Hi, I’m trying to power a gate motor 200m from our house. We will need power to the gate motors, an intercom and a light.
What size and core cable should I use for that distance?
Any advice appreciated, thanks.
Will the intercom need a hardwired connection?
200m is a long way for wireless.
While you've got a trench open. Makes sense to drop in a multicore cable alongside the 230v one
Good shout, although be careful of separation distances between power and data to avoid interference. 200mm (I think) for unshielded cables.
I've put in a gate supply before, we ran a 12 core 2.5mm in the same trench. That gave them options for remote opening, lighting controls and a digital audio 2 way system..
You shouldn't mix voltages and data in the same cable like that.
Depends entirely on the voltages...
All signals were <24 volts and had appropriate circuit protection.
600 watts. I based that on my faac741 operator at 500 watts and 100 watts of lighting/ anti con heaters/ intercom
200metres
3 core swa
4mm2 gives under 3% volt drop
Doesn't just depend on the voltages, but on whether some signals are for SELV or not. SELV and mains (or anything >50V) must not be combined in a single cable.
Hence why Dali data lines are not considered SELV and must be treated as if they carry mains, despite being 24V, just as one example.
I stopped listening when you said 25mm2 tbh.
Plus you should take it as 5% not 3.
The data and control cables were all compatible to be in the same cable..
The contactor arrangement for switching was recommended by the gate manufacturer.
That was me, I hoped I’d caveated it enough with
1 hour ago, LiamJones said:
All depends on how many amps over how many meters.
but clearly not
4 minutes ago, FuerteStu said:
Wasn't me..
My sincere apologies for suggesting you were a:
  • Haha 1
I am about to put electric gates in and my motor is fused at 3 amp, not 13 amp. (But only 10m distance).
Edited by joe90
1 hour ago, Marvin said:
I'm pretty sure I've seen cables for household car charging points being advertised with the power and data cores in the same cable....
https://www.cef.co.uk/catalogue/products/5243696-3-core-6-0mm-cat5-ev-cable-black-cut-length-sold-by-the-mtr?gclid=CjwKCAjwvfmoBhAwEiwAG2tqzKXgR2l1fhLNZr6BMSCtxQOX5knV9vbL1mAtyUlgWK_NRyrDdYrD_xoCV-YQAvD_BwE&gclsrc=aw.ds
not sure how these work...
Specifically designed with extra protection, both mechanical and shielding on the data side.
To my gate I've a bit of 2.5mm2 3 core swa in a bfo DNO duct (60mm dia?), then two 20mm flexible conduits inside that for camera, gate release etc.
If you've got a trench open, put in a couple of conduits with drawstrings rather than extra naked cables.
The house to the gate is exactly the tope of place you will have need for a new run at least once in the next decade eg if something like a phone cable or an old data cable breaks, or if you need a new one.
The prices of bigger rolls of conduit falls so sharply that the extra cost is minimal.
A friend who does gates and access often suggests wiring for a socket at the gate end.
I think it is so he can plug in his charger and make tea when he comes back to service them!
  • Haha 2
Thank you all.  I’ve ordered 200m of 10mm2 3 core which should do the job.
I’m dropping a spare 50mm electric duct in just in case.
