CC45 Posted May 22, 2018 Posted May 22, 2018 are you sure? it would be a lot easier in a decade or so when you get around to the UVC.
Onoff Posted May 22, 2018 Author Posted May 22, 2018 (edited) What would a "proper" plumber do? Solder the joints in situ or off the backing board then clip back on? (It's marine ply btw). I don't want to burn the wood. Got my protective mat, random sheets of metal etc. Figure if I lose the pipe clips nearest the elbow/T/elbow I won't melt them! Obviously I've to add short lengths up for the supply and the long drops of the bottom valves. Edited May 22, 2018 by Onoff
CC45 Posted May 22, 2018 Posted May 22, 2018 you will need to solder the T piece at the same time as the elbows. Personally I'd take it off and lay down on a flat surface then solder & lift back unless you are doing a shape that needs to be help in position to get an accurate fit. No chance of burning wood or melting the clips then.
Nickfromwales Posted May 22, 2018 Posted May 22, 2018 29 minutes ago, CC45 said: you will need to solder the T piece at the same time as the elbows. Personally I'd take it off and lay down on a flat surface then solder & lift back unless you are doing a shape that needs to be help in position to get an accurate fit. No chance of burning wood or melting the clips then. +1 49 minutes ago, Onoff said: What would a "proper" plumber do? Half, or less, of what you've done so far..............if you were lucky. . "Keep fighting the good fight, Sir" ??
Onoff Posted May 23, 2018 Author Posted May 23, 2018 (edited) I'm not happy with the symmetry in that last picture Going to mirror the hot so it matches the cold. The whole board will probably have to drop later anyway as the upstairs en suite mixer is way too high up the wall in the enclosure. Also has a naff BLUE plastic tray about 6" high which will be replaced...along with the Artex ceiling, non P5, "ordinary" chipboard floor, 3/8" pb walls etc Edited May 23, 2018 by Onoff
PeterW Posted May 23, 2018 Posted May 23, 2018 2 hours ago, Onoff said: I'm not happy with the symmetry in that last picture You will never see it.......... just solder it up and get on with the next job ..! 1 1
Pocster Posted May 23, 2018 Posted May 23, 2018 5 hours ago, PeterW said: You will never see it.......... just solder it up and get on with the next job ..! He will see it ! In his mind it will always be there ; non symmetrical; taunting everyday and every night . @Onoff ; you know your fate , you know your destiny young sky walker . Make them symmetrical or have no peace 1
Onoff Posted May 23, 2018 Author Posted May 23, 2018 (edited) Me and plumbing...nah! Started late tonight, playing Dad's taxi etc. Flexis will transfer to the two lengths of 15mm. A quick bend in copper should sort the valve to the ensuite shower cold and get rid of the white push fits. Probably have to do a saddle to sort the feed to the hot: Down lower where the feeds go off to the downstairs shower. I'll need to joint them: Poxy original waste : Edited May 24, 2018 by Onoff
Onoff Posted May 27, 2018 Author Posted May 27, 2018 Gotta get this finished if I want a shower tonight! Working in a hot loft I need one too! Ready for soldering. Some cloaking board off cuts to protect the ply: A lick of paint and a polish up: TF for the olive splitter! Getting there. I'll probably put the flexis higher up so straighter: Got to take off the ensuite bar mixer now and add a couple of bends to get it back up and running.
Onoff Posted May 27, 2018 Author Posted May 27, 2018 (edited) 59 minutes ago, Nickfromwales said: It's a thing of beauty. You took the words right out of my mouth It's taken all f**ing day mind. No wonder plumbers get paid so much! And yes, the bend and double one both done in one: Edit: Got to be bloody careful not to open any of these valves as the sh!tty gate valves the other end are letting by! Edited May 27, 2018 by Onoff 1
Onoff Posted May 27, 2018 Author Posted May 27, 2018 (edited) NOT so pretty the other side! Cracked tile and holes filled with "silicon": Not sure whether to CT1 or Sikaflex EBT these plates back on? It's ALL coming out eventually right back to studs/joists so ceiling, walls and floor will be re "boarded". Edit: CT1'd it all. Next time I touch it it'll all hopefully be coming out in favour of one of those 22mm thick tray things! Edited May 27, 2018 by Onoff
Onoff Posted May 27, 2018 Author Posted May 27, 2018 B@LLOCKS! I swear I didn't go mad getting this off but it was a vice job to separate it from the back plate. It is knackered and I need a new one. Thread is stripped & it's split up the thin wall bit where the wrench flats are. Guessing I might have to buy a complete new bar mixer! Off to have a peruse thru the Screwy's etc catalogue & online.
Onoff Posted May 27, 2018 Author Posted May 27, 2018 (edited) 22 minutes ago, Nickfromwales said: The back to wall kits are in SFx. Link Yep just looking at those in the catalogue. Don't suppose you recognise the bar mixer? The bit I need is less than a fiver online for a pair! https://m.ebay.co.uk/itm/Exposed-Thermostatic-Shower-Bar-Valve-Easy-Fit-Shower-Fixing-Kit-Pair-EFK001/311067821140?hash=item486d164454:g:4nMAAOSwVtZaQ4ti Edited May 27, 2018 by Onoff
Nickfromwales Posted May 27, 2018 Posted May 27, 2018 Don't recognise that tbh, but there's so many of them it's hard to keep track. Cheap enough on eBay for a no name bar mixer. For tonight, two ballofixes and a spray handset on the end. Bit of balancing and away you go.
Onoff Posted May 27, 2018 Author Posted May 27, 2018 1 hour ago, ProDave said: No shower tonight then...... I had a nice bath with Christina Novelli! 1
Onoff Posted May 28, 2018 Author Posted May 28, 2018 (edited) @Hecateh did you know who she was or look it up? If the former then well impressed! Edited May 28, 2018 by Onoff
Hecateh Posted May 28, 2018 Posted May 28, 2018 I knew the name (through my kids though) But what made me smile was the predictable unpredictability of your response ? ? 1
Onoff Posted May 28, 2018 Author Posted May 28, 2018 1 minute ago, Hecateh said: I knew the name (through my kids though) But what made me smile was the predictable unpredictability of your response ? ? My youngest is very into Panic At The Disco. Surprisingly good.
Hecateh Posted May 28, 2018 Posted May 28, 2018 11 minutes ago, Onoff said: My youngest is very into Panic At The Disco. Surprisingly good. You've intrigued me enough to visit Youtube. It's certainly a lot more listenable than the techno stuff my son listened to in his teens (he's 41 now. I generally only heard a less than rythmic thumping through the floor. I liked Kraftwerk, OMD which I guess were early techno (Yes? No?)
Onoff Posted May 28, 2018 Author Posted May 28, 2018 6 minutes ago, Hecateh said: You've intrigued me enough to visit Youtube. It's certainly a lot more listenable than the techno stuff my son listened to in his teens (he's 41 now. I generally only heard a less than rythmic thumping through the floor. I liked Kraftwerk, OMD which I guess were early techno (Yes? No?) Kraftwerk, now you're talking. Got loads on vinyl. On my bucket list to see them live. Amazing how many modern artists sample them. There's was a good article about Chris Martin from Coldplay approaching them to use Computer Love on "Talk". He said he was already starstruck and in awe of them plus dreading they would refuse permission. 1
Onoff Posted May 28, 2018 Author Posted May 28, 2018 This is a good piece on Kraftwerk: https://www.theguardian.com/music/2013/jan/27/kraftwerk-most-influential-electronic-band-tate
newhome Posted May 28, 2018 Posted May 28, 2018 Can’t warm to techno at all. Suggest something that might convert me. Not a lover of rap either. Give me something like The Clash any day!
