Starting to think about the main floor area.
I like large format ( but perhaps not the price ) - wondering how feasible it is for one lowly human to lay them on their own.
Large format of course is anything from 1000 x 1000 up.... ( seen as high as 3200 x 3200!  )
I assume once back buttered ; the weight ( using glass suction cups ) becomes the issue......
Been laying 600 x 900 20mm porcelain for the patio and paths , wouldn't want to lay anything larger on my own. Not to bad carrying to where your working but once down flat lifting to manoeuvre very difficult due to the weight.
Yeah I figure weight would become an issue. I know there is porcelain-thin ( some as low as 4mm! - apparently just as strong ). But pricing for those is always "please call for a quote " - which of course means it is too expensive!
Guess I can manage 1000 x 1000 no more than 10mm on me tod . At that size only around 100 of them to lay ....😶
Edited by pocster
We have 1200 x 1200 x 7mm - two people required to lay them.
We laid ours on Ditra.
Normal suction lifters may not work if tiles have a texture.
Expansion joints in every doorway and across a large opening due to the size of the area.
Definitely use a levelling system.
We also used the tiles as skirting.
Have a decoupling mat and a levelling system . Don’t have any friends so must lay myself ( not rude @Nickfromwales )
  • Haha 1
  • Sad 1
59 minutes ago, Alan Ambrose said:
them being not flat - there was a thread about it here recently.
That was me.  2mm hump in a 900 x 150 porcelain tile. It needed  a levelling system but the first timers are getting on great with it, and using the levellers on smaller tiles now too, for speed.
I am guessing that a big square tile may have a hump in the middle, but the perimeter would all be level. Perhaps a heavy weight in the middle will sort it, but a 2mm flow won't really matter.
Handling? Well you wouldn't want to drop or scratch them so find a helper  (doesn't need to be a friend) and buy a suction lifter?
Edited by saveasteading
Doorway sure . How big was your area and where did you place expansion joints ? ( is there a rule of thumb for this ?? )
If there are contraction joints in the floor then mirror them.
Otherwise, why would you expect the floor to move?
Only obvious crack in screed is in a doorway ( as you might expect ) - rest of floor is fine .
17 minutes ago, Big Jimbo said:
Bloody hard work lifting them on your own Buddy, but has the advantage of not having to hurry because you are paying somebody to help you.
I’m 💪💪💪💪💪💪 - so no (expletive deleted)ing bother
1 hour ago, pocster said:
Around 80sq m
measured with the same tape measure you used for the walk-on glazing?
.....I'll get my coat.
Oi ! You flooded your (expletive deleted)ing house again yet ?
  • Haha 1
5 hours ago, pocster said:
Around 80sq m
Quite big. But the concrete should be totally stable now, and you are using the mat, so i think you can risk omitting movement joints....not nice in a room.
  • 4 months later...
I'm also looking at large format tiles, have 200sqm ... but was also considering resin, early stages so not costed either up. I like the clean, no grout and a subtle pattern. Do you still need expansion joints with resin ? anybody got a cost comparison ?
oh and any thermal benefits of resin over porcelain tiles using UFH ?
Edited by PaulD
forgot something
We layed 1000x1000x6mm on ditra matting/ raft slab. 100% 2 man job. Still got a bathroom with 1200x1200 to do. What's this leveling system you talk about?
Check out Rubi . Wedges and clips . Really good system - reduces lippage .
