JohnMo Posted August 21, 2022 Posted August 21, 2022 Been told we need cooling in the lounge and possibly in the bedroom (about 10m away from lounge) for next year. So looking for advise So two options, as I see it. May be others? 1. Get a heat pump with cooling, run through the UFH, most expensive option. Not sure how good it is compared to aircon 2. A2A, least expensive option, but depending on how many units I need could be more expensive. Could run in heating mode also if required. Not sure how to size? Not keen on pulling house apart to fit something and wife not keen on external units (but may have to live with one) Have seen through wall aircon, but input vs output doesn't appear that good. Water cooled aircon, main water in and then to drain, seems a waste of water.
Kelvin Posted August 21, 2022 Posted August 21, 2022 Out of interest. Given you’ve not long built the house. Other than put active cooling in is there anything you would have done differently?
JohnMo Posted August 21, 2022 Author Posted August 21, 2022 Think I would have shrunk some of the south/west facing windows, trouble is we have great views, seemed a shame to miss out on them.
TonyT Posted August 21, 2022 Posted August 21, 2022 Head over to the Camelot forum , few members have installed A2A over the past few weeks…
Thorfun Posted August 21, 2022 Posted August 21, 2022 1 hour ago, JohnMo said: Think I would have shrunk some of the south/west facing windows, trouble is we have great views, seemed a shame to miss out on them. could you fit external blinds or shading to reduce the solar gain whilst allowing you to keep the large windows and views? might alleviate the need for active cooling. although, we're having AC and also have external blinds so if you want it go for it.
JohnMo Posted August 21, 2022 Author Posted August 21, 2022 We have big overhangs over the windows which is great until mid afternoon and the the lower sun going down to west get in. The internal blinds work quite well, but not good enough. Will have a look at external blinds also, thanks
JohnMo Posted August 21, 2022 Author Posted August 21, 2022 Good suggestion, but there's a 45 degree slope down (down 8m) about 4m in front of the house, then a road then a loch. So not much option for trees unfortunately.
ReedRichards Posted August 21, 2022 Posted August 21, 2022 A2A heat pumps can also be used very economically for heating in spring and autumn when it's not too cold outside. A heat pump with cooling is not a permitted development and would require planning permission. I presume this also applies to A2A.
m0deller Posted August 22, 2022 Posted August 22, 2022 Did you go for a solar reflective coating on the windows? Seems to make quite a difference
Mr Punter Posted August 22, 2022 Posted August 22, 2022 Air to air is great when the external air temperature is high. For solar gain only, external shading is a good solution but will make the room dark.
JohnMo Posted August 22, 2022 Author Posted August 22, 2022 2 hours ago, m0deller said: Did you go for a solar reflective coating on the windows? Seems to make quite a difference Thought the window over hangs would be enough, but unfortunately the sun gets in late afternoon to early evening.
joth Posted August 22, 2022 Posted August 22, 2022 (edited) 19 hours ago, JohnMo said: Been told we need cooling in the lounge and possibly in the bedroom (about 10m away from lounge) for next year. So looking for advise How many story building? I find cooling in UFH on our ground floor "works" fine but creates a pool of cool air 1 ft off the floor downstairs that does nothing to help the building as a whole feel cool. FCUs upstairs are much more effective. (Conversely, the UFH is excellent for heating in winter) Edited August 22, 2022 by joth
joe90 Posted August 22, 2022 Posted August 22, 2022 Is it worth the cost for the few days/weeks it’s required?, I have no heating upstairs but for the odd week or so in winter extra heating is required the plan is just plug in heaters. Why not consider portable air con units you can pull out of storage when required?
SteamyTea Posted August 22, 2022 Posted August 22, 2022 9 minutes ago, joe90 said: Why not consider portable air con units you can pull out of storage when required? Because you have to plumb them to outside air or they just become heaters.
joe90 Posted August 22, 2022 Posted August 22, 2022 3 minutes ago, SteamyTea said: Because you have to plumb them to outside air or they just become heaters. So do a lot of tumble driers 🤷♂️
joe90 Posted August 22, 2022 Posted August 22, 2022 Just now, pocster said: Christ sake ! Everyone missed my joke !!! No we just ignored you 😎 3
Pocster Posted August 22, 2022 Posted August 22, 2022 Just now, joe90 said: No we just ignored you 😎 Yeah I did wonder …
Ferdinand Posted August 22, 2022 Posted August 22, 2022 33 minutes ago, joe90 said: No we just ignored you 😎 He's just saying that. 9 year old people called Joe are your greatest fans. 1 1
JamesPa Posted August 22, 2022 Posted August 22, 2022 9 hours ago, m0deller said: Did you go for a solar reflective coating on the windows? Seems to make quite a difference We recently had our south-facing patio window re-glazed. The solar reflective coating (and a better grade of double glazing) definitely make a massive difference.
