening.
  • Haha 2
Each January, I pack away the decorations, tape the tops shut and store in the attic. Each December I find all tapes are unstuck. It must be the February chill or the summer heat.
I regard tapes as temporary fixings.
I followed the Potton PassivHaus case Study using Kingspan SIPs panels when it was being built 5 - 10 years ago. They were running a blog that was regularly updated. I remember they struggled a bit with the air tightness, failing the first air test they did, and later commenting that an internal membrane was required to get it below the 0.6 ACH target. I thought the blog was quite honest of them.
SIPs are considered "airtight" in a standard building regs environment, but the shortfalls need to be mitigated for PassivHaus levels of airtightness.
0.45 if I remember correctly. I think Glyn Hudson's was even lower, which was very strange. Here's the links.
https://www.youtube.com/watch?v=tFMlJmRiaqo&list=PLzJHPUKEmzWVlbuMLwIeT_52SooH5ROrB&index=4&ab_channel=Booglehead
I think Glyn has done the numbers wrong tbh, though he is a techiehead and loves this sort of thing so it seems unlikely, but I just can't wrap my head around how he has calculated it - he claims it's 0.3Ach.
https://www.youtube.com/watch?v=kkNx2oSO-S4&t=383s&ab_channel=GlynHudson
0.3 for the heat loss calculation, not the blower test. Shows in the thumbnail that's after dividing by 20 and the actual blower test result of 6.4@50Pa
He is playing with numbers, his house leaks like a seize. A passivhaus is also tested at 50Pa, they have to score 0.6 ACH or better from that test, he scored 6.4m3/m2 at the same pressure. Not quite the same scale, but close enough in this case.
So using his example of dividing by 20 a passivhaus would leak at a rate 0.03 ACH.
I thought the conversion from  m3/m2  to ACH was very approximately 1:1 but there is no simple universal conversion because it depends on the geometry of the house, i.e is it single storey, 2 storey, vaulted ceilings etc.
If it really was divide by 20 them my 1.4 m3/m2 would be 0.07ACH.  No way is that the case.
