thefoxesmaltings Posted October 6, 2022 Share Posted October 6, 2022 Anyone had this issue from lenders being generally unhappy and unwilling to lend based on the following condition? This is in our planning permission: "Condition 9 - The development hereby permitted shall be constructed to Building Regulation Part G(2)(b) standards limiting water consumption to 110 litres per person per day. Reason: To reduce demand for finite resources as the district is in a water scarce area. This condition is imposed in accordance with Policy SP10 of the Local Plan." Lenders and valuers alike are concerned about the implications of the above condition under the principle that it affects the saleability of the property, and therefore negatively affects it's value and security. Link to comment Share on other sites More sharing options...
AliG Posted October 6, 2022 Share Posted October 6, 2022 They are being an idiot. That has been in building regs since 2010. It just means that fittings that limit water use have to be used. No one actually checks the water consumption. 1 Link to comment Share on other sites More sharing options...
Kelvin Posted October 6, 2022 Share Posted October 6, 2022 As above although I expect it’s a wilful decision insofar that lenders might have glossed over this before but are not being a lot more stringent on what they’ll lend against as they tighten up money supply Link to comment Share on other sites More sharing options...
joe90 Posted October 6, 2022 Share Posted October 6, 2022 Ha, my BCO looked at my huge bath and said “you know that does not meet building regs but if I make you change it you will only put it back again afterwards!” And moved on….. 1 Link to comment Share on other sites More sharing options...
thefoxesmaltings Posted October 6, 2022 Author Share Posted October 6, 2022 10 minutes ago, joe90 said: Ha, my BCO looked at my huge bath and said “you know that does not meet building regs but if I make you change it you will only put it back again afterwards!” And moved on….. So you also had this condition and were able to get funding from lenders on a self-build mortgage? Link to comment Share on other sites More sharing options...
Temp Posted October 6, 2022 Share Posted October 6, 2022 The relevant bit of the Building Regs is Approved Document G.. Quote (2) The requirement referred to in paragraph (1) is either (a) 125 litres per person per day; or (b) in a case to which paragraph (3) applies the optional requirement of 110 litres per person per day, as measured in either case in accordance with a methodology approved by the Secretary of State. (3) This paragraph applies where the planning permission under which the building work is carried out— (a) specifies the optional requirement in paragraph (2)(b); and (b) makes it a condition that that requirement must be complied with. So yes it is a more stringent standard than otherwise. Never heard of it being a problem for lenders. One option might be to ask the planners if they would remove/replace the condition if you install some sort of rainwater recycling system. Even if only for flushing loos. Propose your own ambiguous condition. What does the SPD SP10 say about rainwater recycling if anything? We have an underground rainwater recycling tank but its only used for garden/car. 2 Link to comment Share on other sites More sharing options...
thefoxesmaltings Posted October 6, 2022 Author Share Posted October 6, 2022 2 minutes ago, Temp said: The relevant bit of the Building Regs is Approved Document G.. So yes it is a more stringent standard than otherwise. Never heard of it being a problem for lenders. One option might be to ask the planners if they would remove/replace the condition if you install some sort of rainwater recycling system. Even if only for flushing loos. Propose your own ambiguous condition. What does the SPD SP10 say about rainwater recycling if anything? We have an underground rainwater recycling tank but its only used for garden/car. Haha, we already have rainwater harvesting proposed to be installed as part of the approval, yet still had this condition imposed. Do you think it might be worth trying another broker? Currently using Mayflower who I was recommended to as they are self-build mortgage specialists. Link to comment Share on other sites More sharing options...
Temp Posted October 6, 2022 Share Posted October 6, 2022 Do you meet the rules for the Ecology Building Soc? Link to comment Share on other sites More sharing options...
joe90 Posted October 6, 2022 Share Posted October 6, 2022 28 minutes ago, thefoxesmaltings said: So you also had this condition and were able to get funding from lenders on a self-build mortgage? No, luckily I had the cash from a previous sale for my build, the building regs include water use and some, like Jeremy, got pulled up on it and made to instal water saving devises in taps etc, my guy was far more laid back about it. 👍 1 Link to comment Share on other sites More sharing options...
thefoxesmaltings Posted October 6, 2022 Author Share Posted October 6, 2022 5 minutes ago, Temp said: Do you meet the rules for the Ecology Building Soc? Ecology also said 'no', based on the aforementioned condition. Link to comment Share on other sites More sharing options...
joe90 Posted October 6, 2022 Share Posted October 6, 2022 1 hour ago, thefoxesmaltings said: Condition 9 - The development hereby permitted shall be constructed to Building Regulation Part G(2) But surely that’s standard building regs which every new build must comply with? Link to comment Share on other sites More sharing options...
Mr Punter Posted October 6, 2022 Share Posted October 6, 2022 Because the condition did not further specify that the property must maintain the rate of consumption indefinitely there is nothing to prevent a future owner from putting in whatever appliances they like. 1 Link to comment Share on other sites More sharing options...
Temp Posted October 6, 2022 Share Posted October 6, 2022 23 minutes ago, joe90 said: But surely that’s standard building regs which every new build must comply with? No its an option at the planners discretion. See my post above. Link to comment Share on other sites More sharing options...
Temp Posted October 6, 2022 Share Posted October 6, 2022 38 minutes ago, thefoxesmaltings said: Haha, we already have rainwater harvesting proposed to be installed as part of the approval, yet still had this condition imposed. One possibility might be to appeal the Condition on the grounds that its not needed to meet Policy SP10 of the Local Plan because you are installing a Rainwater Recycling System. Link to comment Share on other sites More sharing options...
Radian Posted October 6, 2022 Share Posted October 6, 2022 All those restrictors are self-defeating anyway. Tiny volume of water doesn't flush the loo properly so gets flushed two or more times. Pathetic shower doesn't rinse off suds so longer is spent with the water running. 🙄 3 Link to comment Share on other sites More sharing options...
markc Posted October 6, 2022 Share Posted October 6, 2022 4 minutes ago, Radian said: All those restrictors are self-defeating anyway. Tiny volume of water doesn't flush the loo properly so gets flushed two or more times. Pathetic shower doesn't rinse off suds so longer is spent with the water running. 🙄 Yes but they tick the looney greenie boxes 3 1 Link to comment Share on other sites More sharing options...
nod Posted October 6, 2022 Share Posted October 6, 2022 57 minutes ago, markc said: Yes but they tick the looney greenie boxes Exactly Link to comment Share on other sites More sharing options...
Temp Posted October 6, 2022 Share Posted October 6, 2022 1 hour ago, Temp said: One possibility might be to appeal the Condition on the grounds that its not needed to meet Policy SP10 of the Local Plan because you are installing a Rainwater Recycling System. Further.. It might even be possible to prove it with maths. Eg show that with the normal 135L/person/day fittings and rainwater recycling you will draw less than 110L/person/day averaged over a year from the mains. Link to comment Share on other sites More sharing options...
Haylingbilly Posted October 10, 2022 Share Posted October 10, 2022 I had the following condition " Prior to the occupation of the dwelling, details shall be submitted to and be approved in writing by the Local Planning Authority to confirm that the dwelling has been completed to meet the requirement of 110 litres of water per person per day." The Ecology were happy with this . Not sure if this helps or not? 1 Link to comment Share on other sites More sharing options...
Carrerahill Posted October 10, 2022 Share Posted October 10, 2022 On 06/10/2022 at 14:38, thefoxesmaltings said: Anyone had this issue from lenders being generally unhappy and unwilling to lend based on the following condition? This is in our planning permission: "Condition 9 - The development hereby permitted shall be constructed to Building Regulation Part G(2)(b) standards limiting water consumption to 110 litres per person per day. Reason: To reduce demand for finite resources as the district is in a water scarce area. This condition is imposed in accordance with Policy SP10 of the Local Plan." Lenders and valuers alike are concerned about the implications of the above condition under the principle that it affects the saleability of the property, and therefore negatively affects it's value and security. Bankers not understanding Construction industry I guess. Nothing new! Link to comment Share on other sites More sharing options...
Blooda Posted October 10, 2022 Share Posted October 10, 2022 (edited) We initially completed this for Building Regs:- The Water Calculator And made it fit, this was suitably accepted for Building Control, Water Connection and the Warranty. Edited October 10, 2022 by Blooda 1 Link to comment Share on other sites More sharing options...
